Like Tree48Likes
 Old 07-30-2014, 08:12 PM   #761
Dimenus's Avatar
Posts: 2,825   (View Stats)
Groans: 33
Thanks for sharing your findings. GC has mentioned to me in the past that they will swap out springs is people aren't happy with what they received. I don't know if there is a time limit on this (since purchased or since installed) or what the exact process is, but it may be worth inquiring about if anyone wants to swap.
I'm pretty happy with mine but on uneven roads I can still feel the Koni's struggling. They handle small bumps really well but any concrete surface and you can feel the car bounding back and forth. I'm on 1.25 turns from soft on the rear and 1.5 on the front. Softer was worse.
2012 Velocity Red Mica
 Old 07-31-2014, 01:22 AM   #762
JDMJOSH's Avatar
Posts: 642   (View Stats)
JDMJOSH is the leader of the worldJDMJOSH is the leader of the worldJDMJOSH is the leader of the worldJDMJOSH is the leader of the worldJDMJOSH is the leader of the worldJDMJOSH is the leader of the worldJDMJOSH is the leader of the worldJDMJOSH is the leader of the worldJDMJOSH is the leader of the worldJDMJOSH is the leader of the worldJDMJOSH is the leader of the world
Groaned at 8 Times in 5 Posts
I could just be talking out of my ass here but...
A lot of speeds run lowing springs and Koni yellows without issue. I think the problem maybe that the spring rates are too high for OTS Koni yellow valving. After seeing some of the reviews saying the rears were too bouncy, I traded in my 600 springs for 440 and shifted the 525's to the rear. I still don't have these installed but when I do I'll update this thread with my findings.
If the 525's are still causing problems in the rears I'll shift the 440's in the rear and purchase a set of 375's for the fronts. There's not much information on ideal spring rates for OTS yellow's but I think (based on a lot of research) that 550 should be the max that you run without re-valving the shocks.
FWIW I adjusted mine to the settings GC suggested for my spring rates(525F 600R) which was 1 turn from stiff for the rear, and 3/4 turn from stiff front. As others have found the rear end of the car behaves much nicer when you stiffen up the Konis a bit. It rides a little on the stiffer side of stock and does a fairly excellent job soaking up mostly everything thrown at it. I'm keeping mine right where they are now
JBR 3.0" WP // CS Racepipe // UR CBE // CS TMIC // CS SS Plate + Bushings // Autotechs // NGK's // Damond Oil Restrictor Bolt // Forge v2 // JBR RMM 88 // JBR .250 RSB // CS Springs/Struts // SPC Camber Arms //
JDMJOSH is offline   Reply With Quote
The Following 3 Users Say Thank You to JDMJOSH For This Useful Post:
- POD - (07-31-2014), justinsane87 (08-04-2014), nybe0010 (08-04-2014)
 Old 07-31-2014, 06:01 AM   #763
Will fuck up ur day
Chimmike's Avatar
Posts: 6,003   (View Stats)
Groans: 433
Guess I'm probably a bit out of range to swap out at this time eh? I'd probably swap fronts and rears to lower rates. And raise the car a little bit. I'm pretty far from slammed though.
07 MS3
The original Genpoo Hater
 Old 08-03-2014, 11:35 PM   #764
- POD -'s Avatar
Posts: 619   (View Stats)
- POD - is the leader of the world- POD - is the leader of the world- POD - is the leader of the world- POD - is the leader of the world- POD - is the leader of the world- POD - is the leader of the world- POD - is the leader of the world- POD - is the leader of the world- POD - is the leader of the world- POD - is the leader of the world- POD - is the leader of the world
Just adjusted mine to the same settings as JDMJOSH.
Much better.
The car is better behaved. I still get a little bounce over the really rough stuff, but the car no longer feels unsettled and I never feel like the car is out of control. Now I'm really enjoying this kit.
