Like Tree19Likes
 Old 09-01-2015, 05:38 PM   #1
RPM
RPM's Avatar
Posts: 1,149   (View Stats)
Thumbs up BNR S4 Turbos @ therpmstore.com
BNR STAGE 4 IS HERE!
Following the amazing success of the BNR Stage 3, which has been chosen
by many as the best, most cost-effective way to maximize the stock block,
BNR has taken things a step further with the Stage 4!
The Stage 4 turbo steps into true big-turbo territory, featuring a custom
T04E 50 trim compressor wheel with 76mm exducer and a GT30 turbine wheel,
putting this turbo in the same ballpark as the popular Garrett GT3076.
BNR Stage 4 Turbocharger for Mazdaspeed 3 / 6 #BNR-MZ4
^^ ORDER TODAY! ^^
NEED FINANCING?
We've got you covered! We offer two different financing methods.
Read more about them here:
FINANCING OPTIONS @ therpmstore.com
Jackis likes this.
The Following 24 Users Say Thank You to RPM For This Useful Post:
aviator79 (09-02-2015), Awal (09-02-2015), Bolted6 (09-02-2015), Code Monkey (09-01-2015), Dralphy (09-01-2015), ItsNox (09-01-2015), Jackis (10-06-2015), jack_hammer (09-06-2015), JgamB (09-01-2015), Mazdazilla6 (09-03-2015), MD1032 (09-01-2015), MS3Shadow (09-01-2015), mxlplx71 (09-02-2015), neganox (09-02-2015), smileyspeed3 (09-02-2015), SNOW_QN (09-01-2015), SpeedRebirth (09-01-2015), tegxsi (09-01-2015), The Nut (09-03-2015), Thepedigree13 (09-01-2015), Tomas (10-13-2015), WAMBUSHHHH! (09-07-2015), Zoom66 (09-01-2015), [R]usty (09-01-2015)
 Old 09-01-2015, 06:00 PM   #2
g00s3y's Avatar
Posts: 2,127   (View Stats)
Groans: 438
And I just installed my s3 a couple weeks ago......
ItsNox (09-01-2015), MS3Shadow (09-01-2015)
 Old 09-01-2015, 06:01 PM   #3
RPM
RPM's Avatar
Well, the S3 seems like a good fit for what you have listed. Unless you build your motor, you wouldn't be able to take full advantage of what the S4 will offer.
The Following 3 Users Say Thank You to RPM For This Useful Post:
fasteddie128 (09-02-2015), MS3Shadow (09-01-2015), mxlplx71 (09-02-2015)
 Old 09-01-2015, 06:20 PM   #4
g00s3y's Avatar
Groans: 438
Oh I know, building will definitely be happening. Gotta get the house with a garage first so I have a place to build the motor.
This should be a great seller, just like the s3 was.
MS3Shadow (09-01-2015), RPM (09-01-2015)
 Old 09-01-2015, 06:11 PM   #5
JgamB's Avatar
Posts: 2,566   (View Stats)
I'd like to see how responsive this turbo is. If spool characteristics are good, it could be the logical upgrade to ensure you never need more boost unless going full R-tard.
ItsNox and Awal like this.
The Following 7 Users Say Thank You to JgamB For This Useful Post:
Awal (09-02-2015), dale_gribble (09-01-2015), ItsNox (09-01-2015), MD1032 (09-01-2015), MS3Shadow (09-01-2015), Thepedigree13 (09-01-2015), WAMBUSHHHH! (09-07-2015)
 Old 09-01-2015, 06:14 PM   #6
RPM
RPM's Avatar
It's on par with the GT3076 or a little quicker. It will hit 20 PSI around 3700 RPM.
They do plan on releasing dyno charts. They're just waiting until the car is ready, so they can release the best chart first.
