Closed Thread
 Old 12-20-2008, 03:12 PM   #1
maperformance's Avatar
Posts: 4,979   (View Stats)
Default NEW ACT Clutch & Flywheel Packages for the MS3 & MS6
Advanced Clutch Technology (ACT) has released a new Heavy Duty performance clutch kit and components for the 07-09 Mazdaspeed 3, 05-07 Mazdaspeed 6.
ACT’s new clutch kit for the Mazdaspeed 3 and Mazdaspeed 6 features a Heavy Duty Pressure Plate that incorporates hardened diaphragm fingers for decreased wear and provides a 48% increase in clamp force over the stock unit.
The ACT Street Clutch Kit combines the Heavy Duty Pressure Plate and a Performance Organic Disc, a disc that features special performance organic friction materials to withstand increased heat and abuse, steel backed linings for high burst strength and modifications engineered for quicker shifting. The ACT Street Clutch Kit provides increased pedal feel, smooth engagement and significantly improved consistency, durability and increases the torque capacity to 365 lbs/ft.
ACT Race Clutch Kits will hold 470 lbs/ft of torque. Metallic Ceramic Xtreme Discs are available in 4 and 6 puck sprung and un-sprung hub designs and are very durable while allowing for quick shifting. The Xtreme Discs are design for high power engines and are recommended for track use only.
*NOTE: All kits with the ZX4 prefix will include our SFI certified billet steel flywheel, MZ027 pressure plate, RB110 release bearing, AT03 alignment tool and your choice of clutch disc. When replacing the factory self adjusting clutch kit with the ACT clutch kit, the ACT flywheel must be used for the clutch kit to be installed.
All ACT Pressure Plates and discs for the Mazdaspeed 3 and Mazdaspeed 6 are SFI certified. Kits include a new release bearing.
ACT clutches deliver the maximum holding power by applying a series of sound engineering advancements to new (not rebuilt) components which maximizes load and reduces flex. The result is maximum torque capacity, long life and clean, fast shifting. ACT is a premier clutch manufacturer that has more than 300 different applications and more than 500 performance clutch kits. The company’s product line features clutches and forged flywheels for the most popular vehicles in the sport compact car market.
Modern Automotive Performance
maperformance is offline
 Old 12-21-2008, 10:04 AM   #2
SneakyP86's Avatar
Posts: 1,162   (View Stats)
I have purchased the Fidanza Lightweight Flywheel through a group buy here a while back.Will the ACT clutch kit work woth that flywheel?If so is it possible to purchase the clutch kit without the flywheel?
SneakyP86 is offline
 Old 12-22-2008, 10:45 AM   #3
I don't believe that it will as ACT would have offered the clutch and flywheel separately if they were interchangeable
Originally Posted by LBV View Post
I read somewhere else that the flywheel is 16 lbs ... is that correct?
I wasn't able to find this information, but I will report back once I hear from ACT.
Originally Posted by boosted3 View Post
im looking into a clutch and act is a great clutch how much are they gona be
I have added a link to the listing on our website that includes torque ratings as well as pricing. Be sure to add the kit to your shopping cart for even better pricing!
Originally Posted by mrlilguy157 View Post
Their only other options are all puck'd race clutches, but that isn't something I would want to run a dailydriver street car.
I paid $600+ for my Spec Stage III+, and its just the clutch pressure plate and throwout bearing, but it also is rated for 450+ torque.
To be honest the 6 puck sprung is still a VERY streetable setup at least on the DSM / Evo / Subaru / SRT-4 setups we are used to. I can't see why these would be any different...
 Old 12-21-2008, 10:20 AM   #4
LBV
LBV's Avatar
Posts: 700   (View Stats)
LBV has a reputation beyond reputeLBV has a reputation beyond reputeLBV has a reputation beyond reputeLBV has a reputation beyond reputeLBV has a reputation beyond reputeLBV has a reputation beyond reputeLBV has a reputation beyond reputeLBV has a reputation beyond reputeLBV has a reputation beyond reputeLBV has a reputation beyond reputeLBV has a reputation beyond repute
2007 White MazdaSpeed 6 for sale ... new wheels = G8 GXP manual.
LBV is offline
 Old 12-22-2008, 12:49 PM   #5
Confirmed from ACT, 15.75lbs
 Old 12-21-2008, 10:31 AM   #6
boosted3's Avatar
Posts: 855   (View Stats)
boosted3 is the leader of the worldboosted3 is the leader of the worldboosted3 is the leader of the worldboosted3 is the leader of the worldboosted3 is the leader of the worldboosted3 is the leader of the worldboosted3 is the leader of the worldboosted3 is the leader of the worldboosted3 is the leader of the worldboosted3 is the leader of the worldboosted3 is the leader of the world
boosted3 is offline
 Old 12-21-2008, 11:05 AM   #7
Cherryspeed's Avatar
Posts: 205   (View Stats)
Cherryspeed has a reputation beyond reputeCherryspeed has a reputation beyond reputeCherryspeed has a reputation beyond reputeCherryspeed has a reputation beyond reputeCherryspeed has a reputation beyond reputeCherryspeed has a reputation beyond reputeCherryspeed has a reputation beyond reputeCherryspeed has a reputation beyond reputeCherryspeed has a reputation beyond reputeCherryspeed has a reputation beyond reputeCherryspeed has a reputation beyond repute
Prices are listed on his site.
