| Wheels & Tires - BLACK Wheels & Tires on black cars. |
![]() Join Date: Aug 2011
Groaned at 13 Times in 5 Posts
(Thread Starter) | Not Ranked : 0 score Hey guys, I'm sure there is a thread around but I needed an answer asap so I can go out and buy the new wheels! I have my rear guards rolled on my 06 MS6, will the 18 x 8.5 +38 with 235/40/18 fit my car? If it makes any difference... my car is from Australia ![]() If anyone can source a thread link for me I'm more then happy to read through it. Originally I was going with a +44 offset and I know that it's sure to fit but I'm wanting something more "hellaflush" Thanks in advance! |
(Thread Starter) | Not Ranked : 0 score bump.. |
![]() ![]() Join Date: Mar 2008 Location: Foothill Ranch, CA
Rep Power: 2705 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 766
| Not Ranked : 0 score EvoX wheels? Sure go for it.
__________________ 2017 Daytona 392 SOLD//2014 Porsche 981 Cayman S 3.4L STOLEN//2015 BMW S1000R SOLD//2014 Mustang GT// Brembos - Bob's Can - SCT X4 - MGW - GT500 Quad-tip Axle back - Vorshlag Street Pro - Ford K Springs - BMR PHB 2007 MS6 w/ Cheez // COBB V3 AP // Corksport CTS4 // HKS Ignition // SURE ID300 MAF // COBB TIP // CXRacing FMIC // PTP BSD // PTP Windage Tray // PTP TIG // KMD V2.1 CDFP Internals // HD Coil Packs // Corksport DP // TurboXS RP // CP-e 3" Single Cat-back // Bilstein Shocks & H&R Springs // DSS Axle // TSW Interlagos 19x8 +35 // 235/35 Rubber // Defi Red Racer // Block8head Defrost Pod // DDM 3k Fogs & 6k Lowbeams // Custom iPod Integration Hackjob // |
(Thread Starter) | Not Ranked : 0 score Nah, Rota G-Force. Are Evo X wheels the same size? |
| Not Ranked : 0 score yep... make sure you get a good fender roll
(Thread Starter) | Not Ranked : 0 score I can't find any examples of Evo X wheels on MS6's. Could you link me? Would greatly appreciate it! Do alot of people have Evo X wheels on their MS6's? |
| Not Ranked : 0 score a couple... they are around, most likely in the aggressive fitment thread
(Thread Starter) | Not Ranked : 0 score So I got the Rota G-Forces 18x8.5 +38, 235/40/18 tires. There's no scrubbing with a driver and a passenger, but when theres 2 people in the back it scrubs quite abit... I tore some of my edge / corner / sidewall off last night, does it ruin how the tire performs now? I will definitely be getting my guards rolled before I install the Eibach springs |
![]() Join Date: Dec 2010 Location: La Porte, Texas
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 95
| Not Ranked : 0 score Im running a 18x8 with 37mm offset with 235/40/18s on my car, I had to roll mine and im running a stock suspension, I took a baseball bat and rolled the hell out of them and it did the job. I learn my lesson after going over some rail road tracks and took a little piece of meat out of my tire, you might as well roll them just for insurance purposes and if your going to lower it.
__________________ Cobb AP: Stage2+SUR+TIH+IC 93|SURE: Aeros|Sidewinder|Charge Tubes|Return|ShortCut|CounterShift|M6 RacePipe|TorqR6 RMM|TurboSmart Dual Port BOV|CP-E TMIC|MagnaFlow CB 2.5'|StopTech D&S|HAWK HPS|AutoTech Internals|Denso ITV22| |
(Thread Starter) | Not Ranked : 0 score Hmm that's odd cause with only me in the car, it's near impossible to get it to scrub. My tire is worn all around, on the corner of the sidewall.. it seems to have ripped some of the tread pattern off, do you think its going to affect my cornering and hard turning? |
| Not Ranked : 0 score Make sure you roll the fenders at the section that is directly behind the doors... On suspension compression the rear wheels arc toward the front side of the fenders, not straight up and down.. Because of the trailing arm
| Not Ranked : 0 score It depends how bad it is, I couldn't tell you to be honest if you had a picture I could tell you, Im just about the only person who rides in my car and it still happened, I would go ahead and roll them fenders good cause otherwise in the near future when you get new tires they are going to get tore up because of that reason, and if you have insurance on the tires it wont get coved cause of that reason. Just rent a fender roller it will get the job done, you can rent one from streetunit, or you can use a baseball bat if your looking to not spend no money, also besure to have a heat gun so you dont crack your paint!
