Like Tree48Likes
 Old 06-23-2014, 05:30 PM   #681
- POD -'s Avatar
Posts: 619   (View Stats)
- POD - is the leader of the world- POD - is the leader of the world- POD - is the leader of the world- POD - is the leader of the world- POD - is the leader of the world- POD - is the leader of the world- POD - is the leader of the world- POD - is the leader of the world- POD - is the leader of the world- POD - is the leader of the world- POD - is the leader of the world
Originally Posted by justinsane87 View Post
Guess I'm buying a rsb now lol, was planning on it eventually anyways
Sounds like it'd make a great group buy. Maybe RPM can team up with JBR.
Sent from my SGH-I747M using Tapatalk
2012 MS3 SOLD, living in the world of Right Wheel Drive now
Ol' BMO had: Autotech Internals, CS SRI+TIP, CS Short Shift Plate, CS BPV, CS TMIC, UR Catback, CP-e Stage 2 RMM, COBB AP v3.0, UR Test Pipe, JBR Weighted Shift Knob, DM OCC Kit, Koni Yellows+GC springs
- POD - is offline   Reply With Quote
 Old 06-23-2014, 05:34 PM   #682
[R]usty's Avatar
Posts: 2,204   (View Stats)
You should have bought it before upgrading your suspension, totally changes how this car handles. I would recommend JBR.
2010 Mazdaspeed3 w/tech
justinsane87 (06-23-2014)
 Old 06-23-2014, 05:37 PM   #683
justinsane87's Avatar
Posts: 877   (View Stats)
justinsane87 is the leader of the worldjustinsane87 is the leader of the worldjustinsane87 is the leader of the worldjustinsane87 is the leader of the worldjustinsane87 is the leader of the worldjustinsane87 is the leader of the worldjustinsane87 is the leader of the worldjustinsane87 is the leader of the worldjustinsane87 is the leader of the worldjustinsane87 is the leader of the worldjustinsane87 is the leader of the world
I was planning on a rsb first later on this year, but this gb came up and thought it may have been to good to pass on
2013 Mazdaspeed 3 - GTX3076R EWG
Autotechs - FreekBuilt 3.5" - UR Catless Turbo-back - AP V3 - ETS TMIC
JBR 80D Trilogy/SSP/Bushings/Heavy Knob/TIGs/0.250 RSB - GFB BOV
FreekTune'd - DO DVC-30 - Ground Control w/Koni Yellows - DM OCC
Enkei RPF1 17x9 w/ PSS 235/45/17 - Full Race Exhaust Mani
justinsane87 is offline   Reply With Quote
 Old 06-23-2014, 06:39 PM   #684
daafisch's Avatar
Posts: 3,553   (View Stats)
Groans: 58
Originally Posted by timmcc02 View Post
It was only one car and he probably has his control arm bolts loose. my spring doesnt fall out when lifted. so unless he dukes of hazards his car on a rally course i cant see how this is possible. He should call GC and find out what they recommend.
This. The roads are awful in that area but there is no reason the car should be in the air unless the driver is going way to fast for the roads.
The Following User Says Thank You to daafisch For This Useful Post:
461_SS (06-23-2014)
 Old 06-23-2014, 07:01 PM   #685
461_SS's Avatar
Posts: 1,160   (View Stats)
461_SS is the leader of the world461_SS is the leader of the world461_SS is the leader of the world461_SS is the leader of the world461_SS is the leader of the world461_SS is the leader of the world461_SS is the leader of the world461_SS is the leader of the world461_SS is the leader of the world461_SS is the leader of the world461_SS is the leader of the world
You don't need an aftermarket RSB.... Honestly a RSB is just a "fine tuning" device, not a band-aid. Shocks and Springs are numero uno!
