> Mazdaspeed Forums Performance Parts Reviews > Review Discussion
Review Discussion Want to comment on a review, do it here.
 Old 01-31-2009, 08:53 AM   #1
Originally Posted by DaleNixon View Post
Ok I'm curious as to what this does to the sound. Does it mute the WHOOOOOSH sound of the intake and the Forge BPV "Mario Coin"?
So does not change from what you are already hearing. If you want to mute your forge, get a HKS.
 Old 01-31-2009, 09:00 AM   #2
DaleNixon's Avatar
Posts: 2,079   (View Stats)
DaleNixon is the leader of the worldDaleNixon is the leader of the worldDaleNixon is the leader of the worldDaleNixon is the leader of the worldDaleNixon is the leader of the worldDaleNixon is the leader of the worldDaleNixon is the leader of the worldDaleNixon is the leader of the worldDaleNixon is the leader of the worldDaleNixon is the leader of the worldDaleNixon is the leader of the world
Groans: 91
Actually I'm afraid of fucking with my current sound. I love the way it sounds! I don't want to reduce it in any way.
Gay car #1: 2001 Miata (Gay White)
Gay car #2: 2011 Mazda 2 (Gay Blue)
DaleNixon is offline   Reply With Quote
 Old 02-01-2009, 08:05 PM   #3
ptperformance's Avatar
Posts: 4,123   (View Stats)
What size is it? 2.5" 3.0" bigger smaller in between? Great price if it hooks up to a bigger turbo.
 Old 02-01-2009, 11:28 PM   #4
Necks down to stock size, so i think that is 2 or 2 1/4 inch. You will need a different inlet for a ATP setup or anything larger then stock.
 Old 02-02-2009, 11:21 PM   #5
mazdaspeed619sd's Avatar
Posts: 170   (View Stats)
mazdaspeed619sd has much to be proud ofmazdaspeed619sd has much to be proud ofmazdaspeed619sd has much to be proud ofmazdaspeed619sd has much to be proud ofmazdaspeed619sd has much to be proud ofmazdaspeed619sd has much to be proud ofmazdaspeed619sd has much to be proud ofmazdaspeed619sd has much to be proud ofmazdaspeed619sd has much to be proud of
does the inlet pipe work with the SPEED6? Or only CPE inlet works with speeds?
06 MS6 Black Mica
AWD BROTHERS SHALL UNITE!
Boys love straight lines.— Men love curves.— =)— Canyon/Circuit FTW!—
mazdaspeed619sd is offline   Reply With Quote
 Old 02-03-2009, 02:00 AM   #6
Speedie6's Avatar
Posts: 1,838   (View Stats)
The MS3, MS6 and CX-7 all have the same stock part. It'll fit. I don't know why Cobb hasn't yet listed the part officially for the MS6, maybe wanting to do some testing first.
 Old 02-03-2009, 05:14 PM   #7
08cosmic3's Avatar
Posts: 2,920   (View Stats)
Default Installed Cobb Turbo Inlet.
It was harder to install than I thought it would be. There is not a lot of room to work with even after removing everything. Removing the clamp on the turbo was not easy because the oreintataion of the clamp made it hard to get to. Like others, my stock inlet was loose but I did loosen it some more before removing. When I reinstalled the clamp I changed the oreintation so It could be reached from directly above but even then I had to hook three extentions together to reach it from above. I'm not a mechanic, so If I can do it you can too.
The car seems to get into boost faster now, my exhaust tone seems to have changed, not sure if thats possible though, might be my imagination. The sucking sound seems less now and letting off under high boost gets me a chirp, sounds like a squirrel bark. I hope that is not the sound of surge but the sound of the pressure going back into the intake. Can't tell if there is any HP gains but if the boost comes in sooner then there will be a performance gain, but not be detected by dyno #'s.
There is no fastener for the Inlet but I was thinking about fabricating one with a clamp somehow, but it may be best to leave it unfastened so it can flex with engine movement.
Is anyone else getting a chirp under heavy boost and release?
The Following 2 Users Say Thank You to 08cosmic3 For This Useful Post:
steven88 (02-09-2009), Zeya (06-04-2009)
 Old 02-03-2009, 07:23 PM   #8
DaleNixon's Avatar
Groans: 91
Can anyone else with the Cobb inlet comment on the "squirrel bark" sound?
