> Members Rides Gallery
Like Tree59Likes
 Old 01-16-2017, 11:50 AM   #41
BobtailedSnail's Avatar
Posts: 1,375   (View Stats)
Heading to South Jersey tomorrow to pick up a Gen4 4.8 and a TH400, give me some options to play with.
RhoadBlock likes this.
Skreets be calling...
The Following 3 Users Say Thank You to BobtailedSnail For This Useful Post:
Bingo (07-14-2017), Mauro_Penguin (01-17-2017), RhoadBlock (01-16-2017)
 Old 01-17-2017, 06:25 PM   #42
$250 for a GEN4 4.8L short block, TH400, and Powerglide.
The Following 6 Users Say Thank You to BobtailedSnail For This Useful Post:
CWP_MS3 (01-18-2017), Mack_Sant (01-20-2017), Mauro_Penguin (01-17-2017), RhoadBlock (01-17-2017), rymanmazda (01-18-2017), thrisnospork (01-17-2017)
 Old 01-23-2017, 11:04 AM   #43
Default BobtailedSnail's LSx MS6 and N/T Nova
While we wait for this project to lift off, here's a video of Matt Hapel's second Colorado build, Gen 3 LQ4, reused the stock headbolts and headgasket. These motors amaze me everytime I see them.
https://www.youtube.com/watch?v=Zo3kZ8wbnkA
 Old 01-27-2017, 06:18 PM   #44
Little teaser. Friend let me borrow one of his Welds to test fit.
This is a 15x8 5.5"BS (21mm offset) with a 275/60 (28") I'll be doing a 26" tall but tire width is unknown. Also the wheel hit the caliper on the face of all places. So a little spacer will solve that issue or shaving the caliper down. Right where the barrel dips to meet the spokes. I'll probably order a set of 15x8 6.5"BS (51mm offset)
The Following 2 Users Say Thank You to BobtailedSnail For This Useful Post:
Mauro_Penguin (01-28-2017), RhoadBlock (01-29-2017)
 Old 01-28-2017, 07:19 PM   #45
BigRed06's Avatar
Posts: 96   (View Stats)
BigRed06 is a name known to allBigRed06 is a name known to allBigRed06 is a name known to allBigRed06 is a name known to allBigRed06 is a name known to allBigRed06 is a name known to all
Subbing to this so I can follow along even more, I'll continue to help where I can. Glad someone is making my dream come true, I'll be planning out my swap along the way of urs
MODS: AP V3, 3.5" intake, 3bar, gt3076 atp ewg, 38mm wg, SS turbo lines, 3" catless dp, 3" exhaust dp, hpfp, egr delete, vtcs delete, Mac 4port, lil intake mani port work, cxracing fmic, 51R battery cut stock battery tray, Toyota injector seals
BigRed06 is offline   Reply With Quote
The Following User Says Thank You to BigRed06 For This Useful Post:
 Old 01-28-2017, 07:50 PM   #46
More pics
Where it nicks the caliper.
I know the poke is corny. It'll tuck nicely inside the car on the finished product. Thank you to @BigRed06; for getting me straight on what brakes to use in the rear to eliminate the contact issue all together.
Last edited by BobtailedSnail; 01-28-2017 at 07:50 PM. Reason: MSF Database - Automerged Doublepost
Mazdazilla6 (01-29-2017), qtrmile beast (07-16-2017), RhoadBlock (01-29-2017)
 Old 01-29-2017, 06:05 AM   #47
RhoadBlock's Avatar
Posts: 793   (View Stats)
Groaned at 7 Times in 4 Posts
Good to know that 15s will work. What brakes are you gonna use in the rear?
Also, I know fender flares are sorta corny but they would cover the poke.
Sent from my Pixel XL using Tapatalk
2007 MS6 - broked & gone
2006 MS6 - less broked
RhoadBlock is offline   Reply With Quote
 Old 01-29-2017, 06:46 AM   #48
03-05 Mazda6 rears. They should be considerably smaller. A set of good rotors and pads and I should be fine.
I really do want them to tuck. And I'm sure the 6.5"BS (51mm offset) will be nice and flush. I also decided to run 245/55/15 M&H radials. Equivalent to a 26x9. I've had good luck with M&H on my Chevelle (325/45/17) and my Nova (390/45/15). This makes it easier for me on the front tires as well. I can do a 17 in the front with Evo calipers and 245/45/17
The Following User Says Thank You to BobtailedSnail For This Useful Post:
 Old 04-15-2017, 06:35 PM   #49
Little update. Finally sold the motor out of the speed! No more 4cyl in my life.
