> Cobb Tuning >
Cobb ATR Support
Like Tree6Likes
  • 3 Post By R.MS3
  • 1 Post By R.MS3
  • 2 Post By Ziggo
 Old 07-20-2010, 09:02 PM   #1
R.MS3's Avatar
Posts: 987   (View Stats)
R.MS3 is the leader of the worldR.MS3 is the leader of the worldR.MS3 is the leader of the worldR.MS3 is the leader of the worldR.MS3 is the leader of the worldR.MS3 is the leader of the worldR.MS3 is the leader of the worldR.MS3 is the leader of the worldR.MS3 is the leader of the worldR.MS3 is the leader of the worldR.MS3 is the leader of the world
Default How to properly log your WOT run
To make sure people don't waste their own time posting useless logs, here's some info for you...
Only things you have to log for a WOT run: Accel. Pedal position, LTFT, MAF g/s, MAF volts, AFR, KR, Fuel Pressure, Boost, RPM, Calc. load, WG Duty, Spark Advance.
To log a proper WOT run, start at around 2600RPM and floor it all the way to 6300RPM. You can do this in either 3rd or 4th gear.
Unless it's a specific problem you're facing, these parameters should be able to tell anyone how is your car doing. Remember that the more parameters you log, the less your "log rate" is. A faster rate is always better. If you got a specific problem, deselect any parameters you don't need or add them.
If it's a MAF calibration log, you only need RPM,KR,LTFT,STFT,MAF g/s, and MAF Voltage. Start logging from a very low 1500rpm at 2nd gear and SLOWLY bring your RPM's up until you reach about 100g/s (set your AP so you see MAF airflow during the log).
This works almost in the same way for Dashawk users, but you're only able to log 5 parameters at a time. I would highly suggest making 2 separate logs on the same gear so you're able to log 10 things but RPM and KR should be in both logs IMO.
az_jayc, sorpano and BR1JZL like this.
R.MS3 is offline   Reply With Quote
The Following 44 Users Say Thank You to R.MS3 For This Useful Post:
09Speed3Z (08-02-2011), acidbbg (02-19-2011), alikmac1 (03-06-2012), anavrinIV (12-25-2011), AntiStock (07-21-2010), Arnie1229 (01-15-2015), asall667 (08-03-2011), az_jayc (07-15-2012), bigwavedave33 (04-15-2014), DaleNixon (07-21-2010), DownSideFX (01-26-2012), ELiTeNeSs (03-08-2011), GTISPEED3 (03-24-2011), hartlch (08-04-2012), indianaryan (03-25-2011), jcolton (10-11-2015), jdub (10-11-2015), KiwiFlavor (01-27-2015), KnowUhhTee (02-03-2016), kunfu (03-13-2011), manelscout4life (04-01-2011), MarcoAntonio (09-17-2014), massiespeed3 (06-09-2011), mituc (07-21-2010), MS6FL (05-28-2011), MZR165 (11-21-2011), niterydr (03-30-2011), nuttzzy (02-19-2011), OJ Bartley (09-18-2013), Pointless (06-04-2013), redblur (03-24-2011), rfinkle2 (01-15-2011), Rocka (05-25-2011), SJP0tato (07-21-2010), Slow*Jim (05-27-2011), sorpano (10-18-2013), Speed3eak (01-17-2011), stp (01-04-2011), SWAY (05-25-2011), TexasSpeed3 (07-27-2011), thatsmrgimp2u (05-07-2011), wankular (07-21-2010), XLT_66 (01-04-2011), ZetaDrift (05-30-2013)
 Old 07-21-2010, 07:15 AM   #2
AntiStock's Avatar
Posts: 44   (View Stats)
AntiStock is a jewel in the roughAntiStock is a jewel in the roughAntiStock is a jewel in the roughAntiStock is a jewel in the rough
Had to thank you for this...I didn't realize the log rate slowed as the parameters increased. That will be extremely helpful in the future.
Tyler
2008 Mazdaspeed3
AntiStock is offline   Reply With Quote
 Old 07-21-2010, 08:56 AM   #3
SJP0tato's Avatar
Posts: 322   (View Stats)
Good stuff, it's easy for new people to the platform/AP to get overwhelmed and things we take for granted as obvious sometimes aren't very clear until you've been doing it awhile.
Nice post
SJP0tato is offline   Reply With Quote
The Following User Says Thank You to SJP0tato For This Useful Post:
 Old 01-04-2011, 07:46 AM   #4
XLT_66's Avatar
Posts: 850   (View Stats)
I can't seem to open the CSV file.
2009 CWP MS3 Sport
SOLD!
XLT_66 is offline   Reply With Quote
 Old 02-15-2011, 05:47 PM   #5
GTISPEED3's Avatar
Posts: 775   (View Stats)
GTISPEED3 is the leader of the worldGTISPEED3 is the leader of the worldGTISPEED3 is the leader of the worldGTISPEED3 is the leader of the worldGTISPEED3 is the leader of the worldGTISPEED3 is the leader of the worldGTISPEED3 is the leader of the worldGTISPEED3 is the leader of the worldGTISPEED3 is the leader of the worldGTISPEED3 is the leader of the worldGTISPEED3 is the leader of the world
Groaned at 8 Times in 5 Posts
please install microsoft excel. thank you. or if your a cheap bastard then go to openoffice.org and dl that.