 Old 02-09-2009, 12:20 AM   #9
steven88's Avatar
Posts: 773   (View Stats)
Groaned at 9 Times in 5 Posts
I have the cp-e turbo inlet which is similar to the cobb (silicone made)....and my BOV has gotten quieter...the sucking noise at WOT sounds a TAD louder than stock...but overall, the sound has gotten less than the stock inlet...kind of weird huh? who would have thought the plastic POS stock inlet can make so much noise
steven88 is offline   Reply With Quote
 Old 02-09-2009, 06:33 AM   #10
DaleNixon's Avatar
Groans: 91
Everything seems louder with the Cobb Inlet for me, but I think it fixed a leak issue I was having with the stocker. The stocker was very tight on the turbo, however.
 Old 02-09-2009, 07:44 AM   #11
SharkDiver's Avatar
Posts: 969   (View Stats)
SharkDiver is the leader of the worldSharkDiver is the leader of the worldSharkDiver is the leader of the worldSharkDiver is the leader of the worldSharkDiver is the leader of the worldSharkDiver is the leader of the worldSharkDiver is the leader of the worldSharkDiver is the leader of the worldSharkDiver is the leader of the worldSharkDiver is the leader of the worldSharkDiver is the leader of the world
I just installed mine yesterday..Everything seems much louder to me.The BPV and hearing the turbo spool seems alot louder then before.It was so loud I thought something may have come loose but everything is very tight and connected.I like the new sound and the down low power seems to be a bit better but then again I put in my new CDFP at the same time so I dont really know what part is adding more hp.
Pauter rods,Cp pistons 9.5:1 @ .020 over,ARP head & main studs,DNP ceramic coated exhaust mani.,TXS Dp,TXS Tp with high flow cat,PG reworked turbo,Cobb sri,Cobb fmic,Cobb Ap,Cobb inlet,HPFP,BSD,ACT street disk with light flywheel,TWM shifter bushing,rear MM,Oil CC and 1 step colder plugs and more
http://videos.streetfire.net/profile/SharkDiver.htm
http://www.youtube.com/user/sharkdiverjohn
SharkDiver is offline   Reply With Quote
 Old 02-09-2009, 07:46 AM   #12
DaleNixon's Avatar
Groans: 91
Oh I just drove mine to work this morning, and I can definitely feel the improvement. Boost comes on much faster and smoother than before. Power is more predictable between shifts. I'm sure my gas mileage will suffer slightly with the turbo spooling sooner, but you gotta pay to play.
Thanks to Haltech for the awesome review/writeup. It convinced me to get this piece, and his step-by-step was a nice supplement to Cobb's oversimplified install guide.
The Following User Says Thank You to DaleNixon For This Useful Post:
Haltech (02-09-2009)
 Old 02-09-2009, 06:39 AM   #13
bova's Avatar
Posts: 3,820   (View Stats)
Groans: 45
seems quieter to me. silicone doesn't reverberate quite as much as plastic.
 Old 02-09-2009, 08:43 AM   #14
BreakTheStatic's Avatar
Posts: 280   (View Stats)
BreakTheStatic has a brilliant futureBreakTheStatic has a brilliant futureBreakTheStatic has a brilliant futureBreakTheStatic has a brilliant futureBreakTheStatic has a brilliant futureBreakTheStatic has a brilliant futureBreakTheStatic has a brilliant futureBreakTheStatic has a brilliant futureBreakTheStatic has a brilliant futureBreakTheStatic has a brilliant futureBreakTheStatic has a brilliant future
I installed mine yesterday as well, and definitely notice the difference. I wouldn't say power is up much, but delivery seems somewhat smoother and I can hear the turbo a bit more. Also, contrary to what other ppl have said about the BPV, my forge seems louder than before, but the *ting* sounds a bit more like a whoosh than ninjas fighting now. The main difference, however, is spool time. My car gets into boost crazy fast now. Between the exhaust mani and the inlet, I can fully spool up with a tap of the throttle pretty much. I consider that a good thing, although I'm finding it a bit harder to stay out of boost when I'm trying to conserve gas.
