(Thread Starter) | Not Ranked : 0 score Yes, for 2007 models only. For 08 models and up, 91 is not a requirement but it is recommended for the best performance. Got Turbo? Please use 91+ no matter what year. It will run better. I'm having an issue with my CX-7, what should I do? First, before posting a thread search on the issue and see if you can find an answer for your problem or if other members here have experienced the problem you're having or if there is a TSB (Technical Service Bulletin) that outlines the problem and offers a fix. Issues and Troubleshooting ForumMy tires have worn out, should Mazda replace them or will I have to replace them myself? Now, this question has been asked more than enough times. The best thing to do is come out of pocket and get some tires that will last much longer than the OE tires, because chances are you will just get another set of those that will wear out in the same amount of time. ORM tires suck. Period. Tires, Wheels, and Brakes SectionMy brakes are down to the metal, can I upgrade? Should I get just get OE pads? Rotors? Brake pad and Rotor replacement megalistI want to change the oil myself. How to: Change your CX-7's oilWhere is/How do I change my cabin air filter? You can order a replacement from the dealer or online for $20 or less. How To: Replace Cabin Air FilterI want to change out my stock sound system, what are the speaker sizes? BOSE? First, the base 4 speaker sound system has 4 6x8/5x7 speakers. BOSE however has 2 9" Bass drivers in the front door, 5 3 1/2" Mid/High range drivers in the dash and D-Pillar, and 2 6 1/2" mid-range drivers in the rear doors. In order to replace the headunit on BOSE models you need the MAZATO from PAC. The BOSE amplifier is located behind the 2nd row of seats in between it and the spare tire. How do I remove the door panels? How To: Remove door panelNeed OEM Replacement parts? New bumper? Interior trim? ClassicMazdaParts.NetCX-7 Owners Manuals and Maintenance Schedules .PDF -CX-7 Owner's Manual -2007-CX-7 Maintenance Schedule -2007I'll be updating this as I go along.. throw out any suggestions and links. CX-7 Crash Test Scores -IIHS Crash test ratings Frontal / Good MCX-7 Abbreviations BPV | ByPass Valve BOV | Blow Off Valve CEL | Check Engine Light CAI | Cold Air Intake SRI | Short Ram Intake TMIC | Top Mount InterCooler FMIC | Front Mount InterCooler DSC |Directional Stability Control TCS | Traction Control System EBD | Electronic Brakeforce Distribution CX-7 Quick Facts -Performance Numbers 0-60 | 7.7 sec to 8.5 60-0 | 112.9ft Slalom | 64.3mph Bulbs: yoinked from the Sylvanna website OSRAM SYLVANIA - Replacement Guide - Start 2007 MAZDA CX-7 (With HID (high intensity discharge) headlamps) Low beam headlamp HID-D2S High beam headlamp 9005 9005SU Silverstar ULTRA for Ultra Night Vision - The Whitest and Brightest Halogen 9005ST Silverstar High Performance Lighting: The Whiter and Brighter Halogen 9005EB EcoBright - Your Environmental Choice 9005XV XtraVision Halogen - The Brighter Light 9005CB Cool Blue Halogen - The Whiter Light Parking light 1157A 1157AST Silverstar Signal Lighting: Complete the Look: Crisp, Clean, Style 1157ALL Long Life Upgrade: Up to twice the life of the standard lamp Front turn signal 1157A 1157AST Silverstar Signal Lighting: Complete the Look: Crisp, Clean, Style 1157ALL Long Life Upgrade: Up to twice the life of the standard lamp Rear turn signal 992 (7440A) Tail light 7443 Stop light 7443 High mount stop light LED Fog/Driving light H11 H11ST Silverstar High Performance Lighting: The Whiter and Brighter Halogen H11XV XtraVision Halogen - The Brighter Light License plate 2825 2825LL Long Life Upgrade: Up to twice the life of the standard lamp Back up light 7440 7440ST Silverstar Signal Lighting: Complete the Look: Crisp, Clean, Style 7440LL Long Life Upgrade: Up to twice the life of the standard lamp Front sidemarker 2825 2825LL Long Life Upgrade: Up to twice the life of the standard lamp Rear sidemarker 2825 2825LL Long Life Upgrade: Up to twice the life of the standard lamp Map light 2825 2825LL Long Life Upgrade: Up to twice the life of the standard lamp Dome light DE3175 DE3175LL Long Life Upgrade: Up to twice the life of the standard lamp 7443LL Long Life Upgrade: Up to twice the life of the standard lamp Trunk/Cargo area DE3175 DE3175LL Long Life Upgrade: Up to twice the life of the standard lamp 7443LL Long Life Upgrade: Up to twice the life of the standard lamp -OE tire size 235/60/R18 -Optional tire size 255/55/18 -Recommended Oil Full synthetic 5W-30 Rotella T Turbo differences with CX-7 and MS3/MS6 K04 Differences: K0422-582 vs. K0422-881 / K0422-882 Last edited by Raider; 06-25-2014 at 11:25 AM. |
(Thread Starter) | Not Ranked : 0 score Feel free to post anything that may need to be added. |
![]() Join Date: May 2010 Location: West Palm Beach, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6,842
Groans: 819
| Not Ranked : 0 score good shit wat ever happened to Mazoom?
