Like Tree48Likes
 Old 05-18-2014, 04:58 AM   #401
daafisch's Avatar
Posts: 3,553   (View Stats)
Groans: 58
Originally Posted by timmcc02 View Post
I selected the aggressive/ occasional drag. The rears are stamped 600 but the front have a weird stamping so I am unsure of the front. If you are also installing the corksport camber arms be prepared to be extremely pissed when adjusting them.
If the weird "stamping" has a GC in it that means they are GC custom spring rates. They have them on their website.
 Old 05-18-2014, 02:45 PM   #402
timmcc02's Avatar
Posts: 253   (View Stats)
Groaned at 9 Times in 3 Posts
Here's how the car is siting currently
The Following User Says Thank You to timmcc02 For This Useful Post:
gmoney542 (05-18-2014)
 Old 05-18-2014, 03:08 PM   #403
gmoney542's Avatar
Posts: 236   (View Stats)
gmoney542 is the leader of the worldgmoney542 is the leader of the worldgmoney542 is the leader of the worldgmoney542 is the leader of the worldgmoney542 is the leader of the worldgmoney542 is the leader of the worldgmoney542 is the leader of the worldgmoney542 is the leader of the worldgmoney542 is the leader of the worldgmoney542 is the leader of the worldgmoney542 is the leader of the world
Looks great! How do they feel?
2009 CWP Mazdaspeed3
- COBB AP V3 - Richtune - 50/50 E85 - Autotech HPFP Internals - CNT Catless Downpipe - HTP 3" Intake - NGK One Step Colder Plugs -
- Kozmic Motorsports EGR Deletes - JBR 88 RMM/TMM/PMM - JBR Shifter Bushings - JBR TIG + Coolant Bypass - JBR OCC -
- JBR RSB - GroundControl Coilovers - CorkSport Camber Plates - CorkSport Rear Camber Arms - CorkSport Rear Toe Arms -
- WhiteLine Front Endlinks - WhiteLine Bumpsteer Kit - WhiteLine Poly LCA Bushings - AWR Rear Endlinks -
- 18x8 Mazdaspeed MS-01S - Nitto NT05 245/40/18 -
gmoney542 is offline   Reply With Quote
 Old 05-18-2014, 03:19 PM   #404
timmcc02's Avatar
It feels really good actually, I'm gonna put it back on the alignment rack in a couple weeks again to get the specs to where I want them. I have some noise from the rear when going over bumps, thinking it might be the corksport camber arms but I will check it out tomorrow. It could very well be the ground control kit in the rear since there is no rubber isolator piece between the spring and the upper adjustment plate, so it's metal to metal there
 Old 05-20-2014, 06:58 AM   #405
Will fuck up ur day
Chimmike's Avatar
Posts: 6,003   (View Stats)
Groans: 433
So, I got my shipment yesterday. I have a Q:
Anyone with genjuan who got theirs, did GC include instructions for 2010+?
The instructions basically say to remove the bushing/bearings from the top hat leaving only the top hat and the rubber part on the top hat, and the aluminum spring upper perch and the plastic bushing on top of that go straight onto the rubber portion of the top hat, eliminating the bearings. Is this correct? This is the only way I could get it to fit.
I only did the fronts but the improvement is so massive it's taking extra load from the stock rears, lol. However, I do get a clunk on some bumps, though I'm more suspicious that it's my stock front swaybar endlinks more than anything related to the GC's.
@RPM; or anyone else, any thoughts?
Package came EXTREMELY well packaged, suspension components wrapped very nicely. I got photos of the fronts before install, let me upload them.........
07 MS3
The original Genpoo Hater
 Old 05-20-2014, 07:03 AM   #406
Will fuck up ur day
Chimmike's Avatar
Groans: 433
Pic of fronts
07 MS3
 Old 05-20-2014, 07:33 AM   #407
daafisch's Avatar
Groans: 58
Suspension is the same on the Gen2's so it shouldn't matter (well besides the mounting bolt for the rear shocks). The way you attached the upper perch is how I envisioned it working. I'll hopefully get mine installed this Friday and give them a go at autocross on Saturday.
The Following User Says Thank You to daafisch For This Useful Post:
Chimmike (05-20-2014)
 Old 05-20-2014, 07:54 AM   #408
Will fuck up ur day
Chimmike's Avatar
Groans: 433
Definitely stiffer but feels SO much better overall. Firm but supple I guess you could say.
07 MS3
daafisch (05-20-2014)
 Old 05-20-2014, 07:54 AM   #409
jtday's Avatar
Posts: 650   (View Stats)
Thats correct. There was some discussion of that earlier on in this thread too. It should be spring-->GC perch-->GC bearing-->stock top plate.
