![]() Join Date: Jul 2008
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 28
(Thread Starter) | Not Ranked : 0 score So since its getting warmer out (40s-50s) my wastegate is being used more and more. I noticed that I'm having trouble holding 18 psi in the upper RPMs. After about 5500 RPM my wastegate is sometimes maxed at 99% and Ill only be holding mid/high 17psi @ 6000 RPM. Goal is to run 18 psi at 6000 Im fully bolted (minus exhaust mani) with CS catless TBE, and exhaust depot FMIC. I know others don't have much trouble holding 18-19 psi...however I am thinking that me having the FMIC is making the turbo work harder to fill up the extra 10 feet of piping. Think that is a possibility? Are the people that are able to hold 18-19 psi at 6000 RPM have TMIC? Anyone with FMIC able to hold that much @ 6000 rpm? (please only reply if you are experienced...noob inferences are not going to help...thanks)
__________________ |
| The Kamikaze King! ![]() Join Date: Jun 2008
Rep Power: 1829 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6,794
Groans: 754
| Not Ranked : 0 score This doesn't answer your question, but I am going to post it anyway. psi doesnt really matter, what matters is cfm or g/s What is the max g/s you are seeing?
__________________ BB code url is no longer allowed.........so..... http://www.fuelly.com/driver/FreeFlyFreak/speed-3 http://www.fuelly.com/driver/FreeFlyFreak/speed-3 Suspension: OEM --> FSD 4040 --> FSD 4040 with cut stops --> MS Coils --> FSD 4045's --> FSD4045 with cut stops --> Bilstein Sports Yes, that is me in the avatar. |
![]() Join Date: Dec 2008
Rep Power: 403 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,254
Groans: 109
| Not Ranked : 0 score i can only suggest what i have tried.. changing the timing on your tune a bit and a upgraded wg. |
| Not Ranked : 0 score I dont know what good an upgraded wg would do, but you can upgrade the wg actuator to hold more pressure and force more air through the turbine. It takes alot more turbine/compressor rpm for that stock turbo to make 18psi @ 6000rpm than it does to make 18psi @ 3000rpm and if your wg is running wide open that isnt going to help anything. Are you tuned?
Groans: 109
| Not Ranked : 0 score i dunno was just my input, i dont max out the wg not though. |
(Thread Starter) | Not Ranked : 0 score Yes I am tuned. Someone mentioned the upgraded wastegate so it will hold more pressure...anyone have a link to a thread or where its being sold?
![]() Join Date: May 2009
Rep Power: 371 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 558
| Not Ranked : 0 score Grimmspeed EBC , in 3 port mode the wastegate will be pushed closed, stock 2 port bleeder style boost control can't do this
__________________ 2013 Mazdaspeed3 Gen2 Mods: Cobb SRI, Tip, Turbosmart BPV, Cobb AP, Cp-e DP, CPE HPFP, CPE RMM, PTP Kicker Mount |
| Not Ranked : 0 score Timing and VVT up top could get you there. I'm 100% stock but hold 17+ to 6500 in 3rd and 4th, so I would imagine it would allow you to hold at least 19 if you wanted it... |
Like you said...your 100% stock..so it wouldn't surprise me that you'd be able to build a lot of boost with the restrictive TMIC, and DP. Regardless...I really want to hold at least 18 psi up top. Has anyone had experience with PTPs wastegate? In theory, it should help hold more boost up top...but I am VERY skeptical of PTPs products.
__________________ | |
(Thread Starter) | Not Ranked : 0 score You had a FMIC or TMIC?
| Banned ![]() Join Date: Sep 2009 Location: La Crosse, WI
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 309
| Not Ranked : 0 score The PTP WG actuator and the grimmspeed EBC, with the proper tune, should allow to to run as much boost as the turbo can make.
| Not Ranked : 0 score Top Mount.... didn't think about that, but that could make a difference. |
| The Following User Says Thank You to Realgib3 For This Useful Post: | AFcadet (03-14-2010) |
(Thread Starter) | Not Ranked : 0 score Yea...I really think the extra 10 feet of piping is making a difference. its very obvious that the K04 already has trouble up top...so this extra piping may be making a difference. Now I just need to find out if the wastegate is actually being closed all the way and the turbo is just running out of juice for my setup...or if the wastegate is not being closed all the way (duty cycle is maxed) and a aftermarket wastegate solenoid with a stiffer spring would help close it all the way to hold a little more boost up top.