461_SS is offline   Reply With Quote
The Following 5 Users Say Thank You to 461_SS For This Useful Post:
Crarrs (06-23-2014), daafisch (06-23-2014), Helrich (06-23-2014), Nliiitend1 (07-29-2014), phate (06-23-2014)
 Old 06-23-2014, 07:42 PM   #686
thepatient77's Avatar
Posts: 162   (View Stats)
thepatient77 has a reputation beyond reputethepatient77 has a reputation beyond reputethepatient77 has a reputation beyond reputethepatient77 has a reputation beyond reputethepatient77 has a reputation beyond reputethepatient77 has a reputation beyond reputethepatient77 has a reputation beyond reputethepatient77 has a reputation beyond reputethepatient77 has a reputation beyond reputethepatient77 has a reputation beyond reputethepatient77 has a reputation beyond repute
Ive had these on for about 2 weeks with no problems whatsoever. I picked dd/aggresive. I have a JBR rsb on as well. I'm really not sure how people are having the springs pop out at stock height (Would GC sell these with a problem like that). I rode stock height the first 2 days. After that I adjusted them and have about a 2ish-3 finger wheel gap now. Jacking up the car and adjusting them my spring came loose a bit but, not enough to even come close to coming off. I will go try it again and let y'all know. I came from cs springs and wow what a difference this set up makes. Sucks some of y'all are having these issues.
thepatient77 is offline   Reply With Quote
The Following 3 Users Say Thank You to thepatient77 For This Useful Post:
461_SS (06-23-2014), daafisch (06-23-2014), justinsane87 (06-23-2014)
 Old 06-23-2014, 07:52 PM   #687
daafisch's Avatar
Groans: 58
I got occasional autox/race. If I did my maths correctly I have about 1.2 inches from tire to fender. I only measured the distance from rim to fender and that was 13.5cm. I run 235/45r17's which the internet tells me have a 10.5cm sidewall.
I came from Swift springs and used my existing koni shocks. The ride is stiffer for sure but the car feels very stable. The ride only gets very bouncy on consecutive dips in the road. Quick bumps feel fine. The car felt a lot better at autox this past weekend and I still don't have everything aligned correctly, waiting on new tires for that (just ordered RS3 V2's today ).
phate (06-23-2014)
 Old 06-23-2014, 10:45 PM   #688
RPM
RPM's Avatar
Posts: 1,149   (View Stats)
GC is in touch with the owner bennyzoom to try to find out what happened. They did a lot of research when putting the kit together, so it doesn't seem like this is something that would be overlooked. Donovan from GC said he would make an account here to address any concerns, so you should see him here in the coming days.
The Following 8 Users Say Thank You to RPM For This Useful Post:
- POD - (06-24-2014), daafisch (06-24-2014), Dimenus (06-24-2014), Jdraps13 (06-23-2014), Mattyhawk1 (06-24-2014), monkey.bones.007 (06-23-2014), thepatient77 (06-23-2014), [R]usty (06-23-2014)
 Old 06-24-2014, 03:27 PM   #689
Will fuck up ur day
Chimmike's Avatar
Posts: 6,003   (View Stats)
Groans: 433
yeah. After finally putting new endlinks on the front says (the M3 endlinks), I don't get the annoying rattle I had up front, but when I hit a nasty bump, the R front has a solid "CLUNK" that I can almost feel. No idea what it is. These suspension rattles/clunks didn't happen until I put the GC's on. Aftermarket front sway (whiteline). I've driven up on ramps and just can't tell what it may be. Kinda at my wit's end with it.
07 MS3
The original Genpoo Hater
 Old 06-24-2014, 08:06 PM   #690
461_SS's Avatar
Are the M3 endlinks adjustable?
 Old 06-24-2014, 08:26 PM   #691
daafisch's Avatar
Groans: 58
I believe they are just shorter. A lot of the guys that run MS/KW coils use them since the endlink bracket is lower on the strut.
