Like Tree48Likes
 Old 05-12-2014, 03:39 PM   #361
Will fuck up ur day
Chimmike's Avatar
Posts: 6,003   (View Stats)
Groans: 433
Here's to shipping updates today!
07 MS3
The original Genpoo Hater
 Old 05-12-2014, 05:23 PM   #362
RPM
RPM's Avatar
Posts: 1,149   (View Stats)
Originally Posted by TonyTheBrown View Post
I am not talking about the adjustment that is available by a knob. I am talking about the amount of oil the valves can flow throughout the rebound/compression cycle. A knob does not entirely determine this. It works within a set parameter determined by the size, shape, & # of holes found in the internal components. The OTS rebound curve is too aggressive and will impede proper handling/lateral grip more so when there is too much spring involved. What is being changed to the valving or internal components to handle more spring than what Koni recommends for their OTS Yellow?
A twin tube damper is not black magic, so I am only asking if anything is being changed internally to run the spring rates GC is offering.
Understood, but it's not necessary to make any changes in this case. The motion ratio of the suspension has a large effect on the effective spring rate that the KONIs are actually handling. The spring rates quoted in the first post are the direct spring rates, but, due to the motion ratio (which is about 0.6 on the MS3), the effective spring rate is much less.
Today's update:
M.H.'s full kit is shipping today. The others are still being modified.
Yes, I realize this is exactly what I was told on Friday. I'm just relaying what I'm being told and my sales rep is apparently doing the same. I have told them that this is getting annoying. I do have tracking for M.H., though, and I'll be pressing for tracking on the others tomorrow.
Last edited by RPM; 05-12-2014 at 05:23 PM. Reason: MSF Database - Automerged Doublepost
The Following 3 Users Say Thank You to RPM For This Useful Post:
Chimmike (05-12-2014), Dumbguy (05-12-2014), timmcc02 (05-12-2014)
 Old 05-12-2014, 07:44 PM   #363
jeffdevo's Avatar
Posts: 395   (View Stats)
2 weeks is acceptable for a custom job IMO, thanks RPM. The guys on here are like kids who can't sleep waiting to open their presents for Xmas. Just keep us posted as quickly (often is preferred).
[/I][/SIZE][/FONT]
 Old 05-12-2014, 08:24 PM   #364
461_SS's Avatar
Posts: 1,160   (View Stats)
461_SS is the leader of the world461_SS is the leader of the world461_SS is the leader of the world461_SS is the leader of the world461_SS is the leader of the world461_SS is the leader of the world461_SS is the leader of the world461_SS is the leader of the world461_SS is the leader of the world461_SS is the leader of the world461_SS is the leader of the world
While all the theoretical stuff is great to know and a very good place to go from I think this setup has been proven. At this point I'd be more interested in knowing what tire temps and suspension travel actually is (who has a 7 post shaker rig we can test this out on?) and what the driver thinks (since that is ultimately the final say. Every driver is different). I know myself and daafisch do AutoX whenever we can. Depending how motivated I am after competing in an event I'll do a writeup of the suspension setup.
Also what time do we have till to place our order tomorrow?
461_SS is offline   Reply With Quote
The Following User Says Thank You to 461_SS For This Useful Post:
Mattyhawk1 (05-13-2014)
 Old 05-12-2014, 08:28 PM   #365
RPM
RPM's Avatar
Group buy is open until midnight Central time tomorrow (Tuesday).
 Old 05-13-2014, 09:49 AM   #366
Neverlift's Avatar
Posts: 4,699   (View Stats)
Groans: 1,143
That is news to me the macpherson & multi link layout on the car would have a nearly identical motion ratio. I am just learning all of those dynamics, but I thought the front would be close to 1:1 since it is macpherson. How was this motion ration measured? Stock car, at stock height, with stock wheels & tires? I figured all of those factors would change the motion ratio. Thank you for humoring me & getting my wheels turning on this.
Past Mazdas & Speeds
 Old 05-13-2014, 10:03 AM   #367
RPM
RPM's Avatar
Well, I'm no mechanical engineer. I've had to look a bit of this up myself after talking to GC. You might be better off having a chat with them directly, but I'll tell you what I know. The motion ratio is determined by how much the shock moves relative to how much the wheel moves, due to the design of the suspension. So, for example, if the wheel moves 1 inch and the shock only moves 0.6 inches, the motion ratio would be 0.6, which is apparently the case for the MS3. This means that if the direct spring rate of the spring is 500 lbs, the effective rate is actually 300 lbs.