__________________ |
(Thread Starter) | Not Ranked : 0 score He is on here now as a different user. Not sure what it is, the thread vaporized when the forum crashed. I just wanted to make sure he got credit for the info. |
![]() Join Date: Feb 2010 Location: Dallas
Rep Power: 1531 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,819
Groans: 145
| Not Ranked : 0 score Tranny fluid is to be changed every 40k miles and you MUST do the flush not only the drain and fill up because there is about 1gallon of old crappy fluid that's left if you don't do the flush.
__________________ 2011 MS3"Princess GRU" GT2876r AEM Meth Injection, Cobb AP, HTP 3' Intake, KMD interals, Shitty FMIC, JBR 88d RMM, JBR 88d TMM, JBR TIG's x2, JBR BSD, JBR Short THrow Shifter, JBR shifter bushings, Corksport License Plate Bracket, Forge BPV v1, ATP Downpipe, UR Straightpipe Beast Mod, Progress RSB, Koni Yellows, Eibach Pro Kit, Kosei K1-TS Gold 17x8, E85 FREEKTUNE |
![]() Join Date: Mar 2011
Rep Power: 0 ![]() Thanks: 1
| Not Ranked : 0 score I read the frequently asked question point above about replacing the Bose stereo. It was suggested that you need the Mazato by pac. I went to the site and all that comes up are interfaces for Ipod, smart phones, and mp3 players. I'm not sure I understand how that helps with stereo replacement. I've got a 2010 cx-7. I was wondering what would be the repercussions of just replacing the 9 inch woofer with something tighter sounding. I could just cut off the speaker harness interface and connect the wires to the new woofers. That's the first question. The second question is if you pull the bose system out entirely, do you lose the rear view camera that is installed as well as the navigation that is installed or are they separate systems?
__________________ EJCJ |
(Thread Starter) | Not Ranked : 0 score If you have questions, start a new thread in the interior section and you will get more responses. |
![]() Join Date: Nov 2010
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 26
| Not Ranked : 0 score Any possibility of getting a sticky on the type of AWD system the 7 uses?
__________________ 2009 CX-7 Platinum Silver Metallic AWD |
(Thread Starter) | Not Ranked : 0 score Got a thread link? |
| Not Ranked : 0 score Nope, was looking for one...
![]() Join Date: Apr 2014 Location: Brisbane, QLD, Australia
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 225
| Not Ranked : 0 score @Raider How about adding this thread to the CX7 faqs. K04 Differences: K0422-582 vs. K0422-881 / K0422-882
__________________ CX7 - The younger, taller and sexier replacement for the MS6. 2007 CX7 2.3 DISI AWD | Forged Build | Mahle Pistons | Molnar Rods | APR studs | Corksport Turbo @25psi | ETS TMIC | Cobb XLE BOV | CS HPFP | JBR 3.5" WPI | Cooling Mist WMI | CS OCC | CX9 20x7.5's | CX9 Brakes | Pedders Lowered 40mm | VersaTuned by Stratified |
![]() Join Date: Jun 2012 Location: Montreal, QC
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 927
| Not Ranked : 0 score My contribution...
__________________ 2011 CX-7 AWD 2.3 turbo Ported Holset HY35 // Custom top mount EM // Tial MV-S 38mm // Custom DP and catback // L2A intercooler with AMG CWA-100 pump// Perrin MBC // 3.25 Blow-thru MAF // Aquamist HFS-4 v.2 direct port injection // Eagle rods // Supertech 4032 pistons // Forge BPV v.2 // Perrin air/oil separator // Autotech HPFP // Custom RMM insert // TB coolant bypass // Full EGR delete // 3.5 bar MAP // Launch control with anti-lag // Derale remote transmission cooler // Upgraded transmission boost valve // Shimmed transmission accumulators // Adjusted transmission clutch control valve // Digital overboost protection system // Custom firewall heatshield // JKS rear spoiler // Painted VC and IM // BSD // Custom vent pod with boost and meth gauge // Tuned with Versatuner"When the turbo spins the bull$hit ends" BOOST the replacement for displacement |
| The Following 4 Users Say Thank You to torquemaniac For This Useful Post: |
| Neutral : +1 score Here is the engine workshop manual also courtesy of torquemaniac
| The Following User Says Thank You to Ozynigma For This Useful Post: | jaguar_mike (02-06-2016) |
![]() Join Date: Feb 2016 Location: South of Hell, KY
Rep Power: 0 ![]() Thanks: 16
| Not Ranked : 0 score Hi, Great resource manual, you just save me so much time. Now I don't have to wait for one to come and see if it has what I need. Thanks agan, M<e |
| Not Ranked : 0 score Hi, I am going to be able and need both of these manuals. I pulled the engine and transmission from mine, both needed repaired and fixed. I bought the car at the auction and the description said that it needed "mechanical" I guessed that it needed a head, I could only spin the crank to see if it had thrown a rod, it spun ok so no block. But I got the car home got it running sounded good but did have smoke off and on. I think from turbo or just need to be run from sitting. The engine would tack evenly at 5K. So I took it for a ride up the road. The transmission would no shift in normal and only changed shifts using the slap manual mode, hate that system. Is it possible for the transmission to act up and seem like the car has no power at all making you think that the engine is bad? |
| Not Ranked : 0 score It's possible but unlikely. Maybe the ECU is in limp home mode due to transmission problem. Could be a Comms failure between the ECU and TCU. You need to get it checked out by Mazda.
| The Following User Says Thank You to Ozynigma For This Useful Post: | jaguar_mike (02-10-2016) |
