| Wheels & Tires - BLACK Wheels & Tires on black cars. |
![]() Join Date: Mar 2011
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 46
(Thread Starter) | Not Ranked : 0 score During the last 2 winter, I sandpaper my wheel^(400, 800, 1000 grit), primer (3 coat) + paint (rattle can)3 coats. But and the end of each winter my wheel are shoot and I need to do them again ... So I want to sandblast my oem wheel to eliminate all the defect on the wheel and after apply plastidip one rattle can for each wheel and 3 glossifier for the 4 wheels. Do you think it will last longer for our rough winter here in Canada with all the salt ... Because I will start soon to be sure have good condition for the plasitdip and primer. Thanks for your help
__________________ 2008 MAZDASPEED3 Black Stratified Tuned / Stage 2 |
![]() Join Date: Sep 2012 Location: Los Angeles, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,205
| Not Ranked : 0 score Powder coat
__________________ 2010 Mazdaspeed3 w/tech Cobb AP V3 ║ JBR Tru 3" Wide Path ║ JBR Boost Tubes & BPV Hose ║ Cobb XLE BPV ║ CP-E TMIC ║ UR Racepipe ║ Magnaflow CBE ║ AutoTech Internals ║ GrimmSpeed EBCS ║ JBR RSB ║ SPC Camber Arms ║ KW V3 Coilovers ║ JBR IM+TB TIGs & TB Bypass ║ JBR SSP ║ E - Focus RMM ║ StopTech Slotted Rotors and EBC Yellow Stuff Pads ║ Techna-Fit SS Brake Lines |
![]() Join Date: Sep 2012 Location: Elizabeth, NJ
Rep Power: 3180 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 7,265
Groans: 665
| Not Ranked : 0 score |
| Help with winter wheel size | basspunk1001 | 2010 MS3 - Wheels & Tires | 2 | 10-23-2012 09:25 PM |
| MS3 Wheel - winter setup | Atomic41 | Wheels & Tires - BLACK | 3 | 07-08-2012 06:42 PM |
| Winter Wheel/Tire pix on my 2nd Gen | Teal | 2010 MS3 - Wheels & Tires | 1 | 12-31-2010 08:05 AM |
| Winter Wheel Thread | ryandlor | CX-7 > Wheels, Tires, Brakes & Suspension | 9 | 12-29-2010 12:35 PM |
