Like Tree8Likes
  • 5 Post By Sacrilicious
  • 1 Post By Tabasco69
  • 1 Post By pastry00
  • 1 Post By chrono996
 Old 03-04-2012, 11:41 PM   #1
pewpew
Sacrilicious's Avatar
Posts: 2,452   (View Stats)
Groaned at 9 Times in 9 Posts
Default JBR Motor Mounts » The Mounts
Table of Contents
1 - JBR Motor Mounts
2 - The Mounts
3 - The Test
4 - RMM Tested
5 - TMM Tested
6 - PMM Tested
7 - Conclusion
The Mounts
The JBR mounts are constructed from a combination of billet aluminum and steel. Jamie chose bushings that are made using 70a, 80a, and 88a durometer polyurethane. The 70a and 80a bushings are a much larger diameter (~2.75” ID and ~3” OD) than the 88a durometer bushings (~2.00” ID and ~2.25” OD). As mentioned in the previous section, these 70a and 80a bushings are some of the largest available on the aftermarket today.
JBR Rear Motor Mount:
The JBR RMM is made from billet T6-6061 aluminum, and is of extremely solid construction. This is a very solid mount that should last a very long time. The entire mount is coated with a signature black wrinkled powder coat, which is done in house at JBR. The available bushing durometers are: 70a, 80a, and 88a. The 88a bushing is available only in a dogbone design with a smaller bushing diameter:
JBR Transmission Motor Mount:
The JBR TMM is made from .188 steel, and is made with 0.250” plates for the top and bottom plates with a solid 2.00” tall steel perch. This piece is also very solidly built, and should have no problems. The entire mount is powder coated black. Available bushing diameters are: 70a, 80a, 88a.
JBR Passenger Motor Mount:
The JBR PMM has a welded steel support and a billet T6-6061 aluminum piece containing the bushing. This mount comes preassembled with the pictured bolt impacted into place. DO NOT ATTEMPT TO DISASSEMBLE! The steel support is powder coated black, and the billet aluminum piece is coated with the signature JBR wrinkled black powder coat. Available bushing durometers are: 70a and 80a.
« Back 1 2 3 4 5 6 7 Next»
The Following 69 Users Say Thank You to Sacrilicious For This Useful Post:
3ONBOOST (10-15-2012), aaron22388 (01-26-2014), AdrenalineMS3 (06-11-2012), ak_spray (04-10-2012), allo80 (03-05-2013), Arnie1229 (01-13-2015), AwAfrican (01-04-2016), Awesomesauce (04-11-2012), Broxer (04-06-2012), burntRice (04-16-2012), cghms3 (05-06-2013), curlyface (05-29-2012), dantes5823 (05-18-2012), Dave2288 (03-07-2013), DingoDave (04-18-2012), doc_sean (10-23-2015), Donut (03-25-2013), drknyte (04-08-2012), Drumea88 (12-04-2017), Dumbguy (09-26-2013), Eric28243 (04-26-2012), Ferdball (04-23-2012), fyrecrotch (04-11-2012), ge3kspd (08-10-2013), GunGuru727 (04-12-2012), himurax13 (04-19-2012), J-Liss (04-10-2012), JBR (04-06-2012), JDR767 (04-12-2012), jdub0802 (03-09-2013), jeoje (06-11-2012), jokester (04-17-2016), josurr (04-17-2012), Juyoung (09-30-2012), kabobulate (04-07-2012), kevinblack (01-29-2014), mazdafreak (05-24-2012), McGee (04-09-2012), meelo88 (08-07-2014), ms3blackmica (12-15-2012), Ms3_Miami (10-29-2012), msantana101 (10-11-2012), mterry660 (02-16-2014), nando-g (06-24-2016), nathaniel (06-27-2012), new2boost (06-04-2014), niterydr (04-20-2012), outshined (05-21-2012), Paul (04-18-2012), pioneercrazed (04-21-2012), Prodigalson (01-23-2017), Pseud0logik (04-06-2012), Reggaeboy143 (10-30-2013), rikyrick87 (04-30-2012), ruthless013 (04-12-2012), sh4d0w (08-26-2015), speed6qc (10-01-2014), speedaholic (11-06-2013), SpeedLife (08-25-2013), stoickiwi (09-19-2014), Sum1UDidntC (04-07-2013), suparobg (12-14-2015), thepatient77 (04-10-2012), TriO (04-12-2012), V1P3R (04-25-2012), Vinnie (04-09-2012), VulgarKyle (02-21-2013), WillyH (04-07-2012), xI Leveler Ix (04-06-2012)
 Old 04-06-2012, 04:42 PM   #2
Broxer's Avatar
Posts: 875   (View Stats)
Broxer is the leader of the worldBroxer is the leader of the worldBroxer is the leader of the worldBroxer is the leader of the worldBroxer is the leader of the worldBroxer is the leader of the worldBroxer is the leader of the worldBroxer is the leader of the worldBroxer is the leader of the worldBroxer is the leader of the worldBroxer is the leader of the world
Groans: 90
Awesome write up man. I'm really starting to feel the slop since I've went BT. Power is coming on so hard at spool up I think i'm stressing my mounts to the max.