 Old 05-13-2014, 10:31 AM   #368
Mattyhawk1's Avatar
Posts: 739   (View Stats)
That might be for the front. I believe it was determined to be closer to .9 MR for the rear
 Old 05-13-2014, 11:11 AM   #369
RPM
RPM's Avatar
Possibly. I didn't ask specifically about the front or rear.
Chimmike (05-14-2014)
 Old 05-13-2014, 11:58 AM   #370
timmcc02's Avatar
Posts: 253   (View Stats)
Groaned at 9 Times in 3 Posts
Update? Any more kits ship yet? @RPM;
 Old 05-13-2014, 12:19 PM   #371
RPM
RPM's Avatar
They just told me a minimum of 2 should ship today.
 Old 05-13-2014, 01:12 PM   #372
RPM
RPM's Avatar
Today is the last day to order, by the way. If you've been waiting, be sure to get your order in by midnight Central!
 Old 05-13-2014, 07:13 PM   #373
moonrider_99's Avatar
Posts: 185   (View Stats)
moonrider_99 has a reputation beyond reputemoonrider_99 has a reputation beyond reputemoonrider_99 has a reputation beyond reputemoonrider_99 has a reputation beyond reputemoonrider_99 has a reputation beyond reputemoonrider_99 has a reputation beyond reputemoonrider_99 has a reputation beyond reputemoonrider_99 has a reputation beyond reputemoonrider_99 has a reputation beyond reputemoonrider_99 has a reputation beyond reputemoonrider_99 has a reputation beyond repute
Groaned at 46 Times in 14 Posts
two quick questions
what is the difference between an occasional autocross and occasional Race Course configurations in terms of the actual hardware and also how do these kits do in Northeast with winter conditions and salt- do they last? Thank you
2017 Ford Focus RS - Stock
2004 MSM
- AEM Intake - BEGI - FM Turboback - Turbosmart BPV - Hallman Boost Controller - ...
"I'm a Turbo addict, I know."
SCCA Philadelphia: (http://www.phillyscca.com/solo/)
2012 MS3 Silver w/ Tech Package - sold in '17
2009 WRX Stage 2- sold in '12
moonrider_99 is offline   Reply With Quote
 Old 05-13-2014, 08:32 PM   #374
461_SS's Avatar
Originally Posted by moonrider_99 View Post
two quick questions
From what I've read GC kits have lasted some time. If I am not mistaken it is just the spring rates are stiffer. I'm not sure how much that will help or hurt since I don't know what suspension travel is. I'll most likely be going with the "aggressive" setup which what I saw was 525 front/ 600 rear. Push comes to shove you buy two springs OTS at about 65/each .
The Following 3 Users Say Thank You to 461_SS For This Useful Post:
Chimmike (05-14-2014), daafisch (05-14-2014), mrshoulders (05-20-2014)
 Old 05-13-2014, 08:57 PM   #375
Dumbguy's Avatar
Posts: 130   (View Stats)
Dumbguy has a reputation beyond reputeDumbguy has a reputation beyond reputeDumbguy has a reputation beyond reputeDumbguy has a reputation beyond reputeDumbguy has a reputation beyond reputeDumbguy has a reputation beyond reputeDumbguy has a reputation beyond reputeDumbguy has a reputation beyond reputeDumbguy has a reputation beyond reputeDumbguy has a reputation beyond reputeDumbguy has a reputation beyond repute
This was my plan if I decide I don't like how they ride. I'm planning on doing a 3hr trip the weekend after install to really decide what I want to do. I went aggressive occasional autox btw.
2012 VRM Mazdaspeed 3 - “Claudia”
Cobb v3 AP | Autotech HPFP Internals | UR Catback | Cp-e TMIC | Cp-e Stage 2 RMM | Cp-e Catted DP | TWM Full Replacement | CS Occ | CS Bpv | CS Hood Struts | JBR EGR delete | JBR Boost tubes and Recirc hose | HTP 3.5” Intake | 1 Step colder plugs | Blox 490 | BC Coilovers | Drag dr-49
Waiting for install
CS Battery box
2008 Black Mica Mazdaspeed 3 - "April" (Totaled, may she rest in piece)
Dumbguy is offline   Reply With Quote
 Old 05-13-2014, 09:19 PM   #376
RPM
RPM's Avatar
two quick questions
They'd be similar, if not identical.
