> Cobb Tuning >
Cobb ATR Support
 Old 11-16-2014, 11:02 PM   #1
mrmonk7663's Avatar
Posts: 2,997   (View Stats)
Default Maf G/S...commanded vs logged
In the Gen2 mazdaspeed the maf table is a fixed voltage with an editable g/s. The logged g/s is often different from the commanded g/s for a given voltage point. Why is that?
Also, the ltft and stft are corrections factors applied for fueling to reach a target AFR...but are they applied to the commanded g/s or the logged g/s?. Whatever the answer is, it would be good to provide this info in the ATR helpfile for clarification purposes in my opinion. I look forward to your response
2011 Speed3-BT and shit
TEAM LBN BEERS -- FYCN
TEAM MUMFORD -- FYCN
The Following User Says Thank You to mrmonk7663 For This Useful Post:
tastyratz (05-15-2015)
 Old 05-15-2015, 10:51 AM   #2
tastyratz's Avatar
Posts: 58   (View Stats)
tastyratz is a splendid one to beholdtastyratz is a splendid one to beholdtastyratz is a splendid one to beholdtastyratz is a splendid one to beholdtastyratz is a splendid one to beholdtastyratz is a splendid one to behold
I wanted this to rise TTT because I also would like some feedback here
tastyratz is offline   Reply With Quote
 Old 05-15-2015, 11:05 AM   #3
chaser27's Avatar
Posts: 1,276   (View Stats)
Groans: 42
I'm not sure, but I think there are some correction factors that the ECU applies based on IAT. The logged values shouldn't be far off what's in the table. Are you seeing a wide variance?
I'd also assume the LTFT + STFT correction is applied to the "corrected" value.
Coming at ya with all 297/359
ECU: self-tuned
RADAR: Passport Escort 9500ci
 Old 05-15-2015, 11:20 AM   #4
tastyratz's Avatar
The issue is that the logged value does not correspond with the row because there is a calculation delay which makes it inaccurate. It's also not a known predictable so you can't just shift a row or 2 for example
19psi commanded 14psi actual DumbDave MazdaSpeed 3/6 - ECU Computer Tuning 5 06-20-2013 07:47 PM
Not hitting commanded AFR's ledfootrob 2010 MS3 - ECU Computer Tuning 59 11-13-2012 05:35 PM
Overshooting commanded AFR bmylez MazdaSpeed 3/6 - ECU Computer Tuning 30 07-04-2011 05:43 PM
Commanded AFR at idle Doc MazdaSpeed 3 - Engine, Transmission & Driveline 5 07-23-2010 09:16 PM
Why does my commanded AFR not match actual itzl0l
Cobb ATR Support
15 07-10-2009 12:47 AM
Page generated in 0.26050 seconds with 22 queries
