Like Tree21Likes
 Old 05-11-2013, 05:17 PM   #1
Default Corksport Brakes Pads - Mazdaspeed 3 » Page 2 - Installation
Table of Contents
1 - Corksport Brakes Pads - Mazdaspeed 3
2 - Page 2 - Installation
3 - Page 3 - Results
So, there's tons of threads on the forum showing you how to install brakes on these cars. I'm going to blow through the pre-school stuff and cut right to the chase. Its extremely important if you want to remain completely sane, to purchase the correct caliper reset tool for the rear brakes. It makes your life 20x times easier, trust me here. The first time i did brakes on my Gen1, it took me almost 3 hrs total to reset both rear calps with needle noses... The first reset tool didn't fit correctly and at 11:30pm, there are very few places open to buy tools.
This time around... @UnknownSuperhero; provided a working calp reset tool for the rear and about 15 seconds later, the pistons were reset. I would suggest this investment be made for your local Nator chapter, it will pay for itself first time out..
Corksport provides great installation instructions, unlike some vendors who provide none, but i didn't need them since I've already been down this road before. I do recommend picking up a 7mm Allen socket to remove the pistons pins from the rear calipers if you are not changing the rotors. This makes a huge night and day difference then just removing the 2 14mm bolts and pulling the entire assembly off the rotor. Again, my recommendation if you do not like to spend a long time working on stuff.
The rear pads fit without issue and have an anti squeal backing plate as well. Pads were out and back in within 10 mins of removing the wheels. I suggest lubing the pins up before screwing them back into the calipers.
For the fronts, i recommend pulling the piston pins like you did for the rear. Again, its the quickest way to exchange just the pads if you aren't touching the rotors in my case.
So let's blow through this real quick and remove these NASTY Carbotech AX6 pads!
resetting the piston back into the calp. Love these large C-Clamps with the button to retract when finished.
[center][center]
« Back 1 2 3 Next»
The Following 80 Users Say Thank You to Haltech For This Useful Post:
2.0t03speed (05-14-2013), 2eatV8everyday (06-23-2015), 86AmishMs3 (05-13-2013), allo80 (05-13-2013), altaprecision (08-05-2013), Archer (05-14-2013), Arnie1229 (01-06-2015), atvfreek (05-15-2013), AuroraAxela (10-24-2013), Awal (04-22-2015), brakehard (08-19-2013), brandonlee (08-21-2013), breakfstincluded (05-13-2013), btstarcher (05-17-2013), ButtholeRedMS3 (11-18-2014), comcam77 (08-24-2013), CorkSport Vincent (03-04-2016), cshunter (05-13-2013), DaDoctor (05-15-2013), Dahouse702 (10-24-2013), danosrk (09-17-2014), derek13p (05-13-2013), Design (05-15-2013), Dimenus (05-13-2013), DuoofDeath1 (05-14-2013), El_Diablo (05-31-2013), evil MS3 (05-14-2013), fishin53 (05-13-2013), forcedinduktion (06-09-2013), Format (08-31-2013), getoutandlive (05-17-2013), Gringo East (07-04-2013), i8urgti (06-05-2013), Jabl3s (05-06-2014), jax ms3gt (07-24-2013), jeek (07-11-2013), jeopardy98 (12-13-2013), jk_ms3 (05-13-2013), johnbarr00 (06-19-2013), jtt (05-14-2013), Jury (05-19-2015), Juyoung (10-07-2013), Kfunk (05-13-2013), kgb (05-13-2013), KiwiFlavor (05-13-2013), Koke382 (05-15-2013), kritz (06-09-2013), Kyle Undefined (05-14-2013), MD1032 (11-28-2014), Micha (05-16-2013), Mr.Nemesiis (05-13-2013), mrmonk7663 (05-13-2013), ms3blackmica (05-15-2013), NeoKraSH (05-14-2013), neotide87 (02-21-2014), omgvance (05-22-2013), PapaSmurf (05-15-2013), Playaj (05-15-2013), predapio (05-13-2013), Raider (05-17-2013), RobT2009 (08-02-2013), Shayne-ms3 (05-13-2013), SleeperHatch (05-14-2013), SLOWHATCH (05-13-2013), SparkySparks (05-13-2013), Speed3_Guy (05-13-2013), SPEEDRAC3R (05-14-2013), Sterling (05-18-2013), The Nut (09-24-2013), TJM216 (05-13-2013), trancehead (05-16-2013), turboKart (05-30-2013), twincitySPEED6 (11-15-2013), Twofer (05-14-2013), uncorked11 (05-13-2013), VulgarKyle (06-08-2013), WA_MS6 (08-15-2014), xI Leveler Ix (05-14-2013), [R]usty (07-05-2013)
 Old 05-14-2013, 12:53 AM   #2
SleeperHatch's Avatar
Posts: 3,138   (View Stats)
These will be my next set of pads for sure
2009 CWP Speed3
himurax13 (05-14-2013)
 Old 05-14-2013, 05:18 AM   #3
Deldran's Avatar
Posts: 3,139   (View Stats)
Groans: 118
I need to order rotors so I can but mine on lol
Sent from my Nexus 4 using Tapatalk 2
Damond Built Speed 6
 Old 05-14-2013, 06:21 AM   #4
2.0t03speed's Avatar
Posts: 1,302   (View Stats)
Great review as always @Haltech;
The Following User Says Thank You to 2.0t03speed For This Useful Post:
Haltech (05-14-2013)
 Old 05-14-2013, 12:40 PM   #5
himurax13's Avatar
Posts: 4,585   (View Stats)
Groans: 255
These should go along great with my new Centric Rotors. I jus need to get more superblue since the Dealer decided to put the crappy oem DOT 3 fluid in my car.
Pickles Tune in progress
 Old 05-15-2013, 08:57 AM   #6
l4nc3r's Avatar
Posts: 153   (View Stats)
l4nc3r is the leader of the worldl4nc3r is the leader of the worldl4nc3r is the leader of the worldl4nc3r is the leader of the worldl4nc3r is the leader of the worldl4nc3r is the leader of the worldl4nc3r is the leader of the worldl4nc3r is the leader of the worldl4nc3r is the leader of the worldl4nc3r is the leader of the worldl4nc3r is the leader of the world
Sadly I had to purchase Autozone's CMAX pads while out of town to see family. Didn't get to turn my rotors or bleed the lines due to time restraint so everything feels mushy. Was wanting to purchase the Hawks today and thankfully saw this review. I'm going to order these and some SS lines and switch it all out and see how they feel.
l4nc3r is offline   Reply With Quote
The Following User Says Thank You to l4nc3r For This Useful Post:
Haltech (05-15-2013)
 Old 05-15-2013, 09:23 AM   #7
atvfreek's Avatar
Posts: 7,787   (View Stats)
Great review and exactly what I'm looking for. I like the OEM initial bite, but man that fade is scary when it happens. Looks like I know what I'm grabbing, especially at that price
2010 Speed3-PTE5858
Freek built/Freektuned
510hp420tq
11.321@129.93
The Following 2 Users Say Thank You to atvfreek For This Useful Post:
Haltech (05-15-2013), rfinkle2 (05-31-2013)
 Old 05-15-2013, 10:46 AM   #8
When you do a combo of the pads, blanks and SS lines, complete flush, the brakes fully transform.
Yeah i kinda wished i didn't spend an assload of $$ on the Carbotech's from the get-go.. however, curiosity got the best of me and i lost, lol.
 Old 05-15-2013, 10:51 AM   #9
PapaSmurf's Avatar
Posts: 8,236   (View Stats)
finally a solid review on these.
Thanks Hal for making my decision on what pads to buy.
860whp/677wtq
2.7 V6 Ecoboost
 Old 05-15-2013, 11:21 AM   #10
Should help slow down that beastly pu of yours
 Old 05-15-2013, 11:46 AM   #11
Design's Avatar
Posts: 1,887   (View Stats)
Groaned at 9 Times in 5 Posts
Great review. Didn't see it mentioned; did you sand the rotors prior to swapping compounds?
