> Cobb Tuning >
Cobb ATR Support
Closed Thread
 Old 05-10-2009, 02:27 PM   #1
chrisyng's Avatar
Posts: 107   (View Stats)
chrisyng has a reputation beyond reputechrisyng has a reputation beyond reputechrisyng has a reputation beyond reputechrisyng has a reputation beyond reputechrisyng has a reputation beyond reputechrisyng has a reputation beyond reputechrisyng has a reputation beyond reputechrisyng has a reputation beyond reputechrisyng has a reputation beyond reputechrisyng has a reputation beyond reputechrisyng has a reputation beyond repute
Default heads up - AP bricked ECU
Not to raise any paranoia (even though it seems like the common thing to do on here these days) - Seems that a number of people, including me, have ended up with dead ecu's in the last couple days when flashing out ECU's...
flash interrupted car wont start - COBB Forums
It seems odd to me that all of this has started happening in the last couple days.. I did nothing from my usual flashing technique, my AP was plugged in at all times, I did not bump the cable, it just decided to seemingly kill the ECU... From the looks of it, nobody has been able to recover from this yet.. sucks that it looks like the ECU will have to be removed and sent to Cobb.. however, people may want to hold off on flashing their ecus for the momment until we get word back from cobb on what exactly is going on.. I am crossing my fingers that I will not need a new ECU.. how the heck am I going to explain that to the dealer??
chrisyng is offline
 Old 05-10-2009, 02:32 PM   #2
ztuner's Avatar
Posts: 554   (View Stats)
ztuner is the leader of the worldztuner is the leader of the worldztuner is the leader of the worldztuner is the leader of the worldztuner is the leader of the worldztuner is the leader of the worldztuner is the leader of the worldztuner is the leader of the worldztuner is the leader of the worldztuner is the leader of the worldztuner is the leader of the world
hmmn - have you been using ATR ?
Harry
Z32 Specialist
07 Sport
Cobb AP - V103f map
Cobb Sri
ETS 3.25 TMIC
Vibrant Catted midpipeback exhaust
Forge BPV
CS inserts
Dashhawk logger
Soon to follow
SSR Wheels and wider tires
CS downpipe
Check out
http://ztuner.com/newdyno.htm
ztuner is offline
 Old 05-10-2009, 02:34 PM   #3
Deadman's Avatar
Posts: 868   (View Stats)
Deadman is the leader of the worldDeadman is the leader of the worldDeadman is the leader of the worldDeadman is the leader of the worldDeadman is the leader of the worldDeadman is the leader of the worldDeadman is the leader of the worldDeadman is the leader of the worldDeadman is the leader of the worldDeadman is the leader of the worldDeadman is the leader of the world
Groaned at 31 Times in 16 Posts
i have flashed 72345 times and no problems.... no but seriously i have flashed many many times and ecu is still going strong!
Deadman is offline
 Old 05-10-2009, 02:35 PM   #4
Jarods7920's Avatar
Posts: 1,415   (View Stats)
i hope its not a case where the ecu can only be written to a certain number of times.
Jarods7920 is offline
 Old 05-10-2009, 02:41 PM   #5
chrisyng's Avatar
yes, I have been using ATR and was just about to flash a revised map onto my ECU.. I have had my AP since last sept and have flashed my ecu several times since then without issue... until today..
chrisyng is offline
 Old 05-10-2009, 03:00 PM   #6
Derek88's Avatar
Posts: 773   (View Stats)
Derek88 is the leader of the worldDerek88 is the leader of the worldDerek88 is the leader of the worldDerek88 is the leader of the worldDerek88 is the leader of the worldDerek88 is the leader of the worldDerek88 is the leader of the worldDerek88 is the leader of the worldDerek88 is the leader of the worldDerek88 is the leader of the worldDerek88 is the leader of the world
I wouldn't panic. This happened to me and I just needed to update the dongle and the AP from my computer. Get the latest software update from Cobb's website and make sure you update it in AP manager.
