> MazdaSpeed 3/6 - Appearance > Appearance - Exterior > Appearance - RED
Appearance - RED All appearance mods for RED cars
 Old 04-28-2012, 11:26 AM   #1
SwineFLU's Avatar
Posts: 180   (View Stats)
SwineFLU is the leader of the worldSwineFLU is the leader of the worldSwineFLU is the leader of the worldSwineFLU is the leader of the worldSwineFLU is the leader of the worldSwineFLU is the leader of the worldSwineFLU is the leader of the worldSwineFLU is the leader of the worldSwineFLU is the leader of the worldSwineFLU is the leader of the worldSwineFLU is the leader of the world
Default YAY OR NAY - Tail light tint
Well I didnt like the look of the chrome in my tail lights so I tinted them... i didnt want to go too dark but this is the end result... the car needs to be cleaned as well..
2007 MS6, COBB AP, SU RMM, TT DIF MOUNT, COBB SRI/TIP, AUTOTECH
To be installed: CX racing FMIC, CS DP, TWM shifter, Oil catch can
SwineFLU is offline   Reply With Quote
 Old 04-28-2012, 11:30 AM   #2
DickFitzwell's Avatar
Posts: 996   (View Stats)
DickFitzwell is the leader of the worldDickFitzwell is the leader of the worldDickFitzwell is the leader of the worldDickFitzwell is the leader of the worldDickFitzwell is the leader of the worldDickFitzwell is the leader of the worldDickFitzwell is the leader of the worldDickFitzwell is the leader of the worldDickFitzwell is the leader of the worldDickFitzwell is the leader of the worldDickFitzwell is the leader of the world
i can dig it man. looks perfect from behind, but a little dark from the side shots... what tint did you use and %? been thinking of doing this on my MS3
09 CWP MS3: COBB AP / MSD DH / AT HPFP / CPE SRI / CS TIP / CS BT-RH / M2 DP / CNT CBE / HKS BPV / EVO X / E85 PERMFREEKTUNE 330/380
07 TGM MS6: COBB AP / JBR PP SRI/TIP/ JBR BT-RH / CS CBE / FORGE V1 / JBR RMM / H&R CO Stratified OTS
07 BM MS6: DREADNAUGHT / JUGGERNAUT / SU DMM*PMM*TMM / JBR RMM / BC CO / MAGNAFLOW CBE / JBR OCC / SURE BSD / PRODRIVE GC06-H
Long Signature made especially for Micha
DickFitzwell is offline   Reply With Quote
 Old 04-28-2012, 11:36 AM   #3
tbcota25's Avatar
Posts: 1,542   (View Stats)
tbcota25 is the leader of the worldtbcota25 is the leader of the worldtbcota25 is the leader of the worldtbcota25 is the leader of the worldtbcota25 is the leader of the worldtbcota25 is the leader of the worldtbcota25 is the leader of the worldtbcota25 is the leader of the worldtbcota25 is the leader of the worldtbcota25 is the leader of the worldtbcota25 is the leader of the world
Looks good man... I'm about to do mine once the temp here in NY warms up
2012 Black Mica
Mods
CS catless DP, CS RP
Magnaflow CBE
Autotech HPFP
NGK Plugs
CS RMM
JBR PMM
CS Short Shit Kit and Shifter Bushings
Cobb SRI and TIP
CS TMIC
SU Boost Tubes
JBR Reticulation Tube
Cobb AP v2
H&R springs
JBR Rear Sway Bar
Self Built 3 Port EBCS
maisonvi Shift Knob
Tuned on 93 and corn
tbcota25 is offline   Reply With Quote
 Old 04-28-2012, 11:50 AM   #4
are you guys taking them having them tinted or just using a self tint spray or laminex stuff
 Old 04-28-2012, 11:58 AM   #5
SwineFLU's Avatar
I did the spray shit I bought from Canadian tire in Canada... I think its called VHT night shade... 13 bucks a can.. i put on 2 coats... 4 is the max... 1 coat of clear at the end.. a quick sand and then polish.
The cops around here can be idiots so i didnt want to go too dark... im actually happy with the way it turned out.
ohh and the pics were taken with my phone so it looks better in real... the side shot does look darker.
 Old 04-28-2012, 12:07 PM   #6
tbcota25's Avatar
I think im gonna do the stick on shit lol... But hey you Should have put way more then 1 coat of clear coat on...