09 CWP MS3 GT
Ownership & Build Thread
 Old 05-15-2013, 11:53 AM   #12
No, i left it as is.. Ill order new blanks when i move to the new calps.
atvfreek (05-15-2013), Design (05-15-2013)
 Old 05-17-2013, 07:19 AM   #13
jdub0802's Avatar
Posts: 125   (View Stats)
jdub0802 has a reputation beyond reputejdub0802 has a reputation beyond reputejdub0802 has a reputation beyond reputejdub0802 has a reputation beyond reputejdub0802 has a reputation beyond reputejdub0802 has a reputation beyond reputejdub0802 has a reputation beyond reputejdub0802 has a reputation beyond reputejdub0802 has a reputation beyond reputejdub0802 has a reputation beyond reputejdub0802 has a reputation beyond repute
@Haltech; It might be a little early to tell, but how is the dust coming off of these? More or less than the OEM pads?
2011 Speed 3 - Mica Black - Non Tech
Mods Installed: JBR SSR Level 2 with Big Knob/ JBR Motor Mounts / Cobb AP / Cobb TIP + SRI / GFB BPV / CS Race Pipe / Autotech Internals / Denso IVT-22 / JBR Throttle Body Gasket & Bypass / JBR EGR Block Off / JBR TIG / JBR RSB / GA
Apperance: DDM 6000k HID / JBR Mud Flaps / Windows Tinted
Tuning with Boost_Creep in Progress! Working towards Corn.
jdub0802 is offline   Reply With Quote
The Following User Says Thank You to jdub0802 For This Useful Post:
 Old 06-09-2013, 02:55 AM   #14
himurax13's Avatar
Groans: 255
I installed Centric blank rotors when I did the swap to the Corksport pads and the dusting seems to be a much lighter shade and did seem to dust about a third as much as compared to the the stock pads.
I am gonna go a week inbetween cleanings and see how that works out.
After I broke them in I took a 15 min cruise down the freeway and then did a 4th gear log and then exited the freeway. I pit it in neutral and came almost to a complete stop 1/2 of the way down the offramp. I hears the tires squeal for a little bit but I came to a controlled stop
So I let the brakes cool for a few then romped in the canyons for 15 minutes. When I got back and the freeway and I did another 4th gear log and then exited the freeway on the same offramp. This time the tires didn't make any noise but everything came flying forward in the car. I stopped a little sooner than the previous time.
I started to noticed that the car was stopping much sooner and with less pressure on the brake pedal than the oem brakes. I did not notice any brake squeeling and the pedal feel is nice and linear. The initial hard bite of the oem pads doesn't seem to be there but the car seems to a stop with much less fuss.
I will report back after I get some more miles on them.
The Following 2 Users Say Thank You to himurax13 For This Useful Post:
atvfreek (06-09-2013), btstarcher (06-25-2013)
 Old 05-31-2013, 08:46 AM   #15
Nliiitend1's Avatar
Posts: 5,749   (View Stats)
...So, it leaves us searching, testing and ultimately wanting, better pad options for this car. Some move to the Hawk HPS or HPS+ which offer better fade resistance, but do not deliver that initial bite we are used to with the OEMs. They also produce quite a bit of dust...
Just a heads-up:
There is no Hawk "HPS+" available.
HPS and HP+ are the two you mean to reference, I believe.
Stance is not a verb.
2008 MS3 GT
2016 MX-5 Club
 Old 06-09-2013, 04:09 AM   #16
kritz's Avatar
Posts: 7,290   (View Stats)
Groans: 95
@Haltech; Nice review Kevin. It won't help you for you know what, nice effort though.
Nator is what it does.
 Old 06-09-2013, 12:35 PM   #17
Just a heads-up:
Thanks, ill edit.
Hey, im just happy as hell i don't sound like UPS.
kritz likes this.
brandonf (07-12-2013), Nliiitend1 (06-09-2013)
 Old 06-19-2013, 10:38 AM   #18
johnbarr00's Avatar
Posts: 190   (View Stats)
johnbarr00 has a reputation beyond reputejohnbarr00 has a reputation beyond reputejohnbarr00 has a reputation beyond reputejohnbarr00 has a reputation beyond reputejohnbarr00 has a reputation beyond reputejohnbarr00 has a reputation beyond reputejohnbarr00 has a reputation beyond reputejohnbarr00 has a reputation beyond reputejohnbarr00 has a reputation beyond reputejohnbarr00 has a reputation beyond reputejohnbarr00 has a reputation beyond repute
Groaned at 9 Times in 4 Posts
Just installed these CorkSport brake pads on my MS3. LOVE THEM! no noise, and such little dust. Pics of front and rear attached! Highly recommend them. Hell, I highly recommend ANYTHING by CorkSport. IMO, they are the best Mazdaspeed performance parts company. Thanks to Derrick for the birthday card too!
