Like Tree48Likes
 Old 04-01-2014, 04:08 PM   #1
RPM
RPM's Avatar
Posts: 1,149   (View Stats)
Arrow GB: GROUND CONTROL + KONI SPORT Coilovers for Mazdaspeed 3!
We have seen the need for a low cost, yet good quality, suspension option, so we're here to bring it to you! The Ground Control Coilover Conversion Kit and KONI's renowned Yellow Sport Shocks provides us with that opportunity! Quality components from two well-known manufacturers combine to create a customizable set of coilovers that easily exceed the quality of low-cost Taiwanese coilovers while simultaneously coming in at a lower cost!
Ground Control has been creating customizable and personalized suspension options since 1980. They do not offer "one size fits all" products. The spring rates of each kit are customized to best meet your needs. When you place an order with us, our site will ask you questions about your intended use for the vehicle, your desired ride feel, and the weight of your vehicle and Ground Control will use this information to select the proper spring rates to meet your needs. Of course, you're always welcome to specify exact spring rates if you know what you need. The range of spring rates that are considered acceptable for this vehicle with KONI Yellows is 450-650 lb/in in the front and 500-800 lb/in in the rear. If you're using the stock shocks, you will automatically get the softest springs (which are still 15% more firm that the stock springs), as the stock shocks are not suitable for increased spring rates. Ground Control kits consist of a set of Eibach Springs and an anodized aluminum adjuster that provide a drop adjustment range from 0 to 1.6 inches.
KONI has been involved in automobile dampers since 1932 and has produced adjustable telescopic dampers since 1945. KONl Sport's familiar yellow color has for decades meant superior motion control and adjustability for the discerning driving enthusiast. So much so that they are almost always referred to as KONI Yellows! KONI Yellows average force/velocity dyno chart is on par with coilover kits costing twice as much with a very digressive compression curve that remains consistent and a rebound curve that indicates a wide range of adjustment allowing them to perform anything from daily driving duties to regular track events.
This combination of Ground Control and KONI remains very popular among daily drivers and track enthusiasts in a wide range of markets. And now, they can be yours!
Included in this group buy:
  • Ground Control Coilover Spring Kit
  • KONI Sport Yellow Shocks, complete set with bump stops, perches cut, KONI shocks rebound pre-set to match springs, and full warranty through Ground Control*
    *optional if you already have KONI Yellows or will be keeping your stock shocks
GB CLOSED
LOGISTICS
This group buy originally ran through MAY 13, 2014.
HOW TO ORDER
1) Visit this link: Ground Control Coilover Conversion Kit for Mazdaspeed 3
2) Make all selections for the GC kit
3) Check the boxes next to the applicable KONI shocks if you are buying a full kit (note Gen1 and Gen2 rear shocks are different)
4) Check out with the coupon code: GC-GB
5) If you have your own KONI shocks and are NOT cutting the perch, please note this in the "Notes to GC" box, as this is a special order item.
Orders Placed: 20
[R]usty and trancehead like this.
The Following 16 Users Say Thank You to RPM For This Useful Post:
Bap (04-03-2014), brandonnicholson (04-01-2014), Chimmike (04-01-2014), dockinstation (04-01-2014), Domino81 (04-04-2014), Dumbguy (04-08-2014), gmoney542 (04-09-2014), jtday (04-08-2014), kgb (07-30-2014), Mattyhawk1 (04-18-2014), nybe0010 (04-01-2014), smoogs12 (04-01-2014), SparkySparks (04-01-2014), Tomas (05-10-2014), trancehead (04-02-2014), [R]usty (04-01-2014)
 Old 04-01-2014, 04:23 PM   #2
Will fuck up ur day
Chimmike's Avatar
Posts: 6,003   (View Stats)
Groans: 433
Sweet!
GC+Koni 50% likelihood (gotta see how the bonus comes in a couple weeks)
07 MS3
The original Genpoo Hater
RPM (04-01-2014), smoogs12 (04-02-2014)
 Old 04-01-2014, 07:17 PM   #3
smoogs12's Avatar
Posts: 7,731   (View Stats)
Groans: 423
This pricing is pretty fucking mint.