Also wrapped up a single turbo Silverado build for a friend of mine.
My first order of business is to finish my Nova before May 18th and have Nishan tune it so I can go to the Cruisin' in Ocean City. Then the Mazda will be focused on. But I did purchase a motor plate and heads for it so it's not on the back burner by any means. I also sold the Powerglide today and am going to cut to make this TH400 fit. Look for mockup pics soon.
RhoadBlock, SVTJon87 and Mack_Sant like this.
The Following 4 Users Say Thank You to BobtailedSnail For This Useful Post:
cld12pk2go (04-17-2017), Easter Bunny (04-27-2017), Mauro_Penguin (04-16-2017), RhoadBlock (04-15-2017)
 Old 04-26-2017, 08:40 PM   #50
Picked up some coils for the 6 today
Mack_Sant likes this.
 Old 07-14-2017, 09:09 AM   #51
turbskies's Avatar
Posts: 178   (View Stats)
turbskies is a splendid one to beholdturbskies is a splendid one to beholdturbskies is a splendid one to beholdturbskies is a splendid one to beholdturbskies is a splendid one to beholdturbskies is a splendid one to beholdturbskies is a splendid one to behold
Groaned at 9 Times in 6 Posts
https://clinchedflares.com/product/glider12/
I think these should help you fit a bigger tire.
turbskies is offline   Reply With Quote
 Old 12-21-2017, 08:33 PM   #52
MSF's Punishing Member
Pu Manchu's Avatar
Posts: 2,992   (View Stats)
Groans: 546
bump.
sharksinspace and turbskies like this.
94 M
MS6
IS350
The Following 5 Users Say Thank You to Pu Manchu For This Useful Post:
BobtailedSnail (03-20-2018), KiwiFlavor (12-22-2017), Mauro_Penguin (01-11-2018), rymanmazda (12-25-2017), Vansquish (12-21-2017)
 Old 03-20-2018, 03:01 PM   #53
Bump! Spoke to 16W Fab works today and we are finally getting started on mounting the Cobra 8.8 IRS rear in stock rear subframe. I’m putting the finishing touches on my Nova tomorrow get it racing this year. I’m swaying on if I want to still run a TH400 or do the work to fit up a 4L80e.
Flares won’t necessarily help fit a larger tire without cutting the fenders, which I’d rather back half the car and put a 4link in it with tubs before I went with flares.
Last edited by BobtailedSnail; 03-20-2018 at 03:01 PM. Reason: MSF Database - Automerged Doublepost
Db09ms3 (03-20-2018), Pu Manchu (03-22-2018)
 Old 08-14-2018, 10:44 AM   #54
Hey guys. I’m in need of some measurements of the Rear Subframe mounts. My subframe is 4.5hours away and I haven’t been able to pick it up so I need some help.
Here’s what I’m looking for.
Distance left to right and front to back of the mounting holes in the subframe.
Thanks in Advance.
 Old 08-14-2018, 12:46 PM   #55
myarbro1's Avatar
Posts: 39   (View Stats)
myarbro1 has a reputation beyond reputemyarbro1 has a reputation beyond reputemyarbro1 has a reputation beyond reputemyarbro1 has a reputation beyond reputemyarbro1 has a reputation beyond reputemyarbro1 has a reputation beyond reputemyarbro1 has a reputation beyond reputemyarbro1 has a reputation beyond reputemyarbro1 has a reputation beyond reputemyarbro1 has a reputation beyond reputemyarbro1 has a reputation beyond repute
I bet Clint has those measurements Mike. I’m not sure I can get under the car today but I can get that for you soon if he doesn’t.
Mica Black '06 Speed6 GT #02871: E85 tune by Purple Drank - AT internals - Damond RMM - WW FMM - MF CBE - eBay DP - RamFab 4" intake - Custom FMIC - GS EBCS - TS BOV - CS stress bars - CD rotors - EBC Redstuffs - H&R Sports w/ Koni Yellows - Redline hood struts - PnP IM - MS OCC's - Full Race exhaust mani - GTX2867r - CP-e rear diff mount - SURE Juggernaught - Diff caps - DSS axles - EVO 8 Brembos - lots fucking more
myarbro1 is offline   Reply With Quote
The Following User Says Thank You to myarbro1 For This Useful Post:
BobtailedSnail (08-14-2018)
 Old 08-14-2018, 04:09 PM   #56
Thanks. I talked to Clint on Saturday and his car is already gonzo.