 Old 06-24-2014, 09:54 PM   #692
Jdraps13's Avatar
Posts: 703   (View Stats)
Jdraps13 is the leader of the worldJdraps13 is the leader of the worldJdraps13 is the leader of the worldJdraps13 is the leader of the worldJdraps13 is the leader of the worldJdraps13 is the leader of the worldJdraps13 is the leader of the worldJdraps13 is the leader of the worldJdraps13 is the leader of the worldJdraps13 is the leader of the worldJdraps13 is the leader of the world
Groaned at 18 Times in 5 Posts
Anyone get their tracking numbers today?
Jdraps13 is offline   Reply With Quote
 Old 06-25-2014, 12:54 AM   #693
RPM
RPM's Avatar
I sent them to everyone. International orders will come to RPM first, though, so those will ship in a few days.
Jdraps13 (06-25-2014)
 Old 06-25-2014, 10:06 AM   #694
Dimenus's Avatar
Posts: 2,825   (View Stats)
Groans: 33
Anybody with the 525/600 springs have their setup dialed in?
I'm at a half turn stiffer from whatever they came from GC (both front and back) and it feels very good.
2012 Velocity Red Mica
The Following User Says Thank You to Dimenus For This Useful Post:
nybe0010 (08-04-2014)
 Old 06-25-2014, 10:10 AM   #695
Bap
Bap's Avatar
Posts: 248   (View Stats)
Bap is the leader of the worldBap is the leader of the worldBap is the leader of the worldBap is the leader of the worldBap is the leader of the worldBap is the leader of the worldBap is the leader of the worldBap is the leader of the worldBap is the leader of the worldBap is the leader of the worldBap is the leader of the world
I have had an issue in the past of GC in the rear coming unseated when put on a lift. It is the one annoying thing about the kit is that if you don't pay attention when the shop puts your car on the ground sometimes the springs do not seat correctly. I am guessing but that is probably what happened is the springs did not seat correctly when the car was put on the ground. I have GC on my FIT for 7 years now and their is even more of drop with the rear suspension and the springs because of the way the fit is designed. I have never had a spring pop out but I have had to ask shops can you jack my car back up the rear springs did not seat correctly when you put the car down. I usually go and do it my self to make sure they have actually seated. Yes their are some horrible roads around here have gone through two sets of rims on that car because of the horrible roads and never had that issue. For the person that had that issue that is a truly horrible experience, and if that happened to me I would be very uncomfortable about the suspension. I am only sharing my experience with GC and insight for those with the kit as for something to watch out for.
Bap is offline   Reply With Quote
The Following User Says Thank You to Bap For This Useful Post:
 Old 06-25-2014, 11:30 AM   #696
timmcc02's Avatar
Posts: 253   (View Stats)
Groaned at 9 Times in 3 Posts
[QUOTE=Dimenus;2628801]Anybody with the 525/600 springs have their setup dialed in?
I'm at a half turn stiffer from whatever they came from GC (both front and back) and it feels very good.[/QUOTE
I have this same setup but mine are not exactly dialed in. I havent adjusted them since they came from GC. My rear is a bit bouncy, the front feels good though
 Old 06-25-2014, 03:41 PM   #697
Will fuck up ur day
Chimmike's Avatar
Groans: 433
This. I might need adjustable ones that go even shorter.
07 MS3
 Old 06-27-2014, 08:51 AM   #698
Ewind's Avatar
Posts: 235   (View Stats)
Ewind has a reputation beyond reputeEwind has a reputation beyond reputeEwind has a reputation beyond reputeEwind has a reputation beyond reputeEwind has a reputation beyond reputeEwind has a reputation beyond reputeEwind has a reputation beyond reputeEwind has a reputation beyond reputeEwind has a reputation beyond reputeEwind has a reputation beyond reputeEwind has a reputation beyond repute
Groaned at 6 Times in 4 Posts
still waiting!!