-Derek
No longer in the Mazdaspeed Family
Derek88 is offline
 Old 05-10-2009, 03:48 PM   #7
chrisyng's Avatar
I unistalled my AP updater as well as AP manager and reinstalled them from the website files.. once installd and connected to the AP, the AP went through an Update.. after updateing the AP, I plugged it back into the car, the AP still shows an MS3 (It used to show an ms6) and the first option still asks me to install the AP into the car.. which of course stil fails because it can not connect to the ECU... thanks for the suggestion, but it didn't look like this was the same issue you had...
chrisyng is offline
 Old 05-10-2009, 04:32 PM   #8
Fuck sushi rolls
rodrigo's Avatar
Posts: 18,719   (View Stats)
Groans: 356
it has zero to do with firmware updates. this happened to me friday morning. i called cobb my ap did NOT go into recovery mode. they asked me some technical questions, firmware version etc etc. this has happened to 4 speeds this weekend that I am aware of, Monday morning cobb will have my ecu and ap (per their request) . at first I thought that i touched the cable but it never became undone, I dont know what happened im sure cobb will inform me when they look at my ecu vs ap. ill let u guys know, but 4 cars in one weekend is odd.
rodrigo is offline
phillyb (05-10-2009)
 Old 05-10-2009, 04:35 PM   #9
Scatt Nasty's Avatar
Posts: 1,204   (View Stats)
Scatt Nasty is the leader of the worldScatt Nasty is the leader of the worldScatt Nasty is the leader of the worldScatt Nasty is the leader of the worldScatt Nasty is the leader of the worldScatt Nasty is the leader of the worldScatt Nasty is the leader of the worldScatt Nasty is the leader of the worldScatt Nasty is the leader of the worldScatt Nasty is the leader of the worldScatt Nasty is the leader of the world
Groans: 94
Groaned at 43 Times in 33 Posts
sounds like the supposed software failure of the year 2000. Maybe cobb forgot to add some zeros and your day was fail day.
321 HP/348TQ-- 13.940 @ 106 /3kft ASL
Scatt Nasty is offline
 Old 05-10-2009, 04:51 PM   #10
Lymerock's Avatar
Posts: 1,436   (View Stats)
Lymerock is the leader of the worldLymerock is the leader of the worldLymerock is the leader of the worldLymerock is the leader of the worldLymerock is the leader of the worldLymerock is the leader of the worldLymerock is the leader of the worldLymerock is the leader of the worldLymerock is the leader of the worldLymerock is the leader of the worldLymerock is the leader of the world
this is shitty, hope its just cali emission cars or something
07 CB Speed3
COBB AP S2+, MS CAI (shorty w/ straightener), RPMC inlet, ETS 3.25", Devils Own S2 Alchy Injection, PG Manifold V2, TXS DP (with Cobb highflow cat soon), TXS mid, MS CBE, HKS Plugs (1 step colder), Fidanza Flywheel, KMD CDFP internals, COBB Sways, Koni Dual Adjustable Shocks, AWR 88 trans mount, Hawk HP+ pads (F+R), Motul RBF 600 brake fluid, 18x8 +50 weds sa70's 245/40 falken rt-615's, V1 hardwired, Autometer ES Gauges (boost/vac, water, oil pres), Dashhawk, stock turbo with modified boost control system
Lymerock is offline
 Old 05-10-2009, 04:53 PM   #11
Driver
Fobio's Avatar
Posts: 2,479   (View Stats)
Groans: 44
there's a CDN car...we're under the Federal designation...
