> MazdaSpeed 3/6 - Dyno Sheets/Discussions
MazdaSpeed 3/6 - Dyno Sheets/Discussions Post up your dynosheets. Discuss the graphs and any related information.
Like Tree3Likes
  • 1 Post By silvapain
  • 1 Post By NCspecV81
 Old 10-09-2013, 03:03 AM   #1
OG Prostitute
shopety2012's Avatar
Posts: 1,055   (View Stats)
shopety2012 is the leader of the worldshopety2012 is the leader of the worldshopety2012 is the leader of the worldshopety2012 is the leader of the worldshopety2012 is the leader of the worldshopety2012 is the leader of the worldshopety2012 is the leader of the worldshopety2012 is the leader of the worldshopety2012 is the leader of the worldshopety2012 is the leader of the worldshopety2012 is the leader of the world
Groaned at 68 Times in 40 Posts
Default but i have a gen 1 tranny tho...
im thinking these become relevant because im on a gen 1 tranny, therefor having gen 1 tranny gear ratios... therefor gen 1 power to gear ratio... ratios lol
whatever, mods can delete if im out of line
logs and any other details are in this thread
http://www.mazdaspeedforum.org/forum/for...0/#post2289260
all 4 pulls on same road, the 3 on the same sheet are from the same day and time
k04, 93oct, freektuned
File Type: jpg october 8th (4th gear pull) cf 1.01.jpg (54.6 KB, 168 views)
stock as fuck gay blue pu, still haz juan tranny and evox wheels in shocker yellow tho
currently forging a monster sr20det LS swap killer... brb
used to be the "best looking life partner blue ive seen" - Voltron
TEAM LBN BEERS -- FYCN
TEAM MUMFORD -- FYCN
TEAM Dad -- FYCN
shopety2012 is offline   Reply With Quote
 Old 10-09-2013, 03:12 AM   #2
blackms3_71's Avatar
Posts: 2,250   (View Stats)
what do you mean by the tranny stuff?
 Old 10-09-2013, 03:18 AM   #3
OG Prostitute
not sure what exactly you are asking so here are 2 answers
1: i have an entire transmission from a gen 1, but i have a 2010 speed
2: the gen 1's gearing is shorter (so higher ratios) so if i use the same log in VD but calculate power with the longer gears (or lower ratios) from a gen 2 transmission then it will give inaccurate readings by reading far more power than i actually am putting down because it thinks im going through more gear than i actually am in the same amount of power.
TEAM Dad -- FYCN
 Old 10-09-2013, 03:21 AM   #4
oh okay I understand. so then do you just pick the 07-09 ms3 instead of the 10-13? and which do you find to be faster the gen1 trans?
 Old 10-09-2013, 03:25 AM   #5
OG Prostitute
Yes I pick the gen1. And each have pros and cons. I go through gears quicker, a tad more acceleration until about top of 4th or into 5th gear where the gen2s longer gears help to keep pulling the car. I'm sure if someone got the actual ratios each gear had out then you could see which transmission would suit which power level better. For now I'm saying gen 2 tranny is better for higher power levels, speed wise. But if I had traction from 1st - 3rd (lol) the gen 1 would be better IMO. Also all depending on what your uses for the car are.
In the end gen 1 tranny suits low end acceleration and the gen 2 tranny suits high end power
TEAM Dad -- FYCN
 Old 10-09-2013, 03:28 AM   #6
alright cool good info to know. why did u get a gen 1 trans anyways? 2 gear pop out and mazda wont cover and gen 1 tran was cheaper?
 Old 10-09-2013, 03:32 AM   #7
OG Prostitute
friend of mine was building a mile car out of his gen 1, wanted a gen 2 tranny for the longer gears, asked to do tranny swap, i agreed to the deal that he made me
TEAM Dad -- FYCN
 Old 10-09-2013, 03:33 AM   #8
oh shit nice lol
 Old 10-09-2013, 03:36 AM   #9
OG Prostitute
oh shit nice lol
his build fell through... :/ sold everything in need of money
TEAM Dad -- FYCN
 Old 10-09-2013, 03:39 AM   #10
wow that sucks to bad u could swap the tranny back
 Old 10-09-2013, 03:45 AM   #11
OG Prostitute
no lol i like this one... much more solid IMO... especially with the genpu second gear kick out
TEAM Dad -- FYCN
The Following User Says Thank You to shopety2012 For This Useful Post:
blackms3_71 (10-09-2013)
 Old 10-09-2013, 04:11 AM   #12
silvapain's Avatar
Posts: 6,665   (View Stats)
Groans: 136
1. There are already multiple threads about the gearing differences between the Juan and Pu transmissions. I even made nice Excel files to show the redline speed differences.
2. The Juan has the same 2nd gear issues that the Pu has.
CWP_MS3 likes this.
