> Cobb Tuning >
Cobb ATR Support
 Old 12-01-2010, 02:43 PM   #1
Cobb Tuning's Avatar
Posts: 1,192   (View Stats)
Default MAZDASPEED3/6 AccessPORT and AccessTUNER Updates Now Available!
We have just released significant updates to the AccessPORT firmware and AccessTUNER software for the first gen MAZDASPEED3 and MAZDASPEED6. AccessPORT enhancements include improved usability with four higher precision data monitors, a simplified menu system and support for higher boost pressure data logging. AccessTUNER software improvements include a large selection of new tables, two important bug fixes and the addition of software auto-updating to simplify future software upgrades. These new additions continue to expand AccessPORT control of the ECU, letting users dig deeper into the OEM logic to extract even more power from the MAZDASPEED3/6, with unmatched simplicity, functionality, convenience and control!
AccessPORT Firmware
The latest firmware update (version 1.6.3.2) is currently beta. The full release of this firmware will include map support for included Off The Shelf Maps and will be available soon. The changes in this beta firmware version include:
  • Boost pressure data logging limit has been increased to log pressures above 24PSI. Existing maps must be opened in the latest version of AccessTUNER, resaved and flashed back to the ECU to implement new feature.
  • Precision of the following monitors has been increased by another decimal place:
    • STFT (Short Term Fuel Trim)
    • LTFT (Long Term Fuel Trim)
    • MAF Voltage
  • Calculated Load data monitor display has been reworked to reflect the display shown in AccessTUNER (units displayed as Load Value instead of %)
  • Expose ECU Data feature allows the stock ROM to be backed up to a PC using AP Manager
  • Uninstall AccessPORT menu option moved back to the top menu level
  • Installed Stock Mode maps removed from firmware to reduce end user confusion regarding Uninstall vs. Installed Stock Mode
  • Demo Mode added to Settings Menu to enable AP navigation of all menus when powered up while not connected to ECU
AccessTUNER Software
The latest AccessTUNER software update (version 1.8.6.0) has significant enhancements that not only give unprecedented control of the stock ECU, but also make it more convenient to update!
  • Auto Updater allows software updating through the "Help/Updates" menu, eliminating the need to submit additional ATR request forms, waiting for the software to be generated and downloading the new software. Rollback functionality is also included to step back to the previous release
  • AccessPORT Manager 2.0 Installer is included in this release of the software.
  • Six HPFP (high pressure fuel pump) Control Tables have been added
    • HPFP Desired Pressure - Max A
    • HPFP Desired Pressure - Max B
    • HPFP Desired Pressure A
    • HPFP Desired Pressure B
    • HPFP Desired Pressure C
    • HPFP Desired Pressure ECT Comp
  • Eleven new Knock Tables have been added
    • Knock Retard - Decay Magnitude A
    • Knock Retard - Decay Magnitude B
    • Knock Retard - Decay Rate A
    • Knock Retard - Decay Rate B
    • Knock Retard - Multiplier
    • Knock Retard - Offset
    • Knock Retard Active - Min ECT
    • Knock Retard Active - Min Load A
    • Knock Retard Active - Min Load B
    • Knock Retard Active - RPM (Max)
    • Knock Retard Active - RPM (Min)
  • Two new Radiator Fan Tables have been added
    • Radiator Fan - ECT Thresholds
    • Radiator Fan - Voltage Compensation
  • Nine new MAP Sensor Scaling Tables have been added
    • MAP Scalar for EM - Component A
    • MAP Scalar for EM - Component B
    • MAP Scalar for EM - Offset
    • MAP Scalar for Log - Component A
    • MAP Scalar for Log - Component B
    • MAP Scalar for Log - Offset
    • MAP Scalar for OBD - Component A
    • MAP Scalar for OBD - Component B
    • MAP Scalar for OBD - Offset
  • Five new Ignition Compensation Tables have been added
    • Ign BAT vs ECT Comp. - % Used
    • Ign BAT vs ECT Comp. A
    • Ign BAT vs ECT Comp. B
    • Ign Low Octane Reduction
    • Ign Per Cylinder Comp.
