> MazdaSpeed 3/6 - Appearance > Appearance - Exterior > Appearance - COSMIC BLUE
Appearance - COSMIC BLUE All appearance mods for cosmic blue cars
 Old 03-15-2014, 04:15 PM   #1
Dave978's Avatar
Posts: 4   (View Stats)
Dave978 is an unknown quantity at this point
Default Cold weather p2096 turned into p0138
Had this problem with 2096 code for about 2 year but only in the winter .. Finally fixed ( I think ) .. Changed rear o2 sensor multiple time .. ( not fixed) changed hp rail valve ( not fixed ) cleaned maf ( not fixed ) car got shitty mpgs and was sluggish .. Local tuning shop heat taped the down pipe and extended wires from rear o2 sensor so we can use the secondary o2 bung before the cat provided in the cobb dp. They wanted to get the sensor warmer so yes I have both sensors next to each other before cat . Well it worked for a while until something happend with the harness they made to extend the rear o2 . Started getting p0138 high voltage input in rear sensor .. After doing some research I found out a 06 mx5 has same o2 connectors as ms3.. Located a a compony that made an extended harness for a mx 5.. Installed it today and no cel anymore .. Any one els have this problem with a cold rear o2?
Cp-e fmic cp-e hpfp cobb dp cobb bpv cobb Sri cobb tih cobb shift knob cobb AP extended rear o2 UR catback itv22 eonon dvd/nav rota grid 18 8.5 +44 hankook rs3 245/40/18 dyno tuned 18.5 psi 274whp 300wt Dailey driver
Dave978 is offline   Reply With Quote
cold weather mmv3 2010 MS3 - Engine, Transmission & Driveline 3 12-07-2009 01:33 PM
Cold weather cut wassup61 MazdaSpeed 3/6 - ECU Computer Tuning 15 02-10-2009 04:04 PM
New MS6 AP Maps w/ cold weather cut fix bova
Cobb Access Port/Maps
68 01-20-2009 08:56 AM
cold weather is pwning me now aaronc7
67 11-21-2008 01:08 PM
Page generated in 0.27060 seconds with 21 queries
