| Wheels & Tires - SILVER Wheels & Tires on silver cars. |
![]() Join Date: May 2014 Location: Topeka, KS
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 14
(Thread Starter) | Not Ranked : 0 score Stock rims for a 2006 MS6 are 18x8 +46mm offset, right? I'm currently running 235/40-18 Continentals with no issues. Sadly, my tires are all but shot. Ive got a set of 18x9 rims with +30mm offset and nearly new 265/35-18 Nitto 555s on them all but rotting away in my garage. I've looked all over and come up with three basic thoughts I think I'm reading: 265 is too wide for the MS6, 18x9 will cause issues as well, and 265 is too wide for the stock rims. What I want to know is, IN A PINCH, would this set (18x9 rims w/ 265s) possibly work, at all? I'm not road racing or anything along those lines. I want to know if these tires could safely be used on this car and not poke out so much that they look ridiculous. Also it would be great to use the tires before they rot.
__________________ 2006 Mazda Speed6; bone stock with 115k as of 06/01/14 |
![]() Join Date: Dec 2013 Location: Plainfield, IL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,712
| Not Ranked : 0 score I would say no, but fitment is different with my ms3. Are those your boobs?
__________________ 2010 black mica speed3 The go: Depo racing: downpipe (100 cell count), custom: FMIC. HTP: 3.5" intake, under route piping. JBR: shortshifter, RSB. Autotech: HPFP internals. Go fast bits: hybrid BPV, VMR: 18x8.5 V710s, Bridgestone: potenza re760 245/40/18, KW: v3 coilovers,SPC: camber arms, freektuned, Damond Motorsports: dual OCC, PMM, PCV plate, RMM, TMM, EGR delete, FoSt mani, Corksport: battery box(fuck this thing), injector seals, Cobb: EBCS, AP v3. AEM: methanol. Seibon: carbon fiber hood. UR: catback. Bosch: 3bar. BNR: s4, DNP: EWG manifold, Tial: 38mm mvs EWG. The show: 5% tint all around, 50% tint windshield, rally armor mudflaps, Sony XAV64BT touchscreen headunit, katskin leather interior, CPE relocation plate, Maisonvi weighted shift knob, Corksport hoodscoop, black housing headlights. Soon:built motor |
![]() Join Date: Feb 2011 Location: Chicago
Rep Power: 365 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 183
Groans: 74
Too bad the answer was no.
__________________ 2007 TR MazdaSpeed3:Autotech FP inernals, CorkSport Turbo, TR8 Front Mount w/CX piping, JBR 3" intake, COBB EBCS, Cobb AP, Toyota Injector Seals, FR stud mod, Fidanza flywheel/LUK clutch, Forge BPV v2, cp-e xFlex stage 2 RMM, Wiseco .20 Pistons/Manley Rods/BSD, Dual DM catch cans, Koni Yellows/H&R springs, FD wheels, eBay downpipe, stock CBE 2005 Mazda 3 SP23: mods include rusty quarter panels and grinding 3rd gear. It does have a fusion motor, so I guess that's a mod too. | |
| The Following User Says Thank You to stockms3 For This Useful Post: | Djohns (07-09-2016) |
(Thread Starter) | Not Ranked : 0 score Yeah, just running the basic numbers it seems like these are going to be 2" wider than what I've got now. Even if it didn't rub, I have to imagine it would look absolutely terrible. No, not my boobs. I just like purple. And boobs.
![]() Join Date: Oct 2012 Location: Richmond, VA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,593
| Not Ranked : 0 score It will indeed look quite terrible. Will it work in a pinch? Maybe. Depends on how much of a pinch you are in. If it's something you need to roll on for a few days solely while waiting for new tires for your regular wheels I say give it a shot. Worst you'll probably do is rub over bumps for a few days.
__________________ 2009 Mazdaspeed3 Bolted, Mounted, Hypnotic Tuned 2000 Mazda Miata MX-5 NASA TTE build ongoing |
(Thread Starter) | Not Ranked : 0 score Serves me right for buying 265s I guess. Oh well; it was worth a shot. Off I go to buy new tires I suppose.
![]() Join Date: May 2010 Location: SLC, Utah
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 15
| Not Ranked : 0 score put them on and try them out. worst case your out 30 minutes trying it out.
__________________ 2009 MGM MS3 - / HTP 3"/ COBB AP, FMIC, RMM, & DP / AT Internals / Manley Rods & Pistons / ARP studs & bolts / Koyorad radiator / DM OCCs / ACT Clutch / Bilstein B16 / CS Camber Plates, Camber Arms, & Seals / JBR .125 RSB, BSD, 51R Battery Box & Raider's AD / StopTech Brakes |
(Thread Starter) | Not Ranked : 0 score I was going to do that, figuring it really wasn't that big of a deal (I've got to remove them from my Mustang to swap, so it does add some time to the swap) but it sounds like there's almost 0% chance that they'll both fit (and not rub) AND not look completely ridiculous.
| Not Ranked : 0 score There is a someone that runs 265s on his Speed6, but obviously it's a setup optimized to try to fit, not just some takeoffs. Like I said, if it's just a couple day solution I'd say it's worth a shot. Any more than that and I'd just expedite getting tires for your normal wheels.