  • Boost Pressure Logging Limit has been increased to log boost pressure above 24PSI
  • MIL Defeat implementation has been fixed
  • Live Tracing has been fixed
Acquiring Updates
To get the latest AccessPORT firmware update, simply plug your AccessPORT into your computer via the USB cable, open AP Manager 2.0, click on the Options icon in the top icon bar and make sure that Check For Beta Firmware is checked in the Updates section. Then click on the Updates button in the top icon bar and click the Begin Firmware Update button. If you do not yet have AP Manager 2.0, follow this link to download for your operating system.
To get the latest AccessTUNER Race software update, please fill out the AccessTUNER Race Request Form page. With the new Auto Update feature, this should be the last time you will need to fill out this request form. You will receive an email that contains your software download link within 24 hours. Please be sure to check your spam/junk folders if you do not see the email in your inbox.
MAZDASPEED EXPERT GROUP
The Following 31 Users Say Thank You to Cobb Tuning For This Useful Post:
-cj- (12-01-2010), 08cosmic3 (12-01-2010), 4G63 (12-03-2010), 8.5MS3 (12-01-2010), acidbbg (12-01-2010), Addikted To Boost (12-15-2010), Alpha (12-02-2010), AZSPEED3 (12-02-2010), BigjohnB20 (12-02-2010), Blackspeed (12-14-2010), Caldazar (12-05-2010), Doucems6 (12-01-2010), DSIT995 (12-01-2010), evidence (12-01-2010), hnda etr (12-01-2010), i8urgti (12-02-2010), JacksonMS30 (12-03-2010), jtspells (12-03-2010), jwilkins88 (12-02-2010), mason (12-03-2010), MS3-a(sore)ASS-rex (12-01-2010), rodrigo (12-02-2010), sellers (12-01-2010), skeeter149 (12-01-2010), smitty5788 (12-02-2010), Spirry (12-02-2010), spoolin00 (12-01-2010), superskaterxes (12-01-2010), super_pablo_ (12-02-2010), taf0422 (12-25-2010), triplejumper18 (12-01-2010)
 Old 12-01-2010, 02:46 PM   #2
Trail of Fail
Dano's Avatar
Posts: 9,484   (View Stats)
SaaaaaaWeeeeeet!
Last edited by Dano; 12-01-2010 at 02:46 PM. Reason: MSF Database - Automerged Doublepost
 Old 12-01-2010, 03:12 PM   #3
hnda etr's Avatar
Posts: 4,173   (View Stats)
Groans: 90
SaaaaaaWeeeeeet!
Just submitted my request!!
 Old 12-01-2010, 03:22 PM   #4
m4tic's Avatar
Posts: 4,928   (View Stats)
welp.. here goes checking my inbox every 10 minutes
2017 Daytona 392
STOLEN//2015 BMW S1000R
2007 MS6 w/ Cheez
 Old 12-01-2010, 03:26 PM   #5
hnda etr's Avatar
Groans: 90
Forward your email to your cell phone... Derp!
Edit - that way you can check your cell every 10 minutes...
 Old 12-01-2010, 03:27 PM   #6
-cj-'s Avatar
Posts: 649   (View Stats)
-cj- is the leader of the world-cj- is the leader of the world-cj- is the leader of the world-cj- is the leader of the world-cj- is the leader of the world-cj- is the leader of the world-cj- is the leader of the world-cj- is the leader of the world-cj- is the leader of the world-cj- is the leader of the world-cj- is the leader of the world
At least you guys have your serial #'s handy... I have to wait until I get home to submit my request
Mod List: ATP 3071R @ 22 psi, Grimspeed in 3-port mode, Steedspeed Manifold, Snow Performance Stage 2 Meth Kit, Cobb AP, CP-E 3" Nano SRI, CP-E Big Inlet TIP, Cobb "Stage 2" Suspension Kit, CP-E FMIC, CP-E DP, CP-E HPFP, CP-E MM, TWM STS, Custom Tuned by Fobio.
