> MazdaSpeed 3/6 - Wheels & Tires > Wheels & Tires - METRO GREY
Wheels & Tires - METRO GREY Wheels & Tires on metro grey cars.
 Old 03-23-2012, 05:31 PM   #1
Overspent's Avatar
Posts: 1   (View Stats)
Overspent is an unknown quantity at this point
Default MS3 Cupped Tires from Uneven weight distribution
I'm about to buy my THIRD set of tires for a 2009 MS3 with 40K miles. My tire place tells me the cause of my "severely cupped" tires is that too much of the car's weight is up-front, allowing the read wheels to "skip" off the pavement- the cupping happens when they return to the ground.
I don't drive the car hard (much), and the tire have been rotated regularly. I did yank-out the spare tire to make room for a sub, amp, and sound processor. I have also put maybe 15 lbs of Dynamat in it, pretty-evenly distributed fornt-to-back.
The dealer acknowledged that weight distribution was the probem. I said: "so it's a badly-designed car..." Of course the dealer blames my troubles on my sound system and D-mat.
So I'm wondering if anyone else has encountered the "cupped" rear tires issue, and what any of you would say about how to fix it (short of putting 180 lbs of sand in my tiny cargo area (the dealer's suggestion).
Thanks for any thoughts -
Overspent is offline   Reply With Quote
Uneven tread wear JLuth Mazdaspeed3/6 General Discussion 7 11-12-2011 05:51 PM
Uneven Wear - Need help Engi-Freakin-Neer MazdaSpeed 3/6 - Suspension & Brakes 7 08-01-2011 11:50 AM
Weight of Tires...calculating theortical weight? mrmonk7663 Gen2 MS3 General Discussion 17 07-17-2011 07:51 PM
Getting closer to 50/50 weight distribution CCC 2010 MS3 - Suspension & Brakes 18 04-28-2010 06:27 PM
Weight of OEM 18" wheels/tires on 2010 MS3 Driver72 2010 MS3 - Wheels & Tires 19 11-14-2009 09:43 AM
Page generated in 0.30778 seconds with 28 queries
