Like Tree8Likes
  • 5 Post By Raider
  • 1 Post By Turbo_Steve
  • 1 Post By JSmith
 Old 10-22-2015, 12:45 PM   #1
Default Turbo_Steve's Valve Cover and HPFP cover review
As many of you know, @Turbo_Steve; has been playing with fabrication of parts for us. He's also working to get vendor status here, and this thread will move there once established.
I have received and installed the covers. These are aluminum panels that were powder coated wrinkle black. Initial review was of packaging. Packed nicely and no scratches. Both coated panels were plastic wrapped. Then they were wrapped in enough material to keep it immobilized in the box. Color instructions are nice and ended up easy to follow.
For the install, total time was 15 minutes including pics and backing out my car.
Before
Because my piping is protege garage v1, it's own fitment is pretty much butthole. But I was able to remove the coil pack bolts without removing the hot pipe.
Hardware consists of Allen bolts, a washer, a spacer, and a little rubber o-ring that just holds it in place for install which is great, when all 4 are hanging prior to install.
Installed quickly. I slid into place, lining each bolt with the coil pack prior to tightening any.
Hpfp was cake too. Same thing as before. Remove bolts, put plate and hardware on. This one used 2 spacers, but the little o-ring kept it right. Installed in a couple minutes.
Fitment was spot on. I bet others will have a lot more clearance than I do.
Covers the coil mess and looks clean. Not sure if this counts as another modification I have installed, but I'm claiming it. 6 now.
Look for @Turbo_Steve; to be a vendor soon under Adapted Performance.
The Following 19 Users Say Thank You to Raider For This Useful Post:
Boost_creep (10-31-2015), Code Monkey (10-22-2015), dale_gribble (10-22-2015), DevinS (12-23-2015), Easter Bunny (10-22-2015), Finchee (11-06-2015), ItsNox (10-27-2015), John596 (04-08-2016), Justin@Freektune (10-24-2015), macdiesel (10-22-2015), Mauro_Penguin (10-22-2015), monkey.bones.007 (10-22-2015), robbspeed (11-28-2015), Scare Dem (10-22-2015), SofaKingAwesome (10-22-2015), therapist510 (10-23-2015), ToyCop (01-15-2016), Turbo_Steve (10-22-2015), Zoom66 (10-22-2015)
 Old 10-22-2015, 12:55 PM   #2
Turbo_Steve's Avatar
Posts: 944   (View Stats)
Looks good! Nice writeup.
Only sad part is the mazdaspeed logo is partially covered with this charge piping.
I will offer versions with no logo cutout as well & lots of color options.
Thanks!
ouchmonkey likes this.
Soon to come.
WHO KNOWS? A.D.D. FTW!
The Following 8 Users Say Thank You to Turbo_Steve For This Useful Post:
DingoDave (12-05-2015), Easter Bunny (10-22-2015), ericrapp0507@gmail.com (06-16-2016), ItsNox (10-27-2015), jcolton (02-10-2017), Mauro_Penguin (10-22-2015), Raider (10-22-2015), Zoom66 (10-22-2015)
 Old 10-22-2015, 01:03 PM   #3
Thanks!
The MPS logo would be badass too, or just blank. I am sure other piping kits wont be as suckballs as my kit.
 Old 10-22-2015, 01:51 PM   #4
Zoom66's Avatar
Posts: 281   (View Stats)
Need me one of those sets in red with the mazda speed logo. It will be easier to install on mine with the fmic piping routed under the engine. This looks really good.
 Old 10-22-2015, 02:42 PM   #5
knocturnal's Avatar
Posts: 266   (View Stats)
I need one in MattDamond gold. looks good
Mods:
Stratified Tuned Stage 2 OTS+
273whp/330wtq
SnailD Tuned on Meth
316whp/359wtq
412whp/373wtq
 Old 10-22-2015, 03:06 PM   #6
aackthpt's Avatar
Posts: 1,450   (View Stats)
That is sweet.
2013 'speed3, silver
Stage Bro
 Old 10-22-2015, 04:30 PM   #7
macdiesel's Avatar
Posts: 825   (View Stats)
Is it possible to do a smaller mazdaspeed logo and align it to the left? Looks great though.
