| Wheels & Tires - RED Wheels & Tires on red cars. |
![]() Join Date: Aug 2018
Rep Power: 0 ![]() ![]() ![]() ![]() Thanks: 14
(Thread Starter) | Not Ranked : 0 score I'm on Koni yellow's and H&R sports. No spacers in the front and rear is rolled and tab trimmed. No camber kits. Tires are 245/45R17 Falken 615+ Let me know what you think. |
| The Following User Says Thank You to Loophole35 For This Useful Post: | mr_mazda329 (03-28-2019) |
![]() Join Date: May 2016
Rep Power: 0 ![]() Thanks: 0
| Not Ranked : 0 score How is this setup working for you so far? I have been looking for wheels for quite a while and considering 17x9, 17x8.5 and 18x8.5. I am currently on Rx8's and would like something lighter like RPF1's but I don't want to use spacers or have rubbing issues in the back. |
(Thread Starter) | Not Ranked : 0 score Still going strong. Had the very rare rub in the right rear and ended up putting camber kits in the rear and setting to -2.6°. Love the added grip. May try out RE71R's next set of tires though, nothing wrong with the Falkens just want to try the best tire out.
__________________ 2008 True Red Mazdaspeed 3 Mod list: Cobb RMM, TIP, SRI w air box, CBE and AP3 Corksport Short throw plate w/ shifter bushings, TMIC and BPV CPE catted DP Tune done by Will at PD-Tuning (still slow need BT) 150k miles on original motor and turbo H&R sport springs w/ Koni yellows 17x9 +48 6UL with 245/45R17 Flaken Azenis |
| Not Ranked : 0 score Glad is working for you! So how much clearance you think you have on the front? I suppose it is tight since you are not using spacers? |
![]() Join Date: Jan 2009 Location: Tucson/Vegas
Rep Power: 789 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,252
Groans: 55
| Not Ranked : 0 score Nice to see someone try them out. I have about 4 sets of 6ULs for my Miatas. They look great on your car. Tungsten/Red combo works really well. You'll love the RE71Rs over the Falkens, but I would recommend the BFG Rival S 1.5s over them. You pay more, but it truly is the better tire other than wet grip. RE71Rs will heat cycle out quicker than the rivals as well.
__________________ 09 MS3 CWP BNR-S3 GFB Respons BPV, HTP 3.5in whalepenis , CXRacing/TR8L Core FMIC CorkSport CBE CNT Catless long DP, NGK Plugs, DM Trilogy, Cobb AP VEGA Tuned, CP-e HPFP CP-e Injector Seals 97 Miata Daily Driver 04' Mazdaspeed Miata Track Car Road Racing > Autocross > Spirited Driving > Sitting in Traffic > Mowing Lawns > Drag Racing |
| The Following User Says Thank You to mr_mazda329 For This Useful Post: | Loophole35 (03-28-2019) |
If I were running coil overs I would need likely a 10mm spacer.
__________________ 2008 True Red Mazdaspeed 3 Mod list: Cobb RMM, TIP, SRI w air box, CBE and AP3 Corksport Short throw plate w/ shifter bushings, TMIC and BPV CPE catted DP Tune done by Will at PD-Tuning (still slow need BT) 150k miles on original motor and turbo H&R sport springs w/ Koni yellows 17x9 +48 6UL with 245/45R17 Flaken Azenis | |
| Display Modes | |
| 17x9 trm c3 | speed3sailor | Wheels & Tires - SILVER | 7 | 10-06-2014 06:41 AM |
| 17x9 +35 | StevenW | 2010 MS3 - Wheels & Tires | 16 | 09-04-2014 06:40 AM |
| 17x9 +45 with 255/40 | TWOptSL0W | MazdaSpeed 3/6 - Wheels & Tires | 19 | 07-16-2012 02:43 AM |