-cj- is offline   Reply With Quote
 Old 12-01-2010, 03:28 PM   #7
hnda etr's Avatar
Groans: 90
I took a picture of my serial... it's in my cell phone now lol...
-cj- (12-02-2010)
 Old 12-01-2010, 03:28 PM   #8
m4tic's Avatar
check you inbox for old cobb confirmations... my serial was in there
2017 Daytona 392
2007 MS6 w/ Cheez
The Following 2 Users Say Thank You to m4tic For This Useful Post:
-cj- (12-02-2010), hnda etr (12-01-2010)
 Old 12-01-2010, 03:29 PM   #9
hnda etr's Avatar
Groans: 90
Wish I would have thought of that before walking outside to my car... lol...
 Old 12-01-2010, 03:41 PM   #10
DSIT995's Avatar
Posts: 1,768   (View Stats)
just submitted.......
what are the chances they go out tonight!?
that would be great
99 Miata NB - Stock for now
 Old 12-01-2010, 03:47 PM   #11
Trail of Fail
Dano's Avatar
yes the confirmation is almost immediate....the link, in my experience, takes about 24 hours.
 Old 12-01-2010, 04:19 PM   #12
madvillain's Avatar
Posts: 4,160   (View Stats)
Groans: 78
Fuuuuuuuuu
This is awesome, Im glad you didn't ditch the platform, Cobb! I look forward to seeing what some of the BT guys out there can do with this!
The Following User Says Thank You to madvillain For This Useful Post:
 Old 12-01-2010, 04:24 PM   #13
jax ms3gt's Avatar
Posts: 1,151   (View Stats)
request submitted, Updater 1.2.6.0 downloaded, Manager 2.0.1.2 downloaded!
thank you Cobb
PERM TUNED
 Old 12-01-2010, 04:31 PM   #14
Fagwagon's Avatar
Posts: 2,090   (View Stats)
Groans: 75
awesomeness!
SO this means we can control fuel pressure with those tables? And if so willl you be releasing any new help files for those of us who are tuning on our own?
Also, if you plan on reading over the 24psi you are still going to need to upgrade to a map sensor that can read that high. Does cobb have any suggestions for a plug and play map sensor?
 Old 12-01-2010, 04:33 PM   #15
MS3-a(sore)ASS-rex's Avatar
Posts: 7,012   (View Stats)
Groans: 224
Sweet!! Can't wait to pop my injector seals now!
NATOR PA
 Old 12-01-2010, 04:47 PM   #16
bova's Avatar
Posts: 3,820   (View Stats)
Groans: 45
thank you Cobb
You don't need the updater anymore. Manager 2.0 does it now.
 Old 12-01-2010, 04:59 PM   #17
jax ms3gt's Avatar
yeah i just read that. nice new features!
PERM TUNED
 Old 12-01-2010, 05:12 PM   #18
awesomeness!
We should have updated table descriptions out soon. We will host these on our website and on the COBB Forums. We will post links when they are available.
Travis
COBB Tuning
 Old 12-01-2010, 05:56 PM   #19
08cosmic3's Avatar
Posts: 2,920   (View Stats)
subbing
 Old 12-01-2010, 06:05 PM   #20
taf0422's Avatar
Posts: 4,689   (View Stats)
Groans: 192
subbed and put in my request
[SIZE="1"]07 MS3 GT..
GTX3076r --- 479/412
S4-460/400
Highest HP BNR S3
BNR-S3 424/397
 Old 12-01-2010, 06:54 PM   #21
acidbbg's Avatar
Posts: 208   (View Stats)
acidbbg has much to be proud ofacidbbg has much to be proud ofacidbbg has much to be proud ofacidbbg has much to be proud ofacidbbg has much to be proud ofacidbbg has much to be proud ofacidbbg has much to be proud ofacidbbg has much to be proud ofacidbbg has much to be proud of
Just requested the new ATR.
Thanks again Cobb for the continued support of the Mazdaspeed3/6 Platform!!
All content created by this user is for entertainment purposes only.