 Old 10-22-2015, 07:47 PM   #8
The version with no Mazdaspeed logo would be ideal. You can apply vinyl anywhere you wish like in this version.
Soon to come.
The Following 5 Users Say Thank You to Turbo_Steve For This Useful Post:
Easter Bunny (10-24-2015), ericrapp0507@gmail.com (06-16-2016), macdiesel (10-22-2015), Mauro_Penguin (10-22-2015)
 Old 10-23-2015, 08:54 PM   #9
eliwwjd's Avatar
Posts: 518   (View Stats)
Wow those really look good for engine dress up I like them but the only problem is that those of us who have TMIC won't get the benefit of this nice piece of work! Great work Steve!
Forge BPV V2//COBB AP V3// COBB DP //ETS TMIC//AUTOTECH HPFP//JBR SRI//JBR TIP//JBR COOLANT BYPASS KIT//JBR DISI HOSES//JBR BYPASS HOSE//JBR THROTTLE BODY THERMAL GASKETS//JBR SHIFTER BUSHINGS// //RACING BEAT CBE//DAMOND MOTORSPORTS OCC//COBB RMM//CS LED KIT//CS LED FOGS//CBI OSRAM HID BULBS//CONTI EXTREME CONTACT 235/40 R18//RACESENG SHIFT KNOB//FREEKTUNED ON 93 PUMP GAS
 Old 10-24-2015, 05:37 AM   #10
I do want to follow up that it passes the wheel hop/spin test with the JBR high duro trilogy mounts. Had some fun, wheels spun, a little hop in 2nd and no banging heard or damage seen after.
Turbo_Steve (10-28-2015)
 Old 11-28-2015, 07:23 PM   #11
MY DICK IS SMALL-beautfpowers@gmail.com's Avatar
Posts: 327   (View Stats)
MY DICK IS SMALL-beautfpowers@gmail.com is infamous around these partsMY DICK IS SMALL-beautfpowers@gmail.com is infamous around these partsMY DICK IS SMALL-beautfpowers@gmail.com is infamous around these partsMY DICK IS SMALL-beautfpowers@gmail.com is infamous around these partsMY DICK IS SMALL-beautfpowers@gmail.com is infamous around these partsMY DICK IS SMALL-beautfpowers@gmail.com is infamous around these partsMY DICK IS SMALL-beautfpowers@gmail.com is infamous around these partsMY DICK IS SMALL-beautfpowers@gmail.com is infamous around these partsMY DICK IS SMALL-beautfpowers@gmail.com is infamous around these partsMY DICK IS SMALL-beautfpowers@gmail.com is infamous around these partsMY DICK IS SMALL-beautfpowers@gmail.com is infamous around these parts
Groaned at 212 Times in 84 Posts
sex
MY DICK IS SMALL-beautfpowers@gmail.com is offline   Reply With Quote
The Following User Says Thank You to MY DICK IS SMALL-beautfpowers@gmail.com For This Useful Post:
Raider (11-30-2015)
 Old 07-08-2017, 09:40 PM   #12
Partiesplayin's Avatar
Posts: 18   (View Stats)
Partiesplayin is on a distinguished road
Groaned at 3 Times in 1 Post
I want a set with logos
Partiesplayin is offline   Reply With Quote
 Old 07-08-2017, 10:00 PM   #13
JSmith's Avatar
Posts: 707   (View Stats)
Groans: 106
@Partiesplayin; It is generally frowned upon to resurrect 2 year old threads without adding useful content.
macdiesel likes this.
 Old 11-08-2017, 08:17 AM   #14
darkmx-6's Avatar
Posts: 126   (View Stats)
darkmx-6 is just really nicedarkmx-6 is just really nicedarkmx-6 is just really nicedarkmx-6 is just really nicedarkmx-6 is just really nice
At least he searched lol
but It would be better not to revive such an old thread though. Just send the guy a private message.
darkmx-6 is offline   Reply With Quote
The Following User Says NO Thank You to darkmx-6 For This Un-useful Post:
JSmith (11-08-2017)
Page generated in 0.34058 seconds with 31 queries
