 Old 05-19-2014, 10:28 PM   #1
IMASA's Avatar
Posts: 209   (View Stats)
Default black genwin with red RPF1 17x9
Posting this here because before I did this, I was scouring the interwebs for pics of plasti dipped RPF1's in red on a black speed3 but could not find any.
4 cans of red and 3 cans of glossifier
The Following 21 Users Say Thank You to IMASA For This Useful Post:
12blkms3 (05-29-2014), Addikted To Boost (05-20-2014), ArmanRus (05-19-2014), AshFromCan (06-18-2014), bioevolve (05-20-2014), bostongeorge (05-20-2014), Coats (05-20-2014), derek13p (05-19-2014), donjohnk (06-18-2014), Downmented (05-29-2014), Dralphy (05-20-2014), EvoFire (05-20-2014), jrho (05-25-2014), KotzurRacing (05-20-2014), Kyle-609 (06-03-2014), naoandlater (05-20-2014), Pino.yako (05-20-2014), redMS308 (02-06-2015), speed3 britz (05-20-2014), sxman (06-25-2014), white'swhiteMPS (05-20-2014)
 Old 05-19-2014, 11:42 PM   #2
zooomMPS3's Avatar
Posts: 67   (View Stats)
zooomMPS3 has much to be proud ofzooomMPS3 has much to be proud ofzooomMPS3 has much to be proud ofzooomMPS3 has much to be proud ofzooomMPS3 has much to be proud ofzooomMPS3 has much to be proud ofzooomMPS3 has much to be proud ofzooomMPS3 has much to be proud of
I like it, it looks really good against the black. Awesome!
zooomMPS3 is offline   Reply With Quote
 Old 05-20-2014, 12:19 AM   #3
breakfstincluded's Avatar
Posts: 3,588   (View Stats)
i dont hate it, got a picture of your red grill trim too?
 Old 05-20-2014, 12:51 AM   #4
Coats's Avatar
Posts: 580   (View Stats)
Coats is the leader of the worldCoats is the leader of the worldCoats is the leader of the worldCoats is the leader of the worldCoats is the leader of the worldCoats is the leader of the worldCoats is the leader of the worldCoats is the leader of the worldCoats is the leader of the worldCoats is the leader of the worldCoats is the leader of the world
I always thought this combo would not look right but you sir have pulled it off. Car looks real good!!
What size wheels and tires please all I got was 17x9
2013 Dodge Ram Laramie
GONE 2009 335i xdrive coupe COBB AP V3 CPe DCI
SOLD 2009 FREEKED Mazdaspeed3 GT
Coats is offline   Reply With Quote
 Old 05-20-2014, 02:24 PM   #5
IMASA's Avatar
Bridgestone S04 245/40/17
 Old 05-29-2014, 11:03 AM   #6
EvoFire's Avatar
Posts: 389   (View Stats)
So we have the same tires lol.
I notice they aren't very good with standing water, but are great with wet roads in general
 Old 06-22-2014, 02:21 PM   #7
Z32_MS3's Avatar
Posts: 590   (View Stats)
Z32_MS3 is the leader of the worldZ32_MS3 is the leader of the worldZ32_MS3 is the leader of the worldZ32_MS3 is the leader of the worldZ32_MS3 is the leader of the worldZ32_MS3 is the leader of the worldZ32_MS3 is the leader of the worldZ32_MS3 is the leader of the worldZ32_MS3 is the leader of the worldZ32_MS3 is the leader of the worldZ32_MS3 is the leader of the world
Why not run a 45 profile? It would be .2% taller than stock instead of 3.5% smaller. Clearance maybe?
Z32_MS3 is offline   Reply With Quote
 Old 06-23-2014, 10:39 AM   #8
IMASA's Avatar
Figured it would be insurance against rubbing. I had 235/40/17's which are ~4% shorter on there from the previous owner of the wheels and it would occasional rub in the rear. I figured 0.2% taller would rub for sure.
The rear fenders have been rolled and I still get rubbing going over bumps/dips.
 Old 06-23-2014, 11:47 AM   #9
Z32_MS3's Avatar
Interesting, I had a feeling that was the reason. Thanks
 Old 05-20-2014, 04:12 AM   #10
bostongeorge's Avatar
Posts: 141   (View Stats)
bostongeorge is the leader of the worldbostongeorge is the leader of the worldbostongeorge is the leader of the worldbostongeorge is the leader of the worldbostongeorge is the leader of the worldbostongeorge is the leader of the worldbostongeorge is the leader of the worldbostongeorge is the leader of the worldbostongeorge is the leader of the worldbostongeorge is the leader of the worldbostongeorge is the leader of the world
I actually like this......and that mirror finish on the paint is killer! Well done..