The Following 5 Users Say Thank You to RPM For This Useful Post:
ItsNox (09-01-2015), JgamB (09-01-2015), MD1032 (09-01-2015), MS3Shadow (09-01-2015), SpeedRebirth (09-01-2015)
 Old 09-01-2015, 06:25 PM   #7
dale_gribble's Avatar
Posts: 4,720   (View Stats)
My BNR S3 hit 20 psi at ~3600 (before I adjusted WG spring pressure preload and got it to 3,300). That's not bad for a larger turbo. I think the MS3 can benefit from a slightly later spool anyways since big gains in the 2,500-3,500 pretty much translates to wheelspin.
That's great that it drops into the stock location and doesn't need a massive whale penis intake. This could probably pass a roadside visual and smog visual inspection in Cali, and since it mates to stock intake size, it makes it that much easier. That also means guys could swap in the turbo and then upgrade to large intake later.
Knowing Bryan, I'm sure the turbo is balanced flow wise, so probably no boost control problems (i.e. spikes) either.
ItsNox and Justin@Freektune like this.
MINI H1 6.0 - CAR LED TAILS
The Following 11 Users Say Thank You to dale_gribble For This Useful Post:
ItsNox (09-01-2015), Jackis (10-06-2015), JgamB (09-01-2015), Justin@Freektune (09-02-2015), MD1032 (09-01-2015), MS3Shadow (09-01-2015), mxlplx71 (09-02-2015), SpeedRebirth (09-01-2015), The Nut (09-03-2015), Thepedigree13 (09-01-2015), WAMBUSHHHH! (09-07-2015)
 Old 09-01-2015, 07:01 PM   #8
JgamB's Avatar
I'm fairly certain this test car has a JMF intake as well, which isn't going to help spool.
The Following 3 Users Say Thank You to JgamB For This Useful Post:
ItsNox (09-01-2015), MD1032 (09-01-2015), Micha (09-02-2015)
 Old 09-01-2015, 07:04 PM   #9
RPM
RPM's Avatar
Yes, it does have a JMF intake manifold.
 Old 09-01-2015, 06:28 PM   #10
RPM
RPM's Avatar
Well, it does have a 3-inch inlet, so it will need a larger intake, or at least a larger coupler if you already have one. I'm not sure what size starts to constitute "whale penis" size.. haha
ItsNox (09-01-2015), Justin@Freektune (09-02-2015)
 Old 09-01-2015, 06:56 PM   #11
Thepedigree13's Avatar
Posts: 608   (View Stats)
Groans: 64
As a guy that swore I was going to stay stock until the car was paid off, I think this turbo would be good for me.
I swear now I don't want to do an engine build, but I would probably buy an S3 or CS turbo and eventually get bored and/or want more. This S4 may be the right turbo for guys like me. Could be fun on stock block, but has potential to take you further.
And that bundle price is crazy, very tempting.
~2013 BLACK MS3~
COBB: (APV3//Exhaust Hangers)
Thepedigree13 is offline   Reply With Quote
The Following User Says Thank You to Thepedigree13 For This Useful Post:
RPM (09-01-2015)
 Old 09-01-2015, 07:58 PM   #12
Is it possible for Bryan to put a thicker bead closer to the edge or on the edge of the turbo outlet? I used a shorter coupler on my BNR S3 and the t-bolt clamp was above the thick bead and I blew the coupler off after 4 road racing sessions running only 21 psi of boost.
 Old 09-01-2015, 08:09 PM   #13
RPM
RPM's Avatar
The outlet does taper, so if you can get it on a couple inches, you shouldn't have an issue. Honestly, if you have a quality hose clamp and tighten it properly, you shouldn't have that issue. Many people are running more boost for extended periods without issue.
LateralGs likes this.
 Old 09-01-2015, 08:20 PM   #14
^ Yeah, but they hit the boost a few times for a short period of time and call it quits, try doing it 4 times a day, 30 minutes each time.... Just saying, it would not cost him much time or effort, and it would make the turbo better for those who run a fmic. Guys who run a tmic do not have this problem as the coupler is jammed between the turbo outlet and the intercooler inlet.
