| MazdaSpeed 3/6 - Dyno Sheets/Discussions Post up your dynosheets. Discuss the graphs and any related information. |
![]() | | #121 | ![]() |
Groans: 438
| Not Ranked : 0 score
__________________ All good things must come to an end... |
![]() | | #122 | ![]() |
![]() Join Date: Nov 2010 Location: Riverhead, NY
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,457
| Not Ranked : 0 score |
| The Following 2 Users Say Thank You to Boost_creep For This Useful Post: | Philthyphil (09-16-2015), Thepedigree13 (09-08-2015) |
![]() | | #123 | ![]() |
![]() Join Date: Oct 2012 Location: Colorado Springs, CO
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 757
| Not Ranked : 0 score GF in the trunk... nice numbers!
__________________ mods: \\// AT HPFP // AccessPort // CS S2 TIP, SRI and TMIC // CPe S2 RMM // Synapse BPV // Mazda gutted secondary cat // S-OTS+ 91S2 // HKS TP DLi II // Wilwood DP6 13” brakes // TCE 2 piece rear rotors // Maxwell SuperCap/LiFePO4 cell \\// waiting for install: \\// CPE Catted DP // CS Battery Box // Devils Own Meth kit // H&R Coilovers \\// |
![]() | | #124 | ![]() |
![]() Join Date: Oct 2012 Location: Long Beach, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 255
| Not Ranked : 0 score I just had the bitch on a dyno at church made ( yes it reads high ) 401whp. https://www.youtube.com/watch?v=3pa8JhilWT0
__________________ Bnr s3/Act 6 puck/sure full 3inch intake/cobb fmic/cobb downpipe/grimmspeed ebc/3 bar map/hks catback/autotech hpfp internals/turbosmart bpv/bc coilovers/jbr trilogy mounts/ngk one step colder plugs/ms6 rims on nt-01 tires. 24 psi E85 freektuned. Freektuned e85 Focus st as the daily. |
| The Following User Says Thank You to boostdmazda3 For This Useful Post: | JgamB (09-14-2015) |
![]() | | #125 | ![]() |
![]() Join Date: Apr 2013 Location: Atlanta, Georgia
Rep Power: 1578 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 9,584
| Not Ranked : 0 score Somebodies clutch is slipping
__________________ '06 Mazdaspeed 6 GT Power & Drivetrain BNR S3v2 / AP V3 + 100% Meth / Autotechs / JBR Tru 3.5" SRI w/ 51R Battery / ETS TMIC / DO Meth D07 @ 100% / ACT6 Puck w/ Streetlight FW / 80mm CorkSport Exhaust / SLS Test Pipe / Turbosmart BPV / Techna-Fit SS CL / AP Shift Hammer / Bosch 3Bar / Grimspeed EBCS / NGK 1 Step Colder / JBR Boost Tubes / ProSport Sammich Plate / Rotella Suspension & Mounts KWv2 Fronts & Bilstein Rears / AIDS Rear Diff Mounts / Whiteline RSB / Prothane Lowpro Bushings / Steeda Endlinks / JBR 88RMM / JBR Solid Bushings Brakes & Wheels StopTech Slotted Rotors & Pads / Technafit SS Brake Lines / Evo X Wheels / 245/40/18 Potenza RE760s Misc Redline & Unicorn Jizz (XTM5QS) / Sharkfin Antenna / Kuda Mount of Sweetness / Full TRS Mini-H1 Retrofit w/ Demon Eyes / TRS Xb LED Fogs / Hardwired Valentine 1 w/ Bluetooth / AuxMod w/Bluetooth - Miltuned On order/To be installed: E-btec Built Motor , BNR S4, CPe EWG Exhaust Mani, Precision 46mm WG, Kozmic 6th Port, CS FSB, RDMotorsportz Crash Bar, CS Injector Seals.![]() |
| The Following User Says Thank You to ItsNox For This Useful Post: | JgamB (09-14-2015) |
![]() | | #126 | ![]() |
![]() | | #127 | ![]() |
![]() Join Date: Mar 2013 Location: Huntsville, AL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,402
| Not Ranked : 0 score Until that clutch is replaced, I do not know you. Speed6 clutch swaps
