> Cobb Tuning >
Cobb ATR Support
 Old 04-20-2009, 06:17 PM   #1
smakdown61's Avatar
Posts: 1,069   (View Stats)
Default Copying MAF calibrations between maps
I'm currently running 1.03r stage 1+ 93. The ltft's are very close to 0 and I seem to be hitting my AFR's spot on. I tested out a stage 2 map and my fuel trims were nearly -10 and it leaner than the target afr. Would it be acceptable to copy the maf values from the stage 1 map to the stage 2 map?
smakdown61 is offline   Reply With Quote
The Following User Says Thank You to smakdown61 For This Useful Post:
thanox2 (04-21-2009)
 Old 04-21-2009, 12:37 PM   #2
SLS MS3's Avatar
Posts: 1,254   (View Stats)
SLS MS3 is the leader of the worldSLS MS3 is the leader of the worldSLS MS3 is the leader of the worldSLS MS3 is the leader of the worldSLS MS3 is the leader of the worldSLS MS3 is the leader of the worldSLS MS3 is the leader of the worldSLS MS3 is the leader of the worldSLS MS3 is the leader of the worldSLS MS3 is the leader of the worldSLS MS3 is the leader of the world
Yes
2007 Sunlight Silver MS3
Graphite RX8 Rims · 235/40R18 Kumho SPTs
BC Coilovers · Cobb Swaybars · DBA 4000 Slotted Rotors · Technafit SS Brake Lines · SU Rear MM · TRZ Trans Mount · TopSpeed Passenger MM
Cobb AP · MS CAI w/ AEM Straightener · Cobb Turbo Inlet · Cobb FMIC · Black HKS SSQV (recirc) · PG Exhaust Manifold · Corksport Downpipe · Vibrant Exhaust
mrlilguy CDFP · Denso ITV22s plugs · Cobb STS, Shift Knob, & Shifter Weight · F2 Balance Shaft Delete & Oil Baffle
Stock is just plain, gay.
SLS MS3 is offline   Reply With Quote
 Old 04-21-2009, 01:26 PM   #3
thanox2's Avatar
Posts: 1,236   (View Stats)
thanox2 is the leader of the worldthanox2 is the leader of the worldthanox2 is the leader of the worldthanox2 is the leader of the worldthanox2 is the leader of the worldthanox2 is the leader of the worldthanox2 is the leader of the worldthanox2 is the leader of the worldthanox2 is the leader of the worldthanox2 is the leader of the worldthanox2 is the leader of the world
Groans: 639
Groaned at 39 Times in 29 Posts
hmmm this would be awesome
"Asking the front wheels of a car to do their normal job of steering while handling more than 170hp is like asking a man to wire a plug while juggling... penguins... while making love... to a beautiful woman while on fire, on stage... in front of the Queen. It's all going to go wrong." Most people would have just called it "wrong-wheel drive."
thanox2 is offline   Reply With Quote
 Old 04-21-2009, 02:52 PM   #4
SLS MS3's Avatar
You can create your own calibrations as long as you have some datalogs. The excel spreadsheets have the formulas, all you have to do is input the data from your logs and you can copy/paste the output.
V1.03 Calibrations Now Available for Mazdaspeed3 AccessPORT Cobb Tuning MazdaSpeed 3/6 - ECU Computer Tuning 5 01-09-2009 05:54 PM
Teens copying enemies' license plates to get revenge via speed cameras Haltech Automotive News 0 12-24-2008 04:20 PM
Any input from Stage 2 ONLY maps (not + SF, MSCAI maps) steven88
Cobb Access Port/Maps
8 10-15-2008 06:48 AM
101 maps are out subparpunk03
21 07-08-2008 02:58 PM
Page generated in 0.24883 seconds with 22 queries