2012 Black Mica
Mods
Magnaflow CBE
Autotech HPFP
NGK Plugs
CS RMM
JBR PMM
Cobb SRI and TIP
CS TMIC
SU Boost Tubes
Cobb AP v2
H&R springs
JBR Rear Sway Bar
maisonvi Shift Knob
 Old 04-28-2012, 12:10 PM   #7
lilred's Avatar
Posts: 5,792   (View Stats)
i like it, I'm undecided on going with black or red since i dislike the clear of the pu
2010 velocity red mica ms3
AP/AT internals
JBR SSP/bushings
JBR RMM
JBR stage 2 OCC
CS test pipe
 Old 04-28-2012, 12:19 PM   #8
Resident Baus
duappleganger's Avatar
Posts: 504   (View Stats)
duappleganger is the leader of the worldduappleganger is the leader of the worldduappleganger is the leader of the worldduappleganger is the leader of the worldduappleganger is the leader of the worldduappleganger is the leader of the worldduappleganger is the leader of the worldduappleganger is the leader of the worldduappleganger is the leader of the worldduappleganger is the leader of the worldduappleganger is the leader of the world
Groans: 34
Groaned at 56 Times in 18 Posts
it's not bad, would've been great just a little less dark. looks like a good job though
2011 Black Mica MS3
FREEKTUNE (On hold 'til EWG) ATP GTX3071R IWG (soon to be EWG) Full Race exhaust manifold CP-e whale peen + 3.25 in. intake
COBB EBCS + Downpipe + BPV + AP Stage 2 Corksport CBE + Brake Pads Ultimate FMIC NGK Iridium IX @ .28 DDM HID 6000k
Autotech CDFP Internals JBarone EGR delete, TB + IM gaskets, SSP + Shift Anchors, 88D RMM, 70D passenger + tranny mount, RSB, and OCC
HTP battery box TSW Nurburgrings 18x8.5 MBR w/ Michelin Pilot Super Sports 235x40x18 +45 Goodridge SS Brake Lines
Installation TBD: H&R springs + Koni yellow shocks + struts
duappleganger is offline   Reply With Quote
 Old 04-28-2012, 12:26 PM   #9
Keko's Avatar
Posts: 1,455   (View Stats)
Groans: 107
Groaned at 9 Times in 9 Posts
You should black out the emblems. If you use plasti-dip you can take it off if you don't like it.
2012 MS3
Stratified 91
 Old 04-28-2012, 12:41 PM   #10
gotspeed's Avatar
Posts: 146   (View Stats)
gotspeed is the leader of the worldgotspeed is the leader of the worldgotspeed is the leader of the worldgotspeed is the leader of the worldgotspeed is the leader of the worldgotspeed is the leader of the worldgotspeed is the leader of the worldgotspeed is the leader of the worldgotspeed is the leader of the worldgotspeed is the leader of the worldgotspeed is the leader of the world
real nice.
works well with the black rims.
i agree with the black emblems... would make it all look uniform.
gotspeed is offline   Reply With Quote
 Old 04-28-2012, 12:45 PM   #11
SwineFLU's Avatar
I will try it out... plasti dip is hard to find around here... id have to order it from TO and pay shipping... i paid 27 dollars a can last time but they dont stock it anymore because of the chemicals in it.
 Old 04-28-2012, 12:48 PM   #12
cabrone's Avatar
Posts: 529   (View Stats)
cabrone is the leader of the worldcabrone is the leader of the worldcabrone is the leader of the worldcabrone is the leader of the worldcabrone is the leader of the worldcabrone is the leader of the worldcabrone is the leader of the worldcabrone is the leader of the worldcabrone is the leader of the worldcabrone is the leader of the worldcabrone is the leader of the world
Plasti dip is releasing a smoke spray, designed to be a removable tail light (as well as anything, really) tint solution
Tapped
08.5 CWP MS3 GT
AP Stage 2 S-OTS+ | Cobb Catted DP | Magnaflow CBE | JBR SRI | Cobb TIP | JBR 70 Duro RMM |NGK Iridiums | Autotech Internals | Lamin-X Yellow Fog Overlays
cabrone is offline   Reply With Quote
The Following User Says Thank You to cabrone For This Useful Post:
DiGi Faggot (05-03-2012)
 Old 05-03-2012, 06:06 AM   #13
DiGi Faggot's Avatar
Posts: 1,212   (View Stats)
Groans: 148
Tapped
Already is out: Plasti Dip Smoke | Plasti Dip Interntional
Plasti Dip Smoke Blackout Smoked Tail light Tint Taillight Tinting Spray Paint 075815112200 | eBay
 Old 09-17-2012, 10:06 AM   #14
a.cluff's Avatar
Posts: 15   (View Stats)
a.cluff is a jewel in the rougha.cluff is a jewel in the rougha.cluff is a jewel in the rough
Looks great! I was undecided on this but you just sold me on it.
2007 Mazdaspeed 6 Velocity Red Mica - Bone ass stock.
a.cluff is offline   Reply With Quote
Need Tail light Fartee Mazdaspeed3/6 General Discussion 7 02-09-2012 11:21 AM
Need new rear tail light JeffTheMan Mazdaspeed3/6 General Discussion 0 12-24-2011 05:03 PM
CAR LED Tail Light MS6 Poohster MazdaSpeed 3/6 - Appearance 9 06-22-2011 11:47 AM
Tail light question. feldm4n Mazdaspeed3/6 General Discussion 9 12-20-2009 03:05 PM
Page generated in 0.33559 seconds with 29 queries