GC 70%
@brandonnicholson;
-Pat
2008 True Red MS3
GT3071R 'n Stuff
SOLD
1999 Jeep XJ
1996 Jeep XJ
1994 Miata
The Following 4 Users Say Thank You to smoogs12 For This Useful Post:
brandonnicholson (04-01-2014), Chimmike (04-02-2014), Domino81 (04-04-2014), RPM (04-01-2014)
 Old 04-01-2014, 07:46 PM   #4
Mpettograsso's Avatar
Posts: 93   (View Stats)
Mpettograsso has a reputation beyond reputeMpettograsso has a reputation beyond reputeMpettograsso has a reputation beyond reputeMpettograsso has a reputation beyond reputeMpettograsso has a reputation beyond reputeMpettograsso has a reputation beyond reputeMpettograsso has a reputation beyond reputeMpettograsso has a reputation beyond reputeMpettograsso has a reputation beyond reputeMpettograsso has a reputation beyond reputeMpettograsso has a reputation beyond repute
I'm in GC + Koni 100%
May the Bridges I burn Light the Way.
Mpettograsso is offline   Reply With Quote
The Following 3 Users Say Thank You to Mpettograsso For This Useful Post:
Chimmike (04-02-2014), RPM (04-01-2014), smoogs12 (04-01-2014)
 Old 04-01-2014, 07:50 PM   #5
brandonnicholson's Avatar
Posts: 1,699   (View Stats)
brandonnicholson is the leader of the worldbrandonnicholson is the leader of the worldbrandonnicholson is the leader of the worldbrandonnicholson is the leader of the worldbrandonnicholson is the leader of the worldbrandonnicholson is the leader of the worldbrandonnicholson is the leader of the worldbrandonnicholson is the leader of the worldbrandonnicholson is the leader of the worldbrandonnicholson is the leader of the worldbrandonnicholson is the leader of the world
GC + Koni 100% need suspension soon!
smoogs12 likes this.
brandonnicholson is offline   Reply With Quote
The Following 3 Users Say Thank You to brandonnicholson For This Useful Post:
 Old 04-01-2014, 08:15 PM   #6
nybe0010's Avatar
Posts: 276   (View Stats)
nybe0010 is the leader of the worldnybe0010 is the leader of the worldnybe0010 is the leader of the worldnybe0010 is the leader of the worldnybe0010 is the leader of the worldnybe0010 is the leader of the worldnybe0010 is the leader of the worldnybe0010 is the leader of the worldnybe0010 is the leader of the worldnybe0010 is the leader of the worldnybe0010 is the leader of the world
Groaned at 3 Times in 1 Post
GC + Koni 100% if I don't buy them sooner. I need new stuff so badly but I will try to hold out for the deal! So what's the deal with cutting on the konis, I believe it's the spring perch or seat?? Sorry suspension noob lol. I talked to Trevor from GC tonight and he said they are adjustable up to 1.6 drop, but if you want more adjustment then you can cut on the fronts... the only reason I haven't pulled the trigger yet was because I was concerned how that would effect the koni lifetime warranty.
11' Black Mica MS3 ATK Reman Long Block iMOTO Shift Forks LuK Clutch Fidanza Flywheel
GC+Koni Coilovers CNT CBE JBR Trilogy Mounts Forge V1 BPV CPE SafeSeals Block8Head Dual Vent Pod Blowshift Boost / OP
nybe0010 is offline   Reply With Quote
The Following 3 Users Say Thank You to nybe0010 For This Useful Post:
Chimmike (04-02-2014), RPM (04-01-2014), smoogs12 (04-02-2014)
 Old 04-01-2014, 08:21 PM   #7
RPM
RPM's Avatar
I shot them an email asking about the perch, so I'll know more tomorrow. I definitely want to get that clarified.
 Old 04-01-2014, 08:25 PM   #8
nybe0010's Avatar
Alright that would be great thanks. I know @Bap; has been a huge help. He was talking with Donovan I think, I spoke to Trevor but he put me on hold for a while. Sounds like they don't respond to emails, and they've answered all my calls. This is going to be one hell of a deal!