Ewind is offline   Reply With Quote
 Old 06-27-2014, 08:52 AM   #699
Jdraps13's Avatar
Originally Posted by Ewind View Post
still waiting!!
me too man
 Old 06-28-2014, 08:14 AM   #700
moonrider_99's Avatar
Posts: 185   (View Stats)
moonrider_99 has a reputation beyond reputemoonrider_99 has a reputation beyond reputemoonrider_99 has a reputation beyond reputemoonrider_99 has a reputation beyond reputemoonrider_99 has a reputation beyond reputemoonrider_99 has a reputation beyond reputemoonrider_99 has a reputation beyond reputemoonrider_99 has a reputation beyond reputemoonrider_99 has a reputation beyond reputemoonrider_99 has a reputation beyond reputemoonrider_99 has a reputation beyond repute
Groaned at 46 Times in 14 Posts
<crickets >
2017 Ford Focus RS - Stock
2004 MSM
- AEM Intake - BEGI - FM Turboback - Turbosmart BPV - Hallman Boost Controller - ...
"I'm a Turbo addict, I know."
SCCA Philadelphia: (http://www.phillyscca.com/solo/)
2012 MS3 Silver w/ Tech Package - sold in '17
2009 WRX Stage 2- sold in '12
moonrider_99 is offline   Reply With Quote
 Old 06-28-2014, 09:59 AM   #701
RPM
RPM's Avatar
still waiting!!
You guys are the last 2 and your kits will be shipping from RPM on Monday or Tuesday, so you'll have them by the end of the week!
Ewind (06-29-2014), Jdraps13 (06-28-2014)
 Old 07-01-2014, 09:35 AM   #702
Dimenus's Avatar
Groans: 33
Anybody on less than 525/600 springs? I'm very happy with this kit but I've never owned this level of performance suspension. The kit feels well dampened but you can definitely feel every bump.
 Old 07-01-2014, 11:25 AM   #703
RPM
RPM's Avatar
With the setup you have, you should be able to feel the road very well, but everything should still be properly damped. Welcome to the world of performance suspension!
 Old 07-01-2014, 11:31 AM   #704
Jdraps13's Avatar
last kits shipping today?
 Old 07-01-2014, 11:44 AM   #705
RPM
RPM's Avatar
Yes, they are! We'll send you tracking a little later and you'll have the kits by the end of the week!
Jdraps13 (07-01-2014)
 Old 07-01-2014, 11:53 AM   #706
RPM
RPM's Avatar
Also, in order to completely eliminate the possibility of an unseated spring, GC has made new spring cups for the rear adjuster that will ensure that it's impossible to happen.
They will be sending these to every customer who has purchased a kit.
The Following 14 Users Say Thank You to RPM For This Useful Post:
Crarrs (07-01-2014), daafisch (07-01-2014), Dimenus (07-01-2014), gmoney542 (07-02-2014), jack_hammer (07-01-2014), JDMJOSH (07-01-2014), Jdraps13 (07-01-2014), justinsane87 (07-01-2014), Mattyhawk1 (07-09-2014), monkey.bones.007 (07-01-2014), nybe0010 (07-01-2014), thepatient77 (07-01-2014), timmcc02 (07-01-2014), [R]usty (07-01-2014)
 Old 07-01-2014, 11:59 AM   #707
[R]usty's Avatar
Ground control FTW! Awesome!
 Old 07-01-2014, 12:00 PM   #708
Dimenus's Avatar
Groans: 33
Awesome. Thanks @RPM;
And my only issue might be with large bumps / dips in the road. Though I think there's only so much you can do with stiff springs. Anyone else care to chime in?
 Old 07-01-2014, 02:47 PM   #709
Jdraps13's Avatar
Tracking number hell yeah
 Old 07-01-2014, 03:08 PM   #710
Saiyanjin2's Avatar
Posts: 20   (View Stats)
Saiyanjin2 is a jewel in the roughSaiyanjin2 is a jewel in the roughSaiyanjin2 is a jewel in the rough
When can we expect this spring cup? will they be automatically sent out, or do we need to ask for them?