GTISPEED3 is offline   Reply With Quote
 Old 02-15-2011, 06:10 PM   #6
R.MS3's Avatar
I removed the excel file but all the info is on the original post.
kunfu likes this.
 Old 02-15-2011, 06:33 PM   #7
Cataphract_40's Avatar
Posts: 1,730   (View Stats)
Groans: 30
No spark advance? No WGDC?
I would personally not bother to log accel pedal position, we can usually tell when you floor it from when the LTFT transitions or from when the MAF g/s shoots up. Throttle position is also kinda unnecessary.
2008 GT MS3 - 307 WHP/338 WTQ
1995 Miata
 Old 02-15-2011, 07:02 PM   #8
R.MS3's Avatar
Sometimes g/s shoots up but people don't know if they're full throttle or not, or the person seeing the log for that matter.
The missing parameters were in the Excel file but i forgot to add some to my post. WGDC, will add that. Spark is something more advanced and people shouldn't be touching it if they don't even know how to log, lol. I will add that as well though. So many damn parameters and i've been away from ATR for a while.
I removed Throttle Pos since you will tell from the Accel pedal position if they're full WOT or not.
 Old 02-15-2011, 07:07 PM   #9
SSinstaller's Avatar
Posts: 3,989   (View Stats)
Groans: 60
LTFT is useless in a WOT log...
NEVER got WOT below 3K....
 Old 03-06-2011, 12:05 AM   #10
bertrand_CX_7's Avatar
Posts: 1,455   (View Stats)
bertrand_CX_7 is the leader of the worldbertrand_CX_7 is the leader of the worldbertrand_CX_7 is the leader of the worldbertrand_CX_7 is the leader of the worldbertrand_CX_7 is the leader of the worldbertrand_CX_7 is the leader of the worldbertrand_CX_7 is the leader of the worldbertrand_CX_7 is the leader of the worldbertrand_CX_7 is the leader of the worldbertrand_CX_7 is the leader of the worldbertrand_CX_7 is the leader of the world
why not below 3K? just curios.
Also an other question regarding WOT. Why will someone will like to go WgOT, even during racing? Please forgive my naive question but I'm coming from a manual driving background where you usually don't go WOT but instead adjust your speed to your gear.
Thanks.
2010 MazdaSpeed3 Velocity Red: Forge BPV V2, CP-e [HPFP, TMIC, Driver + passenger Mount, 75-A], CorkSport [RSB, Coilover, camber plate], SPC rear camber arm, JBR SSP stg2 + heavy knob, Cobb [ SRI, AP ], HTP 3.5" TIP, - STG2 PERM tuned by DJ, Ultimate Racing TBE (Metal core DP). Aeroforce dual guages, Hankook R-S3 on stock wheels, Sparco Evo2 race seat. ARP long wheel studs -- 17x9 ET 45+ Kosei K1 TS on 255/40/17 on Dunlop Direzza ZII.
Pending install: JB EGR block plate
Next mod:CorkSport[ Front + Rear swaybar endlinks ], OCC, brake upgrade (CorkSport or BBK), 6 point Harness.
2007 CX-7 GT AWD: CPE CAI, ETS 3" TMIC, JB EGR block plate ,Matt's OCC, AutoExec Strut tower bar, AutoExec lower arm bar, Nittos 420 tires, 12" JBL subwoofer with Bose system.
bertrand_CX_7 is offline   Reply With Quote
 Old 03-06-2011, 12:11 AM   #11
08.5MS3's Avatar
Posts: 3,840   (View Stats)
Groans: 89
Too much load on the engine; zoom zoom boom.
Tapatalk
 Old 03-06-2011, 06:04 AM   #12
PheOniX's Avatar
Posts: 160   (View Stats)
PheOniX has a reputation beyond reputePheOniX has a reputation beyond reputePheOniX has a reputation beyond reputePheOniX has a reputation beyond reputePheOniX has a reputation beyond reputePheOniX has a reputation beyond reputePheOniX has a reputation beyond reputePheOniX has a reputation beyond reputePheOniX has a reputation beyond reputePheOniX has a reputation beyond reputePheOniX has a reputation beyond repute
WOT = wide open throttle. full throttle. pedal to the metal. putting the hammer down. flooring it. whatever you want to call it. Essentially you're testing the highest limit of your cars potential which is why you want to log WOT runs to make sure everything is running fine.