Groans: 109
| Not Ranked : 0 score here is a quick log i did tonight of a 3rd and 4th hear pull. still working on the tune but you can see its possible to hold psi up top |
| The Following User Says Thank You to JmkC For This Useful Post: | AFcadet (03-15-2010) |
Also...how did you adjust the wastegate with the AP. (which spring did you use...did you have to change the WGDC table in ATR?) Thanks for your help
![]() Join Date: Apr 2010 Location: Des Plaines, IL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 234
Groaned at 53 Times in 17 Posts
| Not Ranked : 0 score |
Groans: 109
| Not Ranked : 0 score Never really had trouble i adjusted timing but the stock wg was maxing out. the ptp wg only comes with one spring and i slightly changed the tables in atr. |
| Driver ![]() Join Date: May 2008 Location: Toronto
Rep Power: 1986 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,158
Groans: 44
and can you tell me which tables you adjusted? I also have the Grimmspeed EBCS, and it recommends -30% WGDC, but I can seem to find the right way to adjust the whole table.
__________________ ![]() DONE . Cobb AP 22-psi Self-Tuned . ATP GT3071 . CP-e 3.25" MAF+4" inlet . Denso ITV-24 . CP-e HPFP . CP-e FMIC . Turbosmart Ultimate BPV . 50/50 Meth w/ M5 nozzle . PTP IM Spacer+EGR delete . GrimmSpeed EBCS 3-port . SteedSpeed Mani . CP-e TBE . Greddy OCC w/ 2nd PCV valve . F2 BSD + oil-pan baffle . Hawk HP+ pads . Goodridge SS brake lines w/ Ford Super Dot 4 . Cobb Springs+FSB . Tri-Point RSB+Endlinks . Koni Yellows . KMAC Camber Plates . 60mm Boost Gauge . TWM Complete Shifter w/ JBR SSP+weight . CP-e RMM+PTP trans+kicker mount . Sparco Harness Bar w/ MOMO 4-pt harness . Rays/Volks 57F 18x8.5" +45mm 235/40/18 Hankook V12 . BBS RK 17x8" +45mm 235/45/17 RA1/R6 . OEM Snowflakes w/ 215/50/17 Nitto NT-SN1 . 3rd in CSCS 2009 Time Attack Championship - Super Street FWD . 360whp/390wtrq . SOON . 3-bar MAP sensor . MSpeed Tuning & Diagnostics - The Street Lab is ALWAYS OPEN FOR BUSINESS "It is amazing how many drivers, even at the Formula One Level, think that the brakes are for slowing the car down." -- Mario Andretti -- | |
Groans: 109
well the stock wg has 2 nipples for the vac/boost tubes and the ptp only has one. so i just used a tee to tie it all back together. in atr you have your wgdc table, i pretty much started with stock values, and increased and decrease to control the boost the way i wanted. | |
| The Following User Says Thank You to JmkC For This Useful Post: | Fobio (03-18-2010) |
(Thread Starter) | Not Ranked : 0 score oh ok. So you were maxing out the wastegate...you added this upgraded WG actuator...and it lowered your wastegate duty cycle. thats what Im looking for...thanks.
![]() | | #24 | ![]() |
(Thread Starter) | Not Ranked : 0 score I havnt been having good performance out of my Forge WGA. I have the yellow spring (9-14 psi) in...and I started with the preload low and wasnt able to hold stock boost levels. I slowly build up more preload...untill now I spool up very quick...and will even over boost (0% WGDC) in 35 degree weather...yet Ill still get a maxed out WGDC above 5000 RPM and hold LOWER boost then the stock WGA. So its quiet wierd. Mid RPMs I am getting MORE boost...but upper level RPM I am getting maxed wastegate again but LESS boost.
