 Old 03-21-2011, 01:42 PM   #1
aviator79's Avatar
Posts: 3,934   (View Stats)
Default RPM Street Springs
We are trying to get RPM to make a new batch of street springs. We almost have enough people as they are requiring 25 people to make it worth their wild. We currently have 21 people so we are looking for 4 more. More info to come but these were priced at $230. There were some deals if you bought springs and shocks so I am not sure what will happen with that at the moment. Koni is running a 20% off special right now also, but I have not decided if I would go with Koni, or Bilstein. These are not the K-spec's made for the Koni shocks, which had slightly higher spring rates, but those only had a 0.5" drop front and rear.
Street Springs
Having analyzed the Mazdaspeed6 suspension, we determined that the ideal set of springs would provide a moderate drop while increasing the front spring rate by 18% to 330 lb/in and increasing the rear spring rate by 35% to 250 lb/in.
Spring Rates: 330# front / 250# rear
Approx. Drop: 1.1 inch front / 0.75 inch rear
So add your name:
1) Arinzeuno
2) Shaniqua
3) Delpharah
4) MATR6
5) 06Speed6
6) BCM06
7) RayDog26
8) micneill
9) speedtown
10) Ivan-mazda
11) Hixster
12) PIXLGAZR
13) path914
14) SpeedCheese
15) aviator79
16) Funkster777
17)Bigjohnb20
18) jgrangers4
19) turbosomsp
20) MSP06
21) Akito
06Speed6 (03-21-2011)
 Old 03-21-2011, 01:53 PM   #2
zer010gic's Avatar
Posts: 401   (View Stats)
zer010gic is the leader of the worldzer010gic is the leader of the worldzer010gic is the leader of the worldzer010gic is the leader of the worldzer010gic is the leader of the worldzer010gic is the leader of the worldzer010gic is the leader of the worldzer010gic is the leader of the worldzer010gic is the leader of the worldzer010gic is the leader of the worldzer010gic is the leader of the world
I may be interested but would have preferred the K-Specs. How do these compare?
Autotech Internals | ETS TMIC | Cobb AP | JBR Tru-3.5" Wide Path Aluminum | JBR RMM | JBR TMM | JBR PMM | JBR Short Shift Plate | Fidanza Flywheel | TWM Weighted Shift Knob | Hawk HPS 5.0 Pads | Techna-Fit Brake Lines | RedLine Fluids and Unicorn Blood | NGK 1 Step Colder | Damond OCC | TurboSmart Duel Port | CP-e SafeSeals | JBR TIG | JBR TBG | Damond EGR Delete
Miltuned!!!
Ready to Install
ATP Downpipe
zer010gic is offline   Reply With Quote
 Old 03-21-2011, 02:49 PM   #3
FADE2GRY's Avatar
Posts: 144   (View Stats)
FADE2GRY has a reputation beyond reputeFADE2GRY has a reputation beyond reputeFADE2GRY has a reputation beyond reputeFADE2GRY has a reputation beyond reputeFADE2GRY has a reputation beyond reputeFADE2GRY has a reputation beyond reputeFADE2GRY has a reputation beyond reputeFADE2GRY has a reputation beyond reputeFADE2GRY has a reputation beyond reputeFADE2GRY has a reputation beyond reputeFADE2GRY has a reputation beyond repute
The K-Specs (K for Koni) where made specifically for the Koni Yellow shocks and their dampening range. Not many were made as these were like a trial run for RPM. They were replaced by the Sport and Streets. The Sports (still available) are the closest thing to the k-specs but work well with the stock shocks and the Bilstein HD shocks. The Streets (no longer available) were made to satisfy the demand for proper springs for the MS6 AND provide a moderate drop. The Sport springs are probably the best springs for pure performance while the Streets makes some compromise for looks.
The K-Spec existed before there were a good coilover choice (BC Racing). Think of these as coilover kit. You needed to get the springs and the Koni shocks at the same time.
FADE2GRY is offline   Reply With Quote
 Old 03-21-2011, 02:50 PM   #4
aviator79's Avatar
K-spec:
Increasing the front spring rate by 36% and a rear spring rate increase of 57%.