The Following 9 Users Say Thank You to silvapain For This Useful Post:
BobtailedSnail (11-18-2013), breakfstincluded (11-19-2013), CWP_MS3 (10-09-2013), guitarzan134 (10-09-2013), himurax13 (10-09-2013), Micha (11-19-2013), mr.speedy3 (11-19-2013), MS3inDC (10-09-2013), mzr0818 (10-09-2013)
 Old 10-09-2013, 04:19 AM   #13
OG Prostitute
1. There are already multiple threads about the hearing differences between the Juan and Pu transmissions. I even made nice Excel files to show the redline speed differences.
good to know info, thank you
but for the record i was just saying that MY current gen 1 tranny doesn't kick out of second when MY original transmission was kicking out of second occasionally at the time
edit: and this is why you sir are a "gearhead" and i am not worthy (insert not worthy smiley thing)
edit again: i looked on your profile through your threads and couldnt find it.. can i get a link to that file?
TEAM Dad -- FYCN
silvapain (10-09-2013)
 Old 10-09-2013, 06:05 AM   #14
silvapain's Avatar
Groans: 136
I looked but couldn't find the thread.
So here they are...
GenJuan:
GrnPu (with GenJuan tires):
GenPu 1-6 with Juan final drives:
GenJuan 1-6 with Pu final drives:
Biglegg likes this.
The Following 7 Users Say Thank You to silvapain For This Useful Post:
captain slow (10-09-2013), helmetface (10-09-2013), magicka (10-10-2013), Micha (11-19-2013), MS3inDC (10-09-2013), NCspecV81 (10-09-2013), skiptowncat (11-20-2013)
 Old 10-09-2013, 06:11 AM   #15
OG Prostitute
I looked but couldn't find the thread. So here they are... GenJuan: GrnPu (with GenJuan tires): GenPu 1-6 with Juan final drives: GenJuan 1-6 with Pu final drives:
I appreciate it man. So any comments towards my logs/power bands from a gear head?
Edit: sending you a message
TEAM Dad -- FYCN
 Old 10-09-2013, 07:46 AM   #16
shamie's Avatar
Posts: 952   (View Stats)
Were the tranys a direct swap?
 Old 10-09-2013, 07:51 AM   #17
OG Prostitute
Yup
TEAM Dad -- FYCN
 Old 10-09-2013, 08:53 AM   #18
guitarzan134's Avatar
Posts: 948   (View Stats)
guitarzan134 is the leader of the worldguitarzan134 is the leader of the worldguitarzan134 is the leader of the worldguitarzan134 is the leader of the worldguitarzan134 is the leader of the worldguitarzan134 is the leader of the worldguitarzan134 is the leader of the worldguitarzan134 is the leader of the worldguitarzan134 is the leader of the worldguitarzan134 is the leader of the worldguitarzan134 is the leader of the world
My Juan has a Pu transmission. We experienced some jerking in 4th gear at light/part throttle due to the ECU thinking it had Juan gears. Switched the ratios in ATR and all is well. There was a ~25whp drop before we switched the ratios, then everything was normal.
I liked the Juan gears, but I'm extremely pleased with the Pu gears.
Also a direct swap with zero fitment or mechanical issues.
I literally drive the wheels off Mazdaspeeds. Come at me, bruh!
2007 Mazdaspeed3 GT Black Mica
-~CORN!!! - Corksport PMM, CBE, SRI, & TIP - UR TP - Ebay DP - ETS TMIC - PnP IM - CPE SafeSeals - Autotechs - Forge V1 - NGK IX - Cobb AP, RSB - JBR TIG's + CB, Knob, SSB, & 88a RMM - GT-Spec chassis bracing - Hawk HPS/Stoptech Posiquiet - Technafit Lines - DBA T3 - ATE TYP200 - Moog Endlinks - Koni Yellows - Rota Grids 18x8.5 - Michelin PSS 245/40~-
guitarzan134 is offline   Reply With Quote
 Old 10-09-2013, 10:42 AM   #19
shamie's Avatar
That's great news as I've always wanted higher gears. I always want to shift into 7th cruising on the freeway.
Has anyone swapped the final drives between boxes?
 Old 10-09-2013, 11:12 AM   #20
I was just wondering this myself.
 Old 10-09-2013, 11:43 AM   #21
himurax13's Avatar
Posts: 4,585   (View Stats)
Groans: 255
The 5th and 6th gears are the same for both.
As far as I know, nobody has done that yet.
Pickles Tune in progress
 Old 10-09-2013, 01:06 PM   #22
shamie's Avatar
Not based on the tables silvapain posted.
The Following User Says Thank You to shamie For This Useful Post:
shopety2012 (10-09-2013)
 Old 10-09-2013, 01:33 PM   #23
OG Prostitute
The 5th and 6th gears are the same for both. As far as I know, nobody has done that yet.