The "performance" clutch AND flywheel come in at $700...WOW!
Cherryspeed is offline
 Old 12-21-2008, 11:01 AM   #8
Realize you just cut and paste, but the Mazdaspeed 6 was not available in 2005.
Also this is a pretty new set up...could you get some more specifics for us?
Flywheel weight, torque capacity of the different clutches, ect.
So far only Spec clutches and Fidanza flywheels have been available to us so that is what we are mostly familiar with..maybe a discussion about how these products directly comapre would be helpful.
Thanks!
 Old 12-21-2008, 11:03 AM   #9
brian,
alot more specific info is on M6C and i think there was even a another thread on MSF about it.
superskaterxes is offline
 Old 12-21-2008, 11:06 AM   #10
brian,
Thanks...I hardly go there anymore...lol.
 Old 12-21-2008, 11:45 AM   #11
oskinosmee's Avatar
Posts: 743   (View Stats)
oskinosmee has a brilliant futureoskinosmee has a brilliant futureoskinosmee has a brilliant futureoskinosmee has a brilliant futureoskinosmee has a brilliant futureoskinosmee has a brilliant futureoskinosmee has a brilliant futureoskinosmee has a brilliant futureoskinosmee has a brilliant futureoskinosmee has a brilliant futureoskinosmee has a brilliant future
If its 700 id get one. Shit i remember paying 1200 for oem on my spec v
Gotta Love The Turbocharged Wagon
oskinosmee is offline
 Old 12-21-2008, 02:07 PM   #12
SSinstaller's Avatar
Posts: 3,989   (View Stats)
Groans: 60
I f I read it correctly you have to get the ACT flywheel if you want to ruin the puck clutches, that's why they're only sold as a set.. So, I assume they will not work with the fidanza flywheel...
SSinstaller is offline
 Old 12-21-2008, 04:58 PM   #13
SneakyP86's Avatar
If I remember correctly you also got on of the Fidanza flywheels,what clutch did you wind up going with?
 Old 12-21-2008, 06:09 PM   #14
Groans: 60
I got the 3+.
 Old 12-21-2008, 02:19 PM   #15
Speeeeeed
06Speed6's Avatar
Posts: 6,530   (View Stats)
The combos come with a SFI rated flywheel, I don't know what it is rated to though. The Fidanza isn't SFI rated as far as I know and I asked PG what RPM it was rated to and never got a answer.
2006 Mazdaspeed 6
06Speed6 is offline
 Old 12-21-2008, 05:28 PM   #16
mrlilguy157's Avatar
Posts: 606   (View Stats)
mrlilguy157 is the leader of the worldmrlilguy157 is the leader of the worldmrlilguy157 is the leader of the worldmrlilguy157 is the leader of the worldmrlilguy157 is the leader of the worldmrlilguy157 is the leader of the worldmrlilguy157 is the leader of the worldmrlilguy157 is the leader of the worldmrlilguy157 is the leader of the worldmrlilguy157 is the leader of the worldmrlilguy157 is the leader of the world
I'm jealous, but not.
The street clutch is listed at 365 ft/lbs of torque, which I don't think is very much more than what the stock clutch will handle.
Black Mica '07 Mazdaspeed3
Mods:CP-E FMIC - ProtegeGarage Tubular Exhaust Manifold - TurboXS Hybrid BOV, Downpipe, and Custom Catted Racepipe - mrlilguyCDFP - ATP 3" Turbo Inlet - ATP Boost Cut Killer Module - CP-E Rear MM - WelderWerkz Short Shifter - AEM UEGO Wideband - ProSport Blue Boost/EGT/Oil Pressure Gauges - GReddy Full Auto Turbo Timer - PimpWheels Black/Red Edition - Falken Azenis RT-615 - Yakima Roof Rack w/ Fairing
Reppin' ProtegeGarage for life!