Spring Rates: 380# front / 290# rear
Drop: 0.5 inch front / 0.5 inch rear
 Old 03-21-2011, 04:58 PM   #5
zer010gic's Avatar
K-spec:
Damn I want the K-Spec springs.
Also BC-Racing are crap.
I am going Koni or KW v2
Miltuned!!!
Ready to Install
ATP Downpipe
 Old 03-22-2011, 05:55 PM   #6
aviator79's Avatar
Ya, I want K-spec spring rates with street spring lower heights...but I dont think they would make those...
 Old 03-26-2011, 10:43 AM   #7
LMB77's Avatar
Posts: 112   (View Stats)
LMB77 has a reputation beyond reputeLMB77 has a reputation beyond reputeLMB77 has a reputation beyond reputeLMB77 has a reputation beyond reputeLMB77 has a reputation beyond reputeLMB77 has a reputation beyond reputeLMB77 has a reputation beyond reputeLMB77 has a reputation beyond reputeLMB77 has a reputation beyond reputeLMB77 has a reputation beyond reputeLMB77 has a reputation beyond repute
Bump, 2 more people needed!!
06 Speed 6: Cobb SRI/ TIP, AP stage 2, CS TB, CP-E FMIC, Forge BPV, Cp-e rear mm. TT FMM, AT internals, Freek tuned on 50% e85.
LMB77 is offline   Reply With Quote
 Old 05-22-2011, 09:55 PM   #8
slvrMPS6's Avatar
Posts: 34   (View Stats)
slvrMPS6 is a splendid one to beholdslvrMPS6 is a splendid one to beholdslvrMPS6 is a splendid one to beholdslvrMPS6 is a splendid one to beholdslvrMPS6 is a splendid one to beholdslvrMPS6 is a splendid one to behold
is this still going on? if so i want in.
2006 Speed6 - Liquid Platinum Metallic - Cobb SRI, SU TMIC+boost tubes, CP-E dogbone mount, Cobb AP on stage 1 93 w/LC+FFS, Denso ITV22's, JBarone Short Shift Plate, metal shifter bushings, Prosport Boost gauge in vent pod, Apexi TT, Yokohama S-Drive rubbers, DDM 35w 4500k HID fogs, various LEDs, JDM Mazda window visors, Shark fin antenna, Xcarlink IPhone 4 connection
slvrMPS6 is offline   Reply With Quote
 Old 05-23-2011, 01:19 AM   #9
Axle Breaker
jmhinkle's Avatar
Posts: 4,639   (View Stats)
Groans: 162
I've had RPM sports for 3 years now and always said they were the best spring for the MS6. Never liked the streets because they drop the front too much compared to the ass and it doesn't look right on the car. The only complaint I really have with the sports is they are plain out too soft in the rear only. The K-Specs would have been the absolute perfect setup for the 6 ever. Wish I had went that way in the beginning when they were still available.
 Old 05-23-2011, 07:59 AM   #10
triplejumper18's Avatar
Posts: 2,569   (View Stats)
Groans: 196
Joel, do you mean it evens out the wheel gap?
 Old 05-23-2011, 03:12 PM   #11
Axle Breaker
jmhinkle's Avatar
Groans: 162
Yeah, the gap on the sports was even all around. RPM said 3/4, but mine settle about an inch in the end. The streets always slammed the front down lower and makes the rear look like it needs more. The K-Spec were also an even drop, but with higher spring rates which the heavy beast really needs.
 Old 05-23-2011, 03:28 PM   #12
Groans: 196
My my wheel gap with streets is about even front and rear.
 Old 05-23-2011, 03:32 PM   #13
Axle Breaker
jmhinkle's Avatar
Groans: 162
I do remember yours looking good when we did them. If you look at the car in the first pic though they looked slammed in the front and almost no drop in the rear. That's how I've seen several peoples look after those springs. Maybe they changed them up a bit mid run and they came out a bit more even.
 Old 05-23-2011, 04:28 PM   #14
Groans: 196
I do remember yours looking good when I did them. If you look at the car in the first pic though they looked slammed in the front and almost no drop in the rear. That's how I've seen several peoples look after those springs. Maybe they changed them up a bit mid run and they came out a bit more even.
