![]() Join Date: Mar 2008 Location: Navarre, FL
Rep Power: 4956 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,585
Groans: 370
(Thread Starter) | Not Ranked : 0 score Wanted to make a new thread with the jerky throttle "fix", maybe for a good sticky candidate or at least easy for guys who are searching to get there answers/solutions once this area starts filling up with more threads. There's nothing I hate more than having to wade through pages of BS in a thread, trying to find my answer to something. There very well may be more "smooth throttle" fixings and discoveries to be had, but this seems pretty significant and VERY easy to implement, so I thought it was definitely worth letting everyone know about.....anyone can do this fix. -------------------------------- Jerky throttle response (part throttle is like full boost or similar) seems to be mainly linked to one or two tables in the ECU, thankfully. Under your Load tables, check out your "Throttle - Requested Load A" and "C" variation tables (they should be identical). If it looks like this, then you are probably having jerky throttle response, which you probably are already well aware of: http://i165.photobucket.com/albums/u...%203/ATR/1.jpg Here's the fix. I noticed in the official v103 Stage 2 + SF 93 FMIC map, the throttle response was MUCH smoother and better to drive around. I found that this table was the only main difference (at least relevant to throttle response) to another map which was nearly identical, except had very jerky throttle response. It seems like Christian knew about it..I mean obviously he made these changes, but decided not to implement them in all maps for whatever reason. It's been tested and verified by others and myself that you can simple copy and paste over the A and C tables over to your current map and throttle response will be greatly improved. So if you want to fix this in 2 minutes, go to Cobb's site and download the v103 map mentioned above. Here's what your table should look like after the "fix": http://i165.photobucket.com/albums/u...%203/ATR/2.jpg Here's a link to Cobb's map list site: cobb . MAZDASPEED3 accessport . map listing ----------------------------------------------- OR, just copy and paste this into your "Throttle - Requested Load A" and "Throttle - Requested Load C" tables under the "Load Tables" folder Code: 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.64 0.46 0.34 0.19 0.19 0.19 0.19 0.19 0.19 0.19 0.19 0.19 0.19 0.19 0.19 0.67 0.68 0.61 0.38 0.38 0.38 0.38 0.38 0.38 0.38 0.38 0.38 0.38 0.38 0.38 0.68 0.77 0.80 0.58 0.58 0.58 0.58 0.58 0.58 0.58 0.58 0.58 0.58 0.58 0.58 0.69 0.80 0.90 0.77 0.77 0.77 0.77 0.77 0.77 0.77 0.77 0.77 0.77 0.77 0.77 0.69 0.81 0.94 0.96 0.96 0.96 0.96 0.96 0.96 0.96 0.96 0.96 0.96 0.96 0.96 0.70 0.82 0.95 1.15 1.15 1.15 1.15 1.15 1.15 1.15 1.15 1.15 1.15 1.15 1.15 0.70 0.83 0.96 1.35 1.35 1.35 1.35 1.35 1.35 1.35 1.35 1.35 1.35 1.35 1.35 0.70 0.82 0.97 1.54 1.54 1.54 1.54 1.54 1.54 1.54 1.54 1.54 1.54 1.54 1.54 0.70 0.83 0.97 1.73 1.73 1.73 1.73 1.73 1.73 1.73 1.73 1.73 1.73 1.73 1.73 0.70 0.83 0.97 1.92 1.92 1.92 1.92 1.92 1.92 1.92 1.92 1.92 1.92 1.92 1.92 0.70 0.83 0.97 2.12 2.12 2.12 2.12 2.12 2.12 2.12 2.12 2.12 2.12 2.12 2.12 0.70 0.83 0.97 2.31 2.31 2.31 2.31 2.31 2.31 2.31 2.31 2.31 2.31 2.31 2.31 0.70 0.83 0.97 2.50 2.50 2.50 2.50 2.50 2.50 2.50 2.50 2.50 2.50 2.50 2.50 0.70 0.83 0.97 2.50 2.50 2.50 2.50 2.50 2.50 2.50 2.50 2.50 2.50 2.50 2.50 0.70 0.83 0.97 2.50 2.50 2.50 2.50 2.50 2.50 2.50 2.50 2.50 2.50 2.50 2.50 0.70 0.83 0.97 2.50 2.50 2.50 2.50 2.50 2.50 2.50 2.50 2.50 2.50 2.50 2.50 Last edited by aaronc7; 04-16-2010 at 01:29 PM. |