thanks to @acidego; for the new rotors
Performance
CorkSport Stage II Intake, Extreme Turbo Systems TMIC, Cobb Catted DP, CorkSport CBE, Turbo XS BPV, KMD v2 Internals, Denso ITV22, JBR Stage 2 OCC, CorkSport Lowering Springs, CP-e RMM, Sure Shortcut (SSP), Sure Boost Tubes, CorkSport Recirc Tube, Torque Solutions Exhaust Hangers, R1 Concept Premium Cross Drilled and Slotted Rotors w/ CorkSport Brake Pads and Cobb AP v2 Tuned @ Stage 2
Interior Mods
CorkSport Interior LED Lights, CP-e Center Tripple Gauge Pod, ProSport Premium Electronic Boost Gauge, ProSport Air-to-fuel Ratio Gauge, ProSport Voltmeter Gauge, JBR Shift Knob, Koolertron Car Specific Head Unit, and 3000 watt Alpine Type-R Subwoofer w/ Hifonics Gladiator Amplifier in Custom Enclosure
Exterior
DG Motorsports Spoiler Extension, DG Motorsports Vented Hood, 6000k HID low beam, CorkSport LED fogs, CorkSport Mudflaps, Tenzo Racing TZ7 18x8 rims on 215/45/R18 Bridgestone Potenza, Back Up Camera, G2 Red Calipers, Blacked Out Emblems + Grill + Lower Grill + Roof, and Dark Tinted Windows
johnbarr00 is offline   Reply With Quote
The Following 2 Users Say Thank You to johnbarr00 For This Useful Post:
acidego (06-19-2013), himurax13 (06-20-2013)
 Old 06-19-2013, 05:12 PM   #19
acidego's Avatar
Posts: 45   (View Stats)
acidego has a reputation beyond reputeacidego has a reputation beyond reputeacidego has a reputation beyond reputeacidego has a reputation beyond reputeacidego has a reputation beyond reputeacidego has a reputation beyond reputeacidego has a reputation beyond reputeacidego has a reputation beyond reputeacidego has a reputation beyond reputeacidego has a reputation beyond reputeacidego has a reputation beyond repute
Looking good!
AcidEgo
08 Cosmic Blue GT-
Installed- Sure Anchors, Sure Countershift, JBR RMM, COBB TIP, COBB SRI, APv3, JBR Knob, JBR Camber Arms, JBR RSB, JBR OCC, Autotech Internals, Koni Yellows, H&R springs, Whiteline Endlinks, NGK Iridium, Forge V2, ETS Topmount
Not so Installed- Spin on conversion, Sammich plate, Block8head duely, Autometer Boost and Oil Temp, UR Test Pipe
acidego is offline   Reply With Quote
The Following User Says Thank You to acidego For This Useful Post:
 Old 06-19-2013, 09:57 PM   #20
Ace Protege's Avatar
Posts: 753   (View Stats)
Ace Protege is the leader of the worldAce Protege is the leader of the worldAce Protege is the leader of the worldAce Protege is the leader of the worldAce Protege is the leader of the worldAce Protege is the leader of the worldAce Protege is the leader of the worldAce Protege is the leader of the worldAce Protege is the leader of the worldAce Protege is the leader of the worldAce Protege is the leader of the world
Nice write up. having the proper tools for the job is nice isn't it? lol
It's strange how your opinion of the Carbotech ax6 is so negative. I've got a set for a dedicated "aggressive" brake set up. I bedded them with brand new rotors as Carbotech recommends. Yes they are somewhat noisy and very dusty but it's a compromise I'll make for the stopping power they provide. I found them to bite much harder than Hawk HP+ pads and the harder you pushed the pedal the more they bit. I had them up to around 680* as per my infrared thermometer and they were still there 100%. That's obscenely hot and even melted the powder coating off the hub of my wheel and my center caps, but I never had any indication of pedal fade or anything. Now it's not on a speed so maybe the weight of the MS3 over my protege was just too much for that pad? I'm not sure but it leaves me wondering.