I'm really interested to what has to be said about the high rear rates and whos running an aftermarket RSB.
2009 MS3 GT
The Following User Says Thank You to jtday For This Useful Post:
 Old 05-20-2014, 07:58 AM   #410
Will fuck up ur day
Chimmike's Avatar
Groans: 433
I'm running aftermarket sways front and rear. I'm going to try to get the rears on tonight depending on how easily the stock lug studs pop out and the new extended ones go in.
I wish I knew what my front spring rates were.
07 MS3
 Old 05-20-2014, 08:05 AM   #411
daafisch's Avatar
Groans: 58
What's stamped on the springs?
 Old 05-20-2014, 08:54 AM   #412
Will fuck up ur day
Chimmike's Avatar
Groans: 433
I'll look later when I re-torque the spacer bolts.
07 MS3
 Old 05-20-2014, 03:24 PM   #413
covelife1016's Avatar
Posts: 151   (View Stats)
covelife1016 has a reputation beyond reputecovelife1016 has a reputation beyond reputecovelife1016 has a reputation beyond reputecovelife1016 has a reputation beyond reputecovelife1016 has a reputation beyond reputecovelife1016 has a reputation beyond reputecovelife1016 has a reputation beyond reputecovelife1016 has a reputation beyond reputecovelife1016 has a reputation beyond reputecovelife1016 has a reputation beyond reputecovelife1016 has a reputation beyond repute
I didn't get a wrench like that with mine. I got something that is the size of my house key and a allen wrench.
2010 MS3 non tech
// CS TMIC// CS battery box// JBR short shifter// JBR 88a rmm// JBR boost tubes// JBR solid shifter bushings// JBR coolant bypass and throttle body tig// Kozmic Motorsports primary and secondary egr delete// NGK one step colder plugs// AT fuel pump internals// HTP 3" intake// GFB bov// COBB accessport V2 // GroundControl springs// Koni yellows//
TUNED BY STRATIFIED
covelife1016 is offline   Reply With Quote
 Old 05-20-2014, 04:08 PM   #414
Raider's Ohio Bottom Bitch
therza2169's Avatar
Posts: 204   (View Stats)
therza2169 is the leader of the worldtherza2169 is the leader of the worldtherza2169 is the leader of the worldtherza2169 is the leader of the worldtherza2169 is the leader of the worldtherza2169 is the leader of the worldtherza2169 is the leader of the worldtherza2169 is the leader of the worldtherza2169 is the leader of the worldtherza2169 is the leader of the worldtherza2169 is the leader of the world
Same thing here. The did a great job packing them up I must say.
therza2169 is offline   Reply With Quote
The Following 2 Users Say Thank You to therza2169 For This Useful Post:
Chimmike (05-20-2014), covelife1016 (05-20-2014)
 Old 05-20-2014, 05:58 PM   #415
Will fuck up ur day
Chimmike's Avatar
Groans: 433
Rears
07 MS3
daafisch (05-20-2014), [R]usty (05-20-2014)
 Old 05-20-2014, 05:59 PM   #416
daafisch's Avatar
Groans: 58
I didn't get a spanner wrench either. Atleast I don't think I did, I only took out 1 front and 1 rear kit.
 Old 05-20-2014, 06:04 PM   #417
smoogs12's Avatar
Posts: 7,731   (View Stats)
Groans: 423
I told them not to give you one.
-Pat
2008 True Red MS3
GT3071R 'n Stuff
SOLD
1999 Jeep XJ
1996 Jeep XJ
1994 Miata
 Old 05-20-2014, 06:06 PM   #418
Will fuck up ur day
Chimmike's Avatar
Groans: 433
I got a spanner. They're in there. The rear springs are SO much shorter than stock, I had to lower the car slowly and line the spring up so it would slide over the upper perch.
Took a quick spin around the block. Haven't really adjusted the ride height yet, but man, the ride is so much more taut. I don't want to say stiff because it's not stiff/rough, but firm, controlled.
07 MS3
Last edited by Chimmike; 05-20-2014 at 06:06 PM. Reason: MSF Database - Automerged Doublepost
 Old 05-20-2014, 06:14 PM   #419
daafisch's Avatar
Groans: 58
Well then I guess I'll just drink this Nugget Nectar I've been holding for you.
smoogs12 likes this.
 Old 05-20-2014, 07:32 PM   #420
gmoney542's Avatar
@RPM; have anymore kits shipped yet?
 Old 05-20-2014, 09:37 PM   #421
therza2169's Avatar
Was your spanner bubble wrapped in with one of the springs or struts, or separately in the box? I pulled everything out of the box and no wrench. If you're was packed inside he bubble wrap of the kits I'll pull each piece out tomorrow and check there. Was hoping to keep them protected till install lol.