| The Following 31 Users Say Thank You to aaronc7 For This Useful Post: | acidbbg (11-03-2010), alien_sporez (05-23-2012), Andrew85 (08-09-2009), Arrowpoint (04-28-2009), badams118 (04-26-2009), bioevolve (04-26-2009), Constantin (05-23-2012), DaleNixon (12-15-2009), Demi (04-30-2009), dougefresh_ (03-25-2010), evo2ms3 (04-27-2009), Faggmeister (04-29-2014), FreeFlyFreak (04-25-2009), hashboogie (04-29-2009), hnda etr (05-10-2011), itzl0l (04-25-2009), kgb (04-25-2009), mike8748 (04-20-2010), mouse0330 (08-03-2009), mr_mazda329 (03-16-2010), phantom3 (04-25-2009), ponny135 (04-25-2009), Qwik6 (11-20-2009), RayRayBauder (03-26-2010), SharkDiver (06-01-2009), SJP0tato (07-19-2010), SoyBean (11-02-2009), super_pablo_ (02-14-2010), xcoldricex (03-24-2010), Z3roFlaw (06-20-2011), ztuner (04-27-2009) |
![]() Join Date: May 2008 Location: Bellevue, WA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 39
| Not Ranked : 0 score Neat, nice find.
__________________ '06 MS6 Black Mica Street Unit Block, CP Pistons (9.0:1), Pauter Rods, CPBoost Top-mounted Turbo Exhaust Manifold w/ Tial 38mm External Wastegate, Custom 3", CP-E FCF (No Boost cut, 3.25" MAF), CP-E PnP Standback V2, CP-E HPFP, CP-E FMIC Core w/ Custom piping, Denso Spark Plugs, Custom Inlet w/ 3.25" MAF Housing, VCTS Delete, EGR Block-off, Saikou Michi OCC, Fidanza Flywheel, HD Signature 18x8" MSR Wheels, HTR Z III's 235/40/18, BS Delete, TWM Stage 2 SS Kit, Dashhawk, Perrin EBCS. |
![]() Join Date: Jun 2008
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 300
| Not Ranked : 0 score good work man....DEFF STICKY this now did this change anything with the other issue u were having?
__________________ ![]() 07 cb Ms3 - MS cai / Vibrant exhaust / TurboXS DP / Cobb AP - trapped 107 TOTALED 11/2/09 ![]() 04 SRT4 - sold - trapped 120+ |
Groans: 370
(Thread Starter) | Not Ranked : 0 score first post updated with exact code.... now you can just copy and paste this directly into your map of choice. |
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1
| Not Ranked : 0 score Boost doesn't seem to come on as quick. With this map. |
![]() Join Date: Sep 2008 Location: Phoenix, AZ
Rep Power: 1352 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 813
| Not Ranked : 0 score Well before youd get max boost at 30%+ throttle for a quick second, what's most likely happening now that this isnt the case is your feeling the delay of your foot actually covering the 60% of the pedal left to go wot and actually get that same boost. I'd guess Mazda has the car jerky like this from the factory to combat that natural delay and make the car feel peppier.
__________________ Some things. |
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 92
| Not Ranked : 0 score once you get used to it the car drives so much better. Feels like an NA car. Very linear power.
__________________ [SIGPIC]http://i163.photobucket.com/albums/t318/dreadedhero/DSCN2058-2.jpg[/SIGPIC] 2007 ms3 sport black mica completely stock |
| The Following User Says Thank You to dread For This Useful Post: | aaronc7 (04-26-2009) |
![]() Join Date: Mar 2008 Location: GA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 91
| Not Ranked : 0 score +1. Christian just applied this to my e-tune today, and it's exactly what I was looking for with partial throttle. It HAS to be like this on my backroads, so much smoother. First time I can make an AP map hold 5,10,15,20, whatever psi with direct throttle increase. Awesome find.
