![]() Join Date: Mar 2012 Location: merrimack, nh
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 23
| Not Ranked : 0 score The issue is that the logged value does not correspond with the row because there is a calculation delay which makes it inaccurate. It's also not a known predictable so you can't just shift a row or 2 for example |
| 19psi commanded 14psi actual | DumbDave | MazdaSpeed 3/6 - ECU Computer Tuning | 5 | 06-20-2013 07:47 PM |
| Not hitting commanded AFR's | ledfootrob | 2010 MS3 - ECU Computer Tuning | 59 | 11-13-2012 05:35 PM |
| Overshooting commanded AFR | bmylez | MazdaSpeed 3/6 - ECU Computer Tuning | 30 | 07-04-2011 05:43 PM |
| Commanded AFR at idle | Doc | MazdaSpeed 3 - Engine, Transmission & Driveline | 5 | 07-23-2010 09:16 PM |
| Why does my commanded AFR not match actual | itzl0l | Cobb ATR Support | 15 | 07-10-2009 12:47 AM |
