| Revolution Performance Motorsports Revolution Performance Manufacturing (RPM) was started by three Mazda 6 enthusiasts in early 2004 under a simple premise: to develop and manufacture new products for the Mazda 6 at an affordable price. We began to realize our purpose with the short throw shifter and gas hood lifter kits for that vehicle. Since then, we have added many new aftermarket products from well-known manufacturers and continue to expand to offer products for other vehicles with the goal of having the best prices and customer service on the 'net. |
![]() | | #721 | ![]() |
![]() Join Date: Jul 2013 Location: Lancaster, PA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 42
| Not Ranked : 0 score
__________________ 2016 MX-5 Club 2012 MS3 -- RIP in peace |
![]() | | #722 | ![]() |
![]() Join Date: Apr 2009 Location: Danbury, CT
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,851
Groans: 58
| Not Ranked : 0 score |
![]() | | #723 | ![]() |
Groans: 433
| Not Ranked : 0 score Excellent! Looking forward to getting those spring cups. So frustrated with this front end clunking that I'm [] that close to fucking yanking my front sway bar. The E36 endlinks didn't work.
![]() | | #724 | ![]() |
Groans: 58
But I had it before the spring install. I replaced both front and rear bushings, endlinks are next. | |
![]() | | #725 | ![]() |
![]() Join Date: Nov 2012 Location: Milwaukee, WI
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,192
Groans: 33
| Not Ranked : 0 score No clunk here but I had a nasty interior vibe that turned out to be my right front knuckle loosening up after an AutoX run. How can you tell how firm or stiff the rears are with them off the car? They don't have defined adjustment points like the fronts
__________________ 2012 Velocity Red Mica Fast: COBB AP | Autotechs | JBR 3'' WP | CS DP | CS ABE | MDM RMM | JBR RSB | NGK Plugs | JBR SSP | ETS TMIC Rice: Aeroforce Interceptor | AEM M 35psi | Konig Milligrams 18x8.5 + 35 | Z1 Star Specs | JBR Mudflaps ![]() |
![]() | | #726 | ![]() |
![]() Join Date: Apr 2014 Location: Cold lake / Edmonton AB
Groaned at 18 Times in 5 Posts
| Not Ranked : 0 score Got er all buttoned up tonight super happy with the fitment 1 finger gap no roll no rubbing 18x8 +42 235 28 |
| The Following User Says Thank You to Jdraps13 For This Useful Post: | thepatient77 (07-10-2014) |
![]() | | #727 | ![]() |
Groans: 58
| Not Ranked : 0 score If you're adjusting them correctly there are stops for full soft and full stiff. Make sure the piston is compressed completely before spinning the body of the shock. |
| The Following User Says Thank You to daafisch For This Useful Post: | Dimenus (07-10-2014) |
![]() | | #728 | ![]() |
![]() Join Date: Jan 2011 Location: Grapevine, TX
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 242
| Not Ranked : 0 score looks good man. I'll have to snap a photo of mine. As for any problems with this suspension, I've had none. I've had them on for about a month meow and so far so good. I just need to dial in the rear.... maybe a little stiffer and i should be good. |
![]() | | #729 | ![]() |
![]() Join Date: Nov 2010 Location: Edmonton, Alberta, Canada
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 17
Groaned at 6 Times in 4 Posts
| Not Ranked : 0 score I ended up with 525F and 600R Ran with GC settings for a couple of days and didn't like it played with the adjustments in F and R. Front shocks go almost 2.5 revolutions from full soft. More like 2.25. Rears shocks max is 2 revolutions from foll soft I have my F set at 1.25 revolutions from full soft. I have my R set at 1.25 revolutions from full soft. Won't be changing it for street anymore. I like it exactly where it is. |
![]() | | #730 | ![]() |
Groans: 433
| Not Ranked : 0 score yah I saw my sway bar was contacting the frame so I ground/cut away some parts and will see if that helps. Otherwise, I can't figure out where the normal clunking is coming from to save my life. I'm gonna have to check my side motor mounts.....but that doesn't make any sense or I'd get clunks during shifts and engine loading.
![]() | | #731 | ![]() |
![]() Join Date: Mar 2012 Location: Edmonton
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 247
Groaned at 8 Times in 5 Posts
| Not Ranked : 0 score Don't be and just install it. This kit is perfectly safe even without the spring cups at stock height. Just make sure the springs are seated properly when you lower the car and your golden
__________________ JBR 3.0" WP // CS Racepipe // UR CBE // CS TMIC // CS SS Plate + Bushings // Autotechs // NGK's // Damond Oil Restrictor Bolt // Forge v2 // JBR RMM 88 // JBR .250 RSB // CS Springs/Struts // SPC Camber Arms // |
![]() | | #732 | ![]() |
Groans: 33
__________________ 2012 Velocity Red Mica Fast: COBB AP | Autotechs | JBR 3'' WP | CS DP | CS ABE | MDM RMM | JBR RSB | NGK Plugs | JBR SSP | ETS TMIC Rice: Aeroforce Interceptor | AEM M 35psi | Konig Milligrams 18x8.5 + 35 | Z1 Star Specs | JBR Mudflaps ![]() | |
![]() | | #733 | ![]() |
![]() | | #734 | ![]() |
| Not Ranked : 0 score Just installed my kit yesterday, same springs as you; 525F 600R. I'm finding its a little "bouncy" for my liking. Going to give everything a week or so to settle and then try your settings and see what happens.
