Like Tree48Likes
 Old 04-23-2014, 08:35 AM   #201
daafisch's Avatar
Posts: 3,553   (View Stats)
Groans: 58
Originally Posted by timmcc02 View Post
Love jbr's stuff but I'm not going to buy camber arms that you cant adjust on the car
SPC are a pain in the ass to adjust on the car.
 Old 04-23-2014, 08:40 AM   #202
Elvisrosales88's Avatar
Posts: 113   (View Stats)
Elvisrosales88 is the leader of the worldElvisrosales88 is the leader of the worldElvisrosales88 is the leader of the worldElvisrosales88 is the leader of the worldElvisrosales88 is the leader of the worldElvisrosales88 is the leader of the worldElvisrosales88 is the leader of the worldElvisrosales88 is the leader of the worldElvisrosales88 is the leader of the worldElvisrosales88 is the leader of the worldElvisrosales88 is the leader of the world
Groaned at 9 Times in 2 Posts
Which company do you think makes the best ones?
Cobb AP+ Stratified OTS--JBR Powerpath Stage III intake-- Turbosmart BPV--AutoTech Fuel Pump Internals--CPE TMIC-- OBX test pipe+ UR catback--ITV-22 plugs-- H&R springs--CPE RMM- JBR PMM and TMM--
Elvisrosales88 is offline   Reply With Quote
 Old 04-23-2014, 08:48 AM   #203
daafisch's Avatar
Groans: 58
I've only had experience with re-branded SPC's.
 Old 04-23-2014, 09:12 AM   #204
Mattyhawk1's Avatar
Posts: 739   (View Stats)
+1 on this, and not as much adjuability as JBR or Corksport.
 Old 04-23-2014, 09:13 AM   #205
timmcc02's Avatar
Posts: 253   (View Stats)
Groaned at 9 Times in 3 Posts
By design do you think the corksports would be better considering they use spherical bearings instead of bushings? or not a noticable difference?
 Old 04-23-2014, 09:42 AM   #206
daafisch's Avatar
Groans: 58
I guess they could be. I never looked into it too much because it came down to cost for me.
 Old 04-23-2014, 10:40 AM   #207
nybe0010's Avatar
Posts: 276   (View Stats)
nybe0010 is the leader of the worldnybe0010 is the leader of the worldnybe0010 is the leader of the worldnybe0010 is the leader of the worldnybe0010 is the leader of the worldnybe0010 is the leader of the worldnybe0010 is the leader of the worldnybe0010 is the leader of the worldnybe0010 is the leader of the worldnybe0010 is the leader of the worldnybe0010 is the leader of the world
Groaned at 3 Times in 1 Post
all you need! ^^^ ac delco are SPC iirc, i thought they were just repackaged. they can be adjusted on the car. line them up with the stock ones and then install and go get an alignment
11' Black Mica MS3 ATK Reman Long Block iMOTO Shift Forks LuK Clutch Fidanza Flywheel
GC+Koni Coilovers CNT CBE JBR Trilogy Mounts Forge V1 BPV CPE SafeSeals Block8Head Dual Vent Pod Blowshift Boost / OP
nybe0010 is offline   Reply With Quote
The Following 2 Users Say Thank You to nybe0010 For This Useful Post:
Chimmike (04-23-2014), daafisch (04-23-2014)
 Old 04-23-2014, 10:54 AM   #208
specvspeedfreak's Avatar
Posts: 2,371   (View Stats)
Besides the fact JBR's can't be adjusted on the car. JBR's also don't alllow for fine adjustments since you can only adjust half a turn at a time. Don't remember what that translates to in degrees. I know it's a small difference but just creates more work for the alignment guy.
 Old 04-23-2014, 12:37 PM   #209
gmoney542's Avatar
Posts: 236   (View Stats)
gmoney542 is the leader of the worldgmoney542 is the leader of the worldgmoney542 is the leader of the worldgmoney542 is the leader of the worldgmoney542 is the leader of the worldgmoney542 is the leader of the worldgmoney542 is the leader of the worldgmoney542 is the leader of the worldgmoney542 is the leader of the worldgmoney542 is the leader of the worldgmoney542 is the leader of the world
What are you guys gonna run for camber arms? I'm up in the air about either spc or corksport
I got Corksport, but mainly because I got them for free with the store credit I had with them.
They're really nice though, I'd still get them even if I had to pay for them.
