Like Tree48Likes
 Old 04-17-2014, 11:48 AM   #161
timmcc02's Avatar
Posts: 253   (View Stats)
Groaned at 9 Times in 3 Posts
The only thing im worried about is front camber going too negative without camber plates. Anyone have any idea on what to expect front camber to be with using the oem top hats
The Following User Says Thank You to timmcc02 For This Useful Post:
Chimmike (04-17-2014)
 Old 04-17-2014, 11:53 AM   #162
KevinK2's Avatar
Posts: 907   (View Stats)
KevinK2 is the leader of the worldKevinK2 is the leader of the worldKevinK2 is the leader of the worldKevinK2 is the leader of the worldKevinK2 is the leader of the worldKevinK2 is the leader of the worldKevinK2 is the leader of the worldKevinK2 is the leader of the worldKevinK2 is the leader of the worldKevinK2 is the leader of the worldKevinK2 is the leader of the world
Groaned at 79 Times in 52 Posts
One very good point on this kit, vs some others including Bilsteins, is that they appear to come with a visable compression bump cushion inside the spring, and on the shock rod. This provides a stiffer net spring as you experience high compression of the spring. This "soft" stop is better than going into coil-bind "hard impact" stop as some have experienced with the Bilstein PSS kits. They may actually be designed for the lighter Mazda3, and have an internal bump stop, but it has not prevented coil bind up front in a few applications.
Note that the GC/Koni bump cushion is designed for a specific range of drop. This part may require modification, depending on drop used.
From Delaware
Current Fleet: 04 Mazda6, 93 Rx7 TT, 76 Triumph 750 Trident
Tracked Cars: 68 Triumph GT6 (~full race prep'd), 81 Porsche 924 Turbo, 93 Rx7 twin turbo
Last edited by KevinK2; 04-18-2014 at 01:09 PM. Reason: added bump stop info for Bilstein
KevinK2 is offline   Reply With Quote
The Following 2 Users Say Thank You to KevinK2 For This Useful Post:
RPM (04-17-2014), smoogs12 (04-17-2014)
 Old 04-17-2014, 12:58 PM   #163
Steezyms3's Avatar
Posts: 202   (View Stats)
Steezyms3 has a brilliant futureSteezyms3 has a brilliant futureSteezyms3 has a brilliant futureSteezyms3 has a brilliant futureSteezyms3 has a brilliant futureSteezyms3 has a brilliant futureSteezyms3 has a brilliant futureSteezyms3 has a brilliant futureSteezyms3 has a brilliant futureSteezyms3 has a brilliant futureSteezyms3 has a brilliant future
Groaned at 6 Times in 4 Posts
Originally Posted by gingermike View Post
this isn't really a kit you'll want to "slam". there's a pretty obvious point where the ride becomes terrible and bouncy, and that's the suspension's way of saying "raise it back up, junior". Happened with GC's on my old b18 civic. Once I brought it back up a little bit, the ride was awesome and the handling was fantastic.
How low was your EK at the time?
Steezyms3 is offline   Reply With Quote
 Old 04-17-2014, 03:18 PM   #164
skiptowncat's Avatar
Posts: 1,592   (View Stats)
Ok, last question...how much to ship to the uk? I may be able to get a few more onboard
Tuned with by
The Following User Says Thank You to skiptowncat For This Useful Post:
Chimmike (04-18-2014)
 Old 04-17-2014, 03:22 PM   #165
RPM
RPM's Avatar
Posts: 1,149   (View Stats)
The box for the complete kit weighs 42 lbs. and is 31" x 16" x 14". We would need postal codes to get quotes from FedEx. You might also look into using a forwarder like USA Address & Mail Forwarding ? Shipito.com | English as they tend to offer very low rates.
The Following 3 Users Say Thank You to RPM For This Useful Post:
Chimmike (04-18-2014), justinsane87 (04-17-2014), smoogs12 (04-17-2014)
 Old 04-17-2014, 03:35 PM   #166
justinsane87's Avatar
Posts: 877   (View Stats)
justinsane87 is the leader of the worldjustinsane87 is the leader of the worldjustinsane87 is the leader of the worldjustinsane87 is the leader of the worldjustinsane87 is the leader of the worldjustinsane87 is the leader of the worldjustinsane87 is the leader of the worldjustinsane87 is the leader of the worldjustinsane87 is the leader of the worldjustinsane87 is the leader of the worldjustinsane87 is the leader of the world
Just tried out that site, it would cost $90 compared to the $220 on your site to ship to Edmonton.