| The Following User Says Thank You to JDMJOSH For This Useful Post: | nybe0010 (08-04-2014) |
![]() | | #735 | ![]() |
![]() Join Date: Apr 2013 Location: Edmonton, Alberta, Canada
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 300
| Not Ranked : 0 score Im in the same boat as well. At city speeds it's fine. Dips in the highway are too bouncy.
__________________ 2012 MS3 SOLD, living in the world of Right Wheel Drive now Ol' BMO had: Autotech Internals, CS SRI+TIP, CS Short Shift Plate, CS BPV, CS TMIC, UR Catback, CP-e Stage 2 RMM, COBB AP v3.0, UR Test Pipe, JBR Weighted Shift Knob, DM OCC Kit, Koni Yellows+GC springs |
![]() | | #736 | ![]() |
| Not Ranked : 0 score So I'm installing mine, fronts are in, but for the rears, it says to re-use the stock bolt and washer to fasten the collar that goes on top of the rear spring. Well that bolt and washer doesn't fit through the collar. Did I perhaps get the wrong rears? I don't mind drilling that hole in the collar out but wanted to make sure I'm approaching this correctly.
![]() | | #737 | ![]() |
![]() | | #738 | ![]() |
| Not Ranked : 0 score Alright. Just weird I guess that you have to do that for a kit ordered for a specific car. I'm gonna have to grind the washers down a bit too to get them to fit inside.
![]() | | #739 | ![]() |
| Not Ranked : 0 score For what it's worth. The rears on mine did not require any drilling or grinding.
![]() | | #740 | ![]() |
![]() Join Date: Nov 2010 Location: SoCal
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 35
Groaned at 9 Times in 3 Posts
![]() | | #741 | ![]() |
| Not Ranked : 0 score Hrm. Well then maybe I'll give GC a call tomorrow when they're open. I also noticed one of the silicone/rubber rings that go on the bottom of the rear springs has a hole in it, so the spring could touch the bottom steel ring when compressed. Not too worried about that though. Put the stock rears back on for now.
![]() | | #742 | ![]() |
| Not Ranked : 0 score Seems like there was more than a few QC issues with this kit. My fronts were missing the nuts that hold the top hat on but that was no biggie.
![]() | | #743 | ![]() |
| Not Ranked : 0 score I called GC, the guy I talked to said there were two or three kits out of a 200 kit batch that didn't have large enough holes. Not sure why they sent them out anyway but oh well! He said he thinks a 12mm drill bit out to bore that hole out enough, but mine are half an inch ID (12.7mm) and obviously isn't enough so perhaps 14mm. I also noted earlier about the bottom rubber gasket being malformed, looks like they scraped it away on purpose to sit flush with the welds on the steel ring. I do still have full-fledged holes in mine but I doubt it will cause any issues. Of course now that I've said that...
| The Following User Says Thank You to Helrich For This Useful Post: | Jdraps13 (07-21-2014) |
![]() | | #744 | ![]() |
![]() Join Date: Oct 2013 Location: Edmonton, AB
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 814
| Not Ranked : 0 score @RPM; updates on those cups?
__________________ 2013 Mazdaspeed 3 - GTX3076R EWG Autotechs - FreekBuilt 3.5" - UR Catless Turbo-back - AP V3 - ETS TMIC JBR 80D Trilogy/SSP/Bushings/Heavy Knob/TIGs/0.250 RSB - GFB BOV FreekTune'd - DO DVC-30 - Ground Control w/Koni Yellows - DM OCC Enkei RPF1 17x9 w/ PSS 235/45/17 - Full Race Exhaust Mani |
![]() | | #745 | ![]() |
| Not Ranked : 0 score 1/2" drill bit worked. Also looking forward to the cups. Had to poke a spring into the sleeve when lowering the car off the jack.