-- Mario Andretti --
Fobio is offline
 Old 05-11-2009, 11:18 AM   #12
Lama's Avatar
Posts: 339   (View Stats)
Lama has a reputation beyond reputeLama has a reputation beyond reputeLama has a reputation beyond reputeLama has a reputation beyond reputeLama has a reputation beyond reputeLama has a reputation beyond reputeLama has a reputation beyond reputeLama has a reputation beyond reputeLama has a reputation beyond reputeLama has a reputation beyond reputeLama has a reputation beyond repute
There is two canadian car.....my ECU and AP are in the mail. There is no Overnight shipping Canada/USA so it will be a little longer for me : 3 days to ship
I got the code 1014 too and car wont start
Mazdaspeed 6 2007 GT : Cobb AccessPORT, Cobb Stage 2+SF TIH 91 BT map, Cobb SF SRI, Cobb Turbo Inlet, Cobb shifter weight, Cobb XLE BPV, Cp-e TMIC, SAMCO Xtraflex recirc hose, AutoEXE Boost tubes, CP-e Rear Motor Mount, Cp-e diff mount, SURE juggernaut, Magnaflow Catback , SU Test pipe, TWM Short Shifter Stage 2 & Bushings, DashHawk, Denso ITV-22, RPM sport springs, whiteline RSB, freins Rotora, TSW nurburgring wheels
Lama is offline
The Following User Says Thank You to Lama For This Useful Post:
phillyb (05-11-2009)
 Old 05-11-2009, 03:35 PM   #13
stormin84's Avatar
Posts: 128   (View Stats)
stormin84 is the leader of the worldstormin84 is the leader of the worldstormin84 is the leader of the worldstormin84 is the leader of the worldstormin84 is the leader of the worldstormin84 is the leader of the worldstormin84 is the leader of the worldstormin84 is the leader of the worldstormin84 is the leader of the worldstormin84 is the leader of the worldstormin84 is the leader of the world
Did you get in touch with them, what did they tell you (Cobb told me that i should wait to see what happened to lenny's ecu because if there is a fix that can be done with the ap then they will send me a file.)
Falken FK-452 | 215-40R18 | Konig Hotswap |35% Tints| Greddy TT| Cobb Sri| Cobb Shifter| Cobb AP| Cobb Springs| Cobb RSB | Cobb Inlet Pipe |TS BOV |Dashhawk| COBB FMIC |CPE MM|CPE DP|
STILL TO COME: |Whatever I can get my hands on before she kills me|
stormin84 is offline
 Old 05-10-2009, 06:12 PM   #14
phillyb's Avatar
Posts: 14,702   (View Stats)
Groans: 1,940
fucking fail...just as my hopes were getting up
phillyb is offline
 Old 05-10-2009, 06:17 PM   #15
stormin84's Avatar
anyways a canadian car has the same problem, i was just like lenny never touched anything came up to 13% flashing and boom nothing.
 Old 05-10-2009, 06:29 PM   #16
jahman's Avatar
Posts: 903   (View Stats)
jahman is the leader of the worldjahman is the leader of the worldjahman is the leader of the worldjahman is the leader of the worldjahman is the leader of the worldjahman is the leader of the worldjahman is the leader of the worldjahman is the leader of the worldjahman is the leader of the worldjahman is the leader of the worldjahman is the leader of the world
Groaned at 9 Times in 7 Posts
Could it be possible the files were corrupt? EVOs had this problem with one of the OTS maps.
If thats the case, the fear now would be how do you know for sure your files arent corrupt? Sending my ecu in for repair is not an option for me and I'm sure many others. I need my car every day.
Still weird there were almost zero failures before and all in the matter of 2 days we have four.
07 Mazdaspeed3
jahman is offline
 Old 05-10-2009, 06:33 PM   #17
smakdown61's Avatar
Posts: 1,069   (View Stats)
What base maps do you guys that have bricked ecu's been using?
smakdown61 is offline
The Following User Says Thank You to smakdown61 For This Useful Post:
 Old 05-10-2009, 06:42 PM   #18
stormin84's Avatar
was on stage 2 +sf 91 v103 w/ atr
was going to flash stage 2 + sf 93 v103 that when all hell broke loose
 Old 05-10-2009, 06:46 PM   #19
smakdown61's Avatar
fed or cali?
 Old 05-10-2009, 06:49 PM   #20
stormin84's Avatar
Originally Posted by smakdown61 View Post
fed or cali?
fed
 Old 05-10-2009, 06:54 PM   #21
Fuck sushi rolls
rodrigo's Avatar
Groans: 356
so u were running an ots map tweaked with atr??? then were gonna flash a ots map (with no tweaking?)
rodrigo is offline
 Old 05-10-2009, 06:57 PM   #22
stormin84's Avatar
actually forgot to mention that it was with the FMIC and it was with increasing the idle speed, and lower the closed loop..