2009 CWP Mazdaspeed3
- COBB AP V3 - Richtune - 50/50 E85 - Autotech HPFP Internals - CNT Catless Downpipe - HTP 3" Intake - NGK One Step Colder Plugs -
- Kozmic Motorsports EGR Deletes - JBR 88 RMM/TMM/PMM - JBR Shifter Bushings - JBR TIG + Coolant Bypass - JBR OCC -
- JBR RSB - GroundControl Coilovers - CorkSport Camber Plates - CorkSport Rear Camber Arms - CorkSport Rear Toe Arms -
- WhiteLine Front Endlinks - WhiteLine Bumpsteer Kit - WhiteLine Poly LCA Bushings - AWR Rear Endlinks -
- 18x8 Mazdaspeed MS-01S - Nitto NT05 245/40/18 -
gmoney542 is offline   Reply With Quote
The Following 3 Users Say Thank You to gmoney542 For This Useful Post:
Dumbguy (04-24-2014), Mattyhawk1 (04-24-2014), timmcc02 (04-23-2014)
 Old 04-24-2014, 01:10 PM   #210
Will fuck up ur day
Chimmike's Avatar
Posts: 6,003   (View Stats)
Groans: 433
Okay guys, let's keep the orders coming in!
Mattyhawk1 likes this.
07 MS3
The original Genpoo Hater
covelife1016 (04-24-2014), RPM (04-24-2014)
 Old 04-24-2014, 02:47 PM   #211
justinsane87's Avatar
Posts: 877   (View Stats)
justinsane87 is the leader of the worldjustinsane87 is the leader of the worldjustinsane87 is the leader of the worldjustinsane87 is the leader of the worldjustinsane87 is the leader of the worldjustinsane87 is the leader of the worldjustinsane87 is the leader of the worldjustinsane87 is the leader of the worldjustinsane87 is the leader of the worldjustinsane87 is the leader of the worldjustinsane87 is the leader of the world
I'm waiting to hear from my fellow edmontonian @- POD -;
Sent from the flux capacitor
2013 Mazdaspeed 3 - GTX3076R EWG
Autotechs - FreekBuilt 3.5" - UR Catless Turbo-back - AP V3 - ETS TMIC
JBR 80D Trilogy/SSP/Bushings/Heavy Knob/TIGs/0.250 RSB - GFB BOV
FreekTune'd - DO DVC-30 - Ground Control w/Koni Yellows - DM OCC
Enkei RPF1 17x9 w/ PSS 235/45/17 - Full Race Exhaust Mani
justinsane87 is offline   Reply With Quote
 Old 04-24-2014, 04:41 PM   #212
Mike@Stratified's Avatar
Posts: 1,119   (View Stats)
Sadly, after a lot of consideration I am going to have to pass on this deal, and it *is* a deal. The only factor that led me to this decision was the inability to adjust the rear shocks without removing them from the car. This is impractical for a daily driver that is also a weekend autocrosser.
 Old 04-24-2014, 05:17 PM   #213
Mattyhawk1's Avatar
While I completely understand not wanting to take the rear end apart to adjust, it is not as bad as it sounds. For me, it takes 40 minutes total from getting the first tool out to putting the last tool away.
The Following User Says Thank You to Mattyhawk1 For This Useful Post:
Mike@Stratified (04-24-2014)
 Old 04-24-2014, 06:57 PM   #214
Unfortunately making a change between runs would not be possible at most venues.
The Following User Says Thank You to Mike@Stratified For This Useful Post:
 Old 04-24-2014, 07:24 PM   #215
Dumbguy's Avatar
Posts: 130   (View Stats)
Dumbguy has a reputation beyond reputeDumbguy has a reputation beyond reputeDumbguy has a reputation beyond reputeDumbguy has a reputation beyond reputeDumbguy has a reputation beyond reputeDumbguy has a reputation beyond reputeDumbguy has a reputation beyond reputeDumbguy has a reputation beyond reputeDumbguy has a reputation beyond reputeDumbguy has a reputation beyond reputeDumbguy has a reputation beyond repute
Sighs... This is what I get fro not doing more research. If backing out at this point effects the GB then Ill prolly stay on and just figure something out. But if I can make a switch without screwing everyone up then Ill be switching... T.T
2012 VRM Mazdaspeed 3 - “Claudia”
Cobb v3 AP | Autotech HPFP Internals | UR Catback | Cp-e TMIC | Cp-e Stage 2 RMM | Cp-e Catted DP | TWM Full Replacement | CS Occ | CS Bpv | CS Hood Struts | JBR EGR delete | JBR Boost tubes and Recirc hose | HTP 3.5” Intake | 1 Step colder plugs | Blox 490 | BC Coilovers | Drag dr-49
Waiting for install
CS Battery box
2008 Black Mica Mazdaspeed 3 - "April" (Totaled, may she rest in piece)
Dumbguy is offline   Reply With Quote
 Old 04-24-2014, 08:11 PM   #216
RPM
RPM's Avatar
Posts: 1,149   (View Stats)
Just FYI... In an order to try to get these shipped out ASAP, we've already made a commitment to GC on all of these orders so they can begin preparing them. We really need to get the remaining 9 orders in. I'm not sure why everyone has waited to the last minute to start thinking about backing out, but it's very disconcerting.