![]() | | #746 | ![]() |
| Approved MSF Vendor ![]() Join Date: Nov 2008 Location: Euless, TX
Rep Power: 975 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 850
| The Following 3 Users Say Thank You to RPM For This Useful Post: |
![]() | | #747 | ![]() |
| Not Ranked : 0 score As for adjusting the front shocks do you need to lift the front or can it be done while on the ground? |
![]() | | #748 | ![]() |
(Thread Starter) | Not Ranked : 0 score To adjust the damping, you can do it on the ground. You have to lift it to adjust the height, though. |
![]() | | #749 | ![]() |
| Raider's Ohio Bottom Bitch ![]() Join Date: Oct 2012 Location: Cincinnati, OH
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 106
| Not Ranked : 0 score @RPM any word on if the new spring cups shipped? |
![]() | | #750 | ![]() |
![]() | | #751 | ![]() |
![]() | | #752 | ![]() |
![]() Join Date: May 2013 Location: CO
Rep Power: 2407 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,487
| Not Ranked : 0 score I know gc said they would be automatically shipping the cups out, but i purchased mine outside of the group buy. Will it be a situation that anyone with a Mazda who's ordered these will get the cups automatically? I figure that's probably the case but I'd like to confirm. |
![]() | | #753 | ![]() |
(Thread Starter) | Not Ranked : 0 score Just got this from GC: "I was just informed that the Speed 3 spring cones are going to be delayed because of a design change. I'm trying to get the new ETA now and I will contact you shortly as soon as I get the information. I apologize for the delay." Also, they've said that they will be sending them to all customers. |
| The Following User Says Thank You to RPM For This Useful Post: | monkey.bones.007 (07-29-2014) |
![]() | | #754 | ![]() |
Groans: 433
| Not Ranked : 0 score maybe they can work on giving us some good settings to minimize the bounce?
![]() | | #755 | ![]() |
He did say the Konis were on the soft side for my springs (strange, I thought they were supposed to be matched) and suggested I go with 3/4 turn from full stiff front and 1 turn from stiff rear. I checked my front struts and at 1 1/8" drop, they look as though there is not a lot of travel left in them which I think is the source of the issue myself and others are having. I'm thinking if the car is raised a bit or the GC bumpstop is trimmed slightly it might mitigate the issue somewhat. In the meantime I'll try his settings and see how it works.
__________________ JBR 3.0" WP // CS Racepipe // UR CBE // CS TMIC // CS SS Plate + Bushings // Autotechs // NGK's // Damond Oil Restrictor Bolt // Forge v2 // JBR RMM 88 // JBR .250 RSB // CS Springs/Struts // SPC Camber Arms // | |
![]() | | #756 | ![]() |
__________________ 2012 MS3 SOLD, living in the world of Right Wheel Drive now Ol' BMO had: Autotech Internals, CS SRI+TIP, CS Short Shift Plate, CS BPV, CS TMIC, UR Catback, CP-e Stage 2 RMM, COBB AP v3.0, UR Test Pipe, JBR Weighted Shift Knob, DM OCC Kit, Koni Yellows+GC springs | |
![]() | | #757 | ![]() |
Groans: 433
| Not Ranked : 0 score I'm not so sure adjusting rebound that much is going to help. I'm almost wondering if any drop at all on these is just too much for the konis to handle. I know with my old civic, there was a clear feel on how much you could drop before it became a bouncing mess. if you raised it off that, ride was fantastic again. And that was with Tokico blues, which are not adjustable.
![]() | | #758 | ![]() |
![]() Join Date: Sep 2012 Location: Los Angeles, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,205
A lot of speeds run lowing springs and Koni yellows without issue. I think the problem maybe that the spring rates are too high for OTS Koni yellow valving. After seeing some of the reviews saying the rears were too bouncy, I traded in my 600 springs for 440 and shifted the 525's to the rear. I still don't have these installed but when I do I'll update this thread with my findings. If the 525's are still causing problems in the rears I'll shift the 440's in the rear and purchase a set of 375's for the fronts. There's not much information on ideal spring rates for OTS yellow's but I think (based on a lot of research) that 550 should be the max that you run without re-valving the shocks.
__________________ 2010 Mazdaspeed3 w/tech Cobb AP V3 ║ JBR Tru 3" Wide Path ║ JBR Boost Tubes & BPV Hose ║ Cobb XLE BPV ║ CP-E TMIC ║ UR Racepipe ║ Magnaflow CBE ║ AutoTech Internals ║ GrimmSpeed EBCS ║ JBR RSB ║ SPC Camber Arms ║ KW V3 Coilovers ║ JBR IM+TB TIGs & TB Bypass ║ JBR SSP ║ E - Focus RMM ║ StopTech Slotted Rotors and EBC Yellow Stuff Pads ║ Techna-Fit SS Brake Lines | |
| The Following User Says Thank You to [R]usty For This Useful Post: | nybe0010 (08-04-2014) |
![]() | | #759 | ![]() |
![]() | | #760 | ![]() |
People can also buy spare sets of springs if they want a second set for daily driving. They're only $64 a set and range from 300 in lbs all the way to 800 I believe.
| The Following User Says Thank You to [R]usty For This Useful Post: | covelife1016 (07-30-2014) |
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f408/gb-ground-control-koni-sport-coilovers-mazdaspeed-167667/ | ||||
| Konisport + ground control setup | This thread | Refback | 04-25-2014 12:49 PM | |
| Konisport + ground control setup | This thread | Refback | 04-20-2014 03:35 AM | |
| Ground control and koni yellows | Bap | 2010 MS3 - Suspension & Brakes | 212 | 10-20-2016 11:43 AM |
| Koni Yellows | martin_nj | MazdaSpeed 3/6 - Suspension & Brakes | 50 | 05-09-2012 10:27 AM |