I may try a set of the 70 duro side mounts and see how they treat me. Hopefully slightly less vibes and noise.
2012 Triumph Street Triple
SOLD -- 2010 Velocity Mica Red MS3
ATP GTX3071r - Cobb AP(Freek Permed) - CNT Catted DP - UR CBE - DO Stage 2 WMI(80/20) - cp-e TMIC - cp-e xcelXL - cp-e invicid inlet - Grimmspeed MBC - KMD v2.2 hpfp internals - Bosch 3bar MAP - H&R Springs - DDM 6k Raptor Kit - ITV22's - Forge v2 BPV - 225/40/18 Nitto Neogens - SURE RMM
Broxer is offline   Reply With Quote
 Old 04-26-2012, 03:54 PM   #3
Eric28243's Avatar
Posts: 554   (View Stats)
Eric28243 is the leader of the worldEric28243 is the leader of the worldEric28243 is the leader of the worldEric28243 is the leader of the worldEric28243 is the leader of the worldEric28243 is the leader of the worldEric28243 is the leader of the worldEric28243 is the leader of the worldEric28243 is the leader of the worldEric28243 is the leader of the worldEric28243 is the leader of the world
Excellent. Thank you!
'08 Polar White Saturn SKY Redline - "The RAWRmobile"
BorgWarner EFR 6758 + IWG Mani, forge v2 BPV, Energy Full Suspension Bushings, GMPP 3-Bars, Vibrant Racing Catted HiFlow Downpipe, WERKS Boost Tubes, Intake, Power-Steering Relocation Kit, Radiator Hoses, and Race FMIC, Koni Yellows + Eibach Pro-Kit's, RPi GT CBE, HP Tuner SquishyTooned on E40, RK Sport Rotors/Pads, DDMWorks 2-gauge Pillarpod and Armrest, Prosport HALO Electronic Wideband and Boost Gauges, Spec Stage 2+ Clutch + Fidanza Single-Mass FryWhee, XTUNERS Gauge Cluster, GM Roadster.com HID/LED Full Exterior and Interior Light Conversion
Dyno: Uhh... fast as hell?
'08.0 Cosmic Blue MS3 - "The Daily" STOCKED OUT (almost)
COBB SRI/TIP - COBB AP SquishyTooned on E40 - COBB XLE BPV - HKS Hi-Power CBE - ITV22s - Corksport RMM Inserts - JBR Shifter Bushings and SSP - PTP Fuel Pump - PG + Treadstone - 35% Tint - ebaY Double-Penetrator - MS3 Vent Kit Install
Dyno: 319 / 331
CWP_MS3 is my mackdaddy
Eric28243 is offline   Reply With Quote
 Old 03-09-2013, 06:57 PM   #4
Tabasco69's Avatar
Tabasco69 is the leader of the worldTabasco69 is the leader of the worldTabasco69 is the leader of the worldTabasco69 is the leader of the worldTabasco69 is the leader of the worldTabasco69 is the leader of the worldTabasco69 is the leader of the worldTabasco69 is the leader of the worldTabasco69 is the leader of the worldTabasco69 is the leader of the worldTabasco69 is the leader of the world
I really aprecaite the videos, Honestly I haven't been around any other cars with after market mounts and when I upgraded all 3 of mine I wasn't sure if the noises I was hearing where normal, I did it in steps like you did here, the transmission kind of sounds like a straightcut gear box..and when I did the passenger side I could hear the valvetrain noises.
JBR likes this.
425whp/395ftlbs - GTX3071R .82a/r- 20psi- 92 octane pump fuel
Tabasco69 is offline   Reply With Quote
The Following User Says Thank You to Tabasco69 For This Useful Post:
JBR (03-09-2013)
 Old 04-07-2013, 05:20 PM   #5
Sum1UDidntC's Avatar
Posts: 157   (View Stats)
Sum1UDidntC has a reputation beyond reputeSum1UDidntC has a reputation beyond reputeSum1UDidntC has a reputation beyond reputeSum1UDidntC has a reputation beyond reputeSum1UDidntC has a reputation beyond reputeSum1UDidntC has a reputation beyond reputeSum1UDidntC has a reputation beyond reputeSum1UDidntC has a reputation beyond reputeSum1UDidntC has a reputation beyond reputeSum1UDidntC has a reputation beyond reputeSum1UDidntC has a reputation beyond repute
I love mine and now it sounds dual charged with a supercharger at those low speeds lol ;p I actually like the vibes cuz it makes me feel like im in a race car. no compromise!