Saiyanjin2 is offline   Reply With Quote
The Following User Says Thank You to Saiyanjin2 For This Useful Post:
 Old 07-01-2014, 03:28 PM   #711
RPM
RPM's Avatar
They're in production and they'll be automatically shipped out when they're done. I believe they should start shipping next week.
Dimenus (07-01-2014), Saiyanjin2 (07-02-2014)
 Old 07-01-2014, 03:50 PM   #712
RPM
RPM's Avatar
Correction, direct from GC: "We will be sending these out in a couple of weeks when they come in from our machine shop."
The Following 3 Users Say Thank You to RPM For This Useful Post:
daafisch (07-01-2014), Jdraps13 (07-01-2014), timmcc02 (07-01-2014)
 Old 07-02-2014, 12:00 PM   #713
Saiyanjin2's Avatar
If I get the corksport camber plates would I still need to use the stock top hats from the car?
 Old 07-02-2014, 01:33 PM   #714
daafisch's Avatar
Groans: 58
no
 Old 07-03-2014, 02:56 PM   #715
[R]usty's Avatar
I called ground control today about camber plates. They said they will be released soon but would not give me anymore details. If anyone is looking I would hold off as I'd assume their plates are going to be pretty great.
The Following 2 Users Say Thank You to [R]usty For This Useful Post:
daafisch (07-08-2014), Jdraps13 (07-03-2014)
 Old 07-03-2014, 05:22 PM   #716
Originally Posted by JDMJOSH View Post
Anybody know what kind of nut we need for holding the top hat onto the shock? I know its 17mm but that isn't working, unless they are referring to the thread size?
You doing yours already?
 Old 07-03-2014, 05:23 PM   #717
JDMJOSH's Avatar
Posts: 642   (View Stats)
JDMJOSH is the leader of the worldJDMJOSH is the leader of the worldJDMJOSH is the leader of the worldJDMJOSH is the leader of the worldJDMJOSH is the leader of the worldJDMJOSH is the leader of the worldJDMJOSH is the leader of the worldJDMJOSH is the leader of the worldJDMJOSH is the leader of the worldJDMJOSH is the leader of the worldJDMJOSH is the leader of the world
Groaned at 8 Times in 5 Posts
No, just wanted to be ready.
JBR 3.0" WP // CS Racepipe // UR CBE // CS TMIC // CS SS Plate + Bushings // Autotechs // NGK's // Damond Oil Restrictor Bolt // Forge v2 // JBR RMM 88 // JBR .250 RSB // CS Springs/Struts // SPC Camber Arms //
JDMJOSH is offline   Reply With Quote
The Following User Says Thank You to JDMJOSH For This Useful Post:
justinsane87 (07-03-2014)
 Old 07-08-2014, 02:08 PM   #718
Ewind's Avatar
Just wanted to say thanks to RPM and ground control.
Got and installed my kit and I really enjoy them. Can't wait until my ride height and shocks are adjusted to my liking
 Old 07-08-2014, 02:12 PM   #719
daafisch's Avatar
Groans: 58
Damn it, they always say soon. A local has a set of CS plates he is offering me at a good price but I've been trying to hold out for these.
 Old 07-08-2014, 03:14 PM   #720
461_SS's Avatar
Buy 'em! unless the GC will allow you to adjust caster as well. You already know what I think though haha.
The Following User Says Thank You to 461_SS For This Useful Post:
aforst (07-11-2014)
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f408/gb-ground-control-koni-sport-coilovers-mazdaspeed-167667/
Konisport + ground control setup This thread Refback 04-25-2014 12:49 PM
Konisport + ground control setup This thread Refback 04-20-2014 03:35 AM
Ground control and koni yellows Bap 2010 MS3 - Suspension & Brakes 212 10-20-2016 11:43 AM
Koni Yellows martin_nj MazdaSpeed 3/6 - Suspension & Brakes 50 05-09-2012 10:27 AM
Page generated in 0.58336 seconds with 36 queries