 Old 05-21-2014, 04:02 AM   #422
[QUOTE=therza2169;2590138]Was your spanner bubble wrapped in with one of the springs or struts, or separately in the box? I pulled everything out of the box and no wrench. If you're was packed inside he bubble wrap of the kits I'll pull each piece out tomorrow and check there. Was hoping to keep them protected till install lol.[/QUOTE
I just unwrapped all of mine and still didn't find a wrench. Maybe only the genjuans got them.
2010 MS3 non tech
TUNED BY STRATIFIED
 Old 05-21-2014, 05:17 AM   #423
Dumbguy's Avatar
Posts: 130   (View Stats)
Dumbguy has a reputation beyond reputeDumbguy has a reputation beyond reputeDumbguy has a reputation beyond reputeDumbguy has a reputation beyond reputeDumbguy has a reputation beyond reputeDumbguy has a reputation beyond reputeDumbguy has a reputation beyond reputeDumbguy has a reputation beyond reputeDumbguy has a reputation beyond reputeDumbguy has a reputation beyond reputeDumbguy has a reputation beyond repute
I got shipping notification this morning. Being at the end of the list, hopefully almost everyone else's has been sent or is getting ready to be sent. Amped!
2012 VRM Mazdaspeed 3 - “Claudia”
Cobb v3 AP | Autotech HPFP Internals | UR Catback | Cp-e TMIC | Cp-e Stage 2 RMM | Cp-e Catted DP | TWM Full Replacement | CS Occ | CS Bpv | CS Hood Struts | JBR EGR delete | JBR Boost tubes and Recirc hose | HTP 3.5” Intake | 1 Step colder plugs | Blox 490 | BC Coilovers | Drag dr-49
Waiting for install
CS Battery box
2008 Black Mica Mazdaspeed 3 - "April" (Totaled, may she rest in piece)
Dumbguy is offline   Reply With Quote
 Old 05-21-2014, 06:15 AM   #424
thepatient77's Avatar
Posts: 162   (View Stats)
thepatient77 has a reputation beyond reputethepatient77 has a reputation beyond reputethepatient77 has a reputation beyond reputethepatient77 has a reputation beyond reputethepatient77 has a reputation beyond reputethepatient77 has a reputation beyond reputethepatient77 has a reputation beyond reputethepatient77 has a reputation beyond reputethepatient77 has a reputation beyond reputethepatient77 has a reputation beyond reputethepatient77 has a reputation beyond repute
Hopefully mine ships this week! I'm getting antsy after seeing everyone receive theirs!
thepatient77 is offline   Reply With Quote
 Old 05-21-2014, 06:33 AM   #425
Will fuck up ur day
Chimmike's Avatar
Groans: 433
So, this isn't a GC issue, but I'm not at all impressed with how the rear struts are "adjusted". Seems gimmicky.........press the strut down into the body and twist one direction or the other? Really?
07 MS3
 Old 05-21-2014, 06:38 AM   #426
alextheguineapig's Avatar
Posts: 827   (View Stats)
Yeah its a pain in the ass, I've considered selling my swift/koni set up for a coilover kit eventually.
Current
SOLD!
2008 Sunlight Silver MS3:
BNR: S3 V2
Cobb: V3 AccessPort
Damond Motorsports: RMM
Eibach: Prokit
JBR: Rear Sway Bar
Koni: Yellows
MAC: 3-Port EBCS
 Old 05-21-2014, 06:44 AM   #427
daafisch's Avatar
Groans: 58
Yeah, it's a little annoying. I usually just leave the rears on the stiffer side.
 Old 05-21-2014, 06:58 AM   #428
JDMJOSH's Avatar
Posts: 642   (View Stats)
JDMJOSH is the leader of the worldJDMJOSH is the leader of the worldJDMJOSH is the leader of the worldJDMJOSH is the leader of the worldJDMJOSH is the leader of the worldJDMJOSH is the leader of the worldJDMJOSH is the leader of the worldJDMJOSH is the leader of the worldJDMJOSH is the leader of the worldJDMJOSH is the leader of the worldJDMJOSH is the leader of the world
Groaned at 8 Times in 5 Posts
Question
Still waiting on my shipping notification, I was #17 . Hopefully it goes out today!
JBR 3.0" WP // CS Racepipe // UR CBE // CS TMIC // CS SS Plate + Bushings // Autotechs // NGK's // Damond Oil Restrictor Bolt // Forge v2 // JBR RMM 88 // JBR .250 RSB // CS Springs/Struts // SPC Camber Arms //
JDMJOSH is offline   Reply With Quote
 Old 05-21-2014, 08:29 AM   #429
Will fuck up ur day
Chimmike's Avatar
Groans: 433
I think I'll pull 'em tomorrow at home and stiffen 'em up a bit. I'm not sold on how they stiffen cuz it seems like there's no "stop" at either end.