__________________ //Cobb AccessPORT//Cobb E-Tune@20psi//SU TMIC//Mazdaspeed CAI//HKS SSQV//RPMC Turbo Inlet//CP-E HPFP//Corksport Race Pipe//Resonator Delete//Corksport MM Inserts//TWM STS//TWM Bushings//Denso ITV22//Prosport Premium Boost//RX-8 Wheels//Kumho Ecsta XS's 235-40//Valentine One//35% Tint//TRADED IN WW EVO X GSR//SSS//Navi//Advan Racing RS 19x10//BC Racing Coilovers//Cobb AccessPORT//Perrin 3-port/AMS FMIC//UR UICP//Works Air Filter//UR Test Pipe//Trust PE II Exhaust//Defi Boost Gauge//APR Vortex Generator//Ralliart Tails//20% Tint//Valentine One// |
| Not Ranked : 0 score It runs great....now just need more power 8) |
![]() Join Date: Apr 2009 Location: BPT Connecticut
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 72
| Not Ranked : 0 score Good Intel! How do i get my AP to make maps like that on my laptop?? i still view my data logs in excel.
__________________ |
| Not Ranked : 0 score you need to download accesstuner race
| Not Ranked : 0 score ok I tried a slightly different calibration for throttle requested loads tables a and c. This gives more load throughout and maintains the smooth throttle. I like it even better. 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.64 0.46 0.34 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.67 0.68 0.61 0.41 0.41 0.41 0.41 0.41 0.41 0.41 0.41 0.41 0.41 0.41 0.41 0.68 0.77 0.80 0.62 0.62 0.62 0.62 0.62 0.62 0.62 0.62 0.62 0.62 0.62 0.62 0.69 0.80 0.90 0.82 0.82 0.82 0.82 0.82 0.82 0.82 0.82 0.82 0.82 0.82 0.82 0.69 0.81 0.94 1.02 1.02 1.02 1.02 1.02 1.02 1.02 1.02 1.02 1.02 1.02 1.02 0.70 0.82 0.95 1.22 1.22 1.22 1.22 1.22 1.22 1.22 1.22 1.22 1.22 1.22 1.22 0.70 0.83 0.96 1.42 1.42 1.42 1.42 1.42 1.42 1.42 1.42 1.42 1.42 1.42 1.42 0.70 0.82 0.97 1.62 1.62 1.62 1.62 1.62 1.62 1.62 1.62 1.62 1.62 1.62 1.62 0.70 0.83 0.97 1.82 1.82 1.82 1.82 1.82 1.82 1.82 1.82 1.82 1.82 1.82 1.82 0.70 0.83 0.97 2.02 2.02 2.02 2.02 2.02 2.02 2.02 2.02 2.02 2.02 2.02 2.02 0.70 0.83 0.97 2.22 2.22 2.22 2.22 2.22 2.22 2.22 2.22 2.22 2.22 2.22 2.22 0.70 0.83 0.97 2.42 2.42 2.42 2.42 2.42 2.42 2.42 2.42 2.42 2.42 2.42 2.42 0.70 0.83 0.97 2.50 2.50 2.50 2.50 2.50 2.50 2.50 2.50 2.50 2.50 2.50 2.50 0.70 0.83 0.97 2.50 2.50 2.50 2.50 2.50 2.50 2.50 2.50 2.50 2.50 2.50 2.50 0.70 0.83 0.97 2.50 2.50 2.50 2.50 2.50 2.50 2.50 2.50 2.50 2.50 2.50 2.50 0.70 0.83 0.97 2.50 2.50 2.50 2.50 2.50 2.50 2.50 2.50 2.50 2.50 2.50 2.50
| The Following User Says Thank You to dread For This Useful Post: | Fobio (04-28-2009) |
| pewpew ![]() ![]() Join Date: Apr 2008 Location: NoVA
Rep Power: 760 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,124
Groaned at 9 Times in 9 Posts
| Not Ranked : 0 score dread, i'm at work right now, but i just wanted to clarify: can i just copy and paste what you just posted directly into ATR? i'm just hoping the spacings between the entries are correct so that they line themselves up in ATR... |
| Driver ![]() Join Date: May 2008 Location: Toronto
Rep Power: 1986 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,158
Groans: 44
| Not Ranked : 0 score Dread, how did you come up with this? just trying to understand the logic of the changes made for personal understanding.
