 Old 09-15-2009, 08:21 AM   #1
socks's Avatar
Posts: 3,250   (View Stats)
Groans: 125
yes, its a seafoam spray.
 Old 09-15-2009, 05:13 PM   #2
maperformance's Avatar
Posts: 4,979   (View Stats)
Thanks for the input everyone. Let me know if you want some more info on pricing. Also let me know if you have a core you would like to get rid of.
Thanks,
Modern Automotive Performance
 Old 09-15-2009, 10:10 PM   #3
NEC
subparpunk03's Avatar
Posts: 1,267   (View Stats)
Here are some pictures of the stock IM:
There's a vacuum port on the top of the intake manifold that needs to be plugged for the VTCS delete
View through the throttle body inlet... little bit of oil in there...
Runners from passengers side to drivers side:
2006 Lotus Elise: Toy car
2007 Mazdaspeed 3: *sold*
2005 Corolla XRS: *sold*
 Old 09-15-2009, 10:12 PM   #4
JumpingJackson's Avatar
Posts: 967   (View Stats)
subparpunk did your manifold come with that VCTS bracket mentioned earlier?
 Old 09-15-2009, 10:27 PM   #5
NEC
Negative. No bracket.
 Old 09-16-2009, 12:47 AM   #6
Fuck sushi rolls
rodrigo's Avatar
Posts: 18,719   (View Stats)
Groans: 356
very informative thread kurt, thank you!!!
 Old 09-16-2009, 09:00 AM   #7
E4Performance's Avatar
Posts: 690   (View Stats)
E4Performance is the leader of the worldE4Performance is the leader of the worldE4Performance is the leader of the worldE4Performance is the leader of the worldE4Performance is the leader of the worldE4Performance is the leader of the worldE4Performance is the leader of the worldE4Performance is the leader of the worldE4Performance is the leader of the worldE4Performance is the leader of the worldE4Performance is the leader of the world
Groaned at 69 Times in 65 Posts
I have a core that I could part with. It has the port/polish done already but by someone else, so probably not as good. PM me.
E4Performance is offline   Reply With Quote
The Following User Says NO Thank You to E4Performance For This Un-useful Post:
 Old 09-19-2009, 03:33 PM   #8
ILL3ST
xcoldricex's Avatar
Posts: 2,777   (View Stats)
Groans: 105
looks great! what coatings do you guys use? how much for just the coating service?
 Old 09-21-2009, 03:48 PM   #9
Bob @ MA Performance's Avatar
Posts: 2   (View Stats)
Bob @ MA Performance is a glorious beacon of lightBob @ MA Performance is a glorious beacon of lightBob @ MA Performance is a glorious beacon of lightBob @ MA Performance is a glorious beacon of lightBob @ MA Performance is a glorious beacon of lightBob @ MA Performance is a glorious beacon of light
Thanks for the compliments!
We use a thermal dispersant on the exterior (black only) that helps pull heat out of the manifold, and a second thermal blocking coating that goes on the flange. This coating acts similar to a phenoelic and milimizes heat transfer from the head itself. Good stuff for sure.
Typically we charge $90 for the coating for most 4cyl applications, but it can be more if we are talking about another platform.
Bob Schreiber
Airflow Engineer
Porting and Advanced Ceramic Coating Specialist
Bob@maperformance.com
IM: PortingGuru
763-545-3800
Bob @ MA Performance is offline   Reply With Quote
The Following User Says Thank You to Bob @ MA Performance For This Useful Post:
xcoldricex (09-21-2009)
 Old 09-21-2009, 04:43 PM   #10
ILL3ST
xcoldricex's Avatar
Groans: 105
have you seen any chipping of the coating after awhile at all? i've heard the swaintech BBE coating chips off after awhile unfortunately.
 Old 09-21-2009, 04:46 PM   #11
taf0422's Avatar
Posts: 4,689   (View Stats)
Groans: 192
ohh subbing! Very very nice!!
