> MazdaSpeed 3/6 - Wheels & Tires > Wheels & Tires - METRO GREY
Wheels & Tires - METRO GREY Wheels & Tires on metro grey cars.
 Old 09-08-2014, 01:00 PM   #12
EvoFire's Avatar
Posts: 389   (View Stats)
Originally Posted by Addikted To Boost View Post
but then they would just be the gen pu wheels basically, only painted differently
Agreed, but 19 is just a little too big for our cars. The fact that they are forged and lighter makes them better than normal pu wheels.
Parti's Freekbuilt Goodness Fail_6 MazdaSpeed 3/6 - Big Turbo Builds 514 11-21-2015 09:46 PM
JBR Goodness!! EdgeAutosport.com EdgeAutosport.com 20 11-06-2012 10:51 AM
I Haz Teh Goodness Stealth01 MazdaSpeed 6 - Engine, Transmission & Driveline 33 09-18-2012 03:48 PM
More purple goodness. lvmazdaspeed3 MazdaSpeed 3/6 - Wheels & Tires 8 10-16-2009 02:31 PM
Page generated in 0.32801 seconds with 27 queries