__________________ ![]() DONE . Cobb AP 22-psi Self-Tuned . ATP GT3071 . CP-e 3.25" MAF+4" inlet . Denso ITV-24 . CP-e HPFP . CP-e FMIC . Turbosmart Ultimate BPV . 50/50 Meth w/ M5 nozzle . PTP IM Spacer+EGR delete . GrimmSpeed EBCS 3-port . SteedSpeed Mani . CP-e TBE . Greddy OCC w/ 2nd PCV valve . F2 BSD + oil-pan baffle . Hawk HP+ pads . Goodridge SS brake lines w/ Ford Super Dot 4 . Cobb Springs+FSB . Tri-Point RSB+Endlinks . Koni Yellows . KMAC Camber Plates . 60mm Boost Gauge . TWM Complete Shifter w/ JBR SSP+weight . CP-e RMM+PTP trans+kicker mount . Sparco Harness Bar w/ MOMO 4-pt harness . Rays/Volks 57F 18x8.5" +45mm 235/40/18 Hankook V12 . BBS RK 17x8" +45mm 235/45/17 RA1/R6 . OEM Snowflakes w/ 215/50/17 Nitto NT-SN1 . 3rd in CSCS 2009 Time Attack Championship - Super Street FWD . 360whp/390wtrq . SOON . 3-bar MAP sensor . MSpeed Tuning & Diagnostics - The Street Lab is ALWAYS OPEN FOR BUSINESS "It is amazing how many drivers, even at the Formula One Level, think that the brakes are for slowing the car down." -- Mario Andretti -- |
| Not Ranked : 0 score Yes you can copy the values into the throttle requested load table a and c, just make sure the graph still looks smooth. All I did was increase the values from the table aaron posted giving adding slightly more load at even increments. For example he is requesting 2.31 load at 75% throttle. My map request 2.42. You can increase these values more but would need to reach max load at a lower throttle value to keep the values linear.
| The Following 2 Users Say Thank You to dread For This Useful Post: | Fobio (04-28-2009), SharkDiver (06-01-2009) |
| Not Ranked : 0 score awesome...i'll paste in these changes with my next MAF update so that i can see if i like them better... |
| Not Ranked : 0 score Its not a huge difference but the car opens up a bit sooner. You may want to add more load. I will probably end up adding more at some point. I want to see how I like this after the map settles in.
| Not Ranked : 0 score ya, i'm not looking to go crazy on the load mapping right now. i've noticed that the less aggressive load ramp up appears to help with my LTFTs, which makes sense, since sudden jumps in load must make it hard to keep accurate record of how much air is going through the intake. |
![]() Join Date: Nov 2008 Location: Citrus Heights, CA
Rep Power: 0 ![]() ![]() ![]() Thanks: 0
| Not Ranked : 0 score I just wanted to point out an observation. I pasted both Aaronc7's adjusted table and dread's into the table on ATR and the new values make a huge difference in how they graph out. From 2000 rpms the TPS and load values create a completely linear path up to 100% TPS. The Cobb map was very uneven, undulated a lot and at about 65% TPS abruptly jumped up to 100%. I'm no expert in this but i'd like to understand why the 2 tables would be so different? Is there a reason the orig. tables weren't linear like the ones you guys posted? |
![]() Join Date: Nov 2008 Location: Las Vegas, NV
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,218
Groans: 94
Groaned at 38 Times in 19 Posts
| Not Ranked : 0 score It sounds like it was really a "sprint booster" per say but the boosting was actually implemented into the ECU tuning. Not surprising at all considering things like that make the car seem much faster and more responsive.
__________________ "We already have the Speed6 replacement" "It's just called the CX-7 now" ![]() back at http://www.mcx7.com bitches, spam free |
![]() | | #24 | ![]() |
Groans: 44
| Not Ranked : 0 score I never wanted the "boost taper" that haltech/Christian did for 1.02. And in the soapbox hal basically said as much that guys wanted the kick in the pants. The linear throttle is better for driveability and I'm glad now with atr I can choose between the two if needs be.
![]() | | #25 | ![]() |
Rep Power: 414 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 105
| Not Ranked : 0 score My gut reaction is it wasn't a Christian decision, it was a corporate decision to listen to just one group of people. I think Cobb looked at the ots maps as "Branded" maps and developed and marketed them accordingly. A brand has to have recognizable characteristics, appeal to a certain customer etc. Why they chose the least informed is anyone's guess.
__________________ ![]() |
| The Following User Says Thank You to fjames For This Useful Post: | Fobio (04-28-2009) |
![]() | | #26 | ![]() |
Groans: 44
I do wonder if the throttle smoothing slows down throttle response since car might run richer instead, causing a lower EGT and thus slower turbo spool? My LTFT are within +/- 5% but the car doesn't feel like it's running rich at all...