The kits will last fine up north. They are designed to withstand all sorts of conditions, including racing, and are made of the same, or better, materials than the OEM setup.
 Old 05-13-2014, 11:02 PM   #377
nybe0010's Avatar
Posts: 276   (View Stats)
nybe0010 is the leader of the worldnybe0010 is the leader of the worldnybe0010 is the leader of the worldnybe0010 is the leader of the worldnybe0010 is the leader of the worldnybe0010 is the leader of the worldnybe0010 is the leader of the worldnybe0010 is the leader of the worldnybe0010 is the leader of the worldnybe0010 is the leader of the worldnybe0010 is the leader of the world
Groaned at 3 Times in 1 Post
order placed. thanks @RPM;
11' Black Mica MS3 ATK Reman Long Block iMOTO Shift Forks LuK Clutch Fidanza Flywheel
GC+Koni Coilovers CNT CBE JBR Trilogy Mounts Forge V1 BPV CPE SafeSeals Block8Head Dual Vent Pod Blowshift Boost / OP
nybe0010 is offline   Reply With Quote
 Old 05-14-2014, 10:23 AM   #378
Hal
Hal's Avatar
Posts: 233   (View Stats)
Hal is the leader of the worldHal is the leader of the worldHal is the leader of the worldHal is the leader of the worldHal is the leader of the worldHal is the leader of the worldHal is the leader of the worldHal is the leader of the worldHal is the leader of the worldHal is the leader of the worldHal is the leader of the world
So I am regretting my H&R + Koni yellow purchase. H&Rs feel fine but the drop is just garbage to me.
Therefore I would like to purchase just the GC sleeve.
So add me to the list.
www.emeraldtuning.com
twittter: @emeraldtuning
YouTube: https://www.youtube.com/user/EmeraldTuning
2013 CWP w/ Tech
JBR Shortie
JBR TIP
JBR Boost Tubes
JRB RMM
JBR RSB
JBR 5mm Spacers
JBR Heavy Shift Knob
JBR Flaps
Buddy Club Custom 3" Exhaust
Koni Yellows
Corksport 4-Piston Brake Upgrade
Corksport Springs
Corksport Adjustable End Links
Stoptech Slotted
Stoptech Sport Pads
Stoptech SS Lines
Hal is offline   Reply With Quote
The Following User Says Thank You to Hal For This Useful Post:
 Old 05-14-2014, 11:05 AM   #379
JDMJOSH's Avatar
Posts: 642   (View Stats)
JDMJOSH is the leader of the worldJDMJOSH is the leader of the worldJDMJOSH is the leader of the worldJDMJOSH is the leader of the worldJDMJOSH is the leader of the worldJDMJOSH is the leader of the worldJDMJOSH is the leader of the worldJDMJOSH is the leader of the worldJDMJOSH is the leader of the worldJDMJOSH is the leader of the worldJDMJOSH is the leader of the world
Groaned at 8 Times in 5 Posts
I think your too late brah.
JBR 3.0" WP // CS Racepipe // UR CBE // CS TMIC // CS SS Plate + Bushings // Autotechs // NGK's // Damond Oil Restrictor Bolt // Forge v2 // JBR RMM 88 // JBR .250 RSB // CS Springs/Struts // SPC Camber Arms //
JDMJOSH is offline   Reply With Quote
 Old 05-14-2014, 02:48 PM   #380
RPM
RPM's Avatar
UPDATE: A total of 4 kits have shipped. 2 more going out today/tomorrow. The large shipment of KONIs is still supposed to arrive at GC tomorrow. The remaining orders will start shipping Friday or Monday. It will take them time to modify all of these KONIs, so we don't expect them all to ship at once. They'll be going down the list in the order you guys placed the orders.
- POD - (05-14-2014), justinsane87 (05-14-2014), therza2169 (05-14-2014)
 Old 05-14-2014, 06:34 PM   #381
The GB is over so it doesn't matter that much anymore but your answer doesn't really answer my question, there's a lot of ways to select things from the pull down menu on your site and it would be nice to know how this translates into actual numbers and how one kit is different from another based on the selections made by the customer.
