> Cobb Tuning >
Cobb Access Port/Maps
 Old 05-05-2016, 06:19 PM   #1
thegoldnblack's Avatar
Posts: 1   (View Stats)
thegoldnblack is an unknown quantity at this point
Default what map do i use?
hi i have an 06 speed6 just about stock just got my cobb accesport and wondering what map to use i only have a cold air intake and an hks bov
thegoldnblack is offline   Reply With Quote
 Old 05-05-2016, 06:36 PM   #2
wes3id's Avatar
Posts: 611   (View Stats)
If you insist on running a BOV, you need to be tuned for it. i suggest you look into a good e-tuner such as freektune....but there are also many other good ones. otherwise, just get a good BPV.
wes3id is offline   Reply With Quote
Page generated in 0.22691 seconds with 20 queries
