> MazdaSpeed 3/6 - Wheels & Tires > Wheels & Tires - SILVER
Wheels & Tires - SILVER Wheels & Tires on silver cars.
  • 1 Post By KiwiFlavor
  • 1 Post By tdement
 Old 09-15-2016, 08:10 AM   #1
Lex007's Avatar
Posts: 5   (View Stats)
Lex007 will become famous soon enoughLex007 will become famous soon enough
Default XXR 530 or JNC 010?
Looking into getting a set of XXR 530's or a set of JNC 010's. The XXR's are 18x8.75 with a +33 offset. the JNC wheels have are 18x9 with a +30 offset. I plan on going with 245/40/18 tires unless I can make 255's work. I'm lowering the car on H&R coilovers and I have SPC adjustable balljoints for front camber. I don't want to force the issue with the negative camber. Hoping after lowering I can keep both front and rear camber specs within the 1.5-1.8 range. I've looked at all these will they fit threads and all that other stuff, but I need to real validation from an actual human being, not a rim and offset calculator. I understand that the XXR's are probably the best choice, but man I love the look of the JNC wheels. HELP! Any input will help. Thanks
Lex007 is offline   Reply With Quote
 Old 09-15-2016, 08:31 AM   #2
KiwiFlavor's Avatar
Posts: 2,447   (View Stats)
I used to have XXR 530's with the exact specs you posted. Was lowered on Ksport Kontrol coilovers and I only had prob half a finger clearance between the fenders and tires. All I'm saying is, you're going to need a hardcore fender rolling and some bumper tab trimming in the rear.
EDIT: And I have a pu so I have a little bit extra room. But I still needed flat flat flat fender roll
tdement likes this.
2012 NASA Spaceship Gray MS3
 Old 05-31-2017, 07:35 PM   #3
tdement's Avatar
Posts: 103   (View Stats)
tdement has much to be proud oftdement has much to be proud oftdement has much to be proud oftdement has much to be proud oftdement has much to be proud oftdement has much to be proud oftdement has much to be proud oftdement has much to be proud oftdement has much to be proud of
Groaned at 27 Times in 10 Posts
Looks really nice.
I was looking at Enkei EDR-9's for my silver pupu, but with the way my paint is fading, I kinda like the plastidipped stockers I have.
KiwiFlavor likes this.
2011 PuSpeed.
CorkSport SRI + TIP // CorkSport HPFP Internals // CorkSport CBE
tdement is offline   Reply With Quote
 Old 06-02-2017, 06:34 AM   #4
Cruzin101's Avatar
Posts: 1   (View Stats)
Cruzin101 is an unknown quantity at this point
@kiwiflavor- What size tire you go with, with your XXR530s? Thanks
Cruzin101 is offline   Reply With Quote
 Old 09-15-2016, 08:40 AM   #5
anavrinIV's Avatar
Posts: 4,490   (View Stats)
Groans: 63
you'll have a hell of a time fitting the JNCs. XXRs will be a challenge but 18x9+30 with 245s will be too much for a 6 IMO
Blue Pu.
KiwiFlavor (09-15-2016)
 Old 09-15-2016, 09:40 AM   #6
Lex007's Avatar
Thanks for the input guys. Most have already told me that the JNC setup is just going to be too much of a struggle to make it work. i'll probably go with the 530's, but I really want 245/40/18 tires. I see a lot of people with the MS6's running 235, but I've had 235 on my old civics and little bullshit cars. I feel like this car deserves 245's! @ Kiwi I love the look of the 530's on your 3 man. I'll probably go with flat black.
The Following User Says Thank You to Lex007 For This Useful Post:
Page generated in 0.28326 seconds with 23 queries