'02 Bmw 330ci
Kinda low and really slow.
'94 Mazda Protege -SOLD
1.8 BPT Vf10
263whp 258wtq
13.1 @ 107 mph
'05 ZX-6RR - Two Brothers slip on, GPR dampener V1, More to come
Ace Protege is offline   Reply With Quote
 Old 06-19-2013, 10:13 PM   #21
Well it's possible they could of been a bad set. Generally though, if bedding doesn't work properly, you would eventually see an increase in bite over time. I didn't see any improvement on the ax6's I've had.
 Old 06-23-2013, 08:51 AM   #22
Emew's Avatar
Posts: 217   (View Stats)
Emew has a reputation beyond reputeEmew has a reputation beyond reputeEmew has a reputation beyond reputeEmew has a reputation beyond reputeEmew has a reputation beyond reputeEmew has a reputation beyond reputeEmew has a reputation beyond reputeEmew has a reputation beyond reputeEmew has a reputation beyond reputeEmew has a reputation beyond reputeEmew has a reputation beyond repute
Could be over my head as usual, but any word of a set of rear pads for the MS6? I saw someone ask this same question back on the intitial release thread but no answer, so maybe since this is on the front page and is more recent someone might have some word on those?
Flow Student
'07 Speed6 TiGrey: SURE ID300/Shift Plate+Weight/Breather Hose, Forge BPV v2, CX-7 Antenna, ProSport Boost Gauge, Block8Head's MS6 Pod, Cobb AP v3, ITV22 1SC Plugs, TWM Short Shift, Stage 2 Clutch, JBR Shifter Bushings/Shift Knob/RMM/EGR Delete, Euro LED Tails, AutoTech FP Internals, M2 DP, ETS TMIC, Techna-Fit SS Brake Lines/Clutch Line, Hawk HPS Pads, ATE 200, MD OCC VTA v2, 3-Bar MAP, AWR TMM, CP-E RDM, Whiteline RSB, RB Rear Endlinks, Moog Front Endlinks, Bilstein HD6 Shocks, Corksport Springs.
Emew is offline   Reply With Quote
 Old 07-05-2013, 05:47 PM   #23
[R]usty's Avatar
Posts: 2,204   (View Stats)
Stock pads are finally coming to an end at 40K. I'll buy some of these, a set of new rotors, lines and some fluid. Thanks for the review saved me a lot of time searching.
 Old 07-11-2013, 11:28 PM   #24
L3THAL6's Avatar
Posts: 168   (View Stats)
L3THAL6 is the leader of the worldL3THAL6 is the leader of the worldL3THAL6 is the leader of the worldL3THAL6 is the leader of the worldL3THAL6 is the leader of the worldL3THAL6 is the leader of the worldL3THAL6 is the leader of the worldL3THAL6 is the leader of the worldL3THAL6 is the leader of the worldL3THAL6 is the leader of the worldL3THAL6 is the leader of the world
Groaned at 6 Times in 1 Post
I might snag some of these down the road when it comes time to replace my stock rotors.
L3THAL6 is offline   Reply With Quote
 Old 07-12-2013, 12:40 AM   #25
himurax13's Avatar
Groans: 255
I have over 1500 miles on these pads now and the pedal feel is getting firmer. The bite is more consisten than the stockers and the wheels don't hop as much. The reduction in brake dust is just an added bonus. I think the bedding in process needs to be more aggressive than the instructions state.
 Old 07-12-2013, 09:59 AM   #26
CorkSport's Avatar
Posts: 3,416   (View Stats)
I agree on the bedding process needing to be more aggressive, but we legally shouldn't advocate breaking the speed limit... That being said... go fast, brake, don't come to a complete stop, repeat many times, good to go.
Glad you like the pads!!!!