__________________ Manley forged long block, secret snail, manifolds, and 2gal E85 tune running like a champ - about to dial in a lot of meth and see what we've got. 13.10@117.1 full weight DD no prep 1/4 (BNR S3 / E85) |
![]() | | #128 | ![]() |
| Not Ranked : 0 score Unfortunately yes. Luk/Fidanza combo. Funds arent there for anything sweeter . Its a solid combo for my power level so I shouldnt be complaining about not going aftermarket clutch. Yea I've read its pretty much easier to pull the engine and swap the clutch. FML LOL Come on man I got a really comfy recliner, beers, good food, and NFL Sunday Ticket
__________________ '06 Mazdaspeed 6 GT Power & Drivetrain BNR S3v2 / AP V3 + 100% Meth / Autotechs / JBR Tru 3.5" SRI w/ 51R Battery / ETS TMIC / DO Meth D07 @ 100% / ACT6 Puck w/ Streetlight FW / 80mm CorkSport Exhaust / SLS Test Pipe / Turbosmart BPV / Techna-Fit SS CL / AP Shift Hammer / Bosch 3Bar / Grimspeed EBCS / NGK 1 Step Colder / JBR Boost Tubes / ProSport Sammich Plate / Rotella Suspension & Mounts KWv2 Fronts & Bilstein Rears / AIDS Rear Diff Mounts / Whiteline RSB / Prothane Lowpro Bushings / Steeda Endlinks / JBR 88RMM / JBR Solid Bushings Brakes & Wheels StopTech Slotted Rotors & Pads / Technafit SS Brake Lines / Evo X Wheels / 245/40/18 Potenza RE760s Misc Redline & Unicorn Jizz (XTM5QS) / Sharkfin Antenna / Kuda Mount of Sweetness / Full TRS Mini-H1 Retrofit w/ Demon Eyes / TRS Xb LED Fogs / Hardwired Valentine 1 w/ Bluetooth / AuxMod w/Bluetooth - Miltuned On order/To be installed: E-btec Built Motor , BNR S4, CPe EWG Exhaust Mani, Precision 46mm WG, Kozmic 6th Port, CS FSB, RDMotorsportz Crash Bar, CS Injector Seals.![]() Last edited by ItsNox; 09-14-2015 at 02:31 PM. |
| The Following 2 Users Say Thank You to ItsNox For This Useful Post: | JgamB (09-14-2015), Mazdazilla6 (09-14-2015) |
![]() | | #129 | ![]() |
![]() Join Date: May 2011 Location: knoxville, TN
Rep Power: 1702 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,468
What about ky clutch? 6 puck that a few of our tn guys are running @l4nc3r;
__________________ Brent Mazda Dragon Camp - Event Coordinator -Built Block-5858-Meth Dragon Slayer Setup FreekTuned ![]() | |
![]() | | #130 | ![]() |
__________________ '06 Mazdaspeed 6 GT Power & Drivetrain BNR S3v2 / AP V3 + 100% Meth / Autotechs / JBR Tru 3.5" SRI w/ 51R Battery / ETS TMIC / DO Meth D07 @ 100% / ACT6 Puck w/ Streetlight FW / 80mm CorkSport Exhaust / SLS Test Pipe / Turbosmart BPV / Techna-Fit SS CL / AP Shift Hammer / Bosch 3Bar / Grimspeed EBCS / NGK 1 Step Colder / JBR Boost Tubes / ProSport Sammich Plate / Rotella Suspension & Mounts KWv2 Fronts & Bilstein Rears / AIDS Rear Diff Mounts / Whiteline RSB / Prothane Lowpro Bushings / Steeda Endlinks / JBR 88RMM / JBR Solid Bushings Brakes & Wheels StopTech Slotted Rotors & Pads / Technafit SS Brake Lines / Evo X Wheels / 245/40/18 Potenza RE760s Misc Redline & Unicorn Jizz (XTM5QS) / Sharkfin Antenna / Kuda Mount of Sweetness / Full TRS Mini-H1 Retrofit w/ Demon Eyes / TRS Xb LED Fogs / Hardwired Valentine 1 w/ Bluetooth / AuxMod w/Bluetooth - Miltuned On order/To be installed: E-btec Built Motor , BNR S4, CPe EWG Exhaust Mani, Precision 46mm WG, Kozmic 6th Port, CS FSB, RDMotorsportz Crash Bar, CS Injector Seals.![]() | |
![]() | | #131 | ![]() |
