> Cobb Tuning >
Cobb Access Port/Maps
 Old 03-23-2011, 02:18 PM   #1
dizzydtrain's Avatar
Posts: 2,476   (View Stats)
Groans: 64
Default WTF?
So I did a quick log today to see how the fuel pump is running. My mods are tmic, sri, hpfp, and cobb ap.
I am currently running a stg 1 map (cp-e nano 93 octange stg1). At first look, the log does not look bad at all but then I noticed in line 25 that my boost went up to 19.14psi, AFR went to 9.85, and my fp is at 1622. I realized that this was right after I got off the throttle after my run and my throttle position was below two....pretty much not applying any gas at all.
Anyone see anything like this?
dizzydtrain is offline   Reply With Quote
 Old 03-28-2011, 12:22 AM   #2
evidence's Avatar
Posts: 1,033   (View Stats)
Logging/reporting error, look at your timing, g/s, and MAF voltage. I'd be surprised if you ever catch it happening again.
Some things.
Page generated in 0.23167 seconds with 21 queries