 Old 04-01-2014, 08:48 PM   #9
rabble rabble
802MS3's Avatar
Posts: 5,318   (View Stats)
Groans: 221
This is nice. Does koni have a recommendation on what to use for bumpstops?
'08 CWP MS3 w/ T3 3071r
 Old 04-01-2014, 10:14 PM   #10
specvspeedfreak's Avatar
Posts: 2,371   (View Stats)
What a great deal, even at 10 buyers. Only way I can see this getting better is offering just the Koni's. That would be a sick deal. I am sure you can put an exclusion and say only the same amount as GC only buyers. So basically 1:1.
 Old 04-01-2014, 10:55 PM   #11
msantana101's Avatar
Posts: 1,517   (View Stats)
Subbed in case I decide to be an idiot with my money at the last moment.
FreekTuned
 Old 04-01-2014, 11:21 PM   #12
[R]usty's Avatar
Posts: 2,204   (View Stats)
Hell yeah. Already have the Koni's sitting in my garage and Ground Controls were next on my list. I'm thinking I'll sell my Yellows and buy the kit you guys are selling if the perches are already removed. I just have off the shelf Koni's. @RPM; are there any differences with these shocks vs off the shelf Koni's yellows?
80% I'll buy one of them
GC only 50%
GC+KONI 30%
Come on 40 people let's do this! This is hands down the best deal you'll find.
2010 Mazdaspeed3 w/tech
The Following 2 Users Say Thank You to [R]usty For This Useful Post:
Chimmike (04-02-2014), smoogs12 (04-02-2014)
 Old 04-02-2014, 12:09 AM   #13
mrshoulders's Avatar
Posts: 652   (View Stats)
mrshoulders is the leader of the worldmrshoulders is the leader of the worldmrshoulders is the leader of the worldmrshoulders is the leader of the worldmrshoulders is the leader of the worldmrshoulders is the leader of the worldmrshoulders is the leader of the worldmrshoulders is the leader of the worldmrshoulders is the leader of the worldmrshoulders is the leader of the worldmrshoulders is the leader of the world
Groaned at 86 Times in 51 Posts
gc only 75% and koni 25%
2010 Speed3 w/tech
Bolted E85 FREEKTUNE
mrshoulders is offline   Reply With Quote
The Following User Says Thank You to mrshoulders For This Useful Post:
 Old 04-02-2014, 04:57 AM   #14
covelife1016's Avatar
Posts: 151   (View Stats)
covelife1016 has a reputation beyond reputecovelife1016 has a reputation beyond reputecovelife1016 has a reputation beyond reputecovelife1016 has a reputation beyond reputecovelife1016 has a reputation beyond reputecovelife1016 has a reputation beyond reputecovelife1016 has a reputation beyond reputecovelife1016 has a reputation beyond reputecovelife1016 has a reputation beyond reputecovelife1016 has a reputation beyond reputecovelife1016 has a reputation beyond repute
gc+ koni 75%
2010 MS3 non tech
// CS TMIC// CS battery box// JBR short shifter// JBR 88a rmm// JBR boost tubes// JBR solid shifter bushings// JBR coolant bypass and throttle body tig// Kozmic Motorsports primary and secondary egr delete// NGK one step colder plugs// AT fuel pump internals// HTP 3" intake// GFB bov// COBB accessport V2 // GroundControl springs// Koni yellows//
TUNED BY STRATIFIED
covelife1016 is offline   Reply With Quote
The Following User Says Thank You to covelife1016 For This Useful Post:
 Old 04-02-2014, 05:13 AM   #15
Mike@Stratified's Avatar
Posts: 1,119   (View Stats)
gc+koni 90%
The Following 2 Users Say Thank You to Mike@Stratified For This Useful Post:
 Old 04-02-2014, 05:47 AM   #16
hatchedspeed3's Avatar
Posts: 1,966   (View Stats)
GC + Koni 50%
2009 CWP MS3 1-23-2014
 Old 04-02-2014, 05:48 AM   #17
daafisch's Avatar
Posts: 3,553   (View Stats)
Groans: 58
I'm sure once I cut the perches off my current Koni's warranty would be void. Curious to see if we buy the kit if we still get some sort of warranty on the shocks.
