Miata MX-5
> Miata - Wheels, Tires & Appearance
 Old 11-11-2011, 03:59 PM   #1
Neverlift's Avatar
Posts: 4,699   (View Stats)
Groans: 1,143
Default Yokohama S Drive review
This is an initial review based upon some spirited driving for 20 miles with 1 hairpin in each of the 6 runs. Most of the drive consisted of lane change like switch-backs, medium like sweepers, and one 3rd gear 25mph suggested (70mph actual) quick right hander and then left hand sweeper which if you set up right, you should transfer back smoothly and rotate nicely through. Air pressure is unknown at this time but it probably started @ 35psi. I let some air out of the front after the first run to counter act the understeer my shitty alignment induces.
After doing so I noticed the rear was much more tail happy and had a strong snap over when bringing it back. I was throwing the car pretty hard to setup into each corner in an effort to test the progression of grip threw the corner. In most cases traction would begin to be lost but at a very progressive rate and a slight squeal. This is much quieter then the 195/50 Ecsta AST I was running before but short of the howl the 195/50 Falker 502's have. Corners purposely drifted were done so with much more ease then any tire I have ever used. I was very confident with it, and never surprised so I never had to lift or let off.
I noticed my R-package Bilsteins contributing to some of the handling issues probably from being under damped for this tire. However, after I have some actual time on them I will be able to better assess that hypothesis as I usually have trouble with new tires considering they carry their own characteristics. These runs reached speeds of 85+ mph while cornering. This could have also been a bit over ambitious for a new tire and the shocks damping.
They are wide for a 195/50. I would say they may even exceed contact patch for some companies 205/50s
tl;dr
Tires have controllable progression beyond the edge. They regain grip unexpectedly at their current psi at high speed (possible damping issue). Further testing including wet traction and extensive dry traction will be conducted over the holiday weekend.
Past Mazdas & Speeds
The Following 2 Users Say Thank You to Neverlift For This Useful Post:
nobrakez (11-11-2011), WAHBAM (11-11-2011)
 Old 11-11-2011, 04:02 PM   #2
WAHBAM's Avatar
Posts: 283   (View Stats)
WAHBAM is the leader of the worldWAHBAM is the leader of the worldWAHBAM is the leader of the worldWAHBAM is the leader of the worldWAHBAM is the leader of the worldWAHBAM is the leader of the worldWAHBAM is the leader of the worldWAHBAM is the leader of the worldWAHBAM is the leader of the worldWAHBAM is the leader of the worldWAHBAM is the leader of the world
Groans: 47
Groaned at 21 Times in 9 Posts
I am also running these tires. They are lasting longer than the stock dunlop that came with it.
2010 Black Mica Mazdaspeed3
MODS in chronological order of installtion
AEM CAI, JBR SSP Stage 2, JBR Heavy Shift Knob, JBR 80 Duro Billet Rear Motor Mount, CP-E NVISCID Turbo Inlet Pipe. & COBB AP
Debating on Rear Sway Bars, Springs, or internals next...
WAHBAM is offline   Reply With Quote
 Old 11-11-2011, 04:39 PM   #3
nobrakez's Avatar
Posts: 251   (View Stats)
nobrakez is the leader of the worldnobrakez is the leader of the worldnobrakez is the leader of the worldnobrakez is the leader of the worldnobrakez is the leader of the worldnobrakez is the leader of the worldnobrakez is the leader of the worldnobrakez is the leader of the worldnobrakez is the leader of the worldnobrakez is the leader of the worldnobrakez is the leader of the world
I have been running these on my z for about a year. One of the best street tires Ive run on that car. Although I am limited on selection by the 205/55/15 requirement so I am not sure how they would hold up against some of the more aggressive tires. I'm looking forward to your report on wet traction(the z doesnt go out in the rain)...