I fixed your statement for truth. All I did was a miserable job of keeping the downpour from flowing into the garage.
What's funny is the reason I went with these springs over the sports is because I saw a bunch of pictures of people with wheel gap just like what I ended up with. I do like how they don't drop the car too much and my wife wouldn't have even known they were on the car if I didn't say anything.
 Old 06-06-2011, 08:29 PM   #15
vortk355's Avatar
Posts: 27   (View Stats)
vortk355 is a splendid one to beholdvortk355 is a splendid one to beholdvortk355 is a splendid one to beholdvortk355 is a splendid one to beholdvortk355 is a splendid one to beholdvortk355 is a splendid one to beholdvortk355 is a splendid one to beholdvortk355 is a splendid one to behold
I am interested, add me to the list please
06 MS6 -APV3 self tuning, E40, HTP 3" intake w/ CA adapter, CPE tmic, ebay dp w/cat, CS internals, ported TB, SPCs, Brembo swap, SS brake/clutch lines, poly bushing, Bilsteins, RS-R springs
13.64/103mph before dp and E85
87 Mustang LX- stroked and blown 520+rwhp, full MM suspension/will be swapping in IRS and double A arm soon
65 F100- in the middle of crown vic swap
vortk355 is offline   Reply With Quote
 Old 05-14-2014, 04:42 PM   #16
Dizzy Turbo's Avatar
Posts: 2,173   (View Stats)
Can we try this again? Haha
 Old 05-14-2014, 05:45 PM   #17
aviator79's Avatar
nope...
 Old 05-15-2014, 06:46 AM   #18
223Patriot's Avatar
Posts: 54   (View Stats)
223Patriot has a reputation beyond repute223Patriot has a reputation beyond repute223Patriot has a reputation beyond repute223Patriot has a reputation beyond repute223Patriot has a reputation beyond repute223Patriot has a reputation beyond repute223Patriot has a reputation beyond repute223Patriot has a reputation beyond repute223Patriot has a reputation beyond repute223Patriot has a reputation beyond repute223Patriot has a reputation beyond repute
Holy necro post...
I do wish there were more spring options for the MS6 though...I would definitely buy a set of the RPM sports if they were still available.
2006 LPM MS6 "family car" - cobb AP v3, Autotech Internals, Corksport SRI, Corksport TIP, Corksport RMM, CP-E TMIC, M2 DP w/ hammer mod, Relentless Customs ported IM, JBR stage 2 OCC, TIG, EGR delete, TB coolant bypass, Stratified stage 2 S-OTS+ 93 tune.
2003 Mustang GT - SOLD
223Patriot is offline   Reply With Quote
 Old 05-15-2014, 07:43 AM   #19
And so it begins muahaha
 Old 05-15-2014, 08:25 AM   #20
Speeeeeed
06Speed6's Avatar
Posts: 6,530   (View Stats)
I've been mulling a k spec spring type GB since this one fell through years ago. I wonder how hard it would be to do. They really were the best spring ever made for our car.
2006 Mazdaspeed 6
 Old 05-15-2014, 08:29 AM   #21
I know haha that's why I just bring it up everywhere in hopes of some sort of response lol
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f408/rpm-street-springs-75473/
RPM Street Springs Group Buy - Page 12 - Mazda 6 Forums : Mazda 6 / Mazda Atenza Forum Post #1 Pingback 03-21-2011 01:45 PM
KONI Yellows w/ Cobb springs & stock springs Fobio MazdaSpeed 3/6 - Suspension & Brakes 9 08-20-2012 08:24 PM
RPM Street Springs Group Buy MS6 ivan-msp6 MazdaSpeed 3/6 - Suspension & Brakes 2 03-18-2011 04:51 PM
H&R vs. RPM Street Springs Mallyatx MazdaSpeed 3/6 - Suspension & Brakes 41 06-10-2010 11:25 AM
MS6 RPM Street springs and Koni Sport shocks Review MATT DAMOND MazdaSpeed 3/6 - Suspension & Brakes 20 06-01-2010 12:33 PM
Page generated in 0.40231 seconds with 31 queries