2013 Mazdaspeed 3 - GTX3076R EWG
Autotechs - FreekBuilt 3.5" - UR Catless Turbo-back - AP V3 - ETS TMIC
JBR 80D Trilogy/SSP/Bushings/Heavy Knob/TIGs/0.250 RSB - GFB BOV
FreekTune'd - DO DVC-30 - Ground Control w/Koni Yellows - DM OCC
Enkei RPF1 17x9 w/ PSS 235/45/17 - Full Race Exhaust Mani
justinsane87 is offline   Reply With Quote
 Old 04-17-2014, 03:45 PM   #167
RPM
RPM's Avatar
Yeah.. They have some pretty insane pricing through TNT.. Sometimes we can get close by calling FedEx for special rates, but we need the postal code to get a quote.
 Old 04-18-2014, 01:14 AM   #168
Try wn1 2ta @RPM;
Tuned with by
 Old 04-18-2014, 08:59 AM   #169
Will fuck up ur day
Chimmike's Avatar
Posts: 6,003   (View Stats)
Groans: 433
seems like $220 would be some sort of express shipping? That seems INSANELY high for ground shipping
07 MS3
The original Genpoo Hater
 Old 04-18-2014, 09:01 AM   #170
That was the cheapest option on their site, kind of redonkulous
Sent from the flux capacitor
 Old 04-18-2014, 09:24 AM   #171
covelife1016's Avatar
Posts: 151   (View Stats)
covelife1016 has a reputation beyond reputecovelife1016 has a reputation beyond reputecovelife1016 has a reputation beyond reputecovelife1016 has a reputation beyond reputecovelife1016 has a reputation beyond reputecovelife1016 has a reputation beyond reputecovelife1016 has a reputation beyond reputecovelife1016 has a reputation beyond reputecovelife1016 has a reputation beyond reputecovelife1016 has a reputation beyond reputecovelife1016 has a reputation beyond repute
11 days left. I can't wait to get these on the car.
2010 MS3 non tech
// CS TMIC// CS battery box// JBR short shifter// JBR 88a rmm// JBR boost tubes// JBR solid shifter bushings// JBR coolant bypass and throttle body tig// Kozmic Motorsports primary and secondary egr delete// NGK one step colder plugs// AT fuel pump internals// HTP 3" intake// GFB bov// COBB accessport V2 // GroundControl springs// Koni yellows//
TUNED BY STRATIFIED
covelife1016 is offline   Reply With Quote
The Following 2 Users Say Thank You to covelife1016 For This Useful Post:
Chimmike (04-18-2014), daafisch (04-18-2014)
 Old 04-18-2014, 09:29 AM   #172
Mattyhawk1's Avatar
Posts: 739   (View Stats)
The max static negative camber that the front can be set is about -1.5* to -1.9* with no modifications to the strut tower. You will not notice a big difference in camber if you set the top hat back to the original position after install. You will need an alignment anytime you change ride height, since toe changes significantly when raising or lowering the suspension, so you can get camber put to your specs.
You shouldn't be worried about too much negative camber with this setup. If anything, most worry about not enough.
daafisch likes this.
The Following 2 Users Say Thank You to Mattyhawk1 For This Useful Post:
daafisch (04-18-2014), gmoney542 (04-18-2014)
 Old 04-18-2014, 10:13 AM   #173
Mattyhawk1's Avatar
I agree. I tried to get this information out of them, but they just kept saying, "We base it on the individual customer's needs". I finally asked them what information they needed to best design a kit and they told me intended use, ride feel, and weight. The exact wording of the options I made up myself. The most I could get out of them is that the range is 450-650 lb/in in the front and 500-800 lb/in in the rear. With that in mind, at least we know that Daily Driver, Touring is at the low end and Dedicated, Race is at the top...
Out of curiousity, you have an option for using stock shocks for the coilovers only, right? You state in the first post that they are 15% stiffer, is that stiffer than stock? Your response earlier suggests the only option is 450 / 500 as the softest. That will definitely be too much spring for stock shocks. Is this 450/500 meant to apply to the stock shock coilover only option?
I have to caveat all my suspension mod decisions with "Wife Approved". 450/500 will be husband abused...
 Old 04-18-2014, 10:23 AM   #174
gmoney542's Avatar
Posts: 236   (View Stats)
gmoney542 is the leader of the worldgmoney542 is the leader of the worldgmoney542 is the leader of the worldgmoney542 is the leader of the worldgmoney542 is the leader of the worldgmoney542 is the leader of the worldgmoney542 is the leader of the worldgmoney542 is the leader of the worldgmoney542 is the leader of the worldgmoney542 is the leader of the worldgmoney542 is the leader of the world
Originally Posted by Mattyhawk1 View Post
Out of curiosity, you have an option for using stock shocks for the coilovers only, right? You state in the first post that they are 15% stiffer, is that stiffer than stock? Your response earlier suggests the only option is 450 / 500 as the softest. That will definitely be too much spring for stock shocks. Is this 450/500 meant to apply to the stock shock coilover only option?