| Not Ranked : 0 score you will have to call them to find out. best bet it to do that and discuss with them you goals. hp/tq etc. im pretty sure @nindoja; is running one on his six. right @JgamB; ? the guy we have running one sent in a stock disc. they converted it to a 6 puck. hes running a gen 2 pressure plate and fidanza flywheel (im pretty sure). they have a kit that mates to an ACT flywheel too. http://kyclutch.com/
| The Following User Says Thank You to 865ms3 For This Useful Post: | JgamB (09-14-2015) |
![]() | | #132 | ![]() |
__________________ Manley forged long block, secret snail, manifolds, and 2gal E85 tune running like a champ - about to dial in a lot of meth and see what we've got. 13.10@117.1 full weight DD no prep 1/4 (BNR S3 / E85) | |
![]() | | #133 | ![]() |
| Not Ranked : 0 score Food for thought I have a Act 6 puck streetlight disk sprung. My stocker started slipping after the bnrs3. The clutch is not as bad as you think but of course stiffer and much shorter. I also had to replace the master and slave cylinder very shortly after.
| The Following User Says Thank You to boostdmazda3 For This Useful Post: | ItsNox (09-16-2015) |
![]() | | #134 | ![]() |
![]() Join Date: May 2009 Location: Huntsville, AL
Rep Power: 1431 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,522
__________________ True Red 2009 MS3 Damond Motorsports: RMM // Short Shift Plate Suspension: Koni Yellows // Swift Spec-r springs // Fatcat motorsports front bump stops // Rear Camber Arms Brakes: Hawk HPS pads // ATE Superblue fluid // Stainless Steel Brake Lines Other: CP-e Safe Seals // MattDamond shift plate // Masonvi shift knob // 3.5" WP w/recirc // RSB // IM + TB tigs // Synapse Engineering FMIC + BOV // Autotech internals Tune: hypnotic tuned Critical Stats: // 305whp/352tq // 13.34 @ 98 - Mason Dixon Dragway - 4/13/14 Titanium Gray 2006 Mazdaspeed 6 Damond Motorsports: OCC // Short shift plate // Turbo oil feed restrictor bolt Other: Autotech internals // Ebay M2 DP // Masonvi shift knob // | ||
![]() | | #135 | ![]() |
![]() Join Date: Jul 2012 Location: Nashville, TN
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 22
| Not Ranked : 0 score I'm running a Fidanza Flywheel, Gen2 Pressure plate, and KyClutch's 6puck. Car hooks great. Pedal feels stock, just grabs like a mofo. I currently have 10k miles on this setup and it feels amazing. I sent my clutch to them, and less than a day later they already had sent it back. I think I paid $250, which included them shipping it back. Came with new throwout bearing and alignment tool also. I read up on the ACT clutch and everything. I saw that they boasted a ??% more clamping power on their setup than stock. That's because the clutch is a smaller diameter. So to get the same clamping force as stock, they have to stiffen up the pressure plate. So really what are you gaining from it?
__________________ 07 Red Speed3 - SHE'S ALIVE! SHE'S ALIVE!!! GT3071R / HTP 4" Intake / Brentported Intake Manifold / CXRacing Piping with TR8L Core DNP v2 Exhaust Manifold / Stainless Steelworks Downpipe/Test Pipe / HKS Hi-Power CatBack FreekTuned E25 / HKS SSQV2 / JBR 88 Trio Bilstein B8's / Eibach Prokit / Drag DR-34 18x8 Soon to be installed - Snow Performance Meth Kit with CM14 Nozzle |
![]() | | #136 | ![]() |
| Not Ranked : 0 score Thank you for the input everyone. Sorry if I derailed for a bit.