![]() Join Date: Feb 2012 Location: davenport, iowa
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,201
Groans: 128
| Not Ranked : 0 score That would probably poke too much.
__________________ 09 Speed3 ,sold 2012= k04@18lbs, k&n intake, race pipe, selftune13.00@109.76 2013= BNRs2@20lbs E30 FreekedBuilt & Bolted12.63@113.75 full weight, nitto dr's 2014 06 ms6 gt3076 built bolted 2015 06 ms6 parted 2016 07 cosmic MS3 SOLDforged pistons/rods, bsd baffle, cs turbo, fmic, occ, spin on conv, catless long dp, e30, sri, cpe hpfp, rmm, ported im. |
![]() Join Date: May 2012 Location: Greensboro NC
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 751
Groans: 27
| Not Ranked : 0 score stock ms6 wheels are 18x7 +55 offset, those tires would not fit..TBH, 235's are too wide for stock ms6 wheels (pu wheels yes)..225 40 is the max i would run on them. go here it will answer any question u will have about wheels..tires offset...etc --> The Ultimate "Will They Fit" Thread - Everything you need to know about wheels, spacers and tires for your MS
__________________ 06 VRM Speed 6 W/Navi 05 Mazda Family Truckster FREEKTUNED\\Cobb AP\\Autotech Internals\\Eibach Pro Springs\\Sure SRI+TIP\\Street Unit TP\\CPE RMM\AWR 88 Duro TMM\\Forge V1\\JBR Shortcut\\JBR SSB\\CPE & Sure Rear Diff Mounts\\Unicorn Blood (Rotella T6) twitter.com/djern instagram.com/djern facebook.com/djern |
| The Following 2 Users Say Thank You to djern For This Useful Post: | SIXual Panda (07-03-2016), Vansquish (07-05-2016) |
(Thread Starter) | Not Ranked : 0 score Yeah, this was a prayer at getting some use out of tires that are otherwise just going to rot away and since my ms6 tires are circling the drain. Not sure why everyone says 235s are too wide though. I haven't had a single issue (in terms of drivability, etc) with the ones on my car. Maybe it's because it's stock?
They still "fit" as in you can physically fit the tire on the wheel, which you know since you are using them. But in terms of performance, you are beginning to decrease the cornering ability of the car. That's what people are referring to when they say they don't fit or are not properly sized tires for the wheel. If you only use the car for commuting and don't do any aggressive driving with it you'd probably never even notice the difference between those and more appropriately sized tires. To some people who track their cars competitively, that extra sidewall flex could mean a difference in time around the track. It's all relative to how you personally use your car.
__________________ 2009 Mazdaspeed3 Bolted, Mounted, Hypnotic Tuned 2000 Mazda Miata MX-5 NASA TTE build ongoing | |
| The Following User Says Thank You to Quigs For This Useful Post: | KSUWildcatFan (07-05-2016) |
As for tires, it came with these 235s when I bought it so I just assumed that was normal. It seems like a pretty skinny tire as it is so I didn't figure it was pressing the envelope. I think stock tires for my 94 mustang were 195s or something and I went with the 265s because I loved the stance and the extra grip. Different cars though, I get it.
__________________ 2006 Mazda Speed6; bone stock with 115k as of 06/01/14 | |
You can certainly get extra grip out of the MS6 with 235s, just not on the stock wheels. Like with you Mustang you'd just need some wider wheels that fit these cars and you'd be good to go!
![]() Join Date: Mar 2011 Location: Dallas, Texas
| Not Ranked : 0 score Most people are probably responding on what tire size will autocross and corner the best. I've run several different brands of 245's on my stock GenPu rims and didn't have any rubbing issues until I put 20 mm spacers all the way around. Rolled the fenders and really don't have much of an issue. I'm more trying to get improved straight line performance so I go wider than recommended. I'm thinking of running 265/35s on my stock rims (that should get some negative responses)
__________________ Max Bolted and Built Stock K04 |
| The Following User Says Thank You to sheston For This Useful Post: | KSUWildcatFan (07-05-2016) |
(Thread Starter) | Not Ranked : 0 score Yeah... I drive about 15 miles a day. Work and home. lol. I'm not too terribly worried about max performance.
Groans: 63
| Not Ranked : 0 score For performance tires I run 235s on 17x9s. Just for a point of reference. Unfortunately the MS3 needs more negative front camber than it can naturally get so I end up killing the outer edges of the tires anyway. Softer sidewalls mean I roll the tire over substantially (was about 1" of road marks down the sidewall of my conti dw's). Camber plates would be great but I'm not drilling out my strut tower just yet, and there's only so much they can do without coilovers anyway. The MS6 can do more with the front suspension but doesn't fit 265s in the rear unless you hack the fenders.
