Miata MX-5
> Miata - Wheels, Tires & Appearance
 Old 11-11-2010, 01:16 PM   #41
phillyb's Avatar
Posts: 14,702   (View Stats)
Groans: 1,940
another coat of paint on
Originally Posted by Tommy View Post
Philly, you add any flex agent to that body filler? The shit tends to crack without it.
no...
i just used the body filler from bondo...idk wtf is in it.
there's only a few small areas with body filler...i'm not too worried about it
Last edited by phillyb; 11-11-2010 at 01:16 PM. Reason: MSF Database - Automerged Doublepost
 Old 11-11-2010, 01:22 PM   #42
Tommy's Avatar
Posts: 2,309   (View Stats)
Tommy is the leader of the worldTommy is the leader of the worldTommy is the leader of the worldTommy is the leader of the worldTommy is the leader of the worldTommy is the leader of the worldTommy is the leader of the worldTommy is the leader of the worldTommy is the leader of the worldTommy is the leader of the worldTommy is the leader of the world
Groans: 155
Groaned at 44 Times in 37 Posts
I wasn't the body guy but we had something like flex agent (used in paints) for adding to filler to fix bumper covers or other flexible body parts. If not used, the shit cracks open like RoRo's ass at a Saturday night rave.
Tommy is offline   Reply With Quote
The Following 3 Users Say Thank You to Tommy For This Useful Post:
forcedinduktion (11-11-2010), phillyb (11-11-2010), wankular (11-11-2010)
 Old 11-11-2010, 01:28 PM   #43
phillyb's Avatar
Groans: 1,940
hahahah
yeah, i've read the same shit all over the place. i'm not sure if i care or not. if it cracks down the line, maybe i'll have some money to afford a real paint job.
 Old 11-11-2010, 01:35 PM   #44
Fuck sushi rolls
rodrigo's Avatar
Posts: 18,719   (View Stats)
Groans: 356
second u get a strong head wind watch them filler spots knock off....shits gonna be dope
 Old 11-11-2010, 01:38 PM   #45
phillyb's Avatar
Groans: 1,940
SUPER DOPE
 Old 11-11-2010, 01:50 PM   #46
Tommy's Avatar
Groans: 155
That's why most shops will not repair those things or else they make it real clear that it's a temp fix. We've used fiberglass reinforcement strips on the back to keep them together but even they give out after a while.
 Old 11-11-2010, 07:52 PM   #47
Ur moms boyfriend
forcedinduktion's Avatar
Posts: 2,719   (View Stats)
Groans: 70
make sure to not rush the sanding part. esp when doing the final sanding. the guide coat really helps. ive rattle canned a few things, the one that turned out the worse was a body panel. i got all the rust out, and then put some bondo on the low spots and it looked perfect when i sprayed a light primer. it wasnt until i was spraying on the final top coats when i saw the tiny scratches in the finish. so make sure you sand really well with the fine paper. do it once and do it right. as my shop teacher used to say "a paint job is only as good as the prep work"
The Following User Says Thank You to forcedinduktion For This Useful Post:
 Old 11-11-2010, 08:12 PM   #48
phillyb's Avatar
Groans: 1,940
prep sucks.
i don't mind the sanding though. the body filler was the worst!
fuck that shit.
 Old 11-12-2010, 11:24 AM   #49
phillyb's Avatar
Groans: 1,940
ttt
 Old 12-17-2010, 11:45 PM   #50
s!lv!a's Avatar
Posts: 89   (View Stats)
s!lv!a has much to be proud ofs!lv!a has much to be proud ofs!lv!a has much to be proud ofs!lv!a has much to be proud ofs!lv!a has much to be proud ofs!lv!a has much to be proud ofs!lv!a has much to be proud ofs!lv!a has much to be proud of
Back from the dead!!!