GC 65%
GC+Koni 25%
GET THEM TO RELEASE THE DAMN CAMBER PLATES!!!
The Following 4 Users Say Thank You to daafisch For This Useful Post:
802MS3 (04-02-2014), Chimmike (04-02-2014), nybe0010 (04-02-2014), smoogs12 (04-02-2014)
 Old 04-02-2014, 08:26 AM   #18
nybe0010's Avatar
Did you have to cut the perches off? how much adjustment do you have?
 Old 04-02-2014, 09:47 AM   #19
daafisch's Avatar
Groans: 58
I don't have them, hence my interest.
 Old 04-02-2014, 10:06 AM   #20
nybe0010's Avatar
ha I read that way wrong
 Old 04-02-2014, 08:52 AM   #21
RPM
RPM's Avatar
We have an email in to GC to get some clarifications, then we'll have answers to all of the questions that have been posed so far. They don't open until 9am PST, so give me a few hours.
 Old 04-02-2014, 09:48 AM   #22
Dumbguy's Avatar
Posts: 130   (View Stats)
Dumbguy has a reputation beyond reputeDumbguy has a reputation beyond reputeDumbguy has a reputation beyond reputeDumbguy has a reputation beyond reputeDumbguy has a reputation beyond reputeDumbguy has a reputation beyond reputeDumbguy has a reputation beyond reputeDumbguy has a reputation beyond reputeDumbguy has a reputation beyond reputeDumbguy has a reputation beyond reputeDumbguy has a reputation beyond repute
Im in! Already bought a set of konis.
GC only 100%
2012 VRM Mazdaspeed 3 - “Claudia”
Cobb v3 AP | Autotech HPFP Internals | UR Catback | Cp-e TMIC | Cp-e Stage 2 RMM | Cp-e Catted DP | TWM Full Replacement | CS Occ | CS Bpv | CS Hood Struts | JBR EGR delete | JBR Boost tubes and Recirc hose | HTP 3.5” Intake | 1 Step colder plugs | Blox 490 | BC Coilovers | Drag dr-49
Waiting for install
CS Battery box
2008 Black Mica Mazdaspeed 3 - "April" (Totaled, may she rest in piece)
Dumbguy is offline   Reply With Quote
The Following User Says Thank You to Dumbguy For This Useful Post:
 Old 04-02-2014, 09:54 AM   #23
Lakespeed6's Avatar
Posts: 2,403   (View Stats)
Are just MS3 kits available for the GB or could I possible be included for a set on my E30?
1990 Nissan Skyline GTR
1991 White BMW 325ic
The Following 2 Users Say Thank You to Lakespeed6 For This Useful Post:
jtday (04-05-2014), smoogs12 (04-02-2014)
 Old 04-02-2014, 10:07 AM   #24
RPM
RPM's Avatar
We can include the E30 GC kit at the same price. I don't know the price of the KONIs for that vehicle, so if you need those, too, I'll have to check on that and get back to you.
The Following 3 Users Say Thank You to RPM For This Useful Post:
Chimmike (04-02-2014), Lakespeed6 (04-02-2014), smoogs12 (04-02-2014)
 Old 04-02-2014, 10:26 AM   #25
Lakespeed6's Avatar
Right now have some bilstein sports and H&R on order. So will see if I can cancel the H&R. Also need to check funds.
 Old 04-02-2014, 10:34 AM   #26
IMASA's Avatar
Posts: 209   (View Stats)
GC Only - 50%
I'd like to see more details of what needs to be done to modify the Koni shocks.
The Following 3 Users Say Thank You to IMASA For This Useful Post:
nybe0010 (04-02-2014), RPM (04-02-2014), smoogs12 (04-02-2014)
 Old 04-02-2014, 11:27 AM   #27
RPM
RPM's Avatar
Alright, we have a bit more information which should answer most of the questions that have been posed.