I believe those numbers are only for the KONIs. The ranges he posted are what Ground Control says the KONI Yellows can handle without being revalved.
I doubt the springs for the stock shock option will be anywhere near as stiff.
2009 CWP Mazdaspeed3
- COBB AP V3 - Richtune - 50/50 E85 - Autotech HPFP Internals - CNT Catless Downpipe - HTP 3" Intake - NGK One Step Colder Plugs -
- Kozmic Motorsports EGR Deletes - JBR 88 RMM/TMM/PMM - JBR Shifter Bushings - JBR TIG + Coolant Bypass - JBR OCC -
- JBR RSB - GroundControl Coilovers - CorkSport Camber Plates - CorkSport Rear Camber Arms - CorkSport Rear Toe Arms -
- WhiteLine Front Endlinks - WhiteLine Bumpsteer Kit - WhiteLine Poly LCA Bushings - AWR Rear Endlinks -
- 18x8 Mazdaspeed MS-01S - Nitto NT05 245/40/18 -
gmoney542 is offline   Reply With Quote
The Following User Says Thank You to gmoney542 For This Useful Post:
Mattyhawk1 (04-18-2014)
 Old 04-18-2014, 10:38 AM   #175
Mattyhawk1's Avatar
I think you are right, but I want to hear it from RPM's lips before I order.
 Old 04-18-2014, 11:21 AM   #176
RPM
RPM's Avatar
If you order the kit for the Stock shocks, the spring rates will be 15% over stock, as that's the most the stock dampers can handle. The higher range is what they use for KONIs.
Mattyhawk1 likes this.
The Following 4 Users Say Thank You to RPM For This Useful Post:
daafisch (04-18-2014), Mattyhawk1 (04-18-2014), smoogs12 (04-18-2014), [R]usty (04-18-2014)
 Old 04-18-2014, 02:52 PM   #177
KevinK2's Avatar
Ground Control kits consist of a set of Eibach Springs and an anodized aluminum adjuster that provide a drop adjustment range from 0 to 1.6 inches ............. This combination of Ground Control and KONI remains very popular among daily drivers and track enthusiasts in a wide range of markets. And now, they can be yours!
Do you have any concern about how the drop chosen changes the point where the bump cushion is engaged?
It's somewhat similar to just adding drop springs and being instructed to cut one ring off the OEM bump cushions. The lower the drop, the sooner the bump cushion will be engaged. With the front m-struts, the motion ratio is high, so you are seeing close to that drop at the shock.
From Delaware
 Old 04-18-2014, 03:06 PM   #178
RPM
RPM's Avatar
Ground Control includes a relatively small bump stop. The purpose of this bump stop is just to prevent bottoming out. With the travel provided by the KONIs in addition to the increased spring rates, you would have to do some pretty crazy stuff to bottom out, even at the lowest drop.
 Old 04-18-2014, 03:33 PM   #179
Mattyhawk1's Avatar
Just FYI on the Koni Yellows, By my experience, you can safely cut up to 40% length off a new OEM front bumpstop and not have issues with running out of shock stroke. I doubt you will have problems with the lowest height settings, especially if you are running the heavier springs.
RPM (04-18-2014), smoogs12 (04-18-2014)
 Old 04-18-2014, 04:45 PM   #180
Will fuck up ur day
Chimmike's Avatar
Groans: 433
don't know if you've ever used GC's and aftermarket shocks before, but GC the setup pretty much reaches a point in lowering where it tells you, via the ride, that you've gone too low. Ride gets stiff, jouncy. Raise up a little from that point and everything smooths out beautifully, you retain fantastic handling, and the longevity of the shocks is kept intact. Therefore, bumpstop shouldn't be an issue.
07 MS3
 Old 04-18-2014, 06:32 PM   #181
KevinK2's Avatar
No on the GC's, but yes on the Koni yellows that are great, adjustable shocks.
I agree with rpm's reply that the koni and stiff spring combo should not be an issue. But with just the 15% stiffer springs, IMHO they should be verified to contribute when running little drop.