2012 MS3 SOLD, living in the world of Right Wheel Drive now
Ol' BMO had: Autotech Internals, CS SRI+TIP, CS Short Shift Plate, CS BPV, CS TMIC, UR Catback, CP-e Stage 2 RMM, COBB AP v3.0, UR Test Pipe, JBR Weighted Shift Knob, DM OCC Kit, Koni Yellows+GC springs
- POD - is offline   Reply With Quote
The Following 3 Users Say Thank You to - POD - For This Useful Post:
daafisch (08-04-2014), justinsane87 (08-04-2014), nybe0010 (08-04-2014)
 Old 08-04-2014, 09:05 AM   #765
nybe0010's Avatar
Posts: 276   (View Stats)
nybe0010 is the leader of the worldnybe0010 is the leader of the worldnybe0010 is the leader of the worldnybe0010 is the leader of the worldnybe0010 is the leader of the worldnybe0010 is the leader of the worldnybe0010 is the leader of the worldnybe0010 is the leader of the worldnybe0010 is the leader of the worldnybe0010 is the leader of the worldnybe0010 is the leader of the world
Groaned at 3 Times in 1 Post
I got 525F and 600R. I selected DD/Aggressive and from what it sounds like these rates are like max for OTS yellow valving. Daily driver aggressive doesn't sound like it should have the rates it does, so I was a little mislead. Just annoyed because you didn't know what rates went with what description. Only way to know for sure was custom option..So what about the guys that chose track, drag, or AutoX, are those rates just ridiculously high!? Debating if I want to do what you've done @rustysurfsa; and move the fronts back and get some 440's, or keep 525F/600R and make adjustments per @JDMJOSH; haven't installed mine yet waiting on you @rustysurfsa; lol
11' Black Mica MS3 ATK Reman Long Block iMOTO Shift Forks LuK Clutch Fidanza Flywheel
GC+Koni Coilovers CNT CBE JBR Trilogy Mounts Forge V1 BPV CPE SafeSeals Block8Head Dual Vent Pod Blowshift Boost / OP
nybe0010 is offline   Reply With Quote
 Old 08-04-2014, 09:41 AM   #766
daafisch's Avatar
Posts: 3,553   (View Stats)
Groans: 58
I chose occasional autox, race and I have 600F/700R with my 44k mile old yellows set at 1/2 turn from stiff on all 4 corners. Ride doesn't bother me. Some larger dips there is some bounce but everything else feels fine. I also have mine at close to stock ride height.
btstarcher likes this.
 Old 08-04-2014, 11:18 AM   #767
[R]usty's Avatar
Posts: 2,204   (View Stats)
No promises but I'll try and get these installed this week and let you know how they feel. I'll use JDMJOSH's settings from the get go.
2010 Mazdaspeed3 w/tech
 Old 08-05-2014, 11:50 PM   #768
Mattyhawk1's Avatar
Posts: 739   (View Stats)
Just as another data point,
I got the DD on stock shocks, even though I have koni's already installed. The springs I got are 440/550. I was concerned that my wife would not like a harsh ride, needed it to stay closer to stock if possible. I was assured by GC that the 440 in front is 20% stiffer than stock and the rear is more. From my understanding, this is the softest offering in this GB.
I have not installed. I'm waiting for a good time to install and the time just hasn't come. Hopefully I can trade them still as Donovan at GC said they would take them back used if they are still to stiff.
 Old 08-06-2014, 12:43 PM   #769
jrotaryb's Avatar
Posts: 416   (View Stats)
MS3 stock spring rates are supposedly. That means 440/550 are way stiffer than 20%...
Gen1
F: 188 lbs/in
R: 171 lbs/in
Gen2 rates are unclear at this point. There is speculation that the front springs are actually a bit softer, but the dampers all around supposedly have significant changes. I recall an article/interview with Dave Coleman of Mazdaspeed R&D who had brifely discussed significant revisions of the damper characteristics of the Gen2 cars as they were trying to target the feel of an Evo MR.
FYI the spring rates of most coilovers seem to fall in the 400 lbs/in range for these cars.
pedal2plastic.wordpress.com
The driving game blog
Cobb: AP, SRI & RMM
Corksport: TIP, TMIC, RP,SSP
Autotech Internals
Bilstein PSS Coilovers
SPC Rear Camber Arms
JBR RSB
Gram Lights 57F - 18x8.5 +45
Rfinkle2 tuned @21psi
 Old 08-06-2014, 02:18 PM   #770
RPM
RPM's Avatar
Posts: 1,149   (View Stats)
Originally Posted by jrotaryb View Post
Gen1
F: 188 lbs/in
R: 171 lbs/in
These are effective spring rates from the stock progressive springs, also accounting for the motion ratio of the suspension. The rates given by GC and other coilover mfrs are direct spring rates of the linear springs they use. That's why there's a seemingly large difference.