[SIZE="1"]07 MS3 GT..
GTX3076r --- 479/412
S4-460/400
Highest HP BNR S3
BNR-S3 424/397
 Old 09-23-2009, 03:04 PM   #12
No we have not seen any issues. But if the item being coated was not prepped well before hand which we do very well in house then yes I could see how some company's having issues with it holding up..
 Old 10-15-2009, 10:49 PM   #13
hnda etr's Avatar
Posts: 4,173   (View Stats)
Groans: 90
what happened to those dyno numbers?
 Old 10-18-2009, 01:18 PM   #14
NEC
Like I said in the steedspeed thread, I'm working on it.
 Old 11-04-2009, 03:12 PM   #15
QuickSpool's Avatar
Posts: 235   (View Stats)
QuickSpool is a splendid one to beholdQuickSpool is a splendid one to beholdQuickSpool is a splendid one to beholdQuickSpool is a splendid one to beholdQuickSpool is a splendid one to beholdQuickSpool is a splendid one to beholdQuickSpool is a splendid one to behold
Groaned at 9 Times in 5 Posts
Is there going to be a GB on these soon?
What kind of deal would I get if I sent you 2 unmodified mani's and only wanted 1 ported/coated one back?
How much would it be to have the head port matched? Valve job?
Can you leave the VCTS and provide larger flappers that are port matched?
Thanks!
QuickSpool is offline   Reply With Quote
 Old 11-18-2009, 02:19 PM   #16
QuickSpool's Avatar
Hello?
 Old 11-18-2009, 05:04 PM   #17
You have A pm
 Old 12-09-2009, 08:56 PM   #18
NEC
Sorry for the delay fellas, but Dyno is finally in.
Both runs were done at 15 psi boost. I tried to get a 20psi before/after run in, but I'm having trouble getting spikes to go away so 15psi is what I've got to show for now. The tune is a work in progress, so don't hate on the shitty curves
Red is before, blue is after, the torque lines are a little faint so you may have to zoom a bit to see 'em.
The runs were done with the same hardware configuration (except the MAP im of course) and small changes to the tune. No fueling or timing changes, JUST boost control to get the boost curve as close to the same as pre-MAP im as possible.
Happy to answer any questions anyone may have... I'd say I'm pretty darn happy with the gains... I'll get a 20psi run in as soon as I can.
The Following 5 Users Say Thank You to subparpunk03 For This Useful Post:
06Speed6 (12-11-2009), djuosnteisn (12-10-2009), JacksonMS30 (11-10-2010), JumpingJackson (12-15-2009), madvillain (12-09-2009)
 Old 12-09-2009, 10:18 PM   #19
Murse's Avatar
Posts: 136   (View Stats)
Murse has a reputation beyond reputeMurse has a reputation beyond reputeMurse has a reputation beyond reputeMurse has a reputation beyond reputeMurse has a reputation beyond reputeMurse has a reputation beyond reputeMurse has a reputation beyond reputeMurse has a reputation beyond reputeMurse has a reputation beyond reputeMurse has a reputation beyond reputeMurse has a reputation beyond repute
26 hp gain???? very nice
Murse is offline   Reply With Quote
 Old 12-09-2009, 10:38 PM   #20
madvillain's Avatar
Posts: 4,160   (View Stats)
Groans: 78
need moar info.
 Old 12-10-2009, 12:11 AM   #21
bf360's Avatar
Posts: 2,069   (View Stats)
both dyno runs were std corrected?
what were the dyno conditions? no uncorrected sheets?
bf360 is offline   Reply With Quote
 Old 12-10-2009, 12:29 AM   #22
Fuck sushi rolls
rodrigo's Avatar
Groans: 356
a)did u try to run the car with just changing the IM and if so what were the numbers.
b)what was the extent of the tune changes? any logs?
hard to know for sure the tuning u did didnt influence the outcome at all but......looks like it breathes alot better after 4k
very interested in the higher boost results kurt.
good job ese
 Old 12-10-2009, 08:10 AM   #23
NEC
need moar info.