The perches MUST be cut off of the KONI shocks in order to use the GC kit. GC is going to send me instructions on how to do that, so I'll post those once I receive them.
The pricing in the first post was based upon the off-the-shelf KONI shocks with no modifications and no bump stops. I'm currently talking to GC about removing the perches and including bump stops. I don't know if this will add to the cost, or how much, but once they get back to me, I'll follow up and let everyone know.
The Following 4 Users Say Thank You to RPM For This Useful Post:
brandonnicholson (04-02-2014), jtday (04-05-2014), Mike@Stratified (04-02-2014), smoogs12 (04-02-2014)
 Old 04-03-2014, 03:57 PM   #28
Raider's Ohio Bottom Bitch
therza2169's Avatar
Posts: 204   (View Stats)
therza2169 is the leader of the worldtherza2169 is the leader of the worldtherza2169 is the leader of the worldtherza2169 is the leader of the worldtherza2169 is the leader of the worldtherza2169 is the leader of the worldtherza2169 is the leader of the worldtherza2169 is the leader of the worldtherza2169 is the leader of the worldtherza2169 is the leader of the worldtherza2169 is the leader of the world
Any update on them removing the perches, and including bump stops? If they will do that I will most likely be down.
therza2169 is offline   Reply With Quote
 Old 04-03-2014, 04:04 PM   #29
RPM
RPM's Avatar
Still waiting.. Should have an answer later today.. They're Pacific time.
therza2169 (04-03-2014)
 Old 04-03-2014, 04:05 PM   #30
therza2169's Avatar
Ahh makes sense. Thank!
 Old 04-02-2014, 11:33 AM   #31
timmcc02's Avatar
Posts: 253   (View Stats)
Groaned at 9 Times in 3 Posts
Will be interested based upon the answer to the perches and bumpstops
The Following 2 Users Say Thank You to timmcc02 For This Useful Post:
 Old 04-02-2014, 02:07 PM   #32
chomorro's Avatar
Posts: 667   (View Stats)
chomorro is the leader of the worldchomorro is the leader of the worldchomorro is the leader of the worldchomorro is the leader of the worldchomorro is the leader of the worldchomorro is the leader of the worldchomorro is the leader of the worldchomorro is the leader of the worldchomorro is the leader of the worldchomorro is the leader of the worldchomorro is the leader of the world
Which spring version is closest to the Eibach Pro kit? Daily Driver - Touring, aggressive or race? I want the same or similar feel as my eibachs but with height adjustability.
I already have Koni's but i might be interested in a full kit if they can cut the perches and install the bottom section just because of the time savings for this backyard mechanic
2009 Subaru WRX STI Hatchback
2007 GTI - Package 2 w/ Nav - Dieselgeek Short Shifter / TWM Weighted Etched Shift Knob / AWE 2.5" Turbo Back Exhaust w/Metal Cat / APR Stage 2+ Tune / APR Flapper Delete / APR HPFP / Vogtland 2" Springs / R8 Coils / NGK Iridium / P3Cars Digital Vent Gauge / 18" OEM Detroit Rims (SOLD)
2007 Speed 3 - Stratified Tuned with bolts ons (SOLD)
chomorro is offline   Reply With Quote
 Old 04-02-2014, 04:28 PM   #33
Adog35's Avatar
Posts: 309   (View Stats)
Adog35 is the leader of the worldAdog35 is the leader of the worldAdog35 is the leader of the worldAdog35 is the leader of the worldAdog35 is the leader of the worldAdog35 is the leader of the worldAdog35 is the leader of the worldAdog35 is the leader of the worldAdog35 is the leader of the worldAdog35 is the leader of the worldAdog35 is the leader of the world
I spoke directly to GC a few days, according to them would cut the perch and install the spring.
I am assuming the group buy is a different case since it's from a vendor.
2010 MS3
5% REAR 30% FRONT
DDM 5K HID
RMM
CS TIP/SRI
Dizzy Tuned
Autotech Internals
Swift Springs
JBR Rear Sway
Stoptech 309's
First Turbo Car and I love it!