2011 Black Mica MazdaSPEED3 // CS SRI // CS TIP // HKS SSQV-IV VTA w/ CP-E flange // CP-E FMIC // CP-E Triton CBE // CP-E Catted DP // CP-E HPFP // CP-E Stage 2 RMM // COBB AP With Lex Tunes // JBR SSP // JBR 88DM TMM //JBR 80DM PMM // JBR custom cylindrical shift knob // JBR SSB's // Rally Armor Mudflaps // ISC Coilovers and front end links // Denso ITV-22's // SPC Camber Arms // Michelin Pilot SuperSports // STRATIFIED LEX TUNED FTMFW
Mustang Dyno Results:
301WHP 334WTQ on 35% E85
282WHP 325WTQ on 92oct
Sum1UDidntC is offline   Reply With Quote
 Old 09-08-2015, 01:21 PM   #6
pastry00's Avatar
Posts: 154   (View Stats)
pastry00 has much to be proud ofpastry00 has much to be proud ofpastry00 has much to be proud ofpastry00 has much to be proud ofpastry00 has much to be proud ofpastry00 has much to be proud ofpastry00 has much to be proud ofpastry00 has much to be proud of
Groaned at 5 Times in 1 Post
Highly recommend buying their motor mounts. Makes your car feel brand new giving it a great aggressive feel to it. I took out my old motor mount with only 60k miles and it was shot put JBR motor mount and the cars feels brand new and so responsive! It does cause a lot of vibration but only at first acceleration.
JBR likes this.
pastry00 is offline   Reply With Quote
The Following 2 Users Say Thank You to pastry00 For This Useful Post:
JBR (09-08-2015), Mauro_Penguin (09-08-2015)
 Old 09-27-2015, 10:30 PM   #7
chrono996's Avatar
Posts: 88   (View Stats)
chrono996 is the leader of the worldchrono996 is the leader of the worldchrono996 is the leader of the worldchrono996 is the leader of the worldchrono996 is the leader of the worldchrono996 is the leader of the worldchrono996 is the leader of the worldchrono996 is the leader of the worldchrono996 is the leader of the worldchrono996 is the leader of the worldchrono996 is the leader of the world
When I installed my JBR 80duro PMM and TMM, my car shook so violently that I had the plastic liners and such falling out in my car. After about 2000 kilometers though, they barely noticable anymore except for low rpms and a bit of gas, and that sweet spot at like 34-3600 rpm where it hits the right vibes from the engine and shakes the car for a couple seconds.
Rides extremely comfortable for me though I've had a couple passengers say on a long drive that it was a little tiresome. Worth it though? Absolutely! The responsiveness feels amazing and the car is so strapped to the ground that any other little "inconvience" isn't worth not getting these.
When i opened up their extremely good packaging the quality and look of the pieces were awesome. Never once looked at them and thought "Weeell... this could be better".
I'm still on the k04 with a few small things done to the car, refer to sig. I bought them because the OEM ones decided to take a shit in my engine bay.
An in all, a great product worth getting.
James
JBR likes this.
Ye Olde Engine:
Cobb Accessport, Autotech Internals, Cobb SRI, Corksport TIP
Pending a Tune:
CP-E TMIC, ATP Catless Downpipe
Suspension:
H&R Springs, Koni Yellows, Hotchkis Front and Rear Swaybars, Corksport Front and rear Endlinks, Whiteline front Control Arm Bushings
chrono996 is offline   Reply With Quote
The Following User Says Thank You to chrono996 For This Useful Post:
JBR (09-28-2015)
 Old 09-28-2015, 11:14 AM   #8
James
We're very pleased to hear that you're enjoying them so much.
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f337/jbr-motor-mounts-mounts-107059/
STF build Thread - Page 11 - Mazda3 Forums : The #1 Mazda 3 Forum This thread Refback 09-23-2013 02:01 PM
support moteur jbr - Mazda 3 Quebec This thread Refback 01-05-2013 10:31 AM
JBR TMM et PMM - Mazda 3 Quebec This thread Refback 10-28-2012 12:41 PM
Motor mounts.. : mazda3 This thread Refback 06-13-2012 08:09 AM
Motor Mounts Shermer321 MazdaSpeed 6 - Engine, Transmission & Driveline 9 07-21-2010 03:13 PM
Motor Mounts Postulio4joo MazdaSpeed 3 - Engine, Transmission & Driveline 13 02-13-2010 06:59 AM
motor mounts LiEast MazdaSpeed 3 - Engine, Transmission & Driveline 8 06-13-2009 06:34 AM
Page generated in 0.50309 seconds with 28 queries