The Following 3 Users Say Thank You to RPM For This Useful Post:
daafisch (08-06-2014), jrotaryb (08-06-2014), [R]usty (08-06-2014)
 Old 08-06-2014, 02:33 PM   #771
Mattyhawk1's Avatar
I second this, but with a caveat.
I talked to Donovan specifically about this 2 months ago. I was a bit freaked when I saw the rates after I got the kit. He explained that the progressive spring rates of the stock springs are the average of the spring through the full compression of the spring. Donovan said that the ~ 20% stiffer rate of the GC spring compared to stock spring was measured when when cornering hard on the stock springs, effectively the 2nd half of the compression of the stockers. Problem for me is that means the cruising around town and highway driving will be maybe like 40% stiffer than stock spring?
Any case, am going to wait to install before having an opinion as to the GC spring rates being an advertised 20% stiffer, I'm trying to be pragmatic for now.
 Old 08-06-2014, 07:19 PM   #772
Freeblurd's Avatar
Posts: 2   (View Stats)
Freeblurd will become famous soon enoughFreeblurd will become famous soon enough
After a bit of experimenting with my kit, I ended up with 450 front and rear- and I'm finally happy. At my ride height (slightly lower than stock), my rear height adjusters are maxed out- so I may consider longer springs in the future to get a little more height. I also cut the stock rear bump stops, which helped smooth things out a bit.
The larger issue was some crazy coil bind (block) that I was getting in the front. The springs are too damn short for the amount of travel available if you have them raised up. Photo shows that they were contacting each other, which resulted in a terrible bang when I hit a big bump. I replaced the springs in the kit with 7" springs, which fixed the problem.
A lot of trial and error for me on this one... I'm at full stiff all around on the Konis, for what it's worth.
In my opinion, their rates are a bit high, and the springs need to be longer for folks wanting near-stock ride heights.
2009 Speed 3
AEM CAI, Cobb TIP, AP V2, Corksport downpipe, CPE TMIC, CPE HPFP, SURE RMM
Koni Yellow, Tri-Point RSB, Cobb FSB, Whiteline ALK, Tanabe 4pt front under brace, GC Coilover kit
17x8+50 PFO1 with 235/45 R17 Dunlop Direzza Z2
Freeblurd is offline   Reply With Quote
The Following 2 Users Say Thank You to Freeblurd For This Useful Post:
daafisch (08-06-2014), Nliiitend1 (08-19-2014)
 Old 08-15-2014, 12:45 PM   #773
RPM
RPM's Avatar
Just FYI, I just talked to GC and they said that they're expecting to start shipping out the spring cups today or Monday, so you should start seeing them as early as next week.
The Following 5 Users Say Thank You to RPM For This Useful Post:
covelife1016 (08-15-2014), Dimenus (08-15-2014), Ewind (08-16-2014), justinsane87 (08-15-2014), [R]usty (08-15-2014)
 Old 08-16-2014, 05:41 PM   #774
Ewind's Avatar
Posts: 235   (View Stats)
Ewind has a reputation beyond reputeEwind has a reputation beyond reputeEwind has a reputation beyond reputeEwind has a reputation beyond reputeEwind has a reputation beyond reputeEwind has a reputation beyond reputeEwind has a reputation beyond reputeEwind has a reputation beyond reputeEwind has a reputation beyond reputeEwind has a reputation beyond reputeEwind has a reputation beyond repute
Groaned at 6 Times in 4 Posts
Neutral  :  -1 score
Was just looking for the status on this!! Thanks.
Ewind is offline   Reply With Quote
 Old 08-19-2014, 02:09 PM   #775
Nliiitend1's Avatar
Posts: 5,749   (View Stats)
Gen1
F: 188 lbs/in
R: 171 lbs/in
Lol.
The OEM springs are NOT progressive. The coils are evenly spaced, the spring wire is of uniform thickness, and the part of the spring that is wound tighter (on the front springs) is compressed at static height (negating it's net effect on observed rate).
Stance is not a verb.
