> Cobb Tuning >
Cobb ATR Support
 Old 12-14-2010, 06:17 PM   #1
Jarods7920's Avatar
Posts: 1,415   (View Stats)
Default DTC disable....?
So in the old version of ATR i seem to remember there being a wealth of codes you could disable, now it seems there are only the handful of preselected ones? Or am i again missing somethiing?
 Old 12-14-2010, 06:27 PM   #2
trey said its REALLY time consuming to actually implement the code for each diff DTC so he just picked the most popular ones we need to delete. eventually they will all be there.
 Old 12-23-2010, 12:08 PM   #3
RacingToaster's Avatar
Posts: 426   (View Stats)
RacingToaster is the leader of the worldRacingToaster is the leader of the worldRacingToaster is the leader of the worldRacingToaster is the leader of the worldRacingToaster is the leader of the worldRacingToaster is the leader of the worldRacingToaster is the leader of the worldRacingToaster is the leader of the worldRacingToaster is the leader of the worldRacingToaster is the leader of the worldRacingToaster is the leader of the world
Groans: 40
So if I wanted to Disable DTC where would i go?
RacingToaster is offline   Reply With Quote
 Old 12-23-2010, 12:11 PM   #4
m4tic's Avatar
Posts: 4,928   (View Stats)
edit > advanced parameters > toggles
2017 Daytona 392
STOLEN//2015 BMW S1000R
2007 MS6 w/ Cheez
thanox2 (01-29-2011)
 Old 12-23-2010, 02:47 PM   #5
Groans: 40
Ok I had saw that but had no idea what the toggle where for I know it listed the codes. Cool BmorrisJ, your my hero man thanks for answering my retarded questions
 Old 12-23-2010, 09:23 PM   #6
jracer's Avatar
Posts: 1,706   (View Stats)
Groans: 89
do you do it on the AP itself or in Atr ?? or AP manager ??
H&R springs/H&R 15mm spacers
MAP catless testpipe
MAP UICP
Grimmspeed 3 port
Cosworth filter
SSP relay kit
TWM Desert Eagle shift knob
AEM wideband gauge
Prosport boost gauge
EvoX piller pod
30%Tint
Slowpoke Tuned 339hp/336tq
**** SOLD *****
2006 speed6
 Old 01-16-2011, 01:34 PM   #7
evidence's Avatar
Posts: 1,033   (View Stats)
You disable the code in ATR and save your map.
Some things.
 Old 03-10-2011, 05:19 PM   #8
sallyspeed3's Avatar
Posts: 638   (View Stats)
sallyspeed3 is the leader of the worldsallyspeed3 is the leader of the worldsallyspeed3 is the leader of the worldsallyspeed3 is the leader of the worldsallyspeed3 is the leader of the worldsallyspeed3 is the leader of the worldsallyspeed3 is the leader of the worldsallyspeed3 is the leader of the worldsallyspeed3 is the leader of the worldsallyspeed3 is the leader of the worldsallyspeed3 is the leader of the world
so anyone running catless can just permanently deactive that code and never have to worry when getting it inspected? freaking awesome.
2008 Cosmic Blue Mazdaspeed 3 GT - COBB AP DIZZYTUNED for 30% E85//JBR Whale Penis//COBB TIP//COBB DP//COBB STS//COBB Knob//COBB shift weight//COBB Piping TR8L Core//Magnaflow CBE//Turbosmart BPV//PTP internals//SU RMM//TRZ tranny mount//Koni + H&R springs//Tinted 35% front, 20% rear//Lamin-X head-light & tail-light film//ASA GT1 18x8//Hankook Ventus V12 225/40//
sallyspeed3 is offline   Reply With Quote
 Old 03-10-2011, 05:32 PM   #9
SSinstaller's Avatar
Posts: 3,989   (View Stats)
Groans: 60
YEP...
If they keep adding features, it's going to get very hard for me to keep running my SB....
jracer (03-28-2011)
 Old 03-10-2011, 06:17 PM   #10
cpolly69's Avatar
Posts: 2,116   (View Stats)
Groans: 27
Originally Posted by SSinstaller View Post
YEP...
ditto
although i will say i think the same results can be had for this by just unplugging the swas - no matter what any haters say, i've never been happier since i pulled that thing....
08 CB MS3 Sport
Sold
01 MX-5 (Project)
03 P5 (DD)
 Old 10-06-2014, 05:27 PM   #11
Alpha's Avatar
Posts: 3,711   (View Stats)
Hella bump, but which DTC is turned off when going catless?
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f418/dtc-disable-67224/
Passenger power window doesn't work. How do I reset? | MCX7 Community Forums This thread Refback 08-06-2013 02:41 PM
Passenger power window doesn't work. How do I reset? This thread Refback 06-27-2011 10:31 PM
Passenger power window doesn't work. How do I reset? This thread Refback 12-26-2010 08:16 PM
How do I disable the steering angle sensor, to prevent power cut in 2nd gear at track. FreeFlyFreak MazdaSpeed 3 - Engine, Transmission & Driveline 30 08-30-2014 05:30 PM
Throttle limiting disable? Spirry MazdaSpeed 3/6 - ECU Computer Tuning 3 11-14-2010 05:56 PM
How to disable VTA on standback base map chuwi MazdaSpeed 3/6 - ECU Computer Tuning 3 06-14-2010 12:22 PM
GM Recalls 1.5 Million Cars to Disable WindShield Washer Heaters. Haltech Automotive News 1 06-09-2010 12:11 PM
Disable image popup on hover? sweetpickles Website Help/Feedback 10 12-19-2008 04:50 PM
Page generated in 0.32862 seconds with 29 queries