Cheers,
Joel
WWW.CORKSPORT.COM
atvfreek (07-12-2013), ge3kspd (10-23-2013), Mauro_Penguin (07-13-2013), navyspeed3 (07-25-2013), VulgarKyle (07-13-2013)
 Old 08-11-2013, 09:18 PM   #27
Deldran's Avatar
Groans: 118
Well after running these pads for about a month now. I have to say I am not all that impressed. I believe my issues with them are completely subjective but I will try and explain them.
While these pads do give you more overall stopping power compared to stock I personally do not like they way they give you that power.
With the stock pads in my experience the initial bite was much stronger, but after the strength of that initial bite there was not much more stopping power available.
With the corks port pads there is more overall bra king power but the peddle feels softer and requires more pedal travel and pressure to access that power. I think the best description is they have a very linier progression of power. The more you give it the harder you stop.
Me personally doing a lot a fair amount of autocross I prefer being able to punch the brake. The brakes bite very hard then get back on the throttle. With these I feel I spend a bit more time on the brake peddle before I can get back on the throttle. Granted I might get used to this feel more but I personally prefer the brakes to make my face hit the windshield with less needed travel and pressure on the peddle.
Now they are for sure an upgrade over stock. They dust less and give more overall stopping power. Subjectively though I prefer a bit the has a much strong initial bite.
Also before anyone tells me to bleed the brakes to solve the someone mushy peddle feel. After putting these pads on I flushed my brake fluid with a power bleeder. So I am 100% positive there is no air in the system.
Again an upgrade u just am not impressed with how they feel
The Following 5 Users Say Thank You to Deldran For This Useful Post:
86AmishMs3 (11-22-2013), Mauro_Penguin (09-17-2013), Nliiitend1 (08-12-2013), phate (08-11-2013), silvapain (08-12-2013)
 Old 08-30-2013, 10:45 AM   #28
himurax13's Avatar
Groans: 255
Did you install braided steel lines? I feel that this is allows for a consistent and firmer feel, even with the stock pads.
The Following User Says NO Thank You to himurax13 For This Un-useful Post:
nilashish (10-01-2013)
 Old 08-30-2013, 11:17 AM   #29
Eth Fiend
phate's Avatar
Posts: 6,947   (View Stats)
He did a direct comparison, why should he need additional parts to give him the desired braking performance?
It just takes some trial and error to figure out which pads perform for your environment and which have the feel you desire. I've gone through a lot of different compounds over the years looking for that.
Bucker, Deldran and Scoupe like this.
-06 MS6
-Corn fed 07 MS3 - Sold
Bucker (02-19-2014)
 Old 08-30-2013, 12:25 PM   #30
himurax13's Avatar
Groans: 255
I prefer the initial bite of the stock pads but I did make them smoke on more than occasion during some downhill runs and the fade made me nervous.
Installing the braided lines and using different fluid did help reduce brake fading.
Installing the corksport pads and new blanks have eliminated the fading and reduced the brake dust but the initial bite of the stock pads just isn't there for me and I also do find myself spending more time on the brakes. Talking with other folks and trying cars with other varieties of pads, I found that this appears to be the norm for non OEM pads.
 Old 11-25-2013, 11:40 AM   #31
86AmishMs3's Avatar
Posts: 3,639   (View Stats)
Groans: 338
So after two weeks of using corksport front pads and utilizing the stock lines and then stainless lines, I can provide my two cents. I also replaced the front rotors with stoptech slotted rotors
These brake pads do not offer the same bite as OEM. I haven't been able to get them to fade yet, but I don't exactly race my car. But a couple 120-0 stops have proved they are up to the job.
In daily traffic I felt that there was too much time pressing the pedal to get a good strong response. The pads feel more linear, but I felt there was too much pedal movement. I was weary about ceramics, because I know they don't offer the bite I want, and the same holds here.
Once I put in braided stainless ptfe lines the bite is back and I feel a lot more confident about braking.
And if you care, they are quiet, a slight squeal here and there but it's no UPS truck, and don't dust much.