The Following 7 Users Say Thank You to RPM For This Useful Post:
Chimmike (04-25-2014), daafisch (04-25-2014), Elvisrosales88 (04-25-2014), gmoney542 (04-24-2014), justinsane87 (04-24-2014), smoogs12 (04-25-2014), [R]usty (04-24-2014)
 Old 04-24-2014, 09:23 PM   #217
Raider's Ohio Bottom Bitch
therza2169's Avatar
Posts: 204   (View Stats)
therza2169 is the leader of the worldtherza2169 is the leader of the worldtherza2169 is the leader of the worldtherza2169 is the leader of the worldtherza2169 is the leader of the worldtherza2169 is the leader of the worldtherza2169 is the leader of the worldtherza2169 is the leader of the worldtherza2169 is the leader of the worldtherza2169 is the leader of the worldtherza2169 is the leader of the world
Hopefully the other 9 orders get in soon so I can get mine installed .
therza2169 is offline   Reply With Quote
The Following User Says Thank You to therza2169 For This Useful Post:
 Old 04-24-2014, 09:47 PM   #218
- POD -'s Avatar
Posts: 619   (View Stats)
- POD - is the leader of the world- POD - is the leader of the world- POD - is the leader of the world- POD - is the leader of the world- POD - is the leader of the world- POD - is the leader of the world- POD - is the leader of the world- POD - is the leader of the world- POD - is the leader of the world- POD - is the leader of the world- POD - is the leader of the world
Earliest I'll know is Monday. I've got a pending offer on a house. This is probably the worst month to be adding extra expenses, but if everything works out I might have a garage to work on the car in =D
- POD - is offline   Reply With Quote
The Following User Says Thank You to - POD - For This Useful Post:
 Old 04-24-2014, 09:52 PM   #219
gmoney542's Avatar
I can understand your concern about having to remove the shocks to adjust them, but Ground Control is presetting them to match your spring rates, effectively taking the guess work out of adjusting the shocks that you would otherwise have to do and eliminating the need to remove them.
And besides that, I'd rather have to take the shock off and have meaningful adjustments on good shocks, than get comparatively priced coilovers with adjusters that either don't do anything or are confused about what they should be doing on shocks that suck.
The Following 2 Users Say Thank You to gmoney542 For This Useful Post:
Chimmike (04-25-2014), yourname2221 (04-24-2014)
 Old 04-24-2014, 10:57 PM   #220
yourname2221's Avatar
Posts: 224   (View Stats)
yourname2221 is the leader of the worldyourname2221 is the leader of the worldyourname2221 is the leader of the worldyourname2221 is the leader of the worldyourname2221 is the leader of the worldyourname2221 is the leader of the worldyourname2221 is the leader of the worldyourname2221 is the leader of the worldyourname2221 is the leader of the worldyourname2221 is the leader of the worldyourname2221 is the leader of the world
I just want to hop in and apologize ahead of time for anyone else who backs out (inevitable) at the last minute and may completely duck this thread. I hate to see shit like this happen to a forum vendor who took the intiative to get a group buy together, to pass savings on to us.
This is the reason we don't see as many GB's as we should and I thank RPM for putting this together.
Dont take this personally, but why did it take you 3+ weeks to decide this.
This was posted two days after you 'committed'.
Originally Posted by skiptowncat View Post
Quick question - can the konis be adjusted whilst still on the car, I'm sure I read somewhere that they couldn't.
The rears have to be removed. The front can.
smoogs12 likes this.
Installed: JBR SSP/RMM/RSB
Cobb APv3/EBCS
AT Internals
Bilstein Coilovers
SPC arms
UR
TP/DP
BNR S4, JBR Undermount w/TR8, 3.5" intake
OBX CBE
For dat racecar: Gold Caliper Paint
yourname2221 is offline   Reply With Quote
The Following 4 Users Say Thank You to yourname2221 For This Useful Post:
Chimmike (04-25-2014), daafisch (04-25-2014), smoogs12 (04-25-2014), [R]usty (04-24-2014)
 Old 04-25-2014, 06:32 AM   #221
I never take it personal. I needed to research and weigh other options that didn't require removal to adjust, price difference between the two, and whether or not it was worth it. Unfortunately life got in the way of that plan and so it took me longer than I wanted it to.