 Old 08-15-2018, 08:37 AM   #57
myarbro1's Avatar
I was unable to get the measurements out in the parking lot. Ill put it on ramps and get those asap.
The Following 2 Users Say Thank You to myarbro1 For This Useful Post:
BobtailedSnail (08-15-2018), Vansquish (08-15-2018)
 Old 08-15-2018, 09:58 AM   #58
Wow Thank you very much.
Vansquish likes this.
 Old 09-21-2018, 01:00 PM   #59
Should have a few more parts in the next couple of days. Purchased some solid subframe bushings and poly bushings from Phates thread. Ditched the Cobra 8.8 for a S550 super 8.8
 Old 09-22-2018, 03:20 PM   #60
Picture of the converter and example of the 8.8
File Type: jpeg 79A991B0-8041-4383-A670-409225D46DE7.jpeg (55.0 KB, 22 views)
File Type: jpeg 87B5467C-6DF7-410B-B5DE-3B61331138D0.jpeg (116.8 KB, 20 views)
 Old 09-26-2018, 06:21 AM   #61
SNOW_QN's Avatar
Posts: 384   (View Stats)
I like the idea of going with the s550 diff. Any particular reason why you switched when you had the Cobra one already? Looking forward to seeing your build progress. My goal is to ls swap a 6 in the future. My plans are more aligned with @RhoadBlock; is going for, but it will be nice to see all out build like this happen.
The Following User Says Thank You to SNOW_QN For This Useful Post:
BobtailedSnail (09-30-2018)
 Old 09-26-2018, 08:02 AM   #62
SNOW_QN's Avatar
Also, what are you doing as far as intake manifold? I see that you test fitted the long block; would an ls1,2,3, or 6 style intake clear the hood? And lastly, what are you looking at for oil pan? F-body?
 Old 09-30-2018, 06:43 PM   #63
From my river math I think a truck manifold would fit. I’m planing to run a TBSS breadbox intake. Oil pan is TBD because I will need to address the steering rack first.
As for the S550 Rear vs Cobra rear
Here’s the lowdown on why I want this particular rear.
I want to keep IRS. It’s really easy to tell if a car has been Backhalfed with a solid axle.
I want to race in stock suspension races. Grudge/street racers are big on that stuff. That’s my wheel house.
There’s more than 1 type of IRS 8.8
The Cobra 8.8’s are just fine for the job after you upgrade the rear cover mounting point.
1999-some 2000 had a 28 spline Carrier. Weak sauce for pretty much any rear.
03-04 Terminators has a 31 spline carrier. Perfect most most power levels close to 1000hp depending on tire.
You have the iron Lincoln 8.8’s
Explorer IRS 8.8’s which are really big and beefy. But some had two front mounts. Some had one.
15-18 S550 IRS 8.8 (called the Super 8.8. Has a 34 spline carrier. Available in a wide variety of ratios. And a 3.73 Torsen from the Track pack models. Auto cars had aluminum cases. Stick cars had iron. I would stick with iron. All engine choices had an 8.8. It’s been 7’s so I say it’s proven.
Mauro_Penguin (12-01-2018), myarbro1 (10-02-2018), SNOW_QN (10-02-2018)
 Old 09-30-2018, 06:44 PM   #64
This 8.8 is huge. This is next to my th400.
File Type: jpeg ECF6C0C3-045F-42E7-8342-F7277FE84CD3.jpeg (3.49 MB, 34 views)
 Old 10-01-2018, 04:36 PM   #65
Engine mounts and solid subframe bushings have arrived.
File Type: jpeg E1233C2A-DC92-4EF3-A385-00B4715D6EE5.jpeg (2.82 MB, 24 views)
Db09ms3 (11-29-2018), Mauro_Penguin (12-01-2018), mr_mazda329 (04-01-2019), myarbro1 (10-02-2018)
 Old 11-29-2018, 09:10 AM   #66
SNOW_QN's Avatar
How's it going? You starting to work on this a little more now that the weather is getting colder?