2004 MSM
 Old 05-15-2014, 10:50 AM   #382
RPM
RPM's Avatar
I agree, but as we stated earlier, GC never gave us any exact rates. They just told us to collect the information from our customers and they would use it to determine the appropriate rate when the order was processed. The options I made up myself, just so they'd have an idea of how the car was being used. An autocross setup would be basically the same as a road course setup, though.
 Old 05-15-2014, 06:02 PM   #383
yourname2221's Avatar
Posts: 224   (View Stats)
yourname2221 is the leader of the worldyourname2221 is the leader of the worldyourname2221 is the leader of the worldyourname2221 is the leader of the worldyourname2221 is the leader of the worldyourname2221 is the leader of the worldyourname2221 is the leader of the worldyourname2221 is the leader of the worldyourname2221 is the leader of the worldyourname2221 is the leader of the worldyourname2221 is the leader of the world
read the thread, it had been covered when this first opened up.
Installed: JBR SSP/RMM/RSB
Cobb APv3/EBCS
AT Internals
Bilstein Coilovers
SPC arms
UR
TP/DP
BNR S4, JBR Undermount w/TR8, 3.5" intake
OBX CBE
For dat racecar: Gold Caliper Paint
yourname2221 is offline   Reply With Quote
 Old 05-15-2014, 06:25 PM   #384
daafisch's Avatar
Posts: 3,553   (View Stats)
Groans: 58
Got my GC only kit today!
uploadfromtaptalk1400199873876.jpguploadfromtaptalk1400199894325.jpguploadfromtaptalk1400199909389.jpg
Shirls099 likes this.
The Following 10 Users Say Thank You to daafisch For This Useful Post:
bennyzoom (05-17-2014), gmoney542 (05-15-2014), justinsane87 (05-15-2014), RPM (05-15-2014), Saiyanjin2 (05-16-2014), smoogs12 (05-16-2014), thepatient77 (05-15-2014), therza2169 (05-16-2014), yourname2221 (05-15-2014), [R]usty (05-15-2014)
 Old 05-16-2014, 01:39 PM   #385
gmoney542's Avatar
Posts: 236   (View Stats)
gmoney542 is the leader of the worldgmoney542 is the leader of the worldgmoney542 is the leader of the worldgmoney542 is the leader of the worldgmoney542 is the leader of the worldgmoney542 is the leader of the worldgmoney542 is the leader of the worldgmoney542 is the leader of the worldgmoney542 is the leader of the worldgmoney542 is the leader of the worldgmoney542 is the leader of the world
Hopefully some kits ship today!
2009 CWP Mazdaspeed3
- COBB AP V3 - Richtune - 50/50 E85 - Autotech HPFP Internals - CNT Catless Downpipe - HTP 3" Intake - NGK One Step Colder Plugs -
- Kozmic Motorsports EGR Deletes - JBR 88 RMM/TMM/PMM - JBR Shifter Bushings - JBR TIG + Coolant Bypass - JBR OCC -
- JBR RSB - GroundControl Coilovers - CorkSport Camber Plates - CorkSport Rear Camber Arms - CorkSport Rear Toe Arms -
- WhiteLine Front Endlinks - WhiteLine Bumpsteer Kit - WhiteLine Poly LCA Bushings - AWR Rear Endlinks -
- 18x8 Mazdaspeed MS-01S - Nitto NT05 245/40/18 -
gmoney542 is offline   Reply With Quote
 Old 05-16-2014, 01:58 PM   #386
RPM
RPM's Avatar
My sales rep at GC is out today, but I was able to confirm that the KONI shipment arrived at GC. If we get any tracking numbers today, we'll be sure to send them out. Otherwise, I'd expect more kits to start shipping on Monday.
The Following 5 Users Say Thank You to RPM For This Useful Post:
- POD - (05-16-2014), Dumbguy (05-16-2014), gmoney542 (05-16-2014), JDMJOSH (05-16-2014), justinsane87 (05-16-2014)
 Old 05-16-2014, 10:24 PM   #387
jeffdevo's Avatar
I'm running 225s will I need to roll my fenders?