nobrakez is offline   Reply With Quote
 Old 11-11-2011, 04:58 PM   #4
InFeXIoN's Avatar
Posts: 1,159   (View Stats)
InFeXIoN is the leader of the worldInFeXIoN is the leader of the worldInFeXIoN is the leader of the worldInFeXIoN is the leader of the worldInFeXIoN is the leader of the worldInFeXIoN is the leader of the worldInFeXIoN is the leader of the worldInFeXIoN is the leader of the worldInFeXIoN is the leader of the worldInFeXIoN is the leader of the worldInFeXIoN is the leader of the world
Groaned at 42 Times in 15 Posts
I ran these on my msm also at the 3 sisters... I was impressed
Sent from my HTC Vision using Tapatalk
GTX3071R EWG, DNP Tubular Manifold, SSP Ported/VTCS deleted intake manifold, DCR VVT Actuator, CP-E FMIC, Cobb AP, JBR 3.5" WP Intake ||| JBR 80 Duro RMM, JBR 80 Duro PSMM ||| CNT Racing Catless full 3" DP/TP, Speed Daddy 3" CBE ||| AEM Water/Methanol Kit, Autotech FP Internals, PTP Inj Seals, Synapse Engineering Bypass Valve, Matt Jackson map sensor harness, 3 Bar map sensor, Grimmspeed 3-port EBCS, NGK 1 Step Colder Plugs ||| Sure AGS 621G, Sure Shortcut, JBR Solid Base Bushings and Weight ||| AMR Engineering Coilovers, JBR Rear Sway, JBR Rear Camber Arms, XXR 527 18x8.75 +35 Chromium Black ||| CP-E Tow Plate, Rotella T6, FoMoCo XT-M5-QS, JBR OCC, JBR EGR Delete, JBR TB Gasket, JBR TIG and Coolant Bypass, EBC Redstuff.
Build Complete!!!!
InFeXIoN is offline   Reply With Quote
 Old 11-12-2011, 02:10 AM   #5
ChidoriSpeed's Avatar
Posts: 47   (View Stats)
ChidoriSpeed will become famous soon enoughChidoriSpeed will become famous soon enough
I'm running these tires too a little to much road noise for my taste.
ChidoriSpeed is offline   Reply With Quote
 Old 11-12-2011, 05:25 PM   #6
Neverlift's Avatar
Groans: 1,143
So I took the car out last night since it was raining pretty good. Didn't get to hit up the canyons like I wanted but I got extensive business park, highway on ramp and round-about testing in.
I had no problem cruising 80+ comfortably and never hydroplaned or felt unsure of how they were going to react. If I did induce a loss of traction on purpose it could be regained immediately and without much trouble.
They are still new so I would be interested to see how they react in the last 30-40% of their lifespan in the wet.
I am really loving these in the dry though.
InFeXIoN (11-14-2011)
 Old 11-13-2011, 03:58 PM   #7
Neverlift's Avatar
Groans: 1,143
Alright, I put some serious testing on them and I can say they are an incredible tire. I didn't want to stop. I put about 250 canyon miles on them for about 7 hours. Initial bite is quick and crisp and the progression when heading toward a loss in traction is very communitive and not at all surprising. I see no reason to ever switch. I would have no trouble running these on a track day.
However, they are tire pressure sensitive. I played with a few different ones and found 34-35 hot is best. They do get greasy but once again you know it and they cool quickly. Only had to let off for a minute or so and it was good to go.
This is a quick run to show you how they act on the road.
WAHBAM (11-13-2011)
 Old 11-13-2011, 10:52 PM   #8
bigx5murf's Avatar
Posts: 235   (View Stats)
bigx5murf has a reputation beyond reputebigx5murf has a reputation beyond reputebigx5murf has a reputation beyond reputebigx5murf has a reputation beyond reputebigx5murf has a reputation beyond reputebigx5murf has a reputation beyond reputebigx5murf has a reputation beyond reputebigx5murf has a reputation beyond reputebigx5murf has a reputation beyond reputebigx5murf has a reputation beyond reputebigx5murf has a reputation beyond repute
Groaned at 20 Times in 10 Posts
My friend is running these on his wrx, it's quite easy to 4 wheel spin in the rain with them. I'd consider them more a warm dry weather tire.
bigx5murf is offline   Reply With Quote
 Old 11-13-2011, 11:16 PM   #9
How do these compare to the RS3s you tried on your MSM?
 Old 11-14-2011, 01:03 AM   #10
Neverlift's Avatar
Groans: 1,143
Nothing compares to RS3s. These are a 300 treadwear tire. It would be foolish for me to draw a comparison.
InFeXIoN (11-14-2011), kilik2 (12-03-2011)
 Old 11-14-2011, 02:35 PM   #11
The Runner
M4Nathan's Avatar
Posts: 229   (View Stats)
M4Nathan has a brilliant futureM4Nathan has a brilliant futureM4Nathan has a brilliant futureM4Nathan has a brilliant futureM4Nathan has a brilliant futureM4Nathan has a brilliant futureM4Nathan has a brilliant futureM4Nathan has a brilliant futureM4Nathan has a brilliant futureM4Nathan has a brilliant futureM4Nathan has a brilliant future
Hey Bob where was that video taken? Cause i live right next to irvine (tustin) and id love to take my ms3 out there.
'09 Black Mica [MURDERED] MS3- HyperTech Tuned, CPE rear and side motor mounts, COBB TIP, JBarone Short Shifter Plate and Heavy Shift knob, SU Shifter Bushings, CPE Nano SRI, AWR End Links.