____________________
2006 Mazdaspeed 6
Cobb AP Stage 1 Perm // CP-E Xcel Nano SRI // Speedie6 TIP // ETS TMIC // MagnaFlow Cat Back Exhaust // Vei Boost Gauge // BC Coilovers // CP-E RMM // DENSO ITV 22 // TWM Stage 1 Short Shifter w/ Bushings // TWM Desert Eagle // Hawk HPS Brake Pads // Goodyear Eagle GT II Tires
:phillyb:
PheOniX is offline   Reply With Quote
The Following User Says Thank You to PheOniX For This Useful Post:
bertrand_CX_7 (03-06-2011)
 Old 03-06-2011, 07:23 AM   #13
R.MS3's Avatar
Guys, ssinstaller is right in not going wot before 3k rpm but for logging purposes and to make sure your stuff is okay down low, i recommended to start logging at 2600rpm. Going WOT under 3k rpm on a regular basis is bad for your engine.
Good thing about ATR though is that you can also limit boost under 3k to prevent too much stress on the engine.
 Old 04-25-2011, 12:18 PM   #14
Alpha's Avatar
Posts: 3,711   (View Stats)
Can you slowly ramp into throttle or does this make a WOT log file less accurate? I never go WOT under 3800RPM but do start getting into the throttle gradually around 3k or 3200. Thanks.
 Old 04-25-2011, 09:35 PM   #15
Groans: 60
You need to go WOT so the ECM goes open loop and stops using the fuel trims.. Rolling into the throttle may not get you into open loop until well into your pull..
Alpha (04-26-2011)
 Old 04-26-2011, 10:26 AM   #16
Alpha's Avatar
OK, thanks man!
 Old 05-24-2011, 09:37 PM   #17
11mazdaspeed3's Avatar
Posts: 74   (View Stats)
11mazdaspeed3 can only hope to improve
Groaned at 26 Times in 12 Posts
thanks dude, should have ap in a couple days. will do
11mazdaspeed3 is offline   Reply With Quote
 Old 08-26-2011, 07:19 AM   #18
Pedal-Force's Avatar
Posts: 419   (View Stats)
Pedal-Force is the leader of the worldPedal-Force is the leader of the worldPedal-Force is the leader of the worldPedal-Force is the leader of the worldPedal-Force is the leader of the worldPedal-Force is the leader of the worldPedal-Force is the leader of the worldPedal-Force is the leader of the worldPedal-Force is the leader of the worldPedal-Force is the leader of the worldPedal-Force is the leader of the world
Sorry to bump an old one, but I had a question. I don't have an AP yet, but I've been reading about tuning with it. Why 3rd or 4th gear? Why wouldn't 2nd gear work? I'll probably end up doing 3rd gear (4th is too fast), but I'm just curious.
Pedal-Force is offline   Reply With Quote
 Old 08-26-2011, 08:01 AM   #19
Ziggo's Avatar
Posts: 3,843   (View Stats)
Taller gears give more data points since it goes through the rev range slower, and besides, if you have traction at WOT in 2nd gear you are doing it wrong.
Zigatapatalka
ouchmonkey and Arnie1229 like this.
Ask Me About My:
 Old 08-26-2011, 08:07 AM   #20
Thanks. Figured it might be a traction problem. Hadn't thought of the slower accel giving more points, that makes sense.
 Old 07-15-2012, 07:12 AM   #21
Worbit's Avatar
Posts: 2,552   (View Stats)
Groans: 142
subbing for future use
Zoom-Zoom-Coons on 05/10/16
BUILT BY CORKSPORT
 Old 07-15-2012, 06:03 PM   #22
BPASPEED's Avatar
Posts: 1,891   (View Stats)
Groans: 60
what he said^^^
BPASPEED is offline   Reply With Quote
 Old 07-16-2012, 09:58 PM   #23
R.MS3's Avatar
Glad it's still helpful to some of you. It was just a generic post to those very new to AP logging back in the days.
ATR/AP is awesome.
 Old 08-04-2012, 10:21 PM   #24
weakdog85's Avatar
Posts: 493   (View Stats)
weakdog85 is the leader of the worldweakdog85 is the leader of the worldweakdog85 is the leader of the worldweakdog85 is the leader of the worldweakdog85 is the leader of the worldweakdog85 is the leader of the worldweakdog85 is the leader of the worldweakdog85 is the leader of the worldweakdog85 is the leader of the worldweakdog85 is the leader of the worldweakdog85 is the leader of the world
this is pretty good but could someone add the equation you need to fix AFR that isn't hitting target. You know in the MAF curve.
07 MS6 Sport.............
JBR Shifter Bushings * JBR RMM * JBR PMM * SURE SRI * VG Sharkfin Antenna * 20% Tint * Cobb AP * Grimmspeed EBCS * Coolant Bypass * PG TIP * Autotech Internals *
weakdog85 is offline   Reply With Quote
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f418/how-properly-log-your-wot-run-61934/
I got my Accessport today, 2011 Speed3. Hesitant to set it up without HPFP. : mazda3 This thread Refback 03-04-2015 09:47 PM
Throttle not opening properly MaverickX3 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 9 06-01-2010 10:53 AM
IS YOUR FFS WORKING PROPERLY jayspeed3
Cobb ATR Support
30 10-12-2009 06:51 PM
Please help me, i cant seem to record/data log my MS3 properly. Wenis Prinkle
Cobb ATR Support
1 08-01-2009 01:39 PM
Page generated in 0.47125 seconds with 36 queries