[/I][/SIZE][/FONT]
 Old 05-16-2014, 10:48 PM   #388
gmoney542's Avatar
I'm gonna go ahead and roll mine. I've had my 215s rub in the rear on my stock suspension, though I think mine is much lower than it should be. I have about a one finger gap in the rear.
I'd rather take some time to roll the fenders than have them ruin tires or get pulled out by the tires.
 Old 05-17-2014, 08:56 AM   #389
timmcc02's Avatar
Just received mine last night and install happening now
The Following 5 Users Say Thank You to timmcc02 For This Useful Post:
daafisch (05-17-2014), Dumbguy (05-17-2014), gmoney542 (05-17-2014), JDMJOSH (05-17-2014), thepatient77 (05-17-2014)
 Old 05-17-2014, 09:16 AM   #390
smoogs12's Avatar
Posts: 7,731   (View Stats)
Groans: 423
Something isnt right here.
So you have a completely stock wheel/tire setup and you are rubbing?
You should have much more than a 1 finger gap in the rear.
-Pat
2008 True Red MS3
GT3071R 'n Stuff
SOLD
1999 Jeep XJ
1996 Jeep XJ
1994 Miata
 Old 05-17-2014, 11:25 AM   #391
gmoney542's Avatar
My wheels are 18x8 +40. They stick out an inch more than stock wheels, but I don't think it's a very aggressive fitment.
It hasn't always sat that low. My rear shocks are completely blown, and I don't think the struts are in good shape either. When I got the car it was about 4 finger gap in the front and 3 in the back. Now it's about 2 in the front and 1 in the back.
The Following 2 Users Say Thank You to gmoney542 For This Useful Post:
daafisch (05-17-2014), smoogs12 (05-17-2014)
 Old 05-17-2014, 12:13 PM   #392
smoogs12's Avatar
Groans: 423
Aaaah ok. I saw 215 and assumed stock wheels.
Carry on.
-Pat
2008 True Red MS3
GT3071R 'n Stuff
SOLD
1999 Jeep XJ
1996 Jeep XJ
1994 Miata
 Old 05-17-2014, 01:44 PM   #393
gmoney542's Avatar
What options did you select when ordering and what spring rates did GC send you?
 Old 05-17-2014, 06:11 PM   #394
timmcc02's Avatar
I selected the aggressive/ occasional drag. The rears are stamped 600 but the front have a weird stamping so I am unsure of the front. If you are also installing the corksport camber arms be prepared to be extremely pissed when adjusting them.
The Following User Says Thank You to timmcc02 For This Useful Post:
 Old 05-17-2014, 06:28 PM   #395
Dumbguy's Avatar
That's comforting... I got the corksport camber arms too...
Waiting for install
CS Battery box
 Old 05-17-2014, 06:38 PM   #396
timmcc02's Avatar
Don't get me wrong beautifully designed piece but who fucking uses a 26mm nuts, no one in my shop had a 26mm wrench so I used crescent wrench. I literally had to pull the wheels and disconnect the arms on the alignment rack to adjust it
 Old 05-17-2014, 06:45 PM   #397
gmoney542's Avatar
I got Corksport camber arms too. I'm pretty sure all camber arms that can be adjusted on the car are a pain in the ass though.
The Following User Says Thank You to gmoney542 For This Useful Post:
 Old 05-17-2014, 06:48 PM   #398
timmcc02's Avatar
Ya I'm gonna ask my snap on guy next week if he can get me a thin 26mm wrench just to give it another go on the car
 Old 05-17-2014, 09:29 PM   #399
RPM
RPM's Avatar
Your fronts are 525.
gmoney542 (05-17-2014), timmcc02 (05-17-2014)
 Old 05-17-2014, 09:36 PM   #400
timmcc02's Avatar
Hey good job guys for getting this together. Ground control did an excellent job packaging these and cutting the perches
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f408/gb-ground-control-koni-sport-coilovers-mazdaspeed-167667/
Konisport + ground control setup This thread Refback 04-25-2014 12:49 PM
Konisport + ground control setup This thread Refback 04-20-2014 03:35 AM
Ground control and koni yellows Bap 2010 MS3 - Suspension & Brakes 212 10-20-2016 11:43 AM
Koni Yellows martin_nj MazdaSpeed 3/6 - Suspension & Brakes 50 05-09-2012 10:27 AM
Page generated in 0.59003 seconds with 36 queries