Sent from my SM-N910T using Tapatalk
| The Following User Says Thank You to ItsNox For This Useful Post: | MD1032 (01-13-2016) |
![]() | | #137 | ![]() |
![]() Join Date: Nov 2009 Location: Vancouver, Canada
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 13
How is your clutch holding up if you launch the car?
__________________ COBB AP : JBR 3 Inch Full Intake : CORKSPORT TMIC : AUTOTECH INTERNALS : JBR SSP CPE Full RMM : Cobb Catted DOWNPIPE : BNR S3 : KW V1 Coilovers : Klutch SL18 Rims Guardian Angel : Stratified 3 Port : Michelin PSS 235/40/18 : SNOW PERFORMANCE : E85 Stratified Tune | |
![]() | | #138 | ![]() |
Groans: 438
| Not Ranked : 0 score 400/405 Now I just need to get on an actual dyno and see what I get.
| The Following 2 Users Say Thank You to g00s3y For This Useful Post: | InkedInspector (01-13-2016), JgamB (01-13-2016) |
![]() | | #139 | ![]() |
| Police ![]() Join Date: Jul 2013 Location: Louisville, KY
Rep Power: 2719 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 9,545
Groans: 312
| Very nice curve and peak power, but aren't you concerned about your stock block from a longevity stand point at those numbers? Either way, very interested to see your actual dyno numbers.
__________________ |
![]() | | #140 | ![]() |
![]() Join Date: Mar 2012 Location: Waterford, MI - America's High Five
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,451
| Not Ranked : 0 score He's also rollin' on dynojet. Put it at 1.01 CF, correct tire width/height and see what happens.
__________________ Silver 2007 Speed3 GT Xona Rotor 6156, Port Injection w/ E85...Bunch of other stuff. I make some power. Titanium Grey Mazdaspeed6 GTX3071, DD |
![]() | | #141 | ![]() |
![]() Join Date: Mar 2013 Location: North Brunswick, NJ
Rep Power: 1125 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,645
Groans: 143
| Not Ranked : 0 score It's ~372 on 1.01. Seems safe enough to me. FWIW my dyno numbers on CP-E's AWD Mustang dyno were higher by 10 whp with 150°F BATs than they were with 100° BATs doing a 4th gear pull in vdyno with 1.01 CF. Justin and some other people around here are starting to think 1.01 is a little bit low and that seems to be the case. I'm probably going to start reviewing my runs using Dynojet CF to make sure I'm not underestimating torque. I will continue to post vdynos at 1.01 on the forums for comparison purposes. I probably won't dyno my S3 until I get rid of the stock CBE and get my WMI up and running.
__________________ 2007 Mazdaspeed3 GT |
| The Following 3 Users Say Thank You to MD1032 For This Useful Post: |
![]() | | #142 | ![]() |
Or the curb weight for the gen2 is actually lower than stated by a fair margin?
| The Following User Says Thank You to JgamB For This Useful Post: | HawkeyeGeoff (01-13-2016) |
![]() | | #143 | ![]() |
Groans: 438
I know I'll probably get on the dyno (hopefully this weekend), and it be under 400hp (I don't know why I think that, but I just don't want to be let down), but damn I was happy when I threw the log I was able to get in today in VD.
__________________ All good things must come to an end... | ||
| The Following User Says Thank You to g00s3y For This Useful Post: | InkedInspector (01-13-2016) |
| Dyno numbers seem low. | nzjase | 2010 MS3 - Dyno Sheets/Discussions | 15 | 07-15-2013 11:16 AM |
| Guess my Dyno numbers | deekspeed | Gen2 MS3 General Discussion | 17 | 05-03-2013 10:05 AM |
| Stock dyno numbers | Ace99899 | Gen2 MS3 General Discussion | 9 | 10-19-2011 05:36 AM |
| cp-e™ Nano dyno numbers! | www.cp-e.com | Custom Performance Engineering (cp-e.com) | 49 | 10-21-2008 10:20 PM |