Adog35 is offline   Reply With Quote
 Old 04-02-2014, 06:29 PM   #34
RPM
RPM's Avatar
As it turns out, we may be getting the KONIs directly from GC, too. More details tomorrow. Stay tuned.
The Following 6 Users Say Thank You to RPM For This Useful Post:
Chimmike (04-03-2014), daafisch (04-02-2014), magicka (04-02-2014), Mike@Stratified (04-02-2014), smoogs12 (04-02-2014), [R]usty (04-02-2014)
 Old 04-02-2014, 05:19 PM   #35
Will fuck up ur day
Chimmike's Avatar
Groans: 433
cutting the perches off the fronts? Makes me wonder now how these will fit with my wheels.....I have like....VERY limited room in there.
TRM C3's, 17x9 and I think they're +48
07 MS3
 Old 04-02-2014, 05:34 PM   #36
[R]usty's Avatar
@gingermike;
These pics are courtesy of @Bap;. He's running ground controls and there appears to be a fair bit of clearance. Not sure what wheels and tires he's running. Bap any info on that? I also found a pic of the stock shock as well.
File Type: jpg 2013-11-25_09-21-40_910_zpsf9e76740.jpg (70.8 KB, 74 views)
File Type: jpg 2013-11-25_09-16-07_101_zpse72f741f.jpg (229.9 KB, 70 views)
File Type: jpg 2013-08-12_13-36-26_423_zps3ef0d7f7.jpg (230.7 KB, 61 views)
The Following 3 Users Say Thank You to [R]usty For This Useful Post:
802MS3 (04-02-2014), Chimmike (04-03-2014), smoogs12 (04-02-2014)
 Old 04-03-2014, 05:55 AM   #37
Will fuck up ur day
Chimmike's Avatar
Groans: 433
@gingermike;
that actually does help a lot. I'll snap a pic of my stock setup to compare but seeing those pics reassures me that they will, in fact, work.
Here are my photos. Note I'm VERY Close to the stock strut body. Guess maybe a 5mm spacer may be in order? lol.
07 MS3
 Old 04-03-2014, 06:48 AM   #38
rabble rabble
802MS3's Avatar
Groans: 221
yeah I have 5mm ebay spacers up front with 17x9 +45 RPF1s in order to clear the Koni's. I had Bilsteins before which needed the spacer as well.
 Old 04-03-2014, 08:10 AM   #39
Will fuck up ur day
Chimmike's Avatar
Groans: 433
Good deal. Figured I needed 'em.
07 MS3
 Old 04-03-2014, 10:10 AM   #40
Bap
Bap's Avatar
Posts: 248   (View Stats)
Bap is the leader of the worldBap is the leader of the worldBap is the leader of the worldBap is the leader of the worldBap is the leader of the worldBap is the leader of the worldBap is the leader of the worldBap is the leader of the worldBap is the leader of the worldBap is the leader of the worldBap is the leader of the world
Hey my wheel set up is 18x8 + like 45 or 48 with 225/40/18 rubber but the dipole that is in the stock strut body and the koni strut body offers a bit more clearance.
the GC kit comes with everything shown in the picture, including the new upper bearing assemble. I am on aggressive ride with 525 front and 550 rear. car handles really well with them I am enjoying them. For those that want to see before and after pic got to gen 2 suspension topic ground control and Koni yellows has some good pics their.
Last edited by Bap; 04-03-2014 at 10:21 AM. Reason: MSF Database - Automerged Doublepost
Bap is offline   Reply With Quote
The Following User Says Thank You to Bap For This Useful Post:
[R]usty (04-03-2014)
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f408/gb-ground-control-koni-sport-coilovers-mazdaspeed-167667/
Konisport + ground control setup This thread Refback 04-25-2014 12:49 PM
Konisport + ground control setup This thread Refback 04-20-2014 03:35 AM
Ground control and koni yellows Bap 2010 MS3 - Suspension & Brakes 212 10-20-2016 11:43 AM
Koni Yellows martin_nj MazdaSpeed 3/6 - Suspension & Brakes 50 05-09-2012 10:27 AM
Page generated in 0.97788 seconds with 43 queries