"In the end, there can be only one"
FREEKTUNED // BNR S3 TURBO // COBB TBE // COBB FMIC // COBB ACCESSPORT // HTP 3.5" INTAKE // TURBOSMART DUAL PORT // AUTOTECH INTERNALS // KSPORT KONTROL PRO COILOVERS // JBR RSB // JBR RMM // MATT DAMOND PMM/TMM // MATT DAMOND OCC // NGK PLUGS // MAISONVI RED SHIFT KNOB // TSW Valencia 18x8 et40 // BfGoodrich Sport Comp-2 225/45/18
2008 Black Mica MS3
bostongeorge is offline   Reply With Quote
 Old 05-20-2014, 06:54 AM   #11
speed3 britz's Avatar
Posts: 1,155   (View Stats)
Very nice, looks good! Now please change your avatar pic, I hate the default ginger pic
 Old 05-20-2014, 06:56 AM   #12
MSF's Punishing Member
Pu Manchu's Avatar
Posts: 2,992   (View Stats)
Groans: 546
Neutral  -1 score
yea i am sick of seeing that faggot everywhere.
 Old 05-20-2014, 03:30 PM   #13
Addikted To Boost's Avatar
Posts: 1,837   (View Stats)
nice, i just bought some in gold but theyre 17x8, with 235s
09 MGM MS3
 Old 05-29-2014, 11:36 AM   #14
IMASA's Avatar
Yes, wet traction is definately improved over the Kumho SPT's that I had.
 Old 06-03-2014, 08:36 PM   #15
wdautrem's Avatar
Posts: 159   (View Stats)
wdautrem is the leader of the worldwdautrem is the leader of the worldwdautrem is the leader of the worldwdautrem is the leader of the worldwdautrem is the leader of the worldwdautrem is the leader of the worldwdautrem is the leader of the worldwdautrem is the leader of the worldwdautrem is the leader of the worldwdautrem is the leader of the worldwdautrem is the leader of the world
Maybe some black lugs to finish it of? Your body paint gloss is crazy, btw.
wdautrem is offline   Reply With Quote
 Old 06-03-2014, 08:41 PM   #16
Kyle-609's Avatar
Posts: 142   (View Stats)
Kyle-609 has a reputation beyond reputeKyle-609 has a reputation beyond reputeKyle-609 has a reputation beyond reputeKyle-609 has a reputation beyond reputeKyle-609 has a reputation beyond reputeKyle-609 has a reputation beyond reputeKyle-609 has a reputation beyond reputeKyle-609 has a reputation beyond reputeKyle-609 has a reputation beyond reputeKyle-609 has a reputation beyond reputeKyle-609 has a reputation beyond repute
I think RPF1's will look good in any color...
corksport spings and struts. cobb intake. at internals. damond rmm. cnt exhaust. ebay test pipe. evo x wheels 235/40 w/ g-force comp2 a/s hypnotic tuned
Kyle-609 is offline   Reply With Quote
 Old 06-04-2014, 10:35 PM   #17
itzfajardo801's Avatar
Posts: 9   (View Stats)
itzfajardo801 is an unknown quantity at this point
How much did your setup cost you? And what are you lowered on?
itzfajardo801 is offline   Reply With Quote
 Old 06-18-2014, 07:35 PM   #18
JDMCRX's Avatar
Posts: 128   (View Stats)
JDMCRX has a reputation beyond reputeJDMCRX has a reputation beyond reputeJDMCRX has a reputation beyond reputeJDMCRX has a reputation beyond reputeJDMCRX has a reputation beyond reputeJDMCRX has a reputation beyond reputeJDMCRX has a reputation beyond reputeJDMCRX has a reputation beyond reputeJDMCRX has a reputation beyond reputeJDMCRX has a reputation beyond reputeJDMCRX has a reputation beyond repute
Groaned at 18 Times in 6 Posts
Looks good
JDMCRX is offline   Reply With Quote
 Old 02-03-2015, 04:09 PM   #19
r1kcrew's Avatar
Posts: 1   (View Stats)
r1kcrew is an unknown quantity at this point
Did you install a vinyl trim molding on your grill? I wanna install one too on my black gen1.
Thanks!
Looks great!
r1kcrew is offline   Reply With Quote
 Old 08-01-2015, 07:28 PM   #20
Nickhxc4life's Avatar
Posts: 27   (View Stats)
Nickhxc4life will become famous soon enough
Looks good! Now just plastidip those damn chrome emblems red!
Nickhxc4life is offline   Reply With Quote
 Old 08-11-2016, 12:12 PM   #21
sunshine's Avatar
sunshine has a little shameless behaviour in the past
id say spray the emblems black. but the red rpf1 looks much better than i would have thought!!
sunshine is offline   Reply With Quote
The Following User Says NO Thank You to sunshine For This Un-useful Post:
Vansquish (08-11-2016)
 Old 08-11-2016, 12:58 PM   #22
Police - Grammarhead
Vansquish's Avatar
Nice pointless dead-thread revival for your first post.
sunshine (08-11-2016)
 Old 08-11-2016, 01:07 PM   #23
KiwiFlavor's Avatar
Posts: 2,447   (View Stats)
2012 NASA Spaceship Gray MS3
Black RPF1 17x9 on CWP 802MS3 Wheels & Tires - WHITE 44 01-05-2014 09:11 AM
Black 17x9 RPF1's et 45 245/45/17 MGM bnoon MazdaSpeed 3/6 - Wheels & Tires 8 06-05-2012 10:55 AM
Matte Black Enkei rpf1 17x9 +45 myt_tuf1 2010 MS3 - Wheels & Tires 56 04-22-2012 01:15 PM
Page generated in 0.45550 seconds with 38 queries