(Thread Starter) | Not Ranked : 0 score I considered doing a minor drop at some point. Might be best if I do that, see if 235s rub, and reassess prior to buying my new set. That way I don't have brand new 235s that require a bunch of modifying to make fit.
![]() Join Date: Mar 2014 Location: Durham, NC
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 10
I've test fit a set of TSW nurburgrings (however the fuck you spell it) in 18x8.5. I was only 1mm too far outward (I think it was +45) and would've rubbed but it was VERY close only rubbed under a fully loaded suspension. I had tons of room between the coils (this was test fit with 235's and Nitto NT05's) though so a higher offset would've been fine or a fender pull. To answer your second question that's impossible to know without knowing what tires were on it before. You could put tires that last for a long time or only 5k miles, it depends on YOUR driving habit and the tires installed. Typically the tires will be stickier since the car has more than your typical 4cyl power level thus will not last as long. I've had Yokohoma S Drives that have lasted for ~25k and for a summer tire that's not bad. MY PO put some really shitty econo tires on there before and managed ~45k on them. For the stickier tires that go on these cars... no that's not necessarily atypical for the somewhat spirited driver. More importantly you see no weird wear issues. Seeing as how you had DWS this last change (one of the much stickier all seasons) no that's probably not abnormal.
__________________ 2006 Super Clean BCM MS6 Corksport Intake/TIP - Test Pipe - CS FMIC - Freektune - Autotech HPFP - 18x8 Wheels with Nitto NT05's 235/40/18 - H&R Coilovers - SPC Balljoints - CS RMM - Magnaflow CBE - DM Power Steering Cooler - CAR LED Tails - EBC Yellowstuff w/ Centric Blanks - Xcarlink w/ Bluetooth Module Waiting to be installed: Diff Braces - TMM Insert | |
(Thread Starter) | Not Ranked : 0 score The shop I bought my Contis from gave me a big prorated discount since I only got 16k out of the DWS tires so I ordered a set of Goodyear Eagle F1 A/S 225/45-18s. Out the door, it was $366 and I *should* get a $70 rebate from Goodyear. So, I won't do 235s again (duh)..hopefully 225s work better. My local shop only gave up Conti DWS 06's as an option in the 215/45-18 size (for Y-rated tires). Yuck. I did notice that, according to my maintenance log my car has only gotten over 25,000 on a set of tires once (~52k that time). Every other experience has been 16,000-25,000. Is that normal for these cars, or is there something I should be checking? As far as I know, my tires are wearing evenly, just very quickly. I sure hope I get more than 25k out of the F1s :\
(Thread Starter) | Not Ranked : 0 score All I know is that I put 235/40-18 on it because the last tires the PO put on it were 235/40-18s. I'm running stock 7" rims (too narrow for 235s, I know) and I believe my suspension is all stock parts (the maintenance log referenced new shocks at one point due to a "bouncy" ride) but afaik I've never had any rubbing issues. We'll see what the 225s do I guess. I'm gunshy on buying conti DWS again.
| Not Ranked : 0 score I wasn't jabbing at you for putting them on stock wheels I was just telling you if you want to go to an 18x8 & lowered later you WILL RUB I had one of the highest 18x8 rims you can get and it still rubbed (installed by PO). With 8mm more clearance on the stock rim just from the offset alone to the fender and only 7" wide it doesn't surprise me that it didn't rub.
__________________ 2006 Super Clean BCM MS6 Corksport Intake/TIP - Test Pipe - CS FMIC - Freektune - Autotech HPFP - 18x8 Wheels with Nitto NT05's 235/40/18 - H&R Coilovers - SPC Balljoints - CS RMM - Magnaflow CBE - DM Power Steering Cooler - CAR LED Tails - EBC Yellowstuff w/ Centric Blanks - Xcarlink w/ Bluetooth Module Waiting to be installed: Diff Braces - TMM Insert Last edited by Omega; 07-09-2016 at 06:44 PM. |
![]() | | #24 | ![]() |
(Thread Starter) | Not Ranked : 0 score I'm too poor for rims. I'll probably run the stockers until the MS6 dies Indeed an important question, I agree.
__________________ 2006 Mazda Speed6; bone stock with 115k as of 06/01/14 Last edited by KSUWildcatFan; 07-09-2016 at 07:57 PM. Reason: MSF Database - Automerged Doublepost |
| In a pinch - JBR was there for me | GunGuru727 | JAMES BARONE RACING | 37 | 12-17-2012 12:39 PM |
| Jack stands and pinch welds | mhebert2001 | Mazdaspeed3/6 General Discussion | 24 | 11-01-2012 07:52 AM |
| 10 Fun Convertibles That Won't Pinch at the Pump or the Lot | Haltech | Automotive News | 0 | 07-10-2008 11:10 AM |
| 10 Fun Convertibles That Won't Pinch at the Pump or the Lot | Haltech | Automotive News | 0 | 07-03-2008 03:10 PM |
| 10 Fun Convertibles That Won't Pinch at the Pump or the Lot | Haltech | Automotive News | 0 | 07-03-2008 01:20 PM |
