 Old 07-18-2014, 02:48 PM   #1
seige123's Avatar
Posts: 353   (View Stats)
seige123 is the leader of the worldseige123 is the leader of the worldseige123 is the leader of the worldseige123 is the leader of the worldseige123 is the leader of the worldseige123 is the leader of the worldseige123 is the leader of the worldseige123 is the leader of the worldseige123 is the leader of the worldseige123 is the leader of the worldseige123 is the leader of the world
Groaned at 72 Times in 16 Posts
Default Bushings for hotkiss rear sway bar
Is there anyway you guys can get me replacements for the braces that hold the sway bar in place in the horizontal direction for the hotchkiss rear sway bar...mine are brok.
"I See...." said the Blind man as he pissed into the wind
_________________________________
INSTALLED: Cobb SRI Intake and AP V2, Sure Short Shifter, HKS CatBack Exhaust, CP-E Rear Motor Mount & TowPlate & TMIC, Enganeers Shifter Bushings & Passenger Side Mount Mod, JBR TB TIG & TIP & IM TIG, Matt Damond OCC & Banjo Bolt, Forge V1 BPV, HPS Brake pads, Hotchkis Rear Sway Bar, Bilstein Struts/Shocks, DDM Fog HIDS, GT Spec Four Point Brace, Autotech Internals, Rally Armour MudFlaps, Stratified Tune Stage 2, Swift Springs, Denso ITV22 plugs.
WAITING: CPE single guage pod (AEM guage)
seige123 is offline   Reply With Quote
 Old 07-18-2014, 03:04 PM   #2
frothy's Avatar
Posts: 1,067   (View Stats)
James Barone Racing has 'em for $25 a set shipped...
Or you can upgrade to the beefier JBR brackets if you're looking for something that's less likely to fail, though considerably more expensive:
The Following 2 Users Say Thank You to frothy For This Useful Post:
RPM (07-19-2014), seige123 (07-18-2014)
 Old 07-18-2014, 08:17 PM   #3
seige123's Avatar
thanks for the help but I must have wrote it wrong. I am looking for the rings/collars that keep the sway bar centered. The busings are ok.
 Old 07-18-2014, 10:34 PM   #4
frothy's Avatar
Gotcha.
Yeah, I've never seen the locating collars sold individually.
I highly doubt RPM sells them outside of a kit.
Your best bet is probably to contact Hotchkis directly through their website: Contact Information for Hotchkis Sport Suspension
If that doesn't work out, you could try sourcing them through Jamie @ JBR, as his rear sway bars have the same diameter: Contact Us : James Barone Racing, Custom Fabrication
RPM (07-19-2014)
 Old 07-21-2014, 02:15 PM   #5
Crarrs's Avatar
Posts: 1,662   (View Stats)
Pick your coating/material....
Black Oxide
McMaster-Carr
Chrome Plated
McMaster-Carr
Zinc Plated
McMaster-Carr
303 Stainless
McMaster-Carr
Or the stronger version
McMaster-Carr
2004 MSM TiGrey
The Following 3 Users Say Thank You to Crarrs For This Useful Post:
frothy (07-21-2014), RPM (07-22-2014), seige123 (07-21-2014)
 Old 07-21-2014, 11:29 PM   #6
seige123's Avatar
Black Oxide
McMaster-Carr
Chrome Plated
McMaster-Carr
Zinc Plated
McMaster-Carr
303 Stainless
McMaster-Carr
McMaster-Carr
Awesome!
Front sway bar bushings SRTie4k MazdaSpeed 3/6 - Suspension & Brakes 323 10-05-2016 10:07 AM
SURE sway bar bushings? SC08Speed3 MazdaSpeed 3/6 - Suspension & Brakes 70 05-07-2015 09:24 PM
Front sway bar bushings MS3johanna MazdaSpeed 3/6 - Suspension & Brakes 6 01-17-2013 04:12 PM
Page generated in 0.28569 seconds with 22 queries