Ask and you shall receive.... what would you like to know?
Don't know about the STD correction, I drive up to greensboro and do 3 pulls and come home... they print the sheet out for me. They don't do any reconfoobling of the dynomotron between runs that I know of.
It was significantly colder for the run with the MAP IM, maybe a 25* difference which may account for some of the gains, but is by no means the only factor in the equation. Once the car gets goin the BATs are pretty consistent around 100* no matter what the temp is outside.
good job ese
Yeah, I ran the car with just the IM change. It put down almost EXACTLY the same numbers as before but with a 2.5-3 psi drop in boost. As I mentioned above, all I did was try and get the boost/load setup so it would run boost as close to what it was doing before, but obviously with more load requested.
Bottom line is I was able to make more power at the same boost levels, but I had to change the tune to hit those boost targets. I didn't touch fueling or timing or vvt. Just boost/requested load.
I'll be monitoring this thread so let me know if you have any other questions or if you'd like to see any other tests.
The Following User Says Thank You to subparpunk03 For This Useful Post:
rodrigo (12-10-2009)
 Old 12-10-2009, 08:13 AM   #24
Fuck sushi rolls
rodrigo's Avatar
Groans: 356
thats what i wanted to know....basically the added volume dropped u psi and u dialed it up. kinda like going from tmic to fmic...ty
 Old 12-10-2009, 08:21 AM   #25
bf360's Avatar
IF both dynos were std corrected the temperature shouldnt have made a difference, i would hope they left it at std corrected for both runs
 Old 12-11-2009, 01:07 PM   #26
QuickSpool's Avatar
Sweet! Now if MAP would just respond to me....
 Old 12-11-2009, 02:16 PM   #27
Sorry sir I just checked my inbox and dont show a PM from you if you could please resend it that would be great.
 Old 12-11-2009, 02:37 PM   #28
Speeeeeed
06Speed6's Avatar
Posts: 6,530   (View Stats)
The dyno shows basically what it should show, the stock IM is a restriction at stock boost levels when the rpm is higher than 4k. Obviously if you are running higher than 15psi of boost the restriction will hit earlier.
2006 Mazdaspeed 6
 Old 12-12-2009, 10:29 AM   #29
NEC
Yep, restriction gone, the part does what its supposed to. I'm VERY happy with it. The 3071 is going on soon, so well see how it does with that
The Following 2 Users Say Thank You to subparpunk03 For This Useful Post:
djuosnteisn (12-12-2009), rodrigo (12-12-2009)
 Old 12-11-2009, 05:03 PM   #30
madvillain's Avatar
Groans: 78
I wish someone would make a bomb ass manifold, like the one:
 Old 12-12-2009, 10:31 AM   #31
Fuck sushi rolls
rodrigo's Avatar
Groans: 356
give that biotch socks a run for his money kurt!!!
djuosnteisn (12-12-2009), Murse (12-12-2009), subparpunk03 (12-12-2009)
 Old 12-12-2009, 10:42 AM   #32
Captain
djuosnteisn's Avatar
Posts: 11,480   (View Stats)
yeah socks, you need to slow down and let us catch up.
500awhp 440awtq uncorrected
Check out the hair Salon:
www.permtuning.com
 Old 12-12-2009, 06:35 PM   #33
NEC
At the last cars 'n coffee socks popped his hood for a family of four and the toddler started crying in fear when he saw that engine. True story.
The Following 4 Users Say Thank You to subparpunk03 For This Useful Post:
djuosnteisn (12-12-2009), FreeFlyFreak (12-14-2009), Murse (12-12-2009), rodrigo (12-13-2009)
 Old 12-14-2009, 10:51 AM   #34
I just wanted to say thanks again to Kurt for obtaining this information and sharing it with us! We're considering a group buy on these in the near future, would that be of interest to anyone?
