Like Tree3Likes
 Old 04-07-2014, 01:23 PM   #41
RPM
RPM's Avatar
Posts: 1,149   (View Stats)
Do you have the part number for the actual caliper used? so I can get measurements off their website.
thanks
The part number for the caliper used in the MS3 4-pot kit is 120-9692. Here's the drawing:
The part number for the caliper used in the MS6 4-pot kit is 120-11132.
PapaSmurf (04-07-2014)
 Old 04-07-2014, 01:29 PM   #42
RPM
RPM's Avatar
Originally Posted by revin-it02 View Post
That Photoshop concerns me. I don't care how much more pressure these calipers exert, having a smaller contact area with the rotor will promote fading and heat spots. Not to mention the more likelihood of pad deposit on the rotor surface and warping for people DDing their cars. There is a reason for massive pad size and that's heat dissipation.
Has anyone used these in track applications? This just looks like a cosmetic upgrade.
I'm not trying to hate, I'm just looking at the real world application of this.
Your concerns are not unwarranted. This caliper is aluminum, so it's heat dissipation properties would be far superior to the stock cast iron calipers. That said, if you're tracking the car regularly, you should consider the 6-piston kit, as that was it's original intended purpose. The 4-piston kit was designed as a more cost effective option for daily drivers who maybe attend a track event once or twice a year, if at all.
 Old 04-09-2014, 05:20 PM   #43
Mazdazilla6's Avatar
Posts: 3,657   (View Stats)
No rear brakes for the 6?
VersaTuner = Versatune
PTE = JB 5862
Forge = V2 BPV
Tial = 44mm WG
Autotech = HPFP Internals
Grimmspeed = EBCS
 Old 04-09-2014, 10:48 PM   #44
RPM
RPM's Avatar
Not at the moment, but that doesn't mean it can't be done.
Mazdazilla6 (04-10-2014)
 Old 06-19-2014, 06:33 AM   #45
maisonvi's Avatar
Posts: 3,490   (View Stats)
Groans: 75
PM'ed
Sent from my XT907 using Tapatalk
The Following 2 Users Say Thank You to maisonvi For This Useful Post:
Code Monkey (07-03-2014), RPM (06-19-2014)
 Old 02-11-2015, 06:42 AM   #46
maddocx240's Avatar
Posts: 823   (View Stats)
@RPM; what pads does the willwood calipers use for the ms6? Like does it share the same pads from a different vehicle or is it some willwood only pad?
 Old 02-11-2015, 10:08 PM   #47
RPM
RPM's Avatar
It's a Wilwood specific pad.
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f408/fastbrakes-wilwood-brake-caliper-upgrade-kits-therpmstore-167127/
Corksport Calipers ? Mazda MPS Owners Club This thread Refback 07-11-2015 11:10 AM
Corksport Calipers This thread Refback 06-19-2014 08:03 AM
4 Piston Brake Kits for a 2010 MS3 (and what happens when you push the stock brakes as far as they will go) Reedy 2010 MS3 - Suspension & Brakes 264 01-03-2020 03:07 AM
Wilwood Brake Kits at EdgeAutosport! EdgeAutosport.com EdgeAutosport.com 280 02-13-2015 02:26 PM
$5 Off $20 In-Store Coupon Walgreens at Online Store Haltech Hot Deals Section 0 04-11-2008 07:11 AM
Page generated in 0.28639 seconds with 24 queries