WANTED- Radar Detector, Down Pipe, DashHawk, Forge BPV.
M4Nathan is offline   Reply With Quote
 Old 11-14-2011, 02:59 PM   #12
I <3 your mom
Dash08's Avatar
Posts: 7,166   (View Stats)
Groans: 293
I contemplated getting these when I was in the market, but after several credible reviews, I decided on the Hankooks.
This is still interesting to me for future reference. I'll be trying something else when the V12's kick the bucket.
Bob, how's the sidewall? Is it rigid enough to offer sharp steering response and turn in?
I lost a small amount of response and slightly less precision on turn in with the V12's. They definitely have more grip than the Potenzas, but are a little mushy on the sidewall.
this forum serves 2 purposes
 Old 11-14-2011, 03:11 PM   #13
Neverlift's Avatar
Groans: 1,143
Nathan, hit me up when you want to go. Either early morning, random weekday afternoons and late at night is when you can actually drive the road. Otherwise you have other motorists, jogger, long boarders, motorcyclists and deer to deal with.
Tony, the sidewall is softer then the shitty tires I have been running. I would describe the turn in quick like an RS3 (has a soft sidewall) but doesn't hold the road like them.
I need to get a video of me driving so you see how I use the steering wheel in the corners.
Dash08 (11-14-2011)
 Old 11-14-2011, 03:23 PM   #14
I <3 your mom
Dash08's Avatar
Groans: 293
In for this. I'd like to see how the car responds to your inputs. Could give a good idea of how they perform.
 Old 11-14-2011, 03:29 PM   #15
Neverlift's Avatar
Groans: 1,143
Cool. I have one now from the same day but you can only see one hand but you may get the idea of the response. Ill host it now
 Old 11-14-2011, 04:36 PM   #16
Neverlift's Avatar
Groans: 1,143
Bad angle, I know. That is why I didnt post it originally.
Dash08 (11-15-2011)
 Old 11-14-2011, 11:03 PM   #17
InFeXIoN's Avatar
Yes these in no shape can compare to some RS-3's.. but for the dry performance and decent in wet, especially for the price.. they are really hard to beat. As bob said the RS-3's treadwear compared to these are no match but the RS-3's stick like glue! I was overall impressed with them myself when i took them out to the 3 sisters for a 7 hour run, and ran them pretty hard.
Build Complete!!!!
 Old 11-21-2011, 06:42 PM   #18
The Runner
M4Nathan's Avatar
Yeah I go to UCLA so I'm not in tustin currently but maybe over the break.
 Old 11-30-2011, 01:52 PM   #19
WAHBAM's Avatar
Groans: 47
I finally used up my s drives. They are so bald that they are leaking out air from a crack on near 1/3 of the thread.
I'm trying out the Hankooks V12s now. So far I loved that tire, but the fact that they discontinued them I have to jump ship.
On the stock dunlops I had I ruined the inner sidewalls, but with the s drives they showed no wear on the inner sidewalls.
 Old 11-30-2011, 02:01 PM   #20
dizzydtrain's Avatar
Posts: 2,476   (View Stats)
Groans: 64
I had s-drives on my civic si back in the day, great tire for spirited driving. They also look great mounted.
dizzydtrain is offline   Reply With Quote
 Old 11-30-2011, 04:20 PM   #21
Nliiitend1's Avatar
Posts: 5,749   (View Stats)
tl;dr
*through* & *than*
Sorry, I just couldn't resist.
Stance is not a verb.
2008 MS3 GT
2016 MX-5 Club
Last edited by Nliiitend1; 12-01-2011 at 03:12 AM. Reason: missed the second one the first time... lol.
The Following 3 Users Say Thank You to Nliiitend1 For This Useful Post:
Dash08 (11-30-2011), Neverlift (11-30-2011), WAHBAM (11-30-2011)
 Old 11-30-2011, 05:54 PM   #22
I <3 your mom
Dash08's Avatar
Groans: 293
*through*
Win.
The Following User Says Thank You to Dash08 For This Useful Post:
M4Nathan (12-06-2011)
Review: Test Drive Unlimited 2 Haltech Automotive News 0 02-11-2011 01:30 PM
Yokohama AVID ENVigors sideslide4life Wheels & Tires - BLACK 8 12-12-2010 05:39 PM
Yokohama Avid Envigor Tires Jujiro_Prodigy_31 MazdaSpeed 3/6 - Wheels & Tires 2 03-15-2010 03:35 PM
Yokohama peels out with orange tire Haltech Automotive News 0 12-08-2009 10:20 AM
Review: 2009 Mazda MX-5 Miata is still the drive of our childhood dreams Haltech Automotive News 0 10-02-2009 10:10 AM
Page generated in 0.43981 seconds with 30 queries