 Old 05-10-2009, 06:49 PM   #23
dread's Avatar
Posts: 1,223   (View Stats)
dread is the leader of the worlddread is the leader of the worlddread is the leader of the worlddread is the leader of the worlddread is the leader of the worlddread is the leader of the worlddread is the leader of the worlddread is the leader of the worlddread is the leader of the worlddread is the leader of the worlddread is the leader of the world
I am holding off on flashing until this is resolved.
[SIGPIC]http://i163.photobucket.com/albums/t318/dreadedhero/DSCN2058-2.jpg[/SIGPIC]
2007 ms3 sport black mica completely stock
dread is offline
 Old 05-10-2009, 06:51 PM   #24
stormin84's Avatar
haha don't we feel like the guiney pig here...try it and see if yours fucks up....
 Old 05-10-2009, 07:22 PM   #25
jahman's Avatar
Agreed, no flashing for me until there is an explanation.
If it were disconnects or something like that related to user error that'd be one thing, but 4 in one weekend when there were zero failures before, and all failing at 13% with the same error message tells me this is something to be cautious about.
07 Mazdaspeed3
jahman is offline
 Old 05-10-2009, 06:52 PM   #26
Fuck sushi rolls
rodrigo's Avatar
Groans: 356
i was running ots stage 2 sri fmic v.103 with 3 things done to it, afr .300 richer across the board (after 2500) rev limiter raised to 6900 and max speed to 170. i ran that map for a full week . i went to flash a map that i had previously used numerous times months back and it got stuck. so i wasnt flashing anything new.
i can speculate a million things but reality is i have no clue what happened. when i was at the track i flashed this very map i was trying to flash and no problem, then went back to my ATR map. i then later made some changes to it and ran the car for a full week with the new version of atr map and still nothing. so reverting back to an old map i doubt has anything to do with this. ill wait for cobbs results before forming an opinion
and i am CA
rodrigo is offline
 Old 05-10-2009, 06:56 PM   #27
Silver Ecstasy's Avatar
Posts: 2,450   (View Stats)
Silver Ecstasy is the leader of the worldSilver Ecstasy is the leader of the worldSilver Ecstasy is the leader of the worldSilver Ecstasy is the leader of the worldSilver Ecstasy is the leader of the worldSilver Ecstasy is the leader of the worldSilver Ecstasy is the leader of the worldSilver Ecstasy is the leader of the worldSilver Ecstasy is the leader of the worldSilver Ecstasy is the leader of the worldSilver Ecstasy is the leader of the world
Groaned at 81 Times in 33 Posts
Wow, I was really considering investing in a used AP if I find one for the right price but i'd seriously shit my pants if my ECU fried.
I know this has little relation but it could be the AP themselves, having a power failure midway through the flash. That would definitely fuck things up on the ECU's side of things. I've flashed phones in the past, same idea. Disconnect the cord or have a battery failure and you'll wish you hadn't.
Mike
2008.5 CWP Mazda CX-7 Sport FWD - hers
2008.5 CWP Mazdaspeed 3 GT - traded
2011 LSM Mazdaspeed 3 Sport w/tech pkg - sold
Silver Ecstasy is offline
 Old 05-10-2009, 07:08 PM   #28
dread's Avatar
I flashed 5 times this weekend so I have been flashing a lot. I am definately going to chill out .
dread is offline
 Old 05-10-2009, 07:11 PM   #29
Fuck sushi rolls
rodrigo's Avatar
Groans: 356
i wouldnt go into panic mode. but....it doesnt hurt to be wise and hold off on flashing until at least the cause of all of this is determined.
rodrigo is offline
 Old 05-10-2009, 07:12 PM   #30
fhaze's Avatar
Posts: 552   (View Stats)
fhaze is the leader of the worldfhaze is the leader of the worldfhaze is the leader of the worldfhaze is the leader of the worldfhaze is the leader of the worldfhaze is the leader of the worldfhaze is the leader of the worldfhaze is the leader of the worldfhaze is the leader of the worldfhaze is the leader of the worldfhaze is the leader of the world
Groaned at 9 Times in 9 Posts
weren't you both at 13%? That's too much of a coincidence.
