| Wheels & Tires - SILVER Wheels & Tires on silver cars. |
![]() Join Date: Jun 2012 Location: Bel Air, MD
Rep Power: 163 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 136
(Thread Starter) | Not Ranked : 0 score quick pic after installing springs and evo x with yokohama advan 245/40R18's. With the wider wheels and suspension, this shit squats. ill put a few more pictures up soon after i clean it up.
__________________ 2006 MS6 GT - bolted, parted, sold. 2008 MS3 - AP, HTP 3.5", 51R w/ small tray, TRZ rmm/tm, JBR pm, JBR bsd and baffle, Corksport ssp, JBR occ, CP-e injector seals, Autotech hpfp internals, CNT tbe, TurboXS fmic, HKS ssqv, KW Variant 2 coilovers, Enkei RPF1 17x9 +45 - STi lip, eBay side skirts, Rally Armor flaps, Prosport Evo digital gauges - boost/oil pressure/AFR, Pioneer double din, HID conversion headlights/fogs, Halo angel eyes, LED tails, Rally Armor mud flaps...blah blah blah |
| The Following 4 Users Say Thank You to liquidsix For This Useful Post: |
![]() Join Date: Sep 2012 Location: Omaha,Nebraska
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 41
| Not Ranked : 0 score evo wheels look good
__________________ Corksport Sri+Tip, Cobb FMIC, Turbosmart BPV, NGK 1 step colder Plugs,Cobb accessport v2,Cobb RMM,cobb shift weight, Megan racing test pipe, Racing beat catback exhaust, Labonte wmi controller with cooling mist pump,stratified 91 octane & e85 ots tunes,Mazdaspeed oem coilovers,CS camber plates,whiteline ALK, whiteline bumpsteer kit, whiteline poly bushings, JBR rear sway bar, SPC rear camber arms,Gtspec mid chassis Aluminum brace, Gt spec rear cross member Brace with V brace addition,Wilwood 4 pot BBk+hawk DTC 60 with DBA 4000 rotors(F),Stoptech high carbon rotor(R), stoptech street performance pads(R), Stoptech stainless steel braided brake line(FxR), Enkei Rpf1 17*8.8 +30, Aluminum hubcentric rings, Work Rs open ended lug nuts, Hankook Rs3 245/40/17 |