Current: N54 135i
DCI, DP's, Exhaust, FMIC
12.3@122
2009 Mazdaspeed 3:
GT3076 - Corkey tuned
390whp/400wtq
12.8@114
Sold
The Following User Says Thank You to 86AmishMs3 For This Useful Post:
deekspeed (11-25-2013)
 Old 11-25-2013, 12:01 PM   #32
Deldran's Avatar
Groans: 118
I have yet to get the braided lines installed on my car as I cannot get the old ones to come out. Before I switch pads I will go ahead and give the cs pads another review with the ss lines. I will still ultimately switch to ebc yellow as a pretty active autocrosser I simply need more out of my pads than these can provide
86AmishMs3 (11-25-2013)
 Old 11-25-2013, 02:04 PM   #33
86AmishMs3's Avatar
Groans: 338
Really, hmm, the lines should be pretty easy to come out. PB blaster?
Current: N54 135i
12.3@122
2009 Mazdaspeed 3:
390whp/400wtq
12.8@114
Sold
 Old 11-25-2013, 08:23 PM   #34
Deldran's Avatar
Groans: 118
Nope tried that. Even left it on stands over the weekend soaking in pb blaster
 Old 11-25-2013, 08:46 PM   #35
86AmishMs3's Avatar
Groans: 338
Wow, just muscle the fuck out of them haha, if it breaks it breaks. Surprised though. I'm at 50k and mine didn't take much with a little 10mm and 12mm wrench.
Current: N54 135i
12.3@122
2009 Mazdaspeed 3:
390whp/400wtq
12.8@114
Sold
 Old 11-25-2013, 08:50 PM   #36
Deldran's Avatar
Groans: 118
80k on an 07. I don't want to break the connection at the fender well as it could destroy the upstream pipe. It just tries to round off the line
 Old 12-16-2013, 07:45 PM   #37
someguy's Avatar
Posts: 914   (View Stats)
Did my pads a couple weeks ago...just pads, nothing else. Quite happy with them and experiencing the same sort of performance changes as most others have mentioned in this thread. I might do brake lines/bleed in the spring but was due for new pads on the front so just got these done. Glad that the performance is quite good with no other investment or changes necessary.
 Old 12-17-2013, 02:51 PM   #38
86AmishMs3's Avatar
Groans: 338
glad you're happy with them, unfortunately I'm not liking them
Current: N54 135i
12.3@122
2009 Mazdaspeed 3:
390whp/400wtq
12.8@114
Sold
Deldran (12-17-2013)
 Old 02-21-2014, 10:18 AM   #39
Deldran's Avatar
Groans: 118
Well I did finally get the brake lines installed with the help of @silvapain; A quality set of flare wrenches is key. Had an issue with one. It is stripped the fuck out hopefully i never have to take it apart again because the upstream hardline will be a bitch to replace.
I will chime back into this thread after a couple autocross events with the stainless lines on. Pretty sure that will be the most comprehensive review i can give of these pads before i swap them out.
The Following 2 Users Say Thank You to Deldran For This Useful Post:
86AmishMs3 (02-21-2014), silvapain (02-24-2014)
 Old 02-21-2014, 11:39 AM   #40
86AmishMs3's Avatar
Groans: 338
Sounds good. I just bought some HP+'s but have yet to throw them in.
Current: N54 135i
12.3@122
2009 Mazdaspeed 3:
390whp/400wtq
12.8@114
Sold
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f337/corksport-brakes-pads-mazdaspeed-3-page-2-a-145381/
What brake pads are recommended - Page 3 - 2004 to 2014 Mazda 3 Forum and Mazdaspeed 3 Forums This thread Pingback 01-09-2014 09:44 AM
Meilleur front brake pads pour speed - Mazda 3 Quebec This thread Refback 10-01-2013 06:40 PM
OEM vs CS Brake Pads This thread Refback 05-15-2013 09:28 AM
Product Release! CorkSport Mazdaspeed 3 and Mazdaspeed 6 Brake Pads CorkSport CorkSport 54 03-07-2014 07:50 PM
Replaced front pads - squeal when I let off brakes?? TheRealDefman 2010 MS3 - Suspension & Brakes 0 02-27-2013 09:01 PM
CorkSport Product Release! ? CorkSport Mazdaspeed 3 Lowering Springs Now Available CorkSport CorkSport 0 08-05-2011 06:30 PM
Page generated in 0.65995 seconds with 42 queries
