> Cobb Tuning >
Cobb ATR Support
 Old 02-03-2014, 10:08 AM   #1
Gr8Speed's Avatar
Posts: 5,702   (View Stats)
Default 14.0/14.2/14.4 AFR at Part Throttle
Alright not really sure where to post this since I'm not sure if the issue is going to end up being mechanical or map related. But I'm running Cobb OTS Stage 2 with a 3" intake. I installed the intake and a downpipe at the same time. I scaled the MAF table values to accommodate for the intake and after driving for about 20-30 miles the AFR starts to taper down to near 14.0-14.2 and stays there. I also get rich shifts of anywhere between 12.8-13.6, but then spikes back up to the normal 29. At WOT it's like 9.9 usually, nowhere near target. I've started troubleshooting the issue and have come up with a number of possible culprits. My trims aren't really that far off. Not perfect, but I think +/-6 was the highest I was seeing for LTFT. I'm going to run through all of these things tonight and am wondering if anyone has anything to add to the list.
1. I can see a small exhaust leak coming off the turbo/DP connection. There was a small crack in the weld that I fixed with some Quiksteel until next week because nobody can weld stainless here except a few people and they're busy until then, but I can still see a little bit of smoke rise when I rev with the hood open really aggressively.
2. The downpipe has 2 Primary O2 bungs. Is it possible I have the O2 in the wrong one? Gen One which should it be? (DP is eBay M2)
3. Shift Control Tables gone goofy?
4. It's a gen one, so I don't think this is it but the extended bung for the Secondary O2. Will that possibly cause this?
Thanks guys.
 Old 02-03-2014, 10:15 AM   #2
Uranium9v's Avatar
Posts: 142   (View Stats)
Uranium9v has a reputation beyond reputeUranium9v has a reputation beyond reputeUranium9v has a reputation beyond reputeUranium9v has a reputation beyond reputeUranium9v has a reputation beyond reputeUranium9v has a reputation beyond reputeUranium9v has a reputation beyond reputeUranium9v has a reputation beyond reputeUranium9v has a reputation beyond reputeUranium9v has a reputation beyond reputeUranium9v has a reputation beyond repute
check that secondary o2 bung you aren't using! they can loosen or even lose the plug and it will cause chaos.
Uranium9v is offline   Reply With Quote
The Following User Says Thank You to Uranium9v For This Useful Post:
Gr8Speed (02-03-2014)
 Old 02-03-2014, 10:19 AM   #3
Gr8Speed's Avatar
Didn't even think of that. Will do. You know which primary bung to use? I'm using the one that's kinda on the top.
 Old 02-03-2014, 10:26 AM   #4
Dimenus's Avatar
Posts: 2,825   (View Stats)
Groans: 33
Log?
9.9 at WOT screams boost leak to me. Probably hot side of the IC?
2012 Velocity Red Mica
 Old 02-03-2014, 10:34 AM   #5
Gr8Speed's Avatar
Originally Posted by Dimenus View Post
Log?
Will post a log this afternoon. No boost leaks though. First thing I checked.
 Old 02-03-2014, 10:50 AM   #6
Dimenus's Avatar
Groans: 33
Also, always take logs with TCS/DSC completely off. SWAS is a bitch (and will throw your AFRs off).
 Old 02-03-2014, 10:52 AM   #7
Gr8Speed's Avatar
SWAS is gone lol. Fuck traction control.
impossible (07-12-2014)
 Old 02-03-2014, 05:23 PM   #8
Gr8Speed's Avatar
Got some logs. 28 and 29 are just driving. 30 is for an MAF cal.
I also have a video uploading of what I think may be the sound of the exhaust leak.
I also have ruled out that it was tune related. Rob, who is tuning me, sent me over a map with everything set right and it's still being goofy. I am not getting any KR (.7 at times).
 Old 02-03-2014, 06:18 PM   #9
Gr8Speed's Avatar
I think since I have determined that it is not tune related I am going to move this thread.
 Old 02-03-2014, 06:49 PM   #10
It also looks as if you have some funky trim action. Some of your problem is the leak @ the weld.
 Old 07-12-2014, 11:44 AM   #11
BrandonRKD's Avatar
Posts: 417   (View Stats)
BrandonRKD is the leader of the worldBrandonRKD is the leader of the worldBrandonRKD is the leader of the worldBrandonRKD is the leader of the worldBrandonRKD is the leader of the worldBrandonRKD is the leader of the worldBrandonRKD is the leader of the worldBrandonRKD is the leader of the worldBrandonRKD is the leader of the worldBrandonRKD is the leader of the worldBrandonRKD is the leader of the world
Ever find out your problem?
2006 WWP MS6
Cobb AP, SRI, TIP ▌CP-E HPFP, Safe Seals ▌CS TBE ▌TS BPV ▌Custom FMIC ▌NGK Colder Plugs ▌JBR TIG, EGR Blockoff ▌TB Coolant B/P ▌VTCS Delete ▌H&R Springs
FlowTuned By TiGraySpeed6
BrandonRKD is offline   Reply With Quote
 Old 07-12-2014, 11:46 AM   #12
Gr8Speed's Avatar
Yup. Ended up being a massive exhaust leak between the 1st and 2nd O2s.
BrandonRKD (07-12-2014), SarcasticOne (07-12-2014)
Unsettling hesitation under part throttle and full throttle at first track day dachtler 2010 MS3 - ECU Computer Tuning 0 10-01-2012 02:49 PM
Part throttle surging SPEEDRAC3R MazdaSpeed 3/6 - ECU Computer Tuning 23 03-23-2011 07:14 AM
OL/part throttle at what percent throttle? MS3Zoom24
Cobb ATR Support
4 10-31-2009 02:37 PM
Part Throttle AFR badams118
Cobb ATR Support
48 05-19-2009 08:38 PM
Knock at part throttle! SLOMS3 MazdaSpeed 3/6 - ECU Computer Tuning 7 04-13-2009 11:00 AM
Page generated in 0.33111 seconds with 25 queries