Jackis likes this.
Easter Bunny (09-04-2015), Jackis (10-06-2015)
 Old 09-01-2015, 08:37 PM   #15
biggman026's Avatar
Posts: 453   (View Stats)
biggman026 is the leader of the worldbiggman026 is the leader of the worldbiggman026 is the leader of the worldbiggman026 is the leader of the worldbiggman026 is the leader of the worldbiggman026 is the leader of the worldbiggman026 is the leader of the worldbiggman026 is the leader of the worldbiggman026 is the leader of the worldbiggman026 is the leader of the worldbiggman026 is the leader of the world
Groaned at 49 Times in 12 Posts
If you're just wanting a thicker bead on the outlet, that seems like something that would take a few minutes of welding - I can't see a shop charging you more than $20 for something like that.
2007 Mazdaspeed 6 - Black Mica - ZZB RIP 2016!
BNR S3, JBR 3" wp intake, JBR rmm, JBR heavy shift knob, JBR shifter bushings, JBR SSP, South Bend Stage 3 Endurance clutch, Juggernaught/Dreadnaught, Autotech HPFP, 3 bar map sensor, Stratified Boost Dial, Streetunit TMIC, Forge V2 BPV, ebay DP/TP, 3 inch custom single exit cat-back, magnaflow muffler, H&R springs, Cobb AP, JL Audio 12" W3 w/ 500w Alpine amp, 6000k HIDs, LED fogs, dipped and tinted - Stratified 369awhp/383awtq vdyno on 4 gallons of corn
biggman026 is offline   Reply With Quote
 Old 09-01-2015, 09:44 PM   #16
SNOW_QN's Avatar
Posts: 384   (View Stats)
I hate this forum. Every time I get on here I buy something, or plan to buy something that I never intended on purchasing. I'm going to be broke in no time.
On that note, anybody upgrading from an s3 to an s4 need to get rid of their s3 in order to get an s4? 😁 I might be putting up a WTB thread soon. Lol
Edit: that's a hell of a deal on the s4 package btw
MS3Shadow likes this.
The Following User Says Thank You to SNOW_QN For This Useful Post:
 Old 09-01-2015, 10:27 PM   #17
Very good deal on the combo.
Might look into this compared to the CS Turbo.
Sent from my HTC M9
 Old 09-01-2015, 10:29 PM   #18
RPM
RPM's Avatar
Sent from my HTC M9
Thanks! This turbo isn't really comparable to the CS turbo, though. The CS would compare closer to the S3. If you're planning on building your motor at some point, this is the way to go.
Easter Bunny (09-04-2015), Justin@Freektune (09-02-2015), taf0422 (09-02-2015)
 Old 09-02-2015, 12:58 PM   #19
maddocx240's Avatar
Posts: 823   (View Stats)
My motor is getting built as we speak. But as much as I an tempted to get this, bnr turbos have a rep for having issues at first production. I will stick with my s3 for the time being. If I hear of no issues by next summer, then I will get one.
 Old 09-02-2015, 01:28 PM   #20
PurplFox's Avatar
Posts: 352   (View Stats)
PurplFox is the leader of the worldPurplFox is the leader of the worldPurplFox is the leader of the worldPurplFox is the leader of the worldPurplFox is the leader of the worldPurplFox is the leader of the worldPurplFox is the leader of the worldPurplFox is the leader of the worldPurplFox is the leader of the worldPurplFox is the leader of the worldPurplFox is the leader of the world
Cant wait to get more info on this thing.
PurplFox is offline   Reply With Quote
 Old 09-02-2015, 01:43 PM   #21
Zoom66's Avatar
Posts: 281   (View Stats)
Hmmm.... this looks interesting. Do I get this one or a GTX3076 to replace my GTX2867 on my freshly built motor??? Decisions, Decisions....