@RPM; if you get 19 orders paid please contact me directly and I will buy the last set to make you whole.
 Old 04-25-2014, 09:39 AM   #222
Dumbguy's Avatar
NVM… After talking to them for half a minute and knowing this is a better setup than what I was planning on doing anyway is a comfort AND reading some of the things since written here Im still in. I don’t like the inability to adjust with the shocks on the car, but it’s something I can live with. As a noobcake it’s prolly not something I need to be messing with on the regular anyway without parental supervision. Please excuse my dumbassery.
Waiting for install
CS Battery box
The Following 3 Users Say Thank You to Dumbguy For This Useful Post:
Chimmike (04-25-2014), Elvisrosales88 (04-25-2014), RPM (04-25-2014)
 Old 04-25-2014, 01:13 PM   #223
Will fuck up ur day
Chimmike's Avatar
Groans: 433
Agreed with not really having to mess with it. If concerned, find the middle ground of the 5 adjustment settings......or perhaps see if GC can recommend the optimal shock setting for your spring rates and adjust accordingly before install!
07 MS3
 Old 04-25-2014, 02:41 PM   #224
Dumbguy's Avatar
But are they not presetting them for us? O.O Or is this something different that I don't know about yet?
Waiting for install
CS Battery box
 Old 04-25-2014, 03:01 PM   #225
RPM
RPM's Avatar
Yes, they will be. They'll be set and ready to install when you get them.
The Following 3 Users Say Thank You to RPM For This Useful Post:
Chimmike (04-26-2014), Dumbguy (04-25-2014), timmcc02 (04-25-2014)
 Old 04-25-2014, 03:18 PM   #226
Dumbguy's Avatar
Waiting for install
CS Battery box
The Following 2 Users Say Thank You to Dumbguy For This Useful Post:
Chimmike (04-26-2014), timmcc02 (04-25-2014)
 Old 04-26-2014, 07:05 AM   #227
Will fuck up ur day
Chimmike's Avatar
Groans: 433
so i'm guessing your name is pronounced "dumbgeee" because French?
07 MS3
 Old 04-26-2014, 07:13 PM   #228
Dumbguy's Avatar
W8 wut?
Waiting for install
CS Battery box
 Old 04-26-2014, 07:31 PM   #229
covelife1016's Avatar
Posts: 151   (View Stats)
covelife1016 has a reputation beyond reputecovelife1016 has a reputation beyond reputecovelife1016 has a reputation beyond reputecovelife1016 has a reputation beyond reputecovelife1016 has a reputation beyond reputecovelife1016 has a reputation beyond reputecovelife1016 has a reputation beyond reputecovelife1016 has a reputation beyond reputecovelife1016 has a reputation beyond reputecovelife1016 has a reputation beyond reputecovelife1016 has a reputation beyond repute
"This suit is NOT BLACK!" 3 more days left!!! Get them orders in so I can get these on the car.
2010 MS3 non tech
// CS TMIC// CS battery box// JBR short shifter// JBR 88a rmm// JBR boost tubes// JBR solid shifter bushings// JBR coolant bypass and throttle body tig// Kozmic Motorsports primary and secondary egr delete// NGK one step colder plugs// AT fuel pump internals// HTP 3" intake// GFB bov// COBB accessport V2 // GroundControl springs// Koni yellows//
TUNED BY STRATIFIED
covelife1016 is offline   Reply With Quote
The Following 3 Users Say Thank You to covelife1016 For This Useful Post:
Chimmike (04-27-2014), Dumbguy (04-26-2014), Mattyhawk1 (04-26-2014)
 Old 04-27-2014, 10:13 AM   #230
Canuck's Avatar
Posts: 6   (View Stats)
Canuck is just really niceCanuck is just really niceCanuck is just really niceCanuck is just really nice
Order placed.
Canuck is offline   Reply With Quote
The Following 2 Users Say Thank You to Canuck For This Useful Post:
Chimmike (04-27-2014), smoogs12 (04-27-2014)
 Old 04-27-2014, 11:17 AM   #231
- POD -'s Avatar
@justinsane87; We are good to go. My folks will let us ship to their place, and then they will send it up to me. Hopefully this will keep the costs down a bit further.
Let me know when you want to place your order and I'll PM you the address.
justinsane87 likes this.
The Following 2 Users Say Thank You to - POD - For This Useful Post:
Chimmike (04-27-2014), justinsane87 (04-27-2014)
 Old 04-27-2014, 01:12 PM   #232
- POD -'s Avatar
Hey @RPM;
@justinsane87; and I are ready to put orders in. We will be shipping to my folks place in Washington.