Mods: Wouldn't you like to know
acidbbg is offline   Reply With Quote
 Old 12-01-2010, 08:12 PM   #22
my
life
is
complete
fuck this is going to be a long 24 hours lol
Dano (12-01-2010), Decepticon (12-02-2010)
 Old 12-01-2010, 08:15 PM   #23
pewpew
Sacrilicious's Avatar
Posts: 2,452   (View Stats)
Groaned at 9 Times in 9 Posts
i will be guaranteed to pass emissions next year!
 Old 12-01-2010, 08:26 PM   #24
Trail of Fail
Dano's Avatar
and
you
are
gay
 Old 12-01-2010, 09:40 PM   #25
Eth/Meth Junkie
cld12pk2go's Avatar
Posts: 2,998   (View Stats)
Guess, I didn't miss much being of vacation for the last 7 days.
Back just in time it would seem.
Cobb, thanks for being awesome.
 Old 12-01-2010, 10:30 PM   #26
Eth/Meth Junkie
cld12pk2go's Avatar
Originally Posted by John@TheShopCT View Post
The update looks good
I'm playing with my Pro version now
U suck. lol
This is going to be a long 24 hours.
 Old 12-01-2010, 10:33 PM   #27
Lama's Avatar
Posts: 339   (View Stats)
Lama has a reputation beyond reputeLama has a reputation beyond reputeLama has a reputation beyond reputeLama has a reputation beyond reputeLama has a reputation beyond reputeLama has a reputation beyond reputeLama has a reputation beyond reputeLama has a reputation beyond reputeLama has a reputation beyond reputeLama has a reputation beyond reputeLama has a reputation beyond repute
is this feature will be in the new ATR?
Easy toggle switch to force ECU to target boost, not load.
Mazdaspeed 6 2007 GT : Cobb AccessPORT, Cobb Stage 2+SF TIH 91 BT map, Cobb SF SRI, Cobb Turbo Inlet, Cobb shifter weight, Cobb XLE BPV, Cp-e TMIC, SAMCO Xtraflex recirc hose, AutoEXE Boost tubes, CP-e Rear Motor Mount, Cp-e diff mount, SURE juggernaut, Magnaflow Catback , SU Test pipe, TWM Short Shifter Stage 2 & Bushings, DashHawk, Denso ITV-22, RPM sport springs, whiteline RSB, freins Rotora, TSW nurburgring wheels
Lama is offline   Reply With Quote
 Old 12-02-2010, 06:25 AM   #28
I see it in mine
Sent from my ADR6300
john not that you may know but is your pro version any different then ours? i know the last revision was not. are you able to flash directly from your laptop on yours or do you still need to go through the AP?
 Old 12-02-2010, 08:25 AM   #29
jracer's Avatar
Posts: 1,706   (View Stats)
Groans: 89
thanks COBB
H&R springs/H&R 15mm spacers
MAP catless testpipe
MAP UICP
Grimmspeed 3 port
Cosworth filter
SSP relay kit
TWM Desert Eagle shift knob
AEM wideband gauge
Prosport boost gauge
EvoX piller pod
30%Tint
Slowpoke Tuned 339hp/336tq
**** SOLD *****
2006 speed6
 Old 12-02-2010, 08:31 AM   #30
jwilkins88's Avatar
Posts: 3,675   (View Stats)
Groans: 126
Unicorn checking in... Excited to start popping my injector seals.
 Old 12-02-2010, 08:46 AM   #31
DSIT995's Avatar
has it been 24hr yet?
Longest day ever!
Has anyone got it yet?
 Old 12-02-2010, 09:31 AM   #32
m4tic's Avatar
so im waiting for ATR and I got a raise... this week rocks!
2017 Daytona 392
2007 MS6 w/ Cheez
 Old 12-02-2010, 10:12 AM   #33
Groans: 224
Can't find my fucking USB cable!!! FUUUUUUU
NATOR PA
 Old 12-02-2010, 10:35 AM   #34
hnda etr's Avatar
Groans: 90
Hey Boynton...
Fuckyouandyourraisenikka!!