mrlilguy157 is offline
 Old 12-21-2008, 05:34 PM   #17
MazdaMan13's Avatar
Posts: 532   (View Stats)
MazdaMan13 is a splendid one to beholdMazdaMan13 is a splendid one to beholdMazdaMan13 is a splendid one to beholdMazdaMan13 is a splendid one to beholdMazdaMan13 is a splendid one to beholdMazdaMan13 is a splendid one to beholdMazdaMan13 is a splendid one to beholdMazdaMan13 is a splendid one to behold
great we're finally getting more options from top companies
MAZDAMAN13 - 2.221, 9.378 @ 78.89, 14.309 @ 99.72 (CBE) no power-shifting
DON'T SLEEP ON THE MAZDA...:phillyb:
JDM PARKING LOL
MazdaMan13 is offline
 Old 12-21-2008, 06:13 PM   #18
boost_me's Avatar
Posts: 274   (View Stats)
boost_me is the leader of the worldboost_me is the leader of the worldboost_me is the leader of the worldboost_me is the leader of the worldboost_me is the leader of the worldboost_me is the leader of the worldboost_me is the leader of the worldboost_me is the leader of the worldboost_me is the leader of the worldboost_me is the leader of the worldboost_me is the leader of the world
shit ! its about damn time....
first MS3 dynoed@1320performance in jersey
(rockon)
cobb ap stage 2+ maps-mscai-h&r race springs-katz hidkit-forge bpv(blue/2shims)-turbo xs dp/tp-autometer c/f boost guage-235/40/18 falken azenis-ngk colder step plugs-just getting started...
boost_me is offline
 Old 12-21-2008, 07:31 PM   #19
SneakyP86's Avatar
Yeah the 3+ is what I've been leaning towards and its probably what I'm gonna wind up getting but not for a while yet my clutch is still fine at least for now.
 Old 12-22-2008, 02:12 PM   #20
ATE BALLER's Avatar
Posts: 3,227   (View Stats)
That's still a metric shit-ton less than the stocker. Good to here!
And it comes with the throw-out bearing and the alignment tool too.
Originally Posted by StreetUnitMark View Post
I don't think I could go one day without some sort of meat in my mouth.
ATE BALLER is offline
 Old 12-22-2008, 06:37 PM   #21
Speeeeeed
06Speed6's Avatar
What rpm is the combo rated to?
2006 Mazdaspeed 6
06Speed6 is offline
 Old 12-22-2008, 06:47 PM   #22
To be honest I am not aware of an RPM rating, but DSM / Evo / Subaru guys have had them well over 9500rpms...
 Old 12-24-2008, 07:36 AM   #23
Speeeeeed
06Speed6's Avatar
That works, if we had a blow proof bellhousing available I wouldn't be asking.
I really like my legs, I would like to keep them around for a while =)
2006 Mazdaspeed 6
06Speed6 is offline
 Old 12-24-2008, 09:25 AM   #24
Haha I hear that. I can't say that I've heard of anything like that from ACT is all my years in this industry.
 Old 12-29-2008, 09:44 AM   #25
Bump.
 Old 12-29-2008, 05:27 PM   #26
Bump.
 Old 12-29-2008, 08:12 PM   #27
ATE BALLER's Avatar
I'd get a set now, but funds are low at the moment and I wouldn't be able to install it for some time. It is deffinately the option I am leaning toward though. Now if you want a big pretty front page review of the product with your website links plastered all over it, that can be arranged
 Old 12-30-2008, 08:48 AM   #28
PM sent
 Old 12-30-2008, 05:02 PM   #29
Bump.
 Old 12-31-2008, 08:52 AM   #30
Bump.
 Old 12-31-2008, 05:08 PM   #31
Bump.
 Old 01-01-2009, 01:35 PM   #32
Bump.
 Old 01-02-2009, 08:56 AM   #33
Bump.
 Old 01-02-2009, 05:01 PM   #34
Bump.
 Old 01-05-2009, 12:58 AM   #35
Bump.
 Old 01-05-2009, 06:26 PM   #36
Bump.
 Old 01-06-2009, 09:30 AM   #37
Bump.
 Old 01-06-2009, 09:26 PM   #38
chill with the bumps dude
 Old 01-07-2009, 09:05 AM   #39
LBV
LBV's Avatar
This may be the option I'll go with 1 day but until the stock clutch gives out, I'm not replacing.
LBV is offline
 Old 01-07-2009, 09:07 AM   #40
Haha sorry sir we have someone in house bump threads twice a day to make sure they stay visibile, after all that's what we pay for The way this forum is setup we can probably tone that back a bit though.
Edit: I see we already got someone's attention
Closed Thread
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f392/new-act-clutch-flywheel-packages-mazdaspeed-3-a-17676/
Forum Mazda Performance Series - Zobacz temat - [3BK 6GG] - sprzeglo - jakie zamienniki? This thread Refback 06-24-2011 08:57 AM
Light weight flywheel with several staged clutch options? ptperformance Mazdaspeed3/6 General Discussion 97 04-10-2009 01:36 PM
Clutch/Flywheel options fbpem1 MazdaSpeed 3 - Engine, Transmission & Driveline 0 10-04-2008 06:49 PM
Nissan GT-R tuning packages from NISMO coming Aug. 20th Haltech Automotive News 1 08-04-2008 09:07 AM
Expedia - Spring Vacation Packages & One-Way Flights from $64 Haltech Hot Deals Section 0 03-27-2008 06:21 PM
Page generated in 0.60441 seconds with 33 queries