__________________ ![]() DONE . Cobb AP 22-psi Self-Tuned . ATP GT3071 . CP-e 3.25" MAF+4" inlet . Denso ITV-24 . CP-e HPFP . CP-e FMIC . Turbosmart Ultimate BPV . 50/50 Meth w/ M5 nozzle . PTP IM Spacer+EGR delete . GrimmSpeed EBCS 3-port . SteedSpeed Mani . CP-e TBE . Greddy OCC w/ 2nd PCV valve . F2 BSD + oil-pan baffle . Hawk HP+ pads . Goodridge SS brake lines w/ Ford Super Dot 4 . Cobb Springs+FSB . Tri-Point RSB+Endlinks . Koni Yellows . KMAC Camber Plates . 60mm Boost Gauge . TWM Complete Shifter w/ JBR SSP+weight . CP-e RMM+PTP trans+kicker mount . Sparco Harness Bar w/ MOMO 4-pt harness . Rays/Volks 57F 18x8.5" +45mm 235/40/18 Hankook V12 . BBS RK 17x8" +45mm 235/45/17 RA1/R6 . OEM Snowflakes w/ 215/50/17 Nitto NT-SN1 . 3rd in CSCS 2009 Time Attack Championship - Super Street FWD . 360whp/390wtrq . SOON . 3-bar MAP sensor . MSpeed Tuning & Diagnostics - The Street Lab is ALWAYS OPEN FOR BUSINESS "It is amazing how many drivers, even at the Formula One Level, think that the brakes are for slowing the car down." -- Mario Andretti -- | |
![]() | | #27 | ![]() |
| Not Ranked : 0 score I did some more driving with my updated throttle settings and the power definately comes on quicker and the smoothness is maintained. I may end up pushing it more, but I am pretty content with how it drives now.
![]() | | #28 | ![]() |
Groans: 44
| Not Ranked : 0 score I know this sounds really bad...but dread, I can't copy and paste your table onto my atr...it just won't do it.
![]() | | #29 | ![]() |
Code: 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.64 0.46 0.34 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.67 0.68 0.61 0.41 0.41 0.41 0.41 0.41 0.41 0.41 0.41 0.41 0.41 0.41 0.41 0.68 0.77 0.80 0.62 0.62 0.62 0.62 0.62 0.62 0.62 0.62 0.62 0.62 0.62 0.62 0.69 0.80 0.90 0.82 0.82 0.82 0.82 0.82 0.82 0.82 0.82 0.82 0.82 0.82 0.82 0.69 0.81 0.94 1.02 1.02 1.02 1.02 1.02 1.02 1.02 1.02 1.02 1.02 1.02 1.02 0.70 0.82 0.95 1.22 1.22 1.22 1.22 1.22 1.22 1.22 1.22 1.22 1.22 1.22 1.22 0.70 0.83 0.96 1.42 1.42 1.42 1.42 1.42 1.42 1.42 1.42 1.42 1.42 1.42 1.42 0.70 0.82 0.97 1.62 1.62 1.62 1.62 1.62 1.62 1.62 1.62 1.62 1.62 1.62 1.62 0.70 0.83 0.97 1.82 1.82 1.82 1.82 1.82 1.82 1.82 1.82 1.82 1.82 1.82 1.82 0.70 0.83 0.97 2.02 2.02 2.02 2.02 2.02 2.02 2.02 2.02 2.02 2.02 2.02 2.02 0.70 0.83 0.97 2.22 2.22 2.22 2.22 2.22 2.22 2.22 2.22 2.22 2.22 2.22 2.22 0.70 0.83 0.97 2.42 2.42 2.42 2.42 2.42 2.42 2.42 2.42 2.42 2.42 2.42 2.42 0.70 0.83 0.97 2.50 2.50 2.50 2.50 2.50 2.50 2.50 2.50 2.50 2.50 2.50 2.50 0.70 0.83 0.97 2.50 2.50 2.50 2.50 2.50 2.50 2.50 2.50 2.50 2.50 2.50 2.50 0.70 0.83 0.97 2.50 2.50 2.50 2.50 2.50 2.50 2.50 2.50 2.50 2.50 2.50 2.50 0.70 0.83 0.97 2.50 2.50 2.50 2.50 2.50 2.50 2.50 2.50 2.50 2.50 2.50 2.50
__________________ Some things. | |
![]() | | #30 | ![]() |
| Not Ranked : 0 score how do you do the code thing
![]() | | #31 | ![]() |
![]() Join Date: Mar 2008 Location: Columbia, SC
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 275
| Not Ranked : 0 score you can paste into ATR. First select all the values in dread's code block and copy. Then in ATR select the first cell (top left) by left clicking and then scroll all the way down and right so that you can see the last cell (bottom right). Hold shift and click the last cell, now every cell should be selected (the graph at the bottom should be solid white). Now just hit CTRL+V and it will paste the new values.