![]() | | #25 | ![]() |
| Banned ![]() Join Date: Feb 2010
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4
What happens with the forged units is that sometimes on cars trying to run 15-20lbs they seen to work just as you just explained . The fix should be a larger diameter piston of diaphragm to control and stabilize boost at those levels . I'm working on such a unit this coming week . | |
![]() | | #26 | ![]() |
I see your a vender...but who is your affiliation with?
![]() | | #27 | ![]() |
![]() Join Date: Sep 2009 Location: Surburban Detroit Michigan
Rep Power: 2266 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,223
Groaned at 9 Times in 7 Posts
| Not Ranked : 0 score Wow cadet, I rode in your car and it pulls like a freight train. I can't imagine what it'll be like if you get it even MORE dialed in. |
![]() | | #28 | ![]() |
Groans: 109
| Not Ranked : 0 score i use to have forge.. switched to hks not only for sound but so i didnt have to mess around with adjusting the forge |
![]() | | #29 | ![]() |
| ILL3ST ![]() Join Date: Jun 2008 Location: Ann Arbor, MI
Rep Power: 1317 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,292
Groans: 105
| Not Ranked : 0 score we are talking about the forge wastegate actuator not the bpv. |
![]() | | #30 | ![]() |
Groans: 109
| Not Ranked : 0 score ahh good call. thats why i should stay away from the computer after i have been drinking |
| The Following User Says Thank You to JmkC For This Useful Post: | FreeFlyFreak (03-24-2010) |
![]() | | #31 | ![]() |
(Thread Starter) | Not Ranked : 0 score Alright little update. I had the Forge wastegate acuator put in and it didnt really work at all. Id get higher boost with less wastegate duty in mid RPMs...but boost would die off worse than before at higher RPMs. I got PTPs Wastgate actuator and so far its working great. I'm still dialing in the tune...but right now Im able to hold 19.5 psi at 6000 RPM with around 60% WGDC (Before Id hold 17.5 psi @ 6000 RPM with 100% WGDC) and no crazy boost spikes. I was able to do some testing with other guys cars in the area that I've been tuning...and like I thought...the key to holding boost with the stock WGA is a TMIC. A local guy (bud) who has a upgraded TMIC was able to hold 17.5 psi @ 6000 with only 75% WGDC. Then my other buddy with a FMIC (xcoldricex) was maxing out the WGDC around 17.5 psi @ 6000 RPM (like me). So if you want to hold a good amount of boost up top in weather warmer than 40* F with a FMIC...you really need to get an aftermarket WGA
| The Following 2 Users Say Thank You to AFcadet For This Useful Post: | JMEngineer (04-03-2010), xcoldricex (04-03-2010) |
![]() | | #32 | ![]() |
![]() Join Date: Apr 2009 Location: Cincinnati
Rep Power: 2046 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,096
Groans: 32
Groaned at 19 Times in 15 Posts
| Not Ranked : 0 score Good info... I'm still using the stock WGA and I'm not having any trouble hitting my targets (at least when my intercooler isn't cracked) but the control sucks. When I should have a constant 17psi my boost gauge just shakes around 17±1.5psi. I heard the PTP WGA helps with that too. Have you noticed an improvement in boost control other than being able to hit your target?
