> Cobb Tuning >
Cobb Access Port/Maps
 Old 05-05-2016, 06:36 PM   #1
wes3id's Avatar
Posts: 611   (View Stats)
If you insist on running a BOV, you need to be tuned for it. i suggest you look into a good e-tuner such as freektune....but there are also many other good ones. otherwise, just get a good BPV.
wes3id is offline   Reply With Quote
Page generated in 0.22066 seconds with 20 queries