BreakTheStatic is offline   Reply With Quote
 Old 02-11-2009, 12:50 PM   #15
Speedy3's Avatar
Posts: 298   (View Stats)
Speedy3 is the leader of the worldSpeedy3 is the leader of the worldSpeedy3 is the leader of the worldSpeedy3 is the leader of the worldSpeedy3 is the leader of the worldSpeedy3 is the leader of the worldSpeedy3 is the leader of the worldSpeedy3 is the leader of the worldSpeedy3 is the leader of the worldSpeedy3 is the leader of the worldSpeedy3 is the leader of the world
Sure is nice to get a review on a product when the manufacturer sends it to you for free....
2007 MAZDASPEED 3, MS CAI, MS CBE.
Speedy3 is offline   Reply With Quote
 Old 02-11-2009, 01:21 PM   #16
bova's Avatar
Groans: 45
what was the point of this?
 Old 02-12-2009, 05:11 AM   #17
Speedy3's Avatar
RPMC sent him a free inlet to review June of last year. Guess he lost the data on a computer malfunction. Since then, the review never showed up and the inlet disappeared.
 Old 02-12-2009, 09:06 AM   #18
skeeter149's Avatar
Posts: 3,742   (View Stats)
Groans: 91
that sucks is this true?
 Old 03-01-2009, 03:13 PM   #19
Speedy3's Avatar
I want to say that It was inappropriate for me to post my previuos post because Haltec was not at fault. In all intents and purposes, he made an effort to do the review, but just couldn't recover the data. Also, as for the whereabouts of the inlet, I will leave that explaination to him. I made the assumption it was gone.
 Old 05-09-2011, 11:01 AM   #20
sick_role's Avatar
Posts: 815   (View Stats)
sick_role is the leader of the worldsick_role is the leader of the worldsick_role is the leader of the worldsick_role is the leader of the worldsick_role is the leader of the worldsick_role is the leader of the worldsick_role is the leader of the worldsick_role is the leader of the worldsick_role is the leader of the worldsick_role is the leader of the worldsick_role is the leader of the world
Groaned at 6 Times in 3 Posts
FWIW, you'll need at least 13" of extention if you are trying to tighten the inlet/turbo clamp from above (after switching orientation of the clamp, as cosmic stated). I used this method and it was way easier, I would think, than trying to fuck around with my hands wedged down there by the firewall. it was a bitch of a time trying to get in there to get stocker off and it was already loose.
But yeah, I used a 10" & a 3" ext and my ratchet head was right at the cowl weatherstipping. Another inch or two might be a bit more comfortable..
Other than that, a good write up (that I found after I did mine (used Cobb's)). Definitely should've put the clamps on the inlet side of dbl clamped sections prior to putting back in engine bay.
"Also you cannot do anything "like a boss" in a srt4. If you ever get a job where the boss drives a neon, go somewhere else. Apparently that job has no future." - themytb
Oh you mean dogs. Yeah I like dogs. I drive a Hyundai.
sick_role is offline   Reply With Quote
 Old 05-09-2011, 06:12 PM   #21
m4tic's Avatar
Posts: 4,928   (View Stats)
did you guys know theres a turbo mazda hatchback?
2017 Daytona 392
STOLEN//2015 BMW S1000R
2007 MS6 w/ Cheez
 Old 06-03-2011, 06:16 AM   #22
2zz mr-s
dooderek's Avatar
Posts: 5,119   (View Stats)
Groans: 239
03-01-2009, 02:13 PM
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f341/cobb-tuning-inlet-review-discussion-20295/
Day of 2/1/2009: Top 50 of 224 Referring Pages This thread Refback 02-02-2009 08:45 AM
Cobb Tuning Catback Exhaust Review Haltech Review Discussion 13 05-07-2010 12:16 AM
COBB Tuning Turbo Inlet Hose SALE! kevin@gripgarage.com Mazdaspeed3/6 General Discussion 13 06-17-2009 02:51 PM
Cobb Tuning Mazdaspeed 3 Turbo Inlet Haltech Mazdaspeed Forums Performance Parts Reviews 0 01-30-2009 02:14 AM
Cobb Tuning 3" 07-08 MazdaSpeed3 Street Downpipe Review Haltech Mazdaspeed Forums Performance Parts Reviews 0 12-01-2008 03:08 AM
Cobb AP Dyno Graph/Discussion NYpest MazdaSpeed 3/6 - ECU Computer Tuning 212 05-13-2008 02:13 PM
Page generated in 0.44134 seconds with 34 queries