__________________ 2006 MS6 GT - Built engine, twin scroll GT3076R, dual MV-S wastegates dumped to atmosphere, TR1035 FMIC, too many parts to list... ![]() 2009 MS3 GT - Built engine, JBR intake/TIP and short shifter, all engine mounts, Autotech HPFP internals, ETS TMIC, Custom AP tune, Pauter rods, CP pistons, and 6-puck ACT clutch -GTX2867R Coming Soon |
![]() | | #33 | ![]() |
Groans: 109
| Not Ranked : 0 score I hold a pretty consistance boost with the PTP wg. I am sure AFcadet can attest to that |
![]() | | #34 | ![]() |
(Thread Starter) | Not Ranked : 0 score actually Im running into a bit of a issue concerning boost control. It would hold boost really steady up untill around 5700 RPM...then it would shoot up from 19.5 psi to 21-22 psi. No idea why because my load is flat between 5500-6500 RPM. I tried lowering my wastegate duty cycle in the upper RPMs from 50 down to 35...and now it tapers down to 17 psi. So it looks like the key to steady boost control with the PTP WGA is using the wastegate duty cycle table...which I know JmkC mentioned something about this either in this thread or another one. So im going to slowly bump up my WGDC numbers in the upper RPMS untill I get a nice flat boost number. JM Engineer...your flucuating boost might be an issue with the crack in the TMIC forming. I have always had really steady boost with the stock WGA.
![]() | | #35 | ![]() |
Groans: 32
| Not Ranked : 0 score I had the boost control problem long before the crack formed and I still have it now with the stock intercooler back on. I might be able to help it with some tuning (I'm using a modified Cobb stage 2 tune and I haven't done anything with the WGA tables) but I've also heard that it's very hard to get steady boost when you're pushing over double the WG spring pressure.
![]() | | #36 | ![]() |
Groans: 44
| Not Ranked : 0 score Can I please have some help to review this log? I'm maxing out the PTP WGA...I have the Grimmspeed EBCS, but my mechanic haven't "visualized" in his mind how to connect the EBCS in 3-port w/ the PTP WGA with only one nipple...anyway, will work with him Monday to sort it out...in the mean time, what can I do about this:
![]() | | #37 | ![]() |
Rep Power: 414 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 105
WGDC is really solenoid duty cycle, so if the solenoid is plugged in, you'll log something, whether or not it's actually doing anything I think.
__________________ ![]() | |
| The Following User Says Thank You to fjames For This Useful Post: | Fobio (04-04-2010) |
![]() | | #38 | ![]() |
(Thread Starter) | Not Ranked : 0 score First of all...when your doing logs get rid of all the shit that isnt pertinent. Like vehicle speed, intake temp, inj. duty cycle, fuel trims, etc. Every PID that you log is going to restrict how many logs you get per second. You can see you only get like....1 or 2 logs per second because your logging EVERY parameter available. Only log what you need (I just do, RPM, Boost, Knock, Throttle Position, Boost, Wastegate Duty Cycle). My guess is that your WGA is not even hooked up correctly to your WG solenoid....or the solenoid is not working. You can see the solenoid is "doing work" but there is no building of boost. The PTP WGA has a 15 pound spring in it...and it looks like your only getting the spring pressure and no pressure from the solenoid. So yea...its either not hooked up right or the solenoid is not working.
| The Following User Says Thank You to AFcadet For This Useful Post: | Fobio (04-04-2010) |
![]() | | #39 | ![]() |
Groans: 44
| Not Ranked : 0 score thanks... after I updated the AP, I think it resets the parameters I removed fopr logging...I'll make another one today...
![]() | | #40 | ![]() |
| Not Ranked : 0 score Seems to be holding a little higher in the warmer weather, 18-18.5 with no spikes. I need to post up a log of my tasty tune. |
| Wastegate IAT table | AFcadet | Cobb ATR Support | 18 | 01-16-2010 07:51 AM |
| "Maxed Out" CDFP | 06Speed6 | Mazdaspeed3/6 General Discussion | 15 | 12-12-2009 02:08 AM |
| Wastegate... | _Toxic_ | MazdaSpeed 3 - Engine, Transmission & Driveline | 1 | 09-22-2009 07:24 AM |
| wastegate spring | ms3boost | MazdaSpeed 3/6 - Turbo Induction | 5 | 06-15-2009 03:41 PM |
| Maxed Out: FIA president Mosley fighting back in wake of sex scandal | Haltech | Automotive News | 0 | 04-06-2008 09:02 AM |