Certain fabricator/tech I talked to said can't be done easily. And I'm pretty sure 5th and 6th are damn different, unless it's just the final drive throwing me off
TEAM Dad -- FYCN
 Old 10-09-2013, 11:12 AM   #24
NCspecV81's Avatar
Posts: 2,867   (View Stats)
I'd like a pu tranny with juan final.
himurax13 likes this.
captain slow (10-09-2013), himurax13 (10-09-2013)
 Old 10-09-2013, 11:31 AM   #25
captain slow's Avatar
Posts: 5,559   (View Stats)
Groans: 398
I second this!
 Old 10-09-2013, 11:14 AM   #26
I have a broken Juan transmission at Jeff's house. If the final drive gears are still working, that could be an awesome project...
Let the pondering begin.
The Following User Says Thank You to guitarzan134 For This Useful Post:
 Old 10-09-2013, 11:37 AM   #27
NCspecV81's Avatar
Oh yeah! I wouldn't attempt this tho without scoring a second pu tranny. Time to go junk yard diving.
 Old 10-09-2013, 02:23 PM   #28
silvapain's Avatar
Groans: 136
After I made those calculations, I believe Pablo stated the final drive gears wouldn't be easy to swap. Maybe he put more detailed info in his thread about the Euro Diesel MZ6 manual trans thread.
 Old 10-10-2013, 06:33 PM   #29
magicka's Avatar
Posts: 520   (View Stats)
MS6/MS3 gear ratios change
All the discussion is in here. I haven't read through the thread in a while, but the second to last post in it is Pablo saying that he hadn't figured out a way to do it yet. IIRC, the shafts are different between the gens, so at best there would be some serious machining/fab work to get them to mate up correctly.
2009 CWP MS3 GT
The Following 2 Users Say Thank You to magicka For This Useful Post:
guitarzan134 (10-11-2013), silvapain (10-10-2013)
 Old 11-19-2013, 05:27 AM   #30
PapaSmurf's Avatar
Posts: 8,236   (View Stats)
So you have gen1 transmission with gen2 axles or did you swap the axles to gen1 also?
I need to replace my driver side axle and was so wondering if a gen1 axle would work in my gen2
Sent from your girlfriends tapabedroom
860whp/677wtq
2.7 V6 Ecoboost
 Old 11-19-2013, 11:25 AM   #31
OG Prostitute
So you have gen1 transmission with gen2 axles or did you swap the axles to gen1 also? I need to replace my driver side axle and was so wondering if a gen1 axle would work in my gen2 Sent from your girlfriends tapabedroom
Gen 1 axles work. Last time I replaced mine, I used the EMPI brand new half shaft from rock auto, not a rebuilt axle. It seems pretty high quality, and is cheap. comes with a new axle nut too. Went very smoothly, I just pulled the whole knuckle off the axle, instead of trying to get an angle to slide it out
Edit : used EMPI for the 2009 because they didn't have any for the '10
TEAM Dad -- FYCN
 Old 11-19-2013, 11:33 AM   #32
PapaSmurf's Avatar
the gen1 axle fit into the gen2 transmission though?
860whp/677wtq
2.7 V6 Ecoboost
 Old 11-19-2013, 11:55 AM   #33
OG Prostitute
Yes they work. David, Tech/co-owner/Tuner/Fab at kozmic motorsports says they are the same.
TEAM Dad -- FYCN
PapaSmurf (11-19-2013)
 Old 11-19-2013, 12:43 PM   #34
PapaSmurf's Avatar
fuck yeah, save me a bunch of money lol.
A gen2 driver side is like $700 from mazda and almost impossible to find elsewhere.
860whp/677wtq
2.7 V6 Ecoboost
Hatchbackfan (12-11-2013)
 Old 10-28-2014, 06:24 PM   #35
capblueberry's Avatar
Posts: 134   (View Stats)
capblueberry has much to be proud ofcapblueberry has much to be proud ofcapblueberry has much to be proud ofcapblueberry has much to be proud ofcapblueberry has much to be proud ofcapblueberry has much to be proud ofcapblueberry has much to be proud ofcapblueberry has much to be proud ofcapblueberry has much to be proud ofcapblueberry has much to be proud of
EDIT: scratch that just realized this thread is old AF
capblueberry is offline   Reply With Quote
Tranny pix franciscoescn MSP - Engine, Transmission & Driveline 12 09-26-2012 04:24 PM
012 tranny oil shifter48 2010 MS3 - Engine, Transmission & Driveline 7 01-03-2012 10:55 AM
Tranny oil joe76 2010 MS3 - Engine, Transmission & Driveline 3 12-30-2011 07:31 AM
Page generated in 0.54581 seconds with 31 queries