__________________ 07 MS3 GT w/Nav + Mods |
![]() | | #32 | ![]() |
| Not Ranked : 0 score I know how to paste into ATR I am Dread. My question was how do I post the code on here so you guys can use it.
| The Following User Says Thank You to dread For This Useful Post: | Arnie1229 (01-15-2015) |
![]() | | #33 | ![]() |
Groans: 94
| Not Ranked : 0 score liek this [code][ /CODE] Code: duh
![]() | | #34 | ![]() |
| Not Ranked : 0 score haha thanks
![]() | | #35 | ![]() |
![]() Join Date: Mar 2008 Location: Pittsburgh, PA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 17,174
Groans: 45
| Not Ranked : 0 score have you guys done anything with the close loop to open loop delay? |
![]() | | #36 | ![]() |
Groans: 44
| Not Ranked : 0 score yeah, once you do the code quotes it keeps the cell format. I pasted evidence's code and it worked out just as dread's table is. thanks again! Yes...I like how it quickly goes into the 10's w/ my AFR @ WOT.
![]() | | #37 | ![]() |
Groans: 45
| Not Ranked : 0 score what did you set it at? i might have missed it. |
![]() | | #38 | ![]() |
Groans: 44
| Not Ranked : 0 score I'm just using SLS's settings on a tune that Christian did for him.
![]() | | #39 | ![]() |
Groans: 45
| Not Ranked : 0 score ok i was asking what value did you use for the delay. i think cobb has it set at 30ms |
![]() | | #40 | ![]() |
Groans: 44
| Not Ranked : 0 score SLS's settings are @ 15, I believe
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f418/fixing-jerky-throttle-response-atr-26456/ | ||||
| MPS6 engine hesitation - Page 6 | This thread | Refback | 06-03-2013 08:08 PM | |
| Car feels slow after Cobb AP flash - Page 3 | This thread | Pingback | 10-21-2012 07:15 PM | |
| orkut - Trepidação Old Duratec | This thread | Refback | 07-10-2011 06:07 AM | |
| AP Maps - Which one? | This thread | Refback | 05-31-2011 12:47 AM | |
| Catless DP Tune | This thread | Refback | 11-20-2010 09:05 AM | |
| MS3 vs. MS6 vs. CX7 engine failure - Page 2 - Mazda 6 Forums : Mazda 6 / Mazda Atenza Forum | This thread | Refback | 02-28-2010 10:07 AM | |
| MS3 vs. MS6 vs. CX7 engine failure - Mazda6 / Atenza | This thread | Refback | 11-20-2009 01:20 PM | |
| MS3/ATR: Smooth Throttle Fixes (May 23, 2009) - TorontoMazda3 | This thread | Refback | 05-29-2009 08:35 AM | |
| MS3/ATR: Smooth Throttle Fixes (May 23, 2009) - TorontoMazda3 | This thread | Refback | 05-23-2009 06:19 AM | |
| Jerky part throttle acceleration | dread | Cobb ATR Support | 38 | 04-25-2009 09:19 AM |
| car feels jerky in 5 and 6 | Tcman2006 | MazdaSpeed 3/6 - Turbo Induction | 30 | 03-08-2009 02:15 PM |
| fixing my broken used MS3 | Boonestafa | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 17 | 02-25-2009 09:19 PM |
| The HKS CORPORATE response to the HKS SSQ BOV | clown_car | MazdaSpeed 3/6 - Turbo Induction | 5 | 01-30-2009 09:02 PM |
| Whats the problem? (Car jerky while in boost) | MattJackson86 | MazdaSpeed 3 - Engine, Transmission & Driveline | 14 | 12-24-2008 11:20 AM |