 Old 09-03-2015, 07:44 PM   #22
MD1032's Avatar
Posts: 2,624   (View Stats)
Groans: 143
The ATP kit for that turbo retails for $1849. Please explain to me why this decision is so difficult for you.
JgamB and Awal like this.
2007 Mazdaspeed3 GT
Awal (09-03-2015)
 Old 09-04-2015, 06:21 AM   #23
Zoom66's Avatar
For one I have aftermarket Kozmic oil feed and drain lines on the my GTX and there is always the decision of bearing type in the CHRA.
 Old 09-02-2015, 07:34 PM   #24
Awal's Avatar
Posts: 645   (View Stats)
Awal is the leader of the worldAwal is the leader of the worldAwal is the leader of the worldAwal is the leader of the worldAwal is the leader of the worldAwal is the leader of the worldAwal is the leader of the worldAwal is the leader of the worldAwal is the leader of the worldAwal is the leader of the worldAwal is the leader of the world
Nice unit, package, and price point. Definitely tempting for someone who can resist turning up the boost until they build their motor. I'll wait for test results before I decide whether this will be the route I go, I'm always a little wary of first runs on new products that move at 1 million RPMs
I hope it goes well for anyone who tries this turbo.
All Go, No Show
2013 LSM W/ Tech
CORKSPORTFull Race RMM CORKSPORTPMM CORKSPORTTMM CORKSPORTTMIC(temporarily uninstalled for Warranty BS) CORKSPORTECU RELOCATION BATTERY BOX(temporarily uninstalled for Warranty BS) CORKSPORTSSP CORKSPORTSHIFTER BUSHINGS CORKSPORT3.5" POWER SERIES SRI/TIP(temporarily uninstalled for Warranty BS) CORKSPORTBPV(temporarily uninstalled for Warranty BS) CORKSPORTRSB @ Full Stiff CORKSPORTMid Chassis Brace CORKSPORTHood Struts + decals for 20whp CORKSPORTLicense Plate Frames
COBBAP v3 w/ Window Mount
AUTOTECHHPFP INTERNALS
ToBeInstalled:
CORKSPORTFull Catless TBE, Rear Trunk Brace, Adjustable FELs, Cold Air Box (modified for 3.5")
dbaDBA42962S Front and Rear Rotors
StopTechRear Braided SS brake lines
JBROCC & VTA OCC kit, EGR BO, Boost Tubes
Cooling MistWMI kit
StratifiedCustom Tune (as soon as TBE is on)
On Deck
wilwoodFastbrakes DP4front Caliper kit (w/ bp-10 pads and braided SS fr lines)
Hawk PerformanceHB478F.605 or HB478Z.605 rear pads
BilsteinB16s
Awal is offline   Reply With Quote
 Old 09-02-2015, 07:50 PM   #25
taf0422's Avatar
Posts: 4,689   (View Stats)
Groans: 192
Not like its his 1st ever turbo
[SIZE="1"]07 MS3 GT..
GTX3076r --- 479/412
S4-460/400
Highest HP BNR S3
BNR-S3 424/397
The Following 3 Users Say Thank You to taf0422 For This Useful Post:
MS3Shadow (09-02-2015), RPM (09-02-2015), Thepedigree13 (09-02-2015)
 Old 09-03-2015, 08:43 AM   #26
maddocx240's Avatar
Yeah but the s3 had a few issues. Bnr s3 v1 had the bolts that were coming loose from the housing. And the s3 v3 had the wastegate issues. So I would wait to see how the s4 performs initially before I jump on it.
 Old 09-03-2015, 08:53 AM   #27
taf0422's Avatar
Groans: 192
Default BNR Stage 4 is coming soon! PRE-ORDER TODAY!
Also because no one ran the turbo prior to the release. It was just released without testing. V3 wastegate issue due to bryan making own housing instead of reusing k04's.