From Delaware
The Following User Says Thank You to KevinK2 For This Useful Post:
Nliiitend1 (04-19-2014)
 Old 04-19-2014, 08:42 AM   #182
Canuck's Avatar
Posts: 6   (View Stats)
Canuck is just really niceCanuck is just really niceCanuck is just really niceCanuck is just really nice
Let's try this...
@gingermike, @smoogs12, @Mpettograsso, @nybe0010, @rustysurfsa, @mrshoulders, @covelife1016, @Mike@Stratified, @IMASA, @skiptowncat, @easy, @Dumbguy, @Elvisrosales88, @Adog35, @gmoney542, @Hal, @Canuck
Ordering instructions are in the first post! We can't even consider beginning to ship until we get the orders in!
I will put my order in during the last weekend of the month.
Canuck is offline   Reply With Quote
The Following User Says Thank You to Canuck For This Useful Post:
covelife1016 (04-19-2014)
 Old 04-19-2014, 09:10 AM   #183
Mattyhawk1's Avatar
You know, that is an excellent question. I have no numbers or experience to back this claim, but I bet you cannot comfortably run full drop on the DD setup for stock springs, which I believe you are alluding to. You will end up spending most of your time on the bumpstops.
 Old 04-19-2014, 09:30 AM   #184
RPM
RPM's Avatar
Well, a 1.6" drop isn't any more than what people are getting with other lowering springs, like Eibach Pro-Kit. In fact some people go even lower with TEINs and such, though I certainly wouldn't recommend that.
Chimmike (04-19-2014)
 Old 04-19-2014, 12:25 PM   #185
Adog35's Avatar
Posts: 309   (View Stats)
Adog35 is the leader of the worldAdog35 is the leader of the worldAdog35 is the leader of the worldAdog35 is the leader of the worldAdog35 is the leader of the worldAdog35 is the leader of the worldAdog35 is the leader of the worldAdog35 is the leader of the worldAdog35 is the leader of the worldAdog35 is the leader of the worldAdog35 is the leader of the world
Placing order today.
Need to talk to you about spring rates.
2010 MS3
5% REAR 30% FRONT
DDM 5K HID
RMM
CS TIP/SRI
Dizzy Tuned
Autotech Internals
Swift Springs
JBR Rear Sway
Stoptech 309's
First Turbo Car and I love it!
Adog35 is offline   Reply With Quote
The Following User Says Thank You to Adog35 For This Useful Post:
[R]usty (04-19-2014)
 Old 04-19-2014, 12:55 PM   #186
KevinK2's Avatar
The point is not the 1.6" drop, but the range of drop allowed:
With spring kits having the drops lower than the prokit, experience has found that reducing the length of the bump springs/cushions was needed, at least in the M6 world.
I am not condeming this combination of high quality components. Just suggesting that you may quickly verify they can do what's advertised to do. Your company is certainly qualified to do a verification, when you have had great designs:
RPM-Street-Lowering-Springs-for-Mazdaspeed
From Delaware
 Old 04-19-2014, 09:53 PM   #187
RPM
RPM's Avatar
Well, that's true. In the case that you are using the stock shocks and dropping more than 3/4", you should always cut the "section" off of the bump stop to allow for more travel or replace them with smaller bump stops. This is true of all lowering springs on stock shocks, including the ones we offered for the MS6.
I'll have to get back to you on Monday. Lots of family time this weekend due to Easter.
Last edited by RPM; 04-19-2014 at 09:53 PM. Reason: MSF Database - Automerged Doublepost
KevinK2 (04-20-2014)
 Old 04-20-2014, 08:22 AM   #188
Will Ground Control let us know what spring rates they send us? I answered the questions on the site when checking out since I am not a huge guru on spring rates. It would be helpful for in the future if I decide to change the spring rates up.
2010 MS3 non tech
TUNED BY STRATIFIED
 Old 04-20-2014, 09:14 AM   #189
RPM
RPM's Avatar
Of course! The springs will be marked with the spring rates.
Sent from my Galaxy Nexus using Tapatalk
Adog35 (04-21-2014), covelife1016 (04-20-2014), daafisch (04-20-2014), Mattyhawk1 (04-21-2014)
 Old 04-21-2014, 10:32 AM   #190
RPM
RPM's Avatar
Up to 7 orders! Just over a week left!
 Old 04-21-2014, 12:59 PM   #191
Will fuck up ur day
Chimmike's Avatar
Groans: 433
Putting in my order today. The sooner I can get these things the better!
07 MS3
smoogs12 (04-21-2014), [R]usty (04-21-2014)
 Old 04-22-2014, 07:50 AM   #192
Will fuck up ur day
Chimmike's Avatar
Groans: 433
Come on guys! Put in your orders! the sooner, the faster they'll ship!