(Thread Starter) | Not Ranked : 0 score I'll be getting the full fender rolled, I can't rent from SU because I'm in Australia ![]() The grooves circled in red have been torn off, and it has happened to about 3/4 of the tire. |
(Thread Starter) | Not Ranked : 0 score To be exact, I took a photo. |
![]() Join Date: Jun 2010 Location: Ottawa
Rep Power: 617 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 526
| Not Ranked : 0 score That isn't that bad, but I bet it tore the shit out of the fender as well... To run silly big tires you need to have a suspension that can adjust camber, or control links that can be adjusted in and suspension that can adjust camber. You see how the tire is tucked in? The top of the rear tire fits because it is tilted (Camber) in
__________________ Last edited by Brian MP5T; 09-21-2011 at 04:50 AM. Reason: FINE!!! FUCKING WIDE BODY PICTURES ARE UNWELCOMED!!! I GET IT!!! FUUUUCCKKK!!! |
(Thread Starter) | Not Ranked : 0 score I don't have a silly big tire though, and nah it didn't tear the fender. Hopefully it doesn't happen anymore with my guards rolled |
| Not Ranked : 0 score horrible example brian, thats a widebody kit haha
| Not Ranked : 0 score True, but it gave me the chance to post up an awesome picture.. The Kit is only rated for a 235 wide tire... so in actuality the fact that he is running a wide wide tire... it's a bit the same as the OPs situation.
__________________ |
(Thread Starter) | Not Ranked : 0 score Just wondering if I need the front guards rolled? I'm getting the rear tomorrow and if I need to front done might aswell do it on the spot |
| Not Ranked : 0 score with proper negative camber up front (need adj balljoints) you'll be fine
(Thread Starter) | Not Ranked : 0 score ![]() This is it, lowered on Eibach springs. One thing that is bothering me, when I was on stock height the front seemed to stick out more than the rear, now that it's lowered the front still stick out more than the rear. Is this a natural thing with our car? |
| Not Ranked : 0 score i think its an illusion from the uneven fender layout
(Thread Starter) | Not Ranked : 0 score It's not an illusion as I can actually see that it's poked out more at the front, it's noticeable.. BUT I think that it's slowly going away due to springs settling it? |
![]() | | #24 | ![]() |
![]() Join Date: Sep 2011 Location: Fort Riley, KS
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 197
| Not Ranked : 0 score hmmm i have those same exact rims with 235/40 tires... and my fenders are ROLLLLLLED saves lives wen ur slammed.... cant wait to install my coilovers lol.
__________________ -2006 Mazdaspeed6- Engine: CPE FMIC, Sure Aeros, Sure Sidewinder, ATP DP, GHL CBE, TurboSmart BOV, Cobb AP, AT HPFP internals, DNP Mani, OCCDrivetrain: SURE Dread & Jugg, CPE RMM, TT FMM, Spec Clutch, TWM SS (s2) Suspension/Brakes: BC Coils, EBC Ultimax Rotors, Hawk HPS Pads Exterior: NEXTMod Lip Kit, VG Sharkfin, APR Splitter Rods, Rota GForce 18x8.5 with 225/40/18 Hankook Ventus V12 Upcoming: GT3071R ... |
![]() | | #25 | ![]() |
| The Following User Says Thank You to High on PSI For This Useful Post: | Docnox (10-10-2011) |
![]() | | #26 | ![]() |
![]() Join Date: Sep 2008 Location: CT/NY
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6,375
Groans: 35
| Not Ranked : 0 score I think those wheels look awesome, aggressive as hell.
__________________ ---------------------------------------------------------------------------- '06 Speed 6 Black MicaMazdaspeed SRI, Medieval inlet, Eibach Springs, Magnaflow cbe, 3 ebay catless dp, SU rmm, HKS ssqv, JBR stage 2 ssp Altered Customs fmic, Autotech fp internals Cobb AP, Stage 2+ 93 tweaked Centric blanks, EBC red pads Lotek center gauge pod: AEM wideband, Autometer boost and volts Tints, blacked emblems, spec-v front lip, Shark fin Redline MT-90, ITV-22s, Matt Damond OCC 13.66@102 Lebanon Valley 4/10/11 (sri, tp, rmm, ap) DO Meth kit waiting on install |
![]() | | #27 | ![]() |
![]() Join Date: Jan 2013
Rep Power: 0 ![]() ![]() ![]() Thanks: 4
| Not Ranked : 0 score Sorry to bring up an old thread. Have you got more pics of these wheel/car combo? I cant find anything on the net with 18 x 8.5 +38 offset. |