I will be getting Koni + GC. I'm ready to order at any time.
 Old 04-27-2014, 01:22 PM   #233
timmcc02's Avatar
Go to link on first page
The Following User Says Thank You to timmcc02 For This Useful Post:
- POD - (04-27-2014)
 Old 04-27-2014, 01:53 PM   #234
Order placed!
The Following 4 Users Say Thank You to justinsane87 For This Useful Post:
Chimmike (04-27-2014), RPM (04-27-2014), smoogs12 (04-27-2014), [R]usty (04-27-2014)
 Old 04-27-2014, 02:10 PM   #235
- POD -'s Avatar
Order Placed!
The Following 5 Users Say Thank You to - POD - For This Useful Post:
Chimmike (04-27-2014), Elvisrosales88 (04-29-2014), RPM (04-27-2014), smoogs12 (04-27-2014), [R]usty (04-27-2014)
 Old 04-27-2014, 02:29 PM   #236
Will fuck up ur day
Chimmike's Avatar
Groans: 433
Nice guys! Keep it going!
This is as good as it gets in terms of a low-cost coilover substituted, especially considered the struts are adjusted to match the spring rates right from GC, so no messing with strut settings! Set height and go!
07 MS3
The Following 3 Users Say Thank You to Chimmike For This Useful Post:
- POD - (04-27-2014), justinsane87 (04-27-2014), RPM (04-27-2014)
 Old 04-27-2014, 02:47 PM   #237
hmm. I must of misunderstood when "preset" was first announced. Is this just turning the knob to a setting that will handle the spring rate or doing something internally to handle the spring rate?
 Old 04-27-2014, 02:55 PM   #238
RPM
RPM's Avatar
It's setting the rebound using the knob before it's shipped. They are not being revalved, but GC also does not use springs that are beyond the capabilities of the shocks.
Sent from my Galaxy Nexus using Tapatalk
 Old 04-27-2014, 03:37 PM   #239
KevinK2's Avatar
Posts: 907   (View Stats)
KevinK2 is the leader of the worldKevinK2 is the leader of the worldKevinK2 is the leader of the worldKevinK2 is the leader of the worldKevinK2 is the leader of the worldKevinK2 is the leader of the worldKevinK2 is the leader of the worldKevinK2 is the leader of the worldKevinK2 is the leader of the worldKevinK2 is the leader of the worldKevinK2 is the leader of the world
Groaned at 79 Times in 52 Posts
I guess they could be.....
Moving along to do a 1:28+ at Summit Point. My best with my stock Rx7 + tires was 1:30.
Bravo!
From Delaware
Current Fleet: 04 Mazda6, 93 Rx7 TT, 76 Triumph 750 Trident
Tracked Cars: 68 Triumph GT6 (~full race prep'd), 81 Porsche 924 Turbo, 93 Rx7 twin turbo
KevinK2 is offline   Reply With Quote
The Following User Says Thank You to KevinK2 For This Useful Post:
daafisch (04-27-2014)
 Old 04-27-2014, 04:04 PM   #240
Adog35's Avatar
Posts: 309   (View Stats)
Adog35 is the leader of the worldAdog35 is the leader of the worldAdog35 is the leader of the worldAdog35 is the leader of the worldAdog35 is the leader of the worldAdog35 is the leader of the worldAdog35 is the leader of the worldAdog35 is the leader of the worldAdog35 is the leader of the worldAdog35 is the leader of the worldAdog35 is the leader of the world
Order placed.
When will they ship?
Are most of you guys running OEM top hats at this point?
2010 MS3
5% REAR 30% FRONT
DDM 5K HID
RMM
CS TIP/SRI
Dizzy Tuned
Autotech Internals
Swift Springs
JBR Rear Sway
Stoptech 309's
First Turbo Car and I love it!
Adog35 is offline   Reply With Quote
The Following 2 Users Say Thank You to Adog35 For This Useful Post:
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f408/gb-ground-control-koni-sport-coilovers-mazdaspeed-167667/
Konisport + ground control setup This thread Refback 04-25-2014 12:49 PM
Konisport + ground control setup This thread Refback 04-20-2014 03:35 AM
Ground control and koni yellows Bap 2010 MS3 - Suspension & Brakes 212 10-20-2016 11:43 AM
Koni Yellows martin_nj MazdaSpeed 3/6 - Suspension & Brakes 50 05-09-2012 10:27 AM
Page generated in 0.60473 seconds with 39 queries