Oh, and I'm still waiting for d/l link also... anyone get it yet? post it up so we can all d/l!!
ps - boynton - hiring?
 Old 12-02-2010, 10:57 AM   #35
Lama,
Yes, however, please understand that these are untested developmental features for those that are interested in experimenting and evaluating them. They are toggles, so if they don't work as expected, simply switch back.
TOGGLE: Use Boost Based Dynamics (Boost Control)
When checked, the ECU should function using Boost Error to control the WGDC. This should provide what you are calling "PSI tuning". In other words, the ECU will take the result of the Boost Target table and compare it against the actual Boost. If Actual Boost is greater than target boost, it will reduce the WGDC (attempt to lower actual "PSI"). The opposite is true is Actual Boost is less than Target. Normal operation is for the ECU to increase/decrease WGDC based on Load Error (Is actual Load greater/less than Desired Load).
TOGGLE: Use Alt. Load Target Table (Boost Control)
When checked, the ECU should function using this table as the only Load Target to raise or lower WGDC (which drives PSI, y0). Otherwise, the ECU uses a complex routine to look at several tables based on conditions which may lead to "inconsistent" turbo operation because the ECU is attempting to be more dynamic for conditions.
Thanks,
Gary
The Following 2 Users Say Thank You to Cobb Tuning For This Useful Post:
FreeFlyFreak (12-02-2010), Sacrilicious (12-02-2010)
 Old 12-02-2010, 11:05 AM   #36
Fuck sushi rolls
rodrigo's Avatar
Posts: 18,719   (View Stats)
Groans: 356
subbed for cld12pk2go to learn all this shit asap in time fo ma BT drop in
hnda etr (12-02-2010), super_pablo_ (12-02-2010)
 Old 12-02-2010, 11:16 AM   #37
Ur moms boyfriend
forcedinduktion's Avatar
Posts: 2,719   (View Stats)
Groans: 70
any word on 2nd gen?
 Old 12-02-2010, 11:16 AM   #38
Spirry's Avatar
Posts: 700   (View Stats)
Spirry is the leader of the worldSpirry is the leader of the worldSpirry is the leader of the worldSpirry is the leader of the worldSpirry is the leader of the worldSpirry is the leader of the worldSpirry is the leader of the worldSpirry is the leader of the worldSpirry is the leader of the worldSpirry is the leader of the worldSpirry is the leader of the world
Groaned at 28 Times in 15 Posts
A quick word of advise. Disable your anti-virus before installing AP Manager 2.0. I was getting NSIS integrity check errors with ESET NOD32. Disabled and all is peachy now!
Spirry is offline   Reply With Quote
 Old 12-02-2010, 11:22 AM   #39
fjames's Avatar
Posts: 1,058   (View Stats)
Originally Posted by Cobb Tuning View Post
Lama,
Thanks,
Gary
Ohhh ... Does this mean we now have (hypothetically) three means of controlling boost? Boost dynamics/dedicated load dynamics/oem? That's very interesting if true - not the way I originally understood it.
 Old 12-02-2010, 11:28 AM   #40
Trail of Fail
Dano's Avatar
Lama,
Thanks,
Gary
These two features could prove very useful when tuning big turbo setups vs. the K04. I have personally spent much time tuning the load dynamics, boost dynamics, boost comp etc tables to try and dial in desired boost. The logic the ECU used to target load seems to be unknown so a lot of trial and error is needed to get results. With the new features I hope this will eliminate alot of variables.
BTW just received my DL link email.
MAZDASPEED3/6 AccessPORT and AccessTUNER Updates Now Available! Cobb Tuning Cobb Tuning 6 12-03-2010 04:51 PM
AccessTUNER Race for MAZDASPEED3 & 6 Cobb Tuning MazdaSpeed 3/6 - ECU Computer Tuning 407 04-23-2009 10:55 PM
COBB AccessTUNER Pro for MAZDASPEED3 & MAZDASPEED6 Cobb Tuning MazdaSpeed 3/6 - ECU Computer Tuning 246 04-16-2009 11:16 AM
Page generated in 0.57065 seconds with 44 queries