2008 MS3 GT
2016 MX-5 Club
The Following 4 Users Say Thank You to Nliiitend1 For This Useful Post:
daafisch (08-19-2014), Mattyhawk1 (08-20-2014), Micha (08-20-2014), phate (08-19-2014)
 Old 08-20-2014, 08:04 AM   #776
Mattyhawk1's Avatar
Lol.
THats too bad, gives me less confidence in Donovan and Ground Control if they would tell me that.
The Following 2 Users Say Thank You to Mattyhawk1 For This Useful Post:
Nliiitend1 (08-20-2014), phate (08-20-2014)
 Old 08-20-2014, 09:18 AM   #777
Nliiitend1's Avatar
Now that said, the effect of the OEM jounce bumpers on observed spring rate should not be ignored/discounted.
There is not a ton of travel in the OEM suspension before they become engaged, which effectively raises the spring rates (quite significantly, I imagine).
I'm not going to go so far as to assume that's what this guy was trying to say, but it needs to be pointed out...
2008 MS3 GT
2016 MX-5 Club
 Old 08-20-2014, 10:22 AM   #778
Mattyhawk1's Avatar
He did not make reference to the effective rates including bumpstop engagement, but I remember him specifically referencing the oem springs as progressive. I questioned him on this because I thought the OEMs were linear, but he kept saying they were progressive. There may have been some lost in translation going on.
The Following User Says Thank You to Mattyhawk1 For This Useful Post:
 Old 08-22-2014, 12:51 PM   #779
Will fuck up ur day
Chimmike's Avatar
Groans: 433
So this is working well for you?
@RPM; is this something you could work with GC on sending out to those who want it?
I get that bang on big bumps all the time and the ride with the rates I have is just intolerable over undulating concrete. I feel like everyone else that the rates are just too high to match up with these konis.
07 MS3
Dimenus (08-22-2014)
 Old 08-22-2014, 07:51 PM   #780
RPM
RPM's Avatar
Yeah, we could get some 7" 450lb springs if someone wants them. The Eibach part number is 0700.250.0450 (or 07002500450 at some stores). In fact, GC may even swap them out for those who haven't installed the kit. That's something you'd need to ask GC about, though. Unless GC can give us a break (I couldn't get Donovan on the phone today), it looks like the best we could do for a pair is $132.
 Old 08-22-2014, 07:56 PM   #781
Dimenus's Avatar
Groans: 33
Pair? So rears only?
 Old 08-22-2014, 08:12 PM   #782
monkey.bones.007's Avatar
Posts: 3,853   (View Stats)
Was there any word on when spring cups were set to arrive? I've not gotten anything yet.
 Old 08-24-2014, 06:12 PM   #783
Ewind's Avatar
Anyone notice a difference between passenger and driver side height adjustments?
Eg: for fronts, the adjustment is about the same on both sides.
For the rears, to get them even, the driver rear is adjust to almost a full raise and the passenger side rear is lowered probably a quarter from full raise.
This basically means I'll be able to raise the passenger side rear this winter, but not the driver side rear.
 Old 08-24-2014, 06:41 PM   #784
JDMJOSH's Avatar
Not really. My rears are probably within 1/16" of each other and I set them evenly upon install.
 Old 08-24-2014, 06:44 PM   #785
Helrich's Avatar
Posts: 306   (View Stats)
My rears are 1/4" different with a full gas tank, evens out as the tank empties.
2016 MX-5 Club
2012 MS3 -- RIP in peace
The Following User Says Thank You to Helrich For This Useful Post:
Ewind (08-24-2014)
 Old 08-24-2014, 10:47 PM   #786
Ewind's Avatar
Totally didn't think about the fuel tanks. Thanks!
 Old 08-25-2014, 10:43 AM   #787
Will fuck up ur day
Chimmike's Avatar
Groans: 433
I mean, given the overall poor job of matching spring rates to the konis, is this something you think we could get GC to throw us?
07 MS3
 Old 08-25-2014, 11:25 AM   #788
RPM
RPM's Avatar
Well, I just priced them as a pair in case someone wants only the fronts. The spring cups should prevent the described problem in the rear.
