| Not Ranked : 0 score Another thread revival! I don't know if anyone is curious about this, but I'm gonna try something. My wheel speed sensors are indicating 0mph at all times, probably due to wheel bearings pressed in with the magnet on the wrong side. So I'm changing the tables to 1 across the board. It was set at 1.3 while at 0mph.
| The Following User Says Thank You to btstarcher For This Useful Post: | Mauro_Penguin (03-23-2015) |
| Using the App translation tables for smooth powerful results | dread | Cobb ATR Support | 29 | 08-16-2013 07:34 AM |
| functioning trip comp | k0m | MazdaSpeed 3/6 - Car Audio & Electronics | 2 | 09-09-2009 03:38 PM |
| Ford: Falcon to be first RWD four-cylinder EcoBoost car. Translation? No such Mustang until 2011... if at all | Haltech | Automotive News | 0 | 07-24-2009 12:00 PM |
| Boost Comp & RPM | badams118 | Cobb ATR Support | 3 | 05-07-2009 12:36 PM |
| Stock comp pistions | Grim | Mazdaspeed3/6 General Discussion | 14 | 09-17-2008 07:30 AM |