This turbo has been on my car since June 19th with 2500 plus miles on it. Only issue was wastegate port being too large which has been remedied
Just as an fyi
S4-460/400
Highest HP BNR S3
BNR-S3 424/397
The Following 4 Users Say Thank You to taf0422 For This Useful Post:
Easter Bunny (09-04-2015), JgamB (09-03-2015), mxlplx71 (09-03-2015), RPM (09-03-2015)
 Old 09-02-2015, 07:57 PM   #28
Awal's Avatar
Obviously not, by no means did I imply it was. But even 1st run Honda Civics have their fair share of issues.
edit: I'm fully pulling for this to be a fantastic product, just like the others, more great products for our platforms/engines is all one can ask for as a performance enthusiast.
All Go, No Show
2013 LSM W/ Tech
ToBeInstalled:
Cooling MistWMI kit
On Deck
BilsteinB16s
 Old 09-03-2015, 08:58 AM   #29
BLKSTIG's Avatar
Posts: 507   (View Stats)
Well, I went to BNR to visit with Bryan for a bit yesterday. Lots of stuff going on at the shop. Plenty of turbos being built. If you want an s4 you better go ahead and preorder. Killer turbo. The knowledge Bryan has with turbos and how well they will perform always blows my mind. Basically, Just get the turbo is what I'm trying to say.
And Thanks RPM. the 4k$ I spent earlier this is finally about to be put to good use as my build is almost complete. I love it when awesome people team up to offer the community greatness.
The Following User Says Thank You to BLKSTIG For This Useful Post:
RPM (09-03-2015)
 Old 09-03-2015, 09:01 AM   #30
maddocx240's Avatar
I don't doubt bryans knowledge of turbos, I do run the s3 now. Just the kinks it had initially. But if testing them and they are good then that's great.
The Following User Says Thank You to maddocx240 For This Useful Post:
RPM (09-03-2015)
 Old 09-03-2015, 09:16 AM   #31
JgamB's Avatar
The "established" ~500whp turbos haven't been faring too well for reliability if you've done any reading here or on other social media.
@nindoja; and I figured out the initial IWG issue with the S3 V2, Bryan had it fixed within the week, and recalled the whole lot that had been shipped. He takes care of his customers, and some other people haven't been as fortunate with their large turbo manufacturer's followup.
BLKSTIG and Justin@Freektune like this.
The Following 10 Users Say Thank You to JgamB For This Useful Post:
Awal (09-03-2015), Easter Bunny (09-04-2015), Justin@Freektune (09-03-2015), MD1032 (09-03-2015), mxlplx71 (09-03-2015), RPM (09-03-2015), smileyspeed3 (09-03-2015), taf0422 (09-03-2015), The Nut (09-03-2015), Thepedigree13 (09-03-2015)
 Old 09-03-2015, 04:52 PM   #32
maddocx240's Avatar
really haven't heard much on that subject of bigger turbos failing. But I like that the s4 is being tested before it's released so that's a good thing. Like I said I have an s3 and its been fine so I have no issues with Bryan and his product knowledge.
The Following 4 Users Say Thank You to maddocx240 For This Useful Post:
Awal (09-03-2015), JgamB (09-03-2015), mxlplx71 (09-03-2015), RPM (09-03-2015)
 Old 09-03-2015, 09:12 AM   #33
BLKSTIG's Avatar
funny you mention that. I brought that up yesterday when we were talking. It's painful to see things like this happen with any vendor, but they were handled professionally and quickly. He realizes that while his company can suffer when things like this happen his main concern is the consumer and making sure that we are happy. That means a lot to me. These units won't see any problems at all with boost control....
The Following 2 Users Say Thank You to BLKSTIG For This Useful Post:
JgamB (09-03-2015), RPM (09-03-2015)
 Old 09-03-2015, 08:02 PM   #34
Mazdazilla6's Avatar
Posts: 3,657   (View Stats)
Mmmm definitely might have to upgrade after my engine is built. This price is crazy stupid good. Will the price remain the same after it officially launches @RPM;?