07 MS3
daafisch (04-22-2014), smoogs12 (04-22-2014)
 Old 04-22-2014, 09:52 AM   #193
RPM
RPM's Avatar
We're up to 10 now!
Chimmike (04-22-2014), daafisch (04-22-2014), smoogs12 (04-22-2014)
 Old 04-22-2014, 09:54 AM   #194
Dumbguy's Avatar
Posts: 130   (View Stats)
Dumbguy has a reputation beyond reputeDumbguy has a reputation beyond reputeDumbguy has a reputation beyond reputeDumbguy has a reputation beyond reputeDumbguy has a reputation beyond reputeDumbguy has a reputation beyond reputeDumbguy has a reputation beyond reputeDumbguy has a reputation beyond reputeDumbguy has a reputation beyond reputeDumbguy has a reputation beyond reputeDumbguy has a reputation beyond repute
Yes sir @gingermike sir. Just put in the order. Now to order camber arms and a skid plate :3 amped...
2012 VRM Mazdaspeed 3 - “Claudia”
Cobb v3 AP | Autotech HPFP Internals | UR Catback | Cp-e TMIC | Cp-e Stage 2 RMM | Cp-e Catted DP | TWM Full Replacement | CS Occ | CS Bpv | CS Hood Struts | JBR EGR delete | JBR Boost tubes and Recirc hose | HTP 3.5” Intake | 1 Step colder plugs | Blox 490 | BC Coilovers | Drag dr-49
Waiting for install
CS Battery box
2008 Black Mica Mazdaspeed 3 - "April" (Totaled, may she rest in piece)
Dumbguy is offline   Reply With Quote
The Following User Says Thank You to Dumbguy For This Useful Post:
 Old 04-22-2014, 12:39 PM   #195
gmoney542's Avatar
I put my order in last night. Can't wait to get these!
 Old 04-22-2014, 11:16 PM   #196
yourname2221's Avatar
Posts: 224   (View Stats)
yourname2221 is the leader of the worldyourname2221 is the leader of the worldyourname2221 is the leader of the worldyourname2221 is the leader of the worldyourname2221 is the leader of the worldyourname2221 is the leader of the worldyourname2221 is the leader of the worldyourname2221 is the leader of the worldyourname2221 is the leader of the worldyourname2221 is the leader of the worldyourname2221 is the leader of the world
paiiiiidddddd
Installed: JBR SSP/RMM/RSB
Cobb APv3/EBCS
AT Internals
Bilstein Coilovers
SPC arms
UR
TP/DP
BNR S4, JBR Undermount w/TR8, 3.5" intake
OBX CBE
For dat racecar: Gold Caliper Paint
yourname2221 is offline   Reply With Quote
The Following 3 Users Say Thank You to yourname2221 For This Useful Post:
Chimmike (04-23-2014), daafisch (04-23-2014), timmcc02 (04-23-2014)
 Old 04-23-2014, 08:15 AM   #197
timmcc02's Avatar
What are you guys gonna run for camber arms? I'm up in the air about either spc or corksport
 Old 04-23-2014, 08:18 AM   #198
Raider's Ohio Bottom Bitch
therza2169's Avatar
Posts: 204   (View Stats)
therza2169 is the leader of the worldtherza2169 is the leader of the worldtherza2169 is the leader of the worldtherza2169 is the leader of the worldtherza2169 is the leader of the worldtherza2169 is the leader of the worldtherza2169 is the leader of the worldtherza2169 is the leader of the worldtherza2169 is the leader of the worldtherza2169 is the leader of the worldtherza2169 is the leader of the world
I plan on going with JBR personally.
therza2169 is offline   Reply With Quote
 Old 04-23-2014, 08:20 AM   #199
timmcc02's Avatar
Love jbr's stuff but I'm not going to buy camber arms that you cant adjust on the car
 Old 04-23-2014, 08:31 AM   #200
therza2169's Avatar
Hmmm you might have a point there. I don't need my alignment guy hating me anymore lol.
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f408/gb-ground-control-koni-sport-coilovers-mazdaspeed-167667/
Konisport + ground control setup This thread Refback 04-25-2014 12:49 PM
Konisport + ground control setup This thread Refback 04-20-2014 03:35 AM
Ground control and koni yellows Bap 2010 MS3 - Suspension & Brakes 212 10-20-2016 11:43 AM
Koni Yellows martin_nj MazdaSpeed 3/6 - Suspension & Brakes 50 05-09-2012 10:27 AM
Page generated in 0.60714 seconds with 35 queries