And just FYI, GC said some of the spring cups went out last week and the rest are going out this week.
monkey.bones.007 (08-25-2014), [R]usty (08-25-2014)
 Old 08-25-2014, 11:30 AM   #789
RPM
RPM's Avatar
Well, like I said, GC will exchange springs. They will do it no questions asked if the springs haven't been used. If they have been installed, it's handled on a case-by-case basis depending upon the condition of the spring, if it's been driven on, etc. In this case, you'd need to talk to GC directly to see what your options are.
Chimmike (08-25-2014)
 Old 08-25-2014, 11:39 AM   #790
Will fuck up ur day
Chimmike's Avatar
Groans: 433
goody.
well, I'm sure mine will be a "no".
I've driven on 'em too long now.
07 MS3
 Old 08-25-2014, 11:48 AM   #791
[R]usty's Avatar
goody.
I still haven't installed mine do you really think it's worth an exchange to 7" springs?
 Old 08-25-2014, 02:29 PM   #792
Will fuck up ur day
Chimmike's Avatar
Groans: 433
I didn't lower mine much at all, and I think I have 2 things against me: 1) springs are just too damn stiff, and 2) springs are just too short for a minimal drop.
07 MS3
 Old 08-25-2014, 05:06 PM   #793
nybe0010's Avatar
So it's not possible to get it to stock height with teh given 6" springs? I would like to have adjustment for stock height at least for winter. Just worried the 7" springs might not allow for enough drop come summer. Regardless, I'm gonna need to send my springs back for softer ones
 Old 08-25-2014, 05:13 PM   #794
Helrich's Avatar
I'm not sure what springs you guys got, but I'm only 3/4" lower and my springs are fine by a long shot, except when I have both wheels off the ground on jacks. I'm actually looking for stiffer springs I think eventually, the DD/aggressive don't quite cut it for me on the track, although I could probably do with a sway bar upgrade. If anybody went with stiffer springs and is looking for softer ones, let me know lol.
2016 MX-5 Club
 Old 08-25-2014, 08:19 PM   #795
daafisch's Avatar
Groans: 58
You can get the car to stock height.
 Old 08-26-2014, 05:30 AM   #796
Dimenus's Avatar
Groans: 33
Which ones do you have?
 Old 08-26-2014, 05:33 AM   #797
Helrich's Avatar
"Occasional Autocross / Aggressive". Never really looked up the numbers on the springs to get the actual rates because I'm a casual.
2016 MX-5 Club
 Old 08-26-2014, 08:37 AM   #798
461_SS's Avatar
Posts: 1,160   (View Stats)
461_SS is the leader of the world461_SS is the leader of the world461_SS is the leader of the world461_SS is the leader of the world461_SS is the leader of the world461_SS is the leader of the world461_SS is the leader of the world461_SS is the leader of the world461_SS is the leader of the world461_SS is the leader of the world461_SS is the leader of the world
Please elaborate how they do not cut it for you on the track?
If you are looking for stiffer springs, why don't you just get spring rubbers?
461_SS is offline   Reply With Quote
 Old 08-26-2014, 02:07 PM   #799
Helrich's Avatar
A bit too much body roll still. Got some rubbing in the front which obviously could be remedied by increasing the ride height, but the stiffness of my current springs isn't close to bothersome for me so I figure why not?
I actually hadn't heard of spring rubbers before but after googling, that looks like a pretty nice option to look into as well.
2016 MX-5 Club
 Old 08-26-2014, 02:17 PM   #800
Eth Fiend
phate's Avatar
Posts: 6,947   (View Stats)
The why not is because you are probably going to reach the point where the dampers can no longer control the movement. If you think the dampers have more left, try it. If you run too much spring, you will end up losing grip. Adding more roll resistance via ARB's might be a better option.
-06 MS6
-Corn fed 07 MS3 - Sold
daafisch (08-26-2014), Nliiitend1 (08-26-2014)
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f408/gb-ground-control-koni-sport-coilovers-mazdaspeed-167667/
Konisport + ground control setup This thread Refback 04-25-2014 12:49 PM
Konisport + ground control setup This thread Refback 04-20-2014 03:35 AM
Ground control and koni yellows Bap 2010 MS3 - Suspension & Brakes 212 10-20-2016 11:43 AM
Koni Yellows martin_nj MazdaSpeed 3/6 - Suspension & Brakes 50 05-09-2012 10:27 AM
Page generated in 0.61958 seconds with 37 queries