 Old 12-14-2009, 01:17 PM   #35
bf360's Avatar
yes for sure pending on price of course
Originally Posted by DCLXVI View Post
your car is possessed by satan, so i dunno whats goin on with that LOL vta's shootin fire some crazy ass extra fluid lines. secret boost control settings haha ninja, or your demon spawn gas pedal not taking no for an answer lololol but your shit rips it.
 Old 12-14-2009, 10:54 AM   #36
Fuck sushi rolls
rodrigo's Avatar
Groans: 356
maaaaaaybe....
i might want in on this action. especially since i really dont think anyone is making a manifold from scratch
 Old 12-14-2009, 01:42 PM   #37
Speeeeeed
06Speed6's Avatar
If you can get it down under $500 I might consider it, a ported stock cast unit that costs more than most of our aftermarket exhaust manifolds just doesnt seem right.
Im not knocking the work though, I have had several sets of heads ported and I know the costs of hand porting and your price is reasonable.
I think there are quite a few people that would pony up for a full aftermarket unit that is around the same price point as a exhaust mani.
2006 Mazdaspeed 6
 Old 12-14-2009, 01:45 PM   #38
NEC
I'm about to get my throttle body all did up by Maxbore... its gonna get real when that guy and the 3071 go on.
 Old 12-14-2009, 05:08 PM   #39
madvillain's Avatar
Groans: 78
Instead of gathering up a bunch of stock IM and doing a group buy on a P&P, I think a lot of us would much rather see one built from scratch... just a thought. Even if the price is higher.
 Old 12-14-2009, 07:28 PM   #40
bf360's Avatar
I think the ported manifold should come down in price, and like 06speed6 said, around 500 for the gb would get me interested.
Then you should develop a whole new manifold for the guys that would prefer that, and im sure they would pay 800-1000 for a quality manifold, but 750 for a ported manifold is definitely too high for most, 500 for a gb and im sure you would get a large amount.
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f392/maperformance-ported-intake-manifold-37629/
Mazdaspeed Rev3 Intake Manifold Results! +26whp | Aftermarket High Performance Parts Installations & Reviews This thread Refback 01-24-2014 08:55 AM
????????? ????????? ?????????? ? ???????? - ????????????? ????????????? ???? Mazda CX-7, CX-9 - ???????? 2 This thread Refback 01-22-2014 02:40 PM
Mazdaspeed Rev3 Intake Manifold Results! +26whp - Modern Automotive Performance This thread Refback 02-24-2012 12:18 AM
????????? ????????? ?????????? ? ???????? - ????????????? ????????????? ???? Club-CX.ru - Mazda CX - ???????? 2 This thread Refback 08-10-2011 07:48 PM
2009 December | Modern Automotive Performance This thread Refback 06-11-2011 03:18 PM
Mazdaspeed Manifold - ??????? This thread Refback 02-24-2011 02:47 PM
Mike's MS6 build thread This thread Refback 01-19-2011 12:59 PM
The MAP Blog - Part 4 This thread Refback 04-21-2010 06:25 PM
Dyno Results | Modern Automotive Performance This thread Refback 04-19-2010 03:30 PM
The MAP Blog - Part 3 This thread Refback 04-14-2010 11:07 AM
Mazdaspeed Rev3 Intake Manifold Results! +26whp | Modern Automotive Performance Post #57 Pingback 12-15-2009 04:39 PM
Fully Ported Intake mani... Block8head Appearance - BLACK 29 06-18-2009 05:35 AM
*Fully Ported Intake Manifold COMPLETE!* Deadman MazdaSpeed 6 - Engine, Transmission & Driveline 8 06-04-2009 02:57 PM
**WTB** MS6 intake manifold Deadman MazdaSpeed 6 - Engine, Transmission & Driveline 0 12-27-2008 06:24 PM
Ported intake manifold? driver311 Mazdaspeed3/6 General Discussion 17 03-26-2008 01:59 PM
Page generated in 0.63225 seconds with 35 queries