07 MS3
 Old 05-21-2014, 08:46 AM   #430
gmoney542's Avatar
I believe I was #11 and I'm still waiting. Hopefully today is the day!
 Old 05-21-2014, 08:52 AM   #431
daafisch's Avatar
Groans: 58
If you have them compressed all the way there is a stop. Should be about 2.5 full turns.
 Old 05-21-2014, 09:22 AM   #432
Will fuck up ur day
Chimmike's Avatar
Groans: 433
you have to compress the bastards all the way to adjust them?
damn.
07 MS3
 Old 05-21-2014, 09:37 AM   #433
daafisch's Avatar
Groans: 58
damn.
yes. That's why I normally just leave them on the stiffer side.
I thought GC was presetting the rebound for you guys?
 Old 05-21-2014, 10:53 AM   #434
RPM
RPM's Avatar
Posts: 1,149   (View Stats)
You did? I didn't send any out. Maybe it was something else?
Just FYI, GC is still moving slow on this, but I'm about to escalate the issue above my sales rep because I don't feel like GC has been very straightforward with us and that's not fair to you guys.
Chimmike and Shirls099 like this.
The Following 5 Users Say Thank You to RPM For This Useful Post:
Chimmike (05-21-2014), daafisch (05-21-2014), gmoney542 (05-21-2014), JDMJOSH (05-21-2014), justinsane87 (05-21-2014)
 Old 05-21-2014, 11:01 AM   #435
Will fuck up ur day
Chimmike's Avatar
Groans: 433
yeah, but I feel like maybe i'm getting some jounce. not sure how the rears are adjusted.
07 MS3
 Old 05-21-2014, 11:38 AM   #436
You press the shocks down and rotate it. It will stop at some point when moving to firm or soft. The end of the shock that bolts onto the top hat has to be held with a bench vice or vice grip so it doesn't rotate when you adjust them. I'm having a similar issue with my swift/koni set up. For awhile it was fine, but over harsh bumps I have noticed the rear becoming unsettled now that I have stickier rubber. I really don't want to soften mine anymore because I think it'll be too soft.
Edit: You could be talking about how they are adjusted by GC, in that case just ignore me D:
Current
SOLD!
BNR: S3 V2
Cobb: V3 AccessPort
Eibach: Prokit
JBR: Rear Sway Bar
Koni: Yellows
MAC: 3-Port EBCS
The Following User Says Thank You to alextheguineapig For This Useful Post:
 Old 05-21-2014, 11:43 AM   #437
Dumbguy's Avatar
Goddamnit… I saw the email and instantly thought “Hooray for sex! Coilovers for me!” and didn’t even think about what I had just ordered as I ordered a few things from a few places… Another example of keying before thinking… I’m an idiot… Sorry. I’m going back to my corner now.
Waiting for install
CS Battery box
The Following User Says Thank You to Dumbguy For This Useful Post:
 Old 05-21-2014, 03:33 PM   #438
Will fuck up ur day
Chimmike's Avatar
Groans: 433
man. I'm sure it's just shitty 275 in st. Petersburg, but it feels like I've got some bounce going on with some of these weird dips and stuff.
gonna tighten up the rear shocks tomorrow, but I wonder if it's oversprung/underdamped? hmm. almost feels like maybe brief porpoising
Oh and I'm clanks up front on like normal little bumps. OEM sway endlinks possible? Since I hz aftermarket swaybar
07 MS3
 Old 05-21-2014, 03:47 PM   #439
RPM
RPM's Avatar
GC told us 3 kits would ship today. I know it take them 45 mins to an hour to do each kit, but I'm going to continue to press them to get 2-3 out each day. I don't think that's too much to ask. Wish me luck!
Chimmike (05-21-2014), Dimenus (05-21-2014), Dumbguy (05-21-2014), gmoney542 (05-21-2014), justinsane87 (05-21-2014)
 Old 05-21-2014, 04:01 PM   #440
gmoney542's Avatar
Thank you so much, and good luck!
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f408/gb-ground-control-koni-sport-coilovers-mazdaspeed-167667/
Konisport + ground control setup This thread Refback 04-25-2014 12:49 PM
Konisport + ground control setup This thread Refback 04-20-2014 03:35 AM
Ground control and koni yellows Bap 2010 MS3 - Suspension & Brakes 212 10-20-2016 11:43 AM
Koni Yellows martin_nj MazdaSpeed 3/6 - Suspension & Brakes 50 05-09-2012 10:27 AM
Page generated in 0.58311 seconds with 33 queries
