![]() Join Date: Nov 2019
(Thread Starter) | Not Ranked : 0 score Fast foward 3 months, time for oil change. I get some Castrol HM 10w-40 and filter. Drain the oil and its darker then tar and thin as water. Add new, replace filter, start it up and boom, no more noise, its gone. Back to normal engine sounds. So I guess the dealer put in regular oil. Amazing how important proper oil is to an engine. |
Rep Power: 3747 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 8,744
| Well, considering this engine is only supposed to have 5w-30 or 5w-40 in it, your use of thicker oil *could* also be detrimental to performance, longevity, etc.
![]() Join Date: Jun 2009
| Not Ranked : 0 score Castrol HM 10w40 has two problems: 1. It’s the wrong viscosity. To properly lubricate some of the very tiny oil passages in cold weather you need a 5w-30 or 5w40 oil. A 10w40 may sound quieter, but it may fail to reach every rotating or moving surface in cold weather. 2. Castrol HM is not full synthetic. It is a semi-synthetic blend. It will have a lower coking and ash formation point than full synthetic oil. The center shaft of the K04 is lubricated by engine oil. It spins at about 150,000 rpm! Temperatures can reach over 1,500 degrees F. Your turbo will last longer with full synthetic which can handle the higher heat without decomposing, forming hard carbon deposits and ash. Best to run a full synthetic 5w40.
| The Following User Says Thank You to MSMS3 For This Useful Post: | Vansquish (12-21-2019) |
![]() Join Date: May 2010 Location: SLC, Utah
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 15
| Not Ranked : 0 score 10w40 is fine - not optimal but fine. If you're in a cooler climate I would change to 5w30 now but if you are in a warmer climate I would just wait for the next oil service to change. My bet is the dealer put in 0w20 - oil that the CX-5 uses. Dealers are't the smartest (oddly enough) when it comes to our MZR-DISI engines.
__________________ 2009 MGM MS3 - / HTP 3"/ COBB AP, FMIC, RMM, & DP / AT Internals / Manley Rods & Pistons / ARP studs & bolts / Koyorad radiator / DM OCCs / ACT Clutch / Bilstein B16 / CS Camber Plates, Camber Arms, & Seals / JBR .125 RSB, BSD, 51R Battery Box & Raider's AD / StopTech Brakes |
| First proper log. | Slash | 2010 MS3 - ECU Computer Tuning | 20 | 04-21-2013 05:29 PM |
| Is this the proper part that I need? | Caligula | MazdaSpeed 6 - Engine, Transmission & Driveline | 3 | 08-17-2012 05:49 PM |
| Proper wastegate? | TheNewGuy | MazdaSpeed 3/6 - Turbo Induction | 8 | 11-08-2010 07:08 AM |
| What is proper AFR for MS3? | Matrix311 | MazdaSpeed 3/6 - ECU Computer Tuning | 13 | 12-08-2008 10:06 AM |