fhaze is offline
 Old 05-10-2009, 07:15 PM   #31
dread's Avatar
coincidence or just the unlucky number 13
dread is offline
 Old 05-10-2009, 07:21 PM   #32
Fuck sushi rolls
rodrigo's Avatar
Groans: 356
hahah 13 was the last number i saw. maybe it went up a little more who knows
rodrigo is offline
 Old 05-10-2009, 07:27 PM   #33
Fuck sushi rolls
rodrigo's Avatar
Groans: 356
yeah the tech said the 1014 was unusual and is NOT the code it throws when it doesnt recover. so im fucken not so happy about this, 1014 means wrong car
rodrigo is offline
 Old 05-10-2009, 07:31 PM   #34
stormin84's Avatar
how the fuck does it mean wrong car it was plugged into my car and flashing and then this shit came up...
i don't know if i should take it to the dealership or sent it out to Cobb. i guess i'll wait and i will have to drive a company truck for a while...
 Old 05-10-2009, 07:33 PM   #35
jahman's Avatar
Hmm...did you guys by chance recently download your base map? I wonder if the base maps are fucked up somehow, mixed up ms6 and ms3, and when you try to flash an ms6 map to an ms3, this happens.
07 Mazdaspeed3
jahman is offline
 Old 05-10-2009, 07:39 PM   #36
Alittle Faster
bioevolve's Avatar
Posts: 3,522   (View Stats)
bioevolve is the leader of the worldbioevolve is the leader of the worldbioevolve is the leader of the worldbioevolve is the leader of the worldbioevolve is the leader of the worldbioevolve is the leader of the worldbioevolve is the leader of the worldbioevolve is the leader of the worldbioevolve is the leader of the worldbioevolve is the leader of the worldbioevolve is the leader of the world
So is ATR reflashing with another married code to cause these locks, if it's saying wrong car?
Changing it some how or seeing it as a different code?
bioevolve is offline
 Old 05-10-2009, 07:34 PM   #37
Fuck sushi rolls
rodrigo's Avatar
Groans: 356
no , i was trying to load a map from a buddy that was tuned by surgeline ( i have flashed this particular map a dozen times before) the corruption is not in the maps.
rodrigo is offline
 Old 05-10-2009, 07:37 PM   #38
fhaze's Avatar
(Just thinking out loud here)
I wonder if the ECU does a "self-check" periodically. Looking for the same checksum or MD5 Hash that it knew about from the last time it was flashed with the factory tool. If it doesn't get the response it expects it shut her down.
Obviously not while driving or anything, but it wont accept anymore flashes w/o a reset or unbrick back to factory defaults.
fhaze is offline
 Old 05-10-2009, 07:39 PM   #39
Fuck sushi rolls
rodrigo's Avatar
Groans: 356
well this means u would have a limited number of flashes and i can assure u an 08.5 ms3 wont have the same amount of flashes as my 07. i have flashed my shit over 100 times easily
EASILY
rodrigo is offline
 Old 05-10-2009, 07:44 PM   #40
stormin84's Avatar
EASILY
agree i've got an 2008.5 so it can't be the number of flashes
Closed Thread
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f418/heads-up-cobb-access-port-bricked-ecu-27616/
Ap and bricking your ECU - TorontoMazda3 This thread Refback 05-10-2009 08:02 PM
Ap and bricking your ECU - TorontoMazda3 This thread Refback 05-10-2009 07:41 PM
Big Valve Heads 06Speed6 MazdaSpeed 6 - Engine, Transmission & Driveline 159 03-08-2012 05:35 PM
Heads up on CP-e TowPlate Moonpie.Express Custom Performance Engineering (cp-e.com) 13 03-12-2009 09:25 AM
Off with their heads! (But whose?) Haltech Automotive News 0 11-23-2008 10:10 PM
Off with their heads! (But whose?) Haltech Automotive News 0 11-18-2008 01:40 PM
Page generated in 0.57172 seconds with 37 queries