VersaTuner = Versatune
PTE = JB 5862
Forge = V2 BPV
Tial = 44mm WG
Autotech = HPFP Internals
Grimmspeed = EBCS
 Old 09-03-2015, 09:34 PM   #35
RPM
RPM's Avatar
Yes, the price isn't expected to change.
Mazdazilla6 likes this.
 Old 09-07-2015, 09:45 AM   #36
dr_banano's Avatar
Posts: 502   (View Stats)
dr_banano is the leader of the worlddr_banano is the leader of the worlddr_banano is the leader of the worlddr_banano is the leader of the worlddr_banano is the leader of the worlddr_banano is the leader of the worlddr_banano is the leader of the worlddr_banano is the leader of the worlddr_banano is the leader of the worlddr_banano is the leader of the worlddr_banano is the leader of the world
Groaned at 22 Times in 8 Posts
will it come with the studs and the crush rings and drain gasket?
Dr_banano
Car: Mazdaspeed3 2010 VRM- BNR S3 Turbo*FreekTuned*363HP 360TQ-DDM 6000k ,tinted 5%,K&N short ram - COBB AP V3 - COBB XLE bpv - JBR SSP stage 2 - JBR billet 80 RMM - JBR heavy shift knob - cp-e fuel pump - COBB inlet -COBB downpipe - COBB CBE - ETS TMIC black- FALKEN AZENIS tires - NGK LTR7IX-11 plugs - Corksports led kit - Corksport fog led kit.-Aeroforce gauges dual with blockhead dual gauge pod- CS boost tube -KNIGHTSPORTS REAR BUMPER - GS EBCS - 3 Bar Map - mgp brake calipers- corksport rear bumper lights - TWM short shifter - JBR TB/IM TI - EGR block - Njspeed pnp IM - K&W V3 coilover - Rear Carbon Fiber Spoiler - corksport hood scoop - WORK wheels 18 x 9.5 + 38 rear and 18 x 8 +38 front
ptp studs/seals pending
mazda 323 2002 hiboost turbo 1.6L-Automatic- Wife's car
dr_banano is offline   Reply With Quote
 Old 09-07-2015, 10:32 AM   #37
RPM
RPM's Avatar
Yes, it will.
 Old 09-13-2015, 10:12 PM   #38
Yes, it will.
Coolant feed?
PTE = JB 5862
Forge = V2 BPV
Tial = 44mm WG
Grimmspeed = EBCS
 Old 09-03-2015, 10:02 PM   #39
specvspeedfreak's Avatar
Posts: 2,371   (View Stats)
As I am on the shitter; i can vouch that bryan will take care of you if something does happen. 》coming from the (2nd) guy with documented S3 v2 issues...
That being said, i really dont have worries that the S4 will be a great turbo for most... stock or built
RPM (09-03-2015)
 Old 09-03-2015, 10:10 PM   #40
Awal's Avatar
I definitely didn't mean to imply anything bad about Brian's turbos or BNR, sorry to have tilted the thread into that direction. Just thinking out loud, I've been bitten by bad luck a few times on brand new products.
The price is truly insane for a turbo of this magnitude, I wish it great success.
All Go, No Show
2013 LSM W/ Tech
ToBeInstalled:
Cooling MistWMI kit
On Deck
BilsteinB16s
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f408/bnr-s4-turbos-therpmstore-com-192766/
BNR Stage 4 is coming soon! PRE-ORDER TODAY! This thread Refback 12-06-2015 04:59 PM
?????????? - ??????? (??????????, ???????, ??????) This thread Refback 10-06-2015 03:46 PM
New logs, stage 2 autotechs installed today. G26 2010 MS3 - ECU Computer Tuning 31 11-18-2011 07:33 AM
Report: 2012 BMW 3 Series U.S. order guide leaked, M Sport coming late Haltech Automotive News 0 11-10-2011 11:30 AM
Hummer plant coming back online to fill 849-unit order? Haltech Automotive News 0 03-09-2010 09:20 AM
Page generated in 0.62173 seconds with 38 queries