If I can't make you finish on one forum I'll make you finish on another.. Haha, did you buff it out yet?
s!lv!a is offline   Reply With Quote
 Old 12-17-2010, 11:47 PM   #51
phillyb's Avatar
Groans: 1,940
fuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuu
my car is sitting in the driveway without the bumper on...the driver's side headlight was removed and i'm sanding and polishing that...
and then of course there's my massive fucking oil leak.
i'm currently in the middle of fucking FAIL
 Old 12-17-2010, 11:48 PM   #52
snailD's Avatar
Posts: 3,039   (View Stats)
sounds like the usual
NBD
 Old 12-18-2010, 10:42 AM   #53
mr_mazda329's Avatar
Posts: 798   (View Stats)
mr_mazda329 is the leader of the worldmr_mazda329 is the leader of the worldmr_mazda329 is the leader of the worldmr_mazda329 is the leader of the worldmr_mazda329 is the leader of the worldmr_mazda329 is the leader of the worldmr_mazda329 is the leader of the worldmr_mazda329 is the leader of the worldmr_mazda329 is the leader of the worldmr_mazda329 is the leader of the worldmr_mazda329 is the leader of the world
Groans: 55
Damn.. what the hell happened. Where's the oil leak?
09 MS3 CWP BNR-S3 GFB Respons BPV, HTP 3.5in whalepenis , CXRacing/TR8L Core FMIC CorkSport CBE CNT Catless long DP, NGK Plugs, DM Trilogy, Cobb AP VEGA Tuned, CP-e HPFP CP-e Injector Seals
97 Miata Daily Driver
04' Mazdaspeed Miata Track Car
Road Racing > Autocross > Spirited Driving > Sitting in Traffic > Mowing Lawns > Drag Racing
mr_mazda329 is offline   Reply With Quote
 Old 12-18-2010, 11:02 AM   #54
phillyb's Avatar
Groans: 1,940
i think it's oil cooler > block
 Old 12-18-2010, 11:03 AM   #55
John F's Avatar
Posts: 790   (View Stats)
John F is the leader of the worldJohn F is the leader of the worldJohn F is the leader of the worldJohn F is the leader of the worldJohn F is the leader of the worldJohn F is the leader of the worldJohn F is the leader of the worldJohn F is the leader of the worldJohn F is the leader of the worldJohn F is the leader of the worldJohn F is the leader of the world
Philly when you get the leak taken care of...
Finish the wet sand with like 1500, then follow up with something like meguiars 105 and 205. 105 will remove the sanding marks and the 205 will polish it to a high gloss.
2010 Speed Three
John F is offline   Reply With Quote
The Following User Says Thank You to John F For This Useful Post:
phillyb (12-18-2010)
 Old 12-18-2010, 11:12 AM   #56
phillyb's Avatar
Groans: 1,940
send me some, i'll send you my address!!!!
lol
 Old 12-18-2010, 12:46 PM   #57
Groans: 55
you haz oil cooler kit?
 Old 12-18-2010, 03:26 PM   #58
phillyb's Avatar
Groans: 1,940
nah, 99 has an oil cooler
 Old 12-18-2010, 08:22 PM   #59
s!lv!a's Avatar
^^ does it really? or is it just that little lower line?
 Old 12-23-2010, 09:58 AM   #60
phillyb's Avatar
Groans: 1,940
 Old 12-23-2010, 10:10 AM   #61
deuce_WI's Avatar
Posts: 234   (View Stats)
deuce_WI has a reputation beyond reputedeuce_WI has a reputation beyond reputedeuce_WI has a reputation beyond reputedeuce_WI has a reputation beyond reputedeuce_WI has a reputation beyond reputedeuce_WI has a reputation beyond reputedeuce_WI has a reputation beyond reputedeuce_WI has a reputation beyond reputedeuce_WI has a reputation beyond reputedeuce_WI has a reputation beyond reputedeuce_WI has a reputation beyond repute
Groaned at 6 Times in 2 Posts
Looks better than Maaco
deuce_WI is offline   Reply With Quote
The Following User Says Thank You to deuce_WI For This Useful Post:
phillyb (12-23-2010)
spray bar Tcman2006 MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 4 08-28-2009 07:15 AM
Will adding meth/water spray give me any power gain? Sloane MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 4 11-30-2008 03:13 PM
GM stops using hot-spray windshield system Haltech Automotive News 0 10-07-2008 01:10 PM
GM adds 12-month/12,000-mile bumper-to-bumper warranty on certified used vehicles Haltech Automotive News 0 08-19-2008 05:50 PM
Page generated in 0.37425 seconds with 29 queries