Nice breakdown on the 8.8s btw. Didn't know some of that info. Good stuff!
turbskies likes this.
 Old 03-30-2019, 03:51 PM   #67
I have just recently started working on the car again, finally have the space to roll it into the shop and get started. As from the beginning, I my goal is to keep the car functioning like it was factory equipped with an LS. That pretty much translates to breaking down the CAN bus protocols. I plan to use Megasquirt pro 3 for this car, so i need to figure out if i can use it as a piggyback or if i will have to build a CANbus emulator to control the MS-CAN and some HS-CAN gateways between the chassis and MS3Pro ecu.
SNOW_QN and eroler1 like this.
mr_mazda329 (04-01-2019), myarbro1 (04-01-2019), SNOW_QN (04-02-2019)
 Old 05-19-2019, 03:35 PM   #68
Got the speed in the shop finally. This week I will mock up the Mustang K member and see how it all fits up.
File Type: jpeg AB6EB4AE-3701-4F90-98BA-388E05CAD11B.jpeg (776.9 KB, 15 views)
File Type: jpeg 2076196E-BEA9-45D4-94F5-FD9EDD22D487.jpeg (772.8 KB, 14 views)
daafisch (05-21-2019), Db09ms3 (05-20-2019), Fstrnyou (05-21-2019), JSmith (05-25-2019), Pu Manchu (05-19-2019), Tomas (05-22-2019)
 Old 05-24-2019, 07:58 AM   #69
Got the factory subframe out and dropped the body on the mustang K member. It will need to come back about two more inches to get the wheelbase correct, as well as the k member trimmed to fit inside the frame rails so nothing is hanging lower than the floor. All in all moving in the right direction. I didn’t want to build a k member solely for the fact that I can order tubular parts from a huge selection of vendors. The engine will be mounted to an engine plate so where the k member sits has no relation to the engine.
SNOW_QN likes this.
The Following 5 Users Say Thank You to BobtailedSnail For This Useful Post:
Db09ms3 (05-24-2019), myarbro1 (05-29-2019), Pu Manchu (05-26-2019), SNOW_QN (06-01-2019), Tomas (05-28-2019)
 Old 05-28-2019, 06:47 AM   #70
Bob Ross Fanclub
Tomas's Avatar
Posts: 3,811   (View Stats)
I can't really see how all that shit will come together but keep at it brohemian.
Db09ms3 likes this.
 Old 05-28-2019, 09:50 PM   #71
Stock Mustang K member seemed to put me in the right direction. So I tried a tubular Outlaw style one, definitely moving in the right direction. Minor trimming and channeling on the frame rails and slight modifications to the strut towers and we’ll be well on our way.
File Type: jpeg D1908831-A84C-4055-82A3-AF724CAD49AF.jpeg (1.05 MB, 26 views)
File Type: jpeg 87138132-2F95-4DDC-BE49-818208C1284B.jpeg (866.8 KB, 20 views)
Mack_Sant and SNOW_QN like this.
Db09ms3 (05-29-2019), myarbro1 (05-29-2019), SNOW_QN (06-01-2019)
 Old 06-01-2019, 05:02 PM   #72
SNOW_QN's Avatar
Love it! The difference in bulk between that aftermarket k member and stock is ridiculous.
BobtailedSnail (06-02-2019)
 Old 06-02-2019, 07:20 PM   #73
It really is. I think UPR claims it saves 37lbs over the factory K member. I purchased a QA1 member on Friday. I like the way it mounted better than the UPR. The main drop hoop is attached inside of the mounting flange rather than outside. Bringing the overall width down, which is what I want in order to fit inside the factory frame rails, to attain the correct height for the subframe.
 Old 11-05-2019, 05:08 PM   #74
Pitstopdave's Avatar
Posts: 1   (View Stats)
Pitstopdave has a little shameless behaviour in the past
What year mustang k member?
Pitstopdave is offline   Reply With Quote
The Following User Says NO Thank You to Pitstopdave For This Un-useful Post:
Db09ms3 (11-05-2019)
BobtailedSnail's Compound Turbo MS6 BobtailedSnail MazdaSpeed 3/6 - Build Diaries 271 12-31-2016 07:07 PM
New guy from NoVa McBlack Mazdaspeed3/6 General Discussion 14 05-09-2012 10:42 AM
Page generated in 0.53296 seconds with 29 queries
